node-red-contrib-nats-suite 0.2.3
A comprehensive Node-RED module for NATS (Core, JetStream, KV, Object Store, Service API) – generic NATS integration for Node-RED.
npm install node-red-contrib-nats-suite
npm version npm downloads License: Apache 2.0 Node-RED Node.js Version Status: Beta Discord
A comprehensive Node-RED module for NATS (NATS Messaging System) with support for all major NATS features. This is a generic NATS implementation that works with any NATS server - not bound to a specific platform.
Status & Versioning
  • Current version: 0.2.2
  • Stability: APIs and node options may still change between minor versions.
  • Tested with: Node-RED >= 3.0.0, Node.js >= 14.0.0, NATS Server >= 2.9 (with JetStream enabled for JetStream/KV/Object Store features).
  • For detailed manual test flows, see TEST-CASES.md. Automated tests are located in the __tests__ directory and can be executed via npm test.
Core NATS (Basic NATS Core Functionality)
  • Publish/Subscribe: Full support for NATS Pub/Sub messaging
  • Request/Reply: NATS Request/Reply pattern for synchronous communication
  • Queue Groups: Load balancing with Queue Groups
  • Headers: Support for NATS Headers
  • Wildcards: Subject wildcards (*, >)
  • TLS: Encrypted connections
  • Authentication: Token, Username/Password, JWT or NKey
  • Reconnect: Automatic reconnection on connection loss
  • Clustering: Support for NATS clustering
  • Leaf Nodes: Support for NATS Leaf Node connections
JetStream (JetStream Functionality)
  • Streams: JetStream Stream management with auto-creation
  • Publishers: Publishes messages to streams
  • Consumers: Pull/Push consumers with various modes
  • Retention Policies: Limits, Interest, Work Queue
  • Replay: Message replay functionality
  • Deduplication: Automatic deduplication
KV Store (NATS KV Functionality - uses JetStream)
  • Bucket Management: Create and configure KV buckets
  • Get/Put: Read and write values
  • Watch: Monitor changes
  • History: Access to revision history with configurable limit
  • TTL: Time To Live support
  • Compression: Value compression
  • Key Source: Use msg.topic as key source
Or in the Node-RED Editor:
  1. Menu → Manage palette → Install
  2. Search for node-red-contrib-nats-suite
  3. Install
Node Overview
Configuration & Management
Node Description Category
nats-suite-server NATS Server connection configuration (for all other nodes) Config
nats-suite-server-manager Embedded NATS Server with MQTT bridge, JetStream, custom binaries, Leaf Node support Management
Core NATS
Node Function Input Output
nats-suite-publish Publishes messages to subjects + Request/Reply mode + Headers + Message Expiration (TTL) msg.payload, msg.topic, msg.headers, msg.expiration, msg._reply (reply mode) msg.payload (request mode)
nats-suite-subscribe Subscribes to messages from subjects - msg.payload, msg.topic, msg.headers, msg._reply (for request-reply)
JetStream
nats-suite-stream-publisher Publishes to JetStream streams + Stream management (create/update/update-subjects/delete/purge/list/info) msg.payload, Stream name, msg.operation, msg.subjects -
nats-suite-stream-consumer Consumes from JetStream streams + Consumer management (create/info/delete/list/pause/resume/monitor) + Stream management (info/delete/purge) msg.operation, msg.consumer msg.payload (Stream messages or Consumer info)
KV Store (Key-Value)
nats-suite-kv-get Reads values from KV Store + List keys + Watch Key, msg.operation (get/keys/watch) msg.payload (Value/Keys array)
nats-suite-kv-put Writes values to KV Store + Delete/Purge keys + Bucket management (create/info/delete/list) Key, msg.payload (Value), msg.operation (put/create/update/delete/purge) Status
Quick Reference
Core NATS Workflow
[Inject] → [nats-suite-publish] → NATS Server → [nats-suite-subscribe] → [Debug]
Request/Reply Pattern
Option 1: Using Request Mode (Recommended)
[Inject] → [nats-suite-publish (mode: request)] → NATS Server
                                    [nats-suite-subscribe] → [Function] → [nats-suite-publish (mode: reply)]
                                    [nats-suite-publish output] → [Debug]
  • Request node automatically creates an inbox subject
  • Reply node uses msg._reply (automatically set by subscribe node)
  • Response appears at request node output
Option 2: Manual Pub/Sub Pattern
[Inject] → [nats-suite-publish] → NATS Server → [nats-suite-subscribe] → [Function] → [nats-suite-publish]
Note: Include replyTo subject in your payload for manual request/reply patterns.
JetStream Workflow
[Inject] → [nats-suite-stream-publisher] → JetStream → [nats-suite-stream-consumer] → [Debug]
KV Store Workflow
[Inject] → [nats-suite-kv-put] → KV Store
[Inject] → [nats-suite-kv-get] → KV Store → [Debug]
Usage Examples
1. Publish/Subscribe
[Inject] → [nats-suite-publish] → [nats-suite-subscribe] → [Debug]
  • Configure nats-suite-server with your NATS server URL
  • nats-suite-publish: Subject my.topic, msg.payload = message
  • nats-suite-subscribe: Subject my.topic
2. Request/Reply Pattern
Using Request Mode:
[Inject] → [nats-suite-publish (mode: request, subject: "my.service")]
                    NATS Server (auto-creates inbox)
        [nats-suite-subscribe (subject: "my.service")] → [Function Handler]
        [nats-suite-publish (mode: reply)] → NATS Server
  • Request node: Mode = "request", Subject = "my.service"
  • Subscribe node: Subject = "my.service" (must match)
  • Function handler: Receives msg._reply (automatically set by subscribe node)
  • Reply node: Mode = "reply", automatically uses msg._reply as subject
  • Response appears at request node output with msg.payload and msg.requestTime
Note: For advanced service patterns, you can build custom service handlers using the Request/Reply pattern shown above.
3. JetStream Streams
[Inject] → [nats-suite-stream-publisher] → [nats-suite-stream-consumer] → [Debug]
  • Stream is automatically created
  • Messages are persistently stored
4. KV Store
[Inject] → [nats-suite-kv-put] (Key: "mykey", Value: msg.payload)
[Inject] → [nats-suite-kv-get] (Key: "mykey") → [Debug]
  • Bucket is automatically created
  • Values are persistently stored
NATS Server Setup
Option 1: External NATS Server
docker run -p 4222:4222 nats:latest
# or
nats-server
Option 2: NATS Server Manager (in Node-RED)
Use the nats-suite-server-manager node to run an embedded NATS server directly in Node-RED:
Binary Source Options
Source Description
Auto-detect Uses nats-memory-server npm package (optional dependency), falls back to system PATH
Custom Binary Mount your own nats-server binary (e.g., /data/bin/nats-server-v2.12.2-linux-amd64)
System PATH Uses nats-server from system PATH only
  • MQTT Bridge: Enable MQTT protocol support (port configurable)
  • WebSocket: Browser-based client connections
  • TLS/SSL: Encrypted connections with certificate support
  • Authentication: Token or username/password authentication
  • JetStream: Persistent streams and KV store
  • Leaf Node Mode: Connect to remote NATS clusters
  • HTTP Monitoring: Server stats via HTTP endpoints (/varz, /connz, /healthz, etc.)
Pre-built Binaries
This package includes pre-built NATS server binaries in the bin/ folder:
  • nats-server-v2.12.2-linux-amd64 (x86-64)
  • nats-server-v2.12.2-linux-arm64 (ARM64)
Control Commands
msg.payload.command = "start"   // Start server
msg.payload.command = "stop"    // Stop server
msg.payload.command = "restart" // Restart server
msg.payload.command = "status"  // Get server status
msg.payload.command = "toggle"  // Toggle start/stop
Output Payload (on start)
  type: "embedded",           // or "leaf"
  port: 4223,
  url: "nats://localhost:4223",
  version: "2.12.2",
  binarySource: "custom",     // "auto", "custom", or "system"
  binaryPath: "/data/bin/nats-server-v2.12.2-linux-amd64",
  mqtt: { enabled: true, port: 1884, url: "mqtt://localhost:1884" },
  jetstream: true
Requirements
  • Node-RED >= 3.0.0
  • Node.js >= 14.0.0
  • NATS Server (local, remote or Leaf Node)
Advanced Features
Server Manager Extensions
Custom Binary Support
  • Mount your own nats-server binary for specific versions
  • Binary source selection: Auto-detect, Custom Binary, System PATH
  • Status display shows: bin:4223 v2.12.2 (source:port version)
MQTT Bridge
  • Enable MQTT protocol on embedded server
  • Configurable MQTT port (default: 1883)
  • Auto-enables JetStream (required for MQTT)
  • Auto-generates server name if not set
WebSocket Support
  • Enable WebSocket for browser-based clients
  • Configurable WebSocket port (default: 8080)
  • Works with nats.ws JavaScript client
TLS/SSL Encryption
  • Enable TLS for encrypted connections
  • Certificate and key file paths
  • Optional CA certificate for client verification
  • Client certificate verification option
Authentication
  • Token-based authentication
  • Username/password authentication
  • Simple single-user setup
HTTP Monitoring
  • Enable HTTP monitoring port for server statistics
  • Endpoints: /varz, /connz, /subsz, /jsz, /healthz
Core NATS Extensions
Message Headers
  • Static headers in node configuration (JSON)
  • Dynamic headers via msg.headers
  • Automatic merging of static + dynamic headers
  • Debugging support
  • Configurable message-level TTL (0-86400 seconds)
  • Dynamic TTL via msg.expiration
  • Automatic conversion to nanoseconds for NATS
JetStream Extensions
Stream Subject Update
  • New operation update-subjects for Stream Publisher
  • Updates only subjects without changing other stream config
  • Input via msg.subjects (comma-separated)
Consumer Pause/Resume
  • New operations pause and resume for Stream Consumer
  • Temporarily stops/starts message fetching
  • Local state management
  • Status display in Node-RED
Consumer Monitoring
  • New operation monitor for detailed consumer stats
  • Metrics: pending, delivered, ack_pending, redelivered, waiting
  • Delivery rate calculation (messages/second)
  • Pause status display
KV Store Extensions
KV Delete Operations (already available, documented)
  • delete - Soft delete (marked as deleted)
  • purge - Hard delete (removes all revisions)
KV Keys List (already available, documented)
  • New operation keys in KV Get node
  • Lists all keys of a bucket
  • Output: Array with all keys + count
NATS Feature Coverage
This section provides a comprehensive overview of NATS features and their implementation status in node-red-contrib-nats-suite.
Feature Matrix
Core NATS Features
Feature Status Node Notes
Publish/Subscribe ✅ Complete nats-suite-publish, nats-suite-subscribe Full pub/sub messaging
Request/Reply ✅ Complete nats-suite-publish (mode: request/reply) Synchronous communication
Queue Groups ✅ Complete nats-suite-subscribe Load balancing across subscribers
Headers ✅ Complete nats-suite-publish Static + dynamic headers
Wildcards (*, >) ✅ Complete nats-suite-subscribe Subject pattern matching
TLS/SSL ✅ Complete nats-suite-server Encrypted connections
Token Auth ✅ Complete nats-suite-server Token-based authentication
User/Password Auth ✅ Complete nats-suite-server Basic authentication
JWT Auth ✅ Complete nats-suite-server JWT-based authentication
NKey Auth ✅ Complete nats-suite-server NKey-based authentication
Auto Reconnect ✅ Complete nats-suite-server Automatic reconnection handling
Clustering ✅ Complete nats-suite-server Multi-server connections
Leaf Nodes ✅ Complete nats-suite-server-manager Edge server connections
Message TTL ✅ Complete nats-suite-publish Message expiration
Subject Mapping ❌ Not Implemented - Server-side subject transforms
Weighted Mapping ❌ Not Implemented - Canary testing / A-B routing
JetStream Features
Stream Create ✅ Complete nats-suite-stream-publisher Auto-creation supported
Stream Update ✅ Complete nats-suite-stream-publisher Update stream configuration
Stream Delete ✅ Complete nats-suite-stream-publisher Delete streams
Stream Purge ✅ Complete nats-suite-stream-publisher Purge all messages
Stream Info ✅ Complete nats-suite-stream-publisher Get stream details
Stream List ✅ Complete nats-suite-stream-publisher List all streams
Update Subjects ✅ Complete nats-suite-stream-publisher Update subjects only
Publish to Stream ✅ Complete nats-suite-stream-publisher Persistent message publishing
Pull Consumer ✅ Complete nats-suite-stream-consumer On-demand message fetching
Push Consumer ✅ Complete nats-suite-stream-consumer Automatic message delivery
Consumer Create ✅ Complete nats-suite-stream-consumer Create new consumers
Consumer Delete ✅ Complete nats-suite-stream-consumer Delete consumers
Consumer Info ✅ Complete nats-suite-stream-consumer Get consumer details
Consumer List ✅ Complete nats-suite-stream-consumer List all consumers
Consumer Pause/Resume ✅ Complete nats-suite-stream-consumer Pause/resume message fetching
Consumer Monitor ✅ Complete nats-suite-stream-consumer Detailed stats & metrics
Retention: Limits ✅ Complete nats-suite-stream-publisher Size/count/age limits
Retention: Interest ✅ Complete nats-suite-stream-publisher Consumer interest-based
Retention: WorkQueue ✅ Complete nats-suite-stream-publisher Work queue semantics
Message Replay ✅ Complete nats-suite-stream-consumer Replay from sequence/time
Deduplication ✅ Complete nats-suite-stream-publisher Via message ID
Stream Mirrors ❌ Not Implemented - Read-only stream replication
Stream Sources ❌ Not Implemented - Multi-stream aggregation
Stream Republish ❌ Not Implemented - Auto-republish to subjects
Subject Transforms ❌ Not Implemented - Stream-level subject mapping
Consumer Filter Subject 🔄 Partial nats-suite-stream-consumer Basic filtering available
KV Store Features
Bucket Create ✅ Complete nats-suite-kv-put Auto-creation supported
Bucket Delete ✅ Complete nats-suite-kv-put Delete buckets
Bucket Info ✅ Complete nats-suite-kv-put Get bucket details
Bucket List ✅ Complete nats-suite-kv-put List all buckets
Get Value ✅ Complete nats-suite-kv-get Read key values
Put Value ✅ Complete nats-suite-kv-put Write key values
Create (if not exists) ✅ Complete nats-suite-kv-put Conditional create
Update (if exists) ✅ Complete nats-suite-kv-put Conditional update
Delete Key ✅ Complete nats-suite-kv-put Soft delete (tombstone)
Purge Key ✅ Complete nats-suite-kv-put Hard delete (all revisions)
List Keys ✅ Complete nats-suite-kv-get List all keys in bucket
Watch ✅ Complete nats-suite-kv-get Monitor key changes
TTL ✅ Complete nats-suite-kv-put Time-to-live for entries
Compression ✅ Complete nats-suite-kv-put Value compression
Key History ✅ Complete nats-suite-kv-get Access revision history with configurable limit
CAS (Compare-And-Swap) ❌ Not Implemented - Atomic conditional updates
Object Store Features
Bucket Create 🔧 In Development nats-suite-object-put In nodes-dev/ folder
Bucket Delete 🔧 In Development nats-suite-object-put In nodes-dev/ folder
Bucket Info 🔧 In Development nats-suite-object-put In nodes-dev/ folder
Bucket List 🔧 In Development nats-suite-object-put In nodes-dev/ folder
Put Object 🔧 In Development nats-suite-object-put In nodes-dev/ folder
Get Object 🔧 In Development nats-suite-object-get In nodes-dev/ folder
Delete Object 🔧 In Development nats-suite-object-put In nodes-dev/ folder
List Objects 🔧 In Development nats-suite-object-get In nodes-dev/ folder
Object Metadata 🔧 In Development nats-suite-object-put In nodes-dev/ folder
Watch ❌ Not Implemented - Monitor object changes
Object Links ❌ Not Implemented - Create object references
Bucket Links ❌ Not Implemented - Cross-bucket linking
Seal Bucket ❌ Not Implemented - Make bucket read-only
Services API Features
Create Service 🔧 In Development nats-suite-service In nodes-dev/ folder
Add Endpoint 🔧 In Development nats-suite-service In nodes-dev/ folder
Start/Stop Service 🔧 In Development nats-suite-service In nodes-dev/ folder
Service Discovery 🔧 In Development nats-suite-service Ping/Info operations
Service Stats 🔧 In Development nats-suite-service Metrics collection
Health Monitoring 🔧 In Development nats-suite-service Connection health checks
NATS Stats 🔧 In Development nats-suite-service Server/JetStream stats
Service Groups ❌ Not Implemented - Endpoint grouping
Server Management Features
Embedded Server ✅ Complete nats-suite-server-manager Run NATS in Node-RED
Custom Binary ✅ Complete nats-suite-server-manager Use specific server version
MQTT Bridge ✅ Complete nats-suite-server-manager MQTT protocol support
WebSocket ✅ Complete nats-suite-server-manager Browser client support
JetStream Enable ✅ Complete nats-suite-server-manager Enable persistence
HTTP Monitoring ✅ Complete nats-suite-server-manager /varz, /connz, /healthz
Leaf Node Mode ✅ Complete nats-suite-server-manager Connect to remote clusters
Start/Stop/Restart ✅ Complete nats-suite-server-manager Server control commands
Coverage Summary
Category Implemented In Development Not Implemented Coverage
Core NATS 15 0 2 88%
JetStream 20 0 5 80%
KV Store 15 0 1 94%
Object Store 0 9 4 0% (prod) / 69% (dev)
Services API 0 7 1 0% (prod) / 87% (dev)
Server Management 8 0 0 100%
Legend
Symbol Meaning
✅ Complete - Available in production nodes
🔧 In Development - Available in nodes-dev/ folder
🔄 Partial - Basic functionality available
❌ Not Implemented - Not yet available
Roadmap
Features planned for future releases:
  1. Object Store & Services API - Move from nodes-dev/ to production
  2. KV Compare-And-Swap - Atomic conditional updates
  3. Stream Mirrors - Read-only stream replication
  4. Stream Sources - Aggregate from multiple streams
  5. Object Store Watch - Monitor object changes
Apache License 2.0 — see LICENSE and NOTICE.
Copyright 2025-2026 blanpa
Contributing and forks
Pull requests are welcome, including large ones. If you are planning a bigger change — a dependency migration, a restructure, new nodes — please open an issue first. We are happy to discuss it and to land substantial work here; that is usually less effort than maintaining a parallel package, and it keeps a single place for users to report bugs.
If you do publish a fork under its own package name, please also rename the Node-RED node type IDs (for example myprefix-nats-suite-*) and use your own palette category. Node-RED refuses to register a node type that is already claimed, so identical type IDs make it impossible to install both packages side by side.
Support
For issues or questions, please create an issue in the repository.
Join our Discord community: Discord Server
Version: 0.2.3
Updated 2 months, 3 weeks ago
Rating: 5.0 4
45 in the last week
  • nats-suite-server
  • nats-suite-stream-publisher
  • nats-suite-stream-consumer
  • nats-suite-kv-get
  • nats-suite-kv-put
  • nats-suite-server-manager
  • nats
  • messaging
  • pubsub
  • jetstream
  • blanpa
  • dbleul
