node-red-contrib-mygekko 1.0.21
Connects to the Query-Api of the homeautomation system MyGEKKO.
npm install node-red-contrib-mygekko
Allows to poll the Query-Api and generates a message on every status/data-change.
Additionally the linked mygekko-systems can be controlled through the supported Query-Api-commands.
Supports connection through MyGekko-Plus-Services and local connection.
Direct support of node-red-contrib-alexa-home nodes on mygekko-light-nodes and mygekko-blind-nodes.
sudo service nodered restart
How to use
  • Add the desired mygekko-node from the palette to your flow.
    Node Config
  • Configure the used Name for the node
    Note: If you want to use the auto-itemid-assign-feature (recommended), you have to use the same Name for the node as used in the MyGekko-System, in such case leave the field ItemId empty.
    The server-node will then try to auto-assign the correct MyGekko-ItemId to the node.
    You can also assign the ItemId directly, therefor enter the MyGekko-ItemId (like item18). In such case, the Name can be any value.
    Check auto-itemid-assign-feature
    When you use **auto-itemid-assign-feature** the node will appear as **connected** after deploying:
    Node connected
    When the server-node **could not auto assign** the correct itemid, perhaps because of using a false name, the node will throw a message:
    Node not assigned
  • Assign a existing MyGekko-Server to the node or create a new one
    Note: You can set the Active flag in the server-config for polling the QueryApi.
    If you just want to write back values to QueryApi, you can disable polling.
    Server Config
Overview supported features
Detailed information for each individual node can be viewed in the info pane within the node-red-flow-editor.
  • All nodes with output
    • all nodes with an output generate a message with the properties of the linked mygekko-component on each change in its property-values.
  • LIGHT (mygekko_light)
    • Get/Set the current state (on/off)
    • Get/Set the current dimming-value
    • Get/Set the current light-color (24-bit-value)
    • Ability to direct connect a node-red-contrib-alexa-home node on input
  • LOAD (mygekko_load)
    • Get/Set the current state (on, impulse on, off)
  • ACTION (mygekko_action)
    • Get/Set the current state (start, stop)
  • BLIND (mygekko_blind)
    • Get/Set the current state (hold_down, stop, up, ...)
    • Get/Set the current position
    • Get/Set the current angle (slate-rotation)
  • ALARM (mygekko_alarm)
    • Get the current status from alarm-system
  • UNIVERSAL (mygekko_universal)
    • Get the complete JSON-Response for all components from QueryApi
  • PROFILE (mygekko_profile)
    • Get/Set the current profile (Away, at Home)
  • VENT (mygekko_vent)
    • Get the current values from ventilation (level, mode, bypass, temperatures, co2, voc, humidity)
    • Set the level for ventilation
  • METEO (mygekko_meteo)
    • Get the current values from the Meteo-Component from MyGekko if configured (twilight, temperature-outside)
Depencies
This package has no extra requirements, it doesn't add any dependencies, so it can be used in every standard-node-red-installation.
Sample Node-Red-Flow
Here´s a sample node-red-flow to start working with the nodes.
Sample 1 Overview
[{"id":"66f2024a.cf85cc","type":"inject","z":"1e0aa667.3f381a","name":"Lampe ein","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":123,"wires":[["705800d7.63832"]]},{"id":"a4d2a866.7de3f8","type":"debug","z":"1e0aa667.3f381a","name":"Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1030,"y":340,"wires":[]},{"id":"21a0abb7.44c2e4","type":"mygekko_light","z":"1e0aa667.3f381a","name":"Wohnen Deckenlicht","itemid":"","server":"14744af.47b48b5","x":540,"y":143,"wires":[["a4d2a866.7de3f8"]]},{"id":"705800d7.63832","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"state","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":123,"wires":[["21a0abb7.44c2e4"]]},{"id":"c2816116.d854f","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"state","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":163,"wires":[["21a0abb7.44c2e4"]]},{"id":"e95a157c.231478","type":"inject","z":"1e0aa667.3f381a","name":"Lampe aus","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":163,"wires":[["c2816116.d854f"]]},{"id":"7e1cd863.577418","type":"mygekko_alarm","z":"1e0aa667.3f381a","name":"Alarm","server":"14744af.47b48b5","x":590,"y":60,"wires":[["a4d2a866.7de3f8"]]},{"id":"e0679067.b88cb","type":"mygekko_profile","z":"1e0aa667.3f381a","name":"Profil","server":"14744af.47b48b5","x":590,"y":250,"wires":[["a4d2a866.7de3f8"]]},{"id":"f3db2837.e41f88","type":"inject","z":"1e0aa667.3f381a","name":"Profil \"zu Hause\"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":230,"wires":[["d0a6e0f9.22038"]]},{"id":"d0a6e0f9.22038","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"profileid","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":230,"wires":[["e0679067.b88cb"]]},{"id":"77e3c49.004bd3c","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"profileid","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":270,"wires":[["e0679067.b88cb"]]},{"id":"d6617b6.6fdbb88","type":"inject","z":"1e0aa667.3f381a","name":"Profil \"ausser Haus\"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":270,"wires":[["77e3c49.004bd3c"]]},{"id":"32c2c382.755bec","type":"mygekko_load","z":"1e0aa667.3f381a","name":"TV","itemid":"","server":"14744af.47b48b5","x":590,"y":355,"wires":[["a4d2a866.7de3f8"]]},{"id":"95f39574.c0c2d8","type":"inject","z":"1e0aa667.3f381a","name":"TV ein","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":335,"wires":[["47fbc6cc.e31b48"]]},{"id":"47fbc6cc.e31b48","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":335,"wires":[["32c2c382.755bec"]]},{"id":"149b9a7.81bc566","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":375,"wires":[["32c2c382.755bec"]]},{"id":"fe7b2f71.946b5","type":"inject","z":"1e0aa667.3f381a","name":"TV aus","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":375,"wires":[["149b9a7.81bc566"]]},{"id":"19728f63.8fc3a1","type":"mygekko_action","z":"1e0aa667.3f381a","name":"Alle Lichter aus","itemid":"","server":"14744af.47b48b5","x":560,"y":454,"wires":[["a4d2a866.7de3f8"]]},{"id":"2d9110ab.b4995","type":"inject","z":"1e0aa667.3f381a","name":"start Aktion","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":434,"wires":[["d7ee2a11.bb8bf8"]]},{"id":"d7ee2a11.bb8bf8","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":434,"wires":[["19728f63.8fc3a1"]]},{"id":"b5df069f.8aa348","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":474,"wires":[["19728f63.8fc3a1"]]},{"id":"afd72f9c.1c8d1","type":"inject","z":"1e0aa667.3f381a","name":"stop Aktion","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":474,"wires":[["b5df069f.8aa348"]]},{"id":"e7cf9db3.26e7e","type":"mygekko_blind","z":"1e0aa667.3f381a","name":"Küche Rollo","itemid":"","server":"14744af.47b48b5","x":580,"y":619,"wires":[["a4d2a866.7de3f8"]]},{"id":"293c8cce.32aaf4","type":"inject","z":"1e0aa667.3f381a","name":"Position 100%","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":539,"wires":[["e4edd5b3.ec09e8"]]},{"id":"e4edd5b3.ec09e8","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":539,"wires":[["e7cf9db3.26e7e"]]},{"id":"b643a6f7.6eef08","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":619,"wires":[["e7cf9db3.26e7e"]]},{"id":"b525c3cf.620e2","type":"inject","z":"1e0aa667.3f381a","name":"Position 0%","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":619,"wires":[["b643a6f7.6eef08"]]},{"id":"cf7a94f7.f4abf8","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"position","pt":"msg","to":"50","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":579,"wires":[["e7cf9db3.26e7e"]]},{"id":"a0cf8f3a.41531","type":"inject","z":"1e0aa667.3f381a","name":"Position 50%","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":579,"wires":[["cf7a94f7.f4abf8"]]},{"id":"3fcfae98.e21232","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"angle","pt":"msg","to":"25","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":659,"wires":[["e7cf9db3.26e7e"]]},{"id":"68a292a2.fd4afc","type":"inject","z":"1e0aa667.3f381a","name":"Winkel 25%","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":659,"wires":[["3fcfae98.e21232"]]},{"id":"c1c4169c.dd0b58","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"stateid","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":699,"wires":[["e7cf9db3.26e7e"]]},{"id":"119a6da.9c74392","type":"inject","z":"1e0aa667.3f381a","name":"stop","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":699,"wires":[["c1c4169c.dd0b58"]]},{"id":"bb921b92.c7f878","type":"mygekko_universal","z":"1e0aa667.3f381a","name":"","server":"14744af.47b48b5","x":970,"y":590,"wires":[["a4d2a866.7de3f8"]]},{"id":"10a6ece8.f2fb83","type":"mygekko_vent","z":"1e0aa667.3f381a","name":"Erdgeschoss","itemid":"","server":"14744af.47b48b5","x":580,"y":780,"wires":[["a4d2a866.7de3f8"]]},{"id":"66ecb67b.8f0128","type":"inject","z":"1e0aa667.3f381a","name":"Lueftung aus","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":770,"wires":[["57706971.0ceba8"]]},{"id":"57706971.0ceba8","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"level","pt":"msg","to":"-1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":770,"wires":[["10a6ece8.f2fb83"]]},{"id":"15ce6649.8f74ca","type":"change","z":"1e0aa667.3f381a","name":"Set","rules":[{"t":"set","p":"level","pt":"msg","to":"2","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":810,"wires":[["10a6ece8.f2fb83"]]},{"id":"8aad7590.9c0a68","type":"inject","z":"1e0aa667.3f381a","name":"Lueftung Stufe 2","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":810,"wires":[["15ce6649.8f74ca"]]},{"id":"14744af.47b48b5","type":"mygekko_server","z":"","active":true,"api":"local","host":"192.168.178.111","interval":"5"}]
Changelog
  • 1.0.6
    initial repository-release
  • 1.0.7
    modified "readme"
  • 1.0.8
    added Version history , added new node "mygekko_vent" for reading and setting values from vents
  • 1.0.9/.10
    added new node "mygekko_meteo" for reading values from the Meteo-component (currently twilight, temperature-outside)
  • 1.0.11
    improvements in rounding float-values to 1 decimal place for fewer messages
  • 1.0.12
    enhanced description for vent-outputs in info-pane in node-red-flow-editor
  • 1.0.13/14/15/16/17
    reworked "readme"
  • 1.0.18
    Added direct input-support for node-red-contrib-alexa-home in light-node. Nodes can be wired directly.
  • 1.0.19 fixed bug in light-node, alexa-home compability color values
  • 1.0.20 fixed "reference-error" in light-node
  • 1.0.21 Added direct input-support for node-red-contrib-alexa-home in blind-node. Nodes can be wired directly.
Version: 1.0.21
Updated 7 years, 6 months ago
52 in the last week
  • mygekko_server
  • mygekko_alarm
  • mygekko_profile
  • mygekko_light
  • mygekko_blind
  • mygekko_load
  • mygekko_action
  • mygekko_vent
  • mygekko_meteo
  • mygekko_universal
  • mygekko
  • my gekko
  • query api
  • gekko
  • homeautomation
