node-red-contrib-alexa-home 3.0.3
Works directly with Alexa in your local network
npm install node-red-contrib-alexa-home
CI Known Vulnerabilities npm version npm downloads
Transform your Node-RED flows into Alexa-compatible smart home devices - No cloud services required!
This Node-RED package creates a local Philips Hue bridge emulation that allows Amazon Alexa devices to discover and control your Node-RED flows directly within your local network. Perfect for home automation, IoT projects, and custom smart home solutions.
✨ Key Features
  • 🏠 Local Network Only - No cloud dependencies or external services
  • 🔍 Auto-Discovery - Alexa automatically finds your devices via SSDP
  • 🎨 Full Color Control - RGB, brightness, and color temperature support
  • 🔒 HTTPS/TLS Support - Secure communication with SSL/TLS encryption
  • 📱 Multiple Device Types - Lights, switches, dimmers, and color bulbs
  • 🌐 Philips Hue API v1/v2 - Compatible with modern Alexa requirements
  • 🔧 Enhanced Validation - Robust error handling and input validation
🚀 Quick Start
Option 1: Node-RED Palette Manager
  1. Open Node-RED editor
  2. Go to Menu → Manage Palette → Install
  3. Search for node-red-contrib-alexa-home
  4. Click Install
Option 2: npm Command Line
Basic Setup
  1. Add Controller Node: Drag the alexa-home-controller node to your flow
  2. Configure Port: Set port to 80 (HTTP) or 443 (HTTPS) for Alexa compatibility
  3. Add Device Nodes: Add alexa-home nodes for each device you want to control
  4. Deploy Flow: Deploy your flow and wait for Alexa to discover devices
  5. Discover Devices: Say "Alexa, discover devices" or use the Alexa app
Example Flow
[{"id":"controller1","type":"alexa-home-controller","name":"Alexa Hub","port":"80"},
 {"id":"light1","type":"alexa-home","controller":"controller1","devicename":"Living Room Light","devicetype":"Extended color light"}]
⚙️ Configuration
Alexa Generation 3+ Compatibility
Modern Alexa devices require communication on standard ports:
  • Port 80 for HTTP communication
  • Port 443 for HTTPS communication
Choose one of these setup methods:
Node Configuration
The easiest way to configure the Alexa Home Controller is through the Node-RED interface:
alexa-home-controller Node Settings
Basic Configuration:
  • Name: Custom name for the controller node
  • Port: Web server port (default: 60000)
  • Max Items: Maximum number of devices to expose to Alexa
Server Options:
  • Use Node-RED Server: ✅ Recommended - Reuses Node-RED's existing web server
    • Automatically detects Node-RED's port and configuration
    • No separate web server process needed
    • Inherits Node-RED's security settings
    • Simpler deployment and maintenance
  • Standalone Server: Creates a separate web server instance
    • Useful when Node-RED runs on non-standard ports
    • Allows independent HTTPS configuration
    • Required for custom SSL certificate setup
HTTPS Configuration (Standalone Server only):
  • Use HTTPS: Enable secure communication
  • Certificate Path: Path to SSL certificate file (.pem, .crt)
  • Private Key Path: Path to SSL private key file (.key)
  • CA Bundle Path: Optional Certificate Authority bundle file
alexa-home Device Settings
Device Configuration:
  • Device Name: Name that Alexa will recognize (e.g., "Living Room Light")
  • Device Type: Choose device capabilities:
    • Extended color light: Full RGB color and brightness control
    • Dimmable light: Brightness control only
    • Color light: Color and brightness control
    • On/Off plug-in unit: Simple switch functionality
  • Input Trigger: Allow input messages to update device state
Port Requirements for Alexa
⚠️ Important: Alexa Generation 3+ devices require communication on standard ports:
  • Port 80 for HTTP
Recommended Solution: Use the "Use Node-RED Server" option and configure Node-RED itself to run on port 80 or 443.
Alternative Solutions: For advanced setups involving environment variables, iptables port forwarding, or reverse proxy configurations, see the Advanced Setup Guide.
Configuration Restrictions
⚠️ Important Limitations:
  • "Use Node-RED Server" and "HTTPS Configuration" are mutually exclusive
    • When using Node-RED's server: Configure HTTPS at the Node-RED application level
    • When using standalone server: Configure HTTPS directly in the controller node
  • Port 80/443 may require elevated privileges when using standalone server mode
  • Certificate files must be readable by the Node-RED process
📡 Message API
Output Message Properties
When Alexa interacts with your devices, the following message properties are generated:
Property Type Description Example
msg.payload.on boolean Device on/off state true / false
msg.payload.bri number Brightness level (0-254) 128
msg.payload.bri_normalized number Brightness percentage (0-100) 50
msg.payload.xy array CIE XY color coordinates [0.3127, 0.329]
msg.payload.command string Command type "switch" / "dim" / "color"
msg.device_name string Device name from configuration "Living Room Light"
msg.light_id string Unique device identifier "light_001"
msg.alexa_ip string IP address of requesting Alexa device "192.168.1.100"
msg.change_direction number Brightness change direction -1 / 0 / 1
Input Message Format
Send commands to your devices using these payload formats:
On/Off Control
msg.payload = { on: true };  // Turn on
msg.payload = { on: false }; // Turn off
// Or simple values
msg.payload = "on";   // Turn on
msg.payload = "off";  // Turn off
msg.payload = 1;      // Turn on
msg.payload = 0;      // Turn off
Brightness Control
msg.payload = { bri: 128 };     // Set brightness (0-254)
msg.payload = { bri: 254, on: true }; // Full brightness and on
Color Control
msg.payload = { xy: [0.675, 0.322] };  // Set color (CIE XY coordinates)
msg.payload = {
  xy: [0.675, 0.322],
  bri: 200,
  on: true
}; // Color with brightness
Combined Commands
msg.payload = {
  on: true,
  bri: 180,
  xy: [0.4, 0.5]
}; // Turn on with specific brightness and color
Advanced Features
Input Passthrough
By default, input messages don't generate output to prevent feedback loops. To enable passthrough:
msg.output = true; // Allow input to pass through as output
📚 Examples
The examples/ directory contains ready-to-use Node-RED flows demonstrating various use cases. Each example includes detailed documentation and can be imported directly into your Node-RED instance.
🔸 Basic Smart Lighting (basic-smart-lighting.json)
Perfect for beginners - demonstrates:
  • Simple on/off control
  • Brightness adjustment
  • Basic color control
  • MQTT integration
Voice Commands:
  • "Alexa, turn on the living room light"
  • "Alexa, set the kitchen light to 50 percent"
  • "Alexa, turn the bedroom light red"
🔸 Advanced Color Scenes (advanced-color-scenes.json)
Professional color control featuring:
  • CIE XY color space validation
  • RGB hex color output
  • Predefined color presets
  • Scene-based lighting (movie, party, relax, work)
Voice Commands:
  • "Alexa, set RGB strip to red"
  • "Alexa, activate movie scene"
  • "Alexa, turn on party scene"
🔸 Multi-Device Integration (multi-device-integration.json)
Comprehensive smart home ecosystem with:
  • Multiple device types
  • Scene coordination
  • Advanced automation
  • MQTT and HTTP integration
📖 How to Use Examples
  1. Download: Save the JSON file from the examples/ directory
  2. Import: In Node-RED, go to Menu → Import → Select file/paste JSON
  3. Configure: Update device names, MQTT brokers, and other settings as needed
  4. Deploy: Deploy the flow and discover devices with Alexa
  5. Test: Use the provided voice commands to test functionality
For detailed documentation of each example, see the examples/README.md file.
🔧 Troubleshooting
Common Issues
Alexa Can't Discover Devices
  1. Check Port Configuration: Ensure you're using port 80 (HTTP) or 443 (HTTPS)
  2. Verify Network: Alexa and Node-RED must be on the same network
  3. Firewall Settings: Allow traffic on the configured port
  4. SSDP Service: Ensure SSDP is running (automatic with controller node)
  5. Device Limits: Check if you've exceeded the maximum devices limit
Devices Not Responding
  1. Controller Status: Verify the controller node shows "Connected"
  2. Device Registration: Ensure devices are properly registered with controller
  3. Message Flow: Check debug nodes for incoming/outgoing messages
  4. Error Logs: Monitor Node-RED logs for error messages
HTTPS/TLS Issues
  1. Certificate Validity: Ensure SSL certificates are valid and readable
  2. File Permissions: Verify Node-RED can read certificate files
  3. Path Configuration: Double-check certificate and key file paths
  4. Port Privileges: Running on port 443 may require elevated privileges
Debug Tips
  1. Enable Debug Nodes: Add debug nodes to monitor message flow
  2. Check Controller Logs: Monitor Node-RED logs for detailed error information
  3. Network Analysis: Use tools like Wireshark to analyze SSDP traffic
  4. Alexa App: Check device status in the Alexa mobile app
Performance Optimization
  • Device Limits: Keep device count reasonable (recommended: <50 devices)
  • Response Time: Ensure fast response times for better Alexa experience
  • Resource Usage: Monitor Node-RED memory and CPU usage
  • Network Latency: Minimize network delays for responsive control
🏗️ Technical Details
Architecture
  • SSDP Discovery: Uses Simple Service Discovery Protocol for device discovery
  • Hue API Emulation: Emulates Philips Hue Bridge API v1 and v2
  • Express.js Server: Built-in web server for handling Alexa requests
  • Template Engine: Flexible template system for API responses
Supported Alexa Features
  • ✅ Device discovery via "discover devices" command
  • ✅ On/off control
  • ✅ Brightness/dimming control
  • ✅ Color control (RGB, XY coordinates)
  • ✅ Device state synchronization
  • ✅ Multiple device types
  • ✅ Scene support (through device grouping)
Network Requirements
  • Same Network: Alexa and Node-RED must be on the same local network
  • Multicast Support: Network must support multicast for SSDP discovery
  • Port Access: HTTP (80) or HTTPS (443) port access required
  • IPv4: Currently supports IPv4 networks only
API Compatibility
  • Philips Hue API v1: Full compatibility for legacy Alexa devices
  • Philips Hue API v2: Modern API support for newer Alexa devices
  • Auto-Detection: Automatically serves appropriate API version
📋 Requirements
  • Node.js: >= 18.5.0
  • Node-RED: >= 4.0.0
  • Network: Local network with multicast support
  • Alexa Device: Amazon Echo, Echo Dot, Echo Show, or Alexa-enabled device
🤝 Contributing
Contributions are welcome! Please read our contributing guidelines and submit pull requests for any improvements.
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes
  4. Add tests if applicable
  5. Submit a pull request
📄 License
🔗 Links
Version: 3.0.3
Updated 1 year, 3 months ago
Rating: 3.7 6
141 in the last week
  • alexa-home
  • alexa-home-controller
  • alexa
  • phillips
  • hue
