node-red-contrib-multi-action-switch 0.0.5
A custom Node-RED node for handling multi-click, longpress, press and release events for SmartHome systems.
npm install node-red-contrib-multi-action-switch
Multi Action Switch is a custom Node-RED node for handling various button press events, including:
  • Single Click
  • Double Click
  • Triple Click
  • Long Press
  • Press & Release
It is designed for smart home systems and integrates well with MQTT, Home Assistant, and Apple HomeKit.
🛠 Installation
To install the node directly from Node-RED:
  1. Open Node-RED.
  2. Go to Manage Palette → Install.
  3. Search for "node-red-contrib-multi-action-switch".
  4. Click Install.
Alternatively, you can install it manually using:
Then restart Node-RED:
node-red-restart
🎛 Node Configuration
After installing, the Multi Action Switch node will be available in the "function" category.
🔧 Node Properties
Property Type Default Description
Trigger Value String "true" The value that triggers the switch.
Double Click Time Number 400 ms The maximum time window for a double click.
Long Press Time Number 700 ms The minimum time required for a long press.
Toggle State Boolean false Whether the node should manage on/off state.
Include Timestamp Boolean false If enabled, the node adds a timestamp to each event.
Output Topic String (optional) MQTT-style topic for event output. If left blank, the node will pass through the incoming message's topic (msg.topic).
🔄 How It Works
Event Handling
The node processes button inputs and generates output messages based on how the button is pressed. The supported events:
Event Type Description
press Triggered immediately when the button is pressed.
release Triggered when the button is released.
singleclick Sent after a single press and release.
doubleclick Sent after two quick presses.
tripleclick Sent after three quick presses.
longpress Sent if the button is held longer than the configured Long Press Time.
Example Usage with MQTT
If Output Topic is set to "home/livingroom/switch", the node will send messages like:
  "topic": "home/livingroom/switch",
  "payload": {
    "eventType": "singleclick",
    "timestamp": 1700000000000
🚀 Example Flows
Basic Usage
The following flow demonstrates how to connect a button input to a multi-action-switch node and print the output.
        "id": "n1",
        "type": "multi-action-switch",
        "triggerValue": "true",
        "doubleClickTime": "400",
        "longPressTime": "700",
        "toggleState": false,
        "includeTimestamp": true,
        "outputTopic": "home/test",
        "wires": [["n2"]]
        "id": "n2",
        "type": "debug",
        "name": "Debug Output"
Using with MQTT
If you're integrating this with Home Assistant via MQTT, you can set up an MQTT Out node with:
  • Topic: home/livingroom/switch
  • Payload: msg.payload
Then, Home Assistant can listen for events like "singleclick" or "longpress".
🔄 State Management
If Toggle State is enabled (toggleState: true), the node will remember its current state ("on" or "off"). The state will be included in singleclick events:
  "state": "on",
The state toggles on each singleclick.
🛠 Troubleshooting
Problem Possible Solution
The node is not responding to button presses Ensure that the Trigger Value matches the expected input ("true", 1, etc.).
Double click or triple click events are not detected Increase the Double Click Time slightly to allow for slower clicking.
Long press fires too early Increase the Long Press Time value.
📜 License
This project is licensed under the MIT License.
🔗 Links
✅ Summary
The Multi Action Switch node makes handling button presses in smart home systems easy. It supports multi-click events, long press detection, and state toggling. It is useful for integrating physical switches into Home Assistant, MQTT, and Apple HomeKit.
If you have any questions or need help, feel free to open an issue on GitHub! 🚀
Version: 0.0.5
Updated 1 year, 9 months ago
7 in the last week
  • multi-action-switch
  • smarthome
  • switch
  • multi-click
  • longpress
  • multi-action
