node-red-contrib-mcp 1.0.3
MCP (Model Context Protocol) nodes for Node-RED — connect AI agents to any MCP server
npm install node-red-contrib-mcp
The bridge between Node-RED and AI agents
npm downloads Node-RED License Stars
Install · Quick Start · Nodes · AI Agent · Examples
AI agent flow in Node-RED — manufacturing OEE deep analysis using MCP tools
Multi-phase OEE analysis agent built with MCP tool nodes in Node-RED
MCP (Model Context Protocol) is the open standard by Anthropic for connecting AI to external tools and data. This package brings MCP to Node-RED — the world's most popular low-code platform for industrial automation and IoT.
4M+ Node-RED installations meet 10,000+ MCP servers. Build AI agents visually. No code required.
  • Any MCP server — Streamable HTTP and SSE transport, with optional auth
  • Any LLM — OpenAI, Anthropic, Ollama, vLLM, Azure, Gemini, or any OpenAI-compatible API
  • AI Agent node — full agentic loop (tool discovery → LLM reasoning → tool execution → repeat)
  • Zero lock-in — Apache-2.0 license, no cloud dependency, runs fully local
  • Production-ready — error handling, status indicators, configurable timeouts
  • Node-RED native — config nodes, msg passing, debug panel integration
Architecture
│  Node-RED                                                       │
│  [inject] → [mcp tool] → [llm call] → [mcp tool] → [debug]   │
│  [inject] → [ai agent] → [debug]    ← autonomous agent loop   │
    │  MCP Server  │                      │   LLM API    │
    │  (any tool)  │                      │  (any model) │
Or search for node-red-contrib-mcp in the Palette Manager:
Menu → Manage palette → Install → node-red-contrib-mcp
Node Description
mcp server Config — MCP server connection (URL, transport, API key)
llm config Config — LLM provider (base URL, model, API key)
mcp tool Call any MCP tool. Pass arguments as msg.payload, tool name in config or msg.topic
mcp tools List all available tools from an MCP server. Great for discovery and debugging
mcp resource Read resources exposed by an MCP server
llm call Call any OpenAI-compatible LLM. Supports system prompt, JSON mode, multi-turn chat
ai agent Autonomous agent — LLM + MCP tools in a reasoning loop until it has an answer
Quick Start
1. Call an MCP tool
[inject {"machine": "CNC-001"}] → [mcp tool "get_oee"] → [debug]
2. LLM + MCP pipeline
[inject] → [mcp tool "get_data"] → [llm call "Summarize this"] → [debug]
3. AI Agent (the magic node)
[inject "Why did OEE drop on machine 9014?"] → [ai agent] → [debug]
The agent autonomously discovers tools, reasons about which to call, executes them, and synthesizes a final answer. Same pattern as ChatGPT or Claude — but visual, auditable, and in your Node-RED.
AI Agent
The ai agent node runs a full agentic reasoning loop:
User: "Why did OEE drop on machine 9014 last week?"
  ┌─── Agent Loop ──────────────────────────────────────────┐
  │  Step 1: LLM sees 91 tools, picks get_oee              │
  │          → calls MCP server → gets OEE data             │
  │  Step 2: LLM analyzes, picks get_downtime_events        │
  │          → calls MCP server → gets 3 events             │
  │  Step 3: LLM synthesizes final answer                   │
Agent: "OEE dropped from 85% to 62% due to 3 unplanned stops:
        bearing failure (47min), tool change delay (23min),
        and material shortage (18min)."
  msg.agentLog = [{tool: "get_oee", ...}, {tool: "get_downtime_events", ...}]
  msg.iterations = 3
Agent settings
Setting Default Description
MCP Server — Which MCP server to use for tools
LLM — Which LLM provider for reasoning
System Prompt — Agent personality and instructions
Max Loops 10 Maximum LLM ↔ tool iterations
Temperature 0.3 LLM creativity (0 = focused, 1 = creative)
Examples
Import this flow
Copy the JSON below, then in Node-RED: Menu → Import → Paste
Example: MCP Tool Call
    "id": "mcp-demo-inject",
    "type": "inject",
    "name": "Trigger",
    "props": [{ "p": "payload" }],
    "payload": "{\"machine_id\": \"CNC-001\"}",
    "payloadType": "json",
    "wires": [["mcp-demo-tool"]],
    "x": 150,
    "y": 100
    "id": "mcp-demo-tool",
    "type": "mcp-tool-call",
    "name": "Get OEE",
    "server": "mcp-demo-server",
    "toolName": "get_oee",
    "wires": [["mcp-demo-debug"]],
    "x": 350,
    "y": 100
    "id": "mcp-demo-debug",
    "type": "debug",
    "name": "Result",
    "active": true,
    "x": 550,
    "y": 100
    "id": "mcp-demo-server",
    "type": "mcp-server-config",
    "name": "My MCP Server",
    "url": "http://localhost:8021/mcp",
    "transportType": "http"
Example: AI Agent
    "id": "agent-demo-inject",
    "type": "inject",
    "name": "Ask question",
    "payload": "What is the current OEE of machine CNC-001 and what are the main loss factors?",
    "payloadType": "str",
    "wires": [["agent-demo-agent"]],
    "x": 170,
    "y": 100
    "id": "agent-demo-agent",
    "type": "ai-agent",
    "name": "Factory Agent",
    "server": "agent-demo-mcp",
    "llmConfig": "agent-demo-llm",
    "systemPrompt": "You are a manufacturing AI assistant. Use the available MCP tools to answer questions about factory operations. Be precise and cite specific numbers.",
    "maxIterations": 10,
    "temperature": 0.3,
    "maxTokens": 4096,
    "wires": [["agent-demo-debug"]],
    "x": 400,
    "y": 100
    "id": "agent-demo-debug",
    "type": "debug",
    "name": "Agent Response",
    "active": true,
    "x": 620,
    "y": 100
    "id": "agent-demo-mcp",
    "name": "Factory MCP",
    "url": "http://localhost:8024/mcp",
    "id": "agent-demo-llm",
    "type": "llm-config",
    "name": "OpenAI",
    "baseUrl": "https://api.openai.com/v1",
    "model": "gpt-4o"
Example: MQTT → AI Agent → MQTT (IIoT)
    "id": "mqtt-in",
    "type": "mqtt in",
    "name": "machine/alerts",
    "topic": "machine/+/alert",
    "broker": "mqtt-broker",
    "wires": [["mqtt-agent"]],
    "x": 150,
    "y": 100
    "id": "mqtt-agent",
    "type": "ai-agent",
    "name": "Alert Agent",
    "server": "mqtt-mcp-server",
    "llmConfig": "mqtt-llm",
    "systemPrompt": "You are an industrial AI agent. When you receive a machine alert, investigate using MCP tools and recommend an action. Be concise.",
    "maxIterations": 5,
    "wires": [["mqtt-out"]],
    "x": 380,
    "y": 100
    "id": "mqtt-out",
    "type": "mqtt out",
    "name": "machine/actions",
    "topic": "machine/actions",
    "x": 600,
    "y": 100
MQTT alert comes in → AI agent investigates via MCP tools → action goes out via MQTT.
Compatible with
MCP Servers
Works with any MCP server that supports Streamable HTTP or SSE transport:
  • OpenShopFloor — 91 manufacturing MCP tools (ERP, OEE, QMS, WMS)
  • Anthropic MCP Servers — filesystem, GitHub, PostgreSQL, Slack, Google Drive, ...
  • Any custom MCP server you build
LLM Providers
Works with any OpenAI-compatible API:
Provider Base URL
OpenAI https://api.openai.com/v1
Ollama (local) http://localhost:11434/v1
Azure OpenAI https://YOUR.openai.azure.com/openai/deployments/YOUR_DEPLOYMENT/v1
vLLM http://localhost:8000/v1
LiteLLM http://localhost:4000/v1
LM Studio http://localhost:1234/v1
Anthropic via LiteLLM proxy
msg Reference
mcp-tool-call
Direction Property Type Description
Input msg.payload object Tool arguments
Input msg.topic string Tool name (if not set in config)
Output msg.payload any Tool result (auto-parsed JSON)
Output msg.mcpResult object Raw MCP response
ai-agent
Input msg.payload string User question or task
Output msg.payload string Agent's final answer
Output msg.agentLog array [{tool, args, result}] for each call
Output msg.iterations number Total LLM reasoning steps
llm-call
Input msg.payload string User message
Input msg.messages array Previous conversation (multi-turn)
Input msg.tools array OpenAI-format tool definitions
Output msg.payload string LLM response text
Output msg.toolCalls array Tool calls (if any)
Output msg.usage object Token usage stats
MCP Server (config node)
Field Description Example
URL MCP server endpoint http://localhost:3001/mcp
Transport Protocol variant Streamable HTTP (default) or SSE
API Key Optional Bearer token sk-...
LLM Provider (config node)
Base URL OpenAI-compatible endpoint https://api.openai.com/v1
Model Model identifier gpt-4o
API Key Your API key sk-...
Use Cases
Domain What you can build
Manufacturing OEE monitoring, capacity planning, predictive maintenance, quality root cause analysis
IIoT MQTT → AI Agent → MQTT pipelines, sensor data analysis, anomaly detection
Building Automation Smart energy management, BACnet/Modbus + AI reasoning
IT / DevOps Database agents, log analysis, automated incident response
Prototyping Fastest way to prototype agentic AI — visual debugging in Node-RED
Requirements
  • Node-RED >= 3.0.0
  • Node.js >= 18.0.0
  • An MCP server to connect to
  • An LLM API key (for llm-call and ai-agent nodes)
Contributing
Issues and PRs welcome! github.com/BavarianAnalyst/node-red-contrib-mcp
Apache-2.0 — use it anywhere, commercially or not.
Built by OpenShopFloor — the open-source AI platform for factory operations
Live Demo · GitHub · Node-RED Flow Library
Version: 1.0.3
Updated 8 months, 3 weeks ago
Rating: 1.0 1
118 in the last week
  • mcp-server-config
  • llm-config
  • mcp-tool-call
  • mcp-tool-list
  • mcp-resource-read
  • llm-call
  • ai-agent
  • mcp
  • model-context-protocol
  • ai
  • agent
  • agentic
  • llm
  • openai
  • anthropic
  • manufacturing
  • iiot
  • automation
  • tools
