node-red-contrib-influxdb3 1.1.1
Node-RED nodes for InfluxDB v3 integration
npm install node-red-contrib-influxdb3
npm version npm downloads Node-RED License: MIT
Node-RED nodes for writing data to InfluxDB v3.
This package provides Node-RED integration with InfluxDB v3 using the official @influxdata/influxdb3-client JavaScript library.
From npm (when published)
From local directory
npm install /path/to/node-red-contrib-influxdb3
Development Installation
  1. Clone this repository
  2. Install dependencies:
    npm install
  3. Link to your Node-RED installation:
  4. Restart Node-RED
This package includes two nodes:
InfluxDB v3 Config Node
A configuration node that stores connection details for your InfluxDB v3 instance.
Configuration:
  • Name: A friendly name for the connection
  • Host: Your InfluxDB v3 host URL (e.g., https://us-east-1-1.aws.cloud2.influxdata.com)
  • Token: Your InfluxDB v3 authentication token
  • Database: The default database (bucket) name
  • Verify TLS: Toggle TLS certificate verification for this connection (unchecked disables verification for this connection only)
  • CA Cert Path: Optional filesystem path to a PEM CA certificate used to verify this connection's TLS certificate
InfluxDB v3 Write Node
Writes data points to InfluxDB v3.
Configuration:
  • Connection: Select an InfluxDB v3 config node
  • Name: Optional node name
  • Measurement: Default measurement name (can be overridden by msg.measurement)
  • Database: Optional database override (uses connection default if not set)
  • Partial writes: Accept the valid lines of a batch even if other lines are rejected (InfluxDB 3 Core/Enterprise only)
  • No sync: Respond without waiting for WAL persistence — faster writes without durability confirmation (InfluxDB 3 Core/Enterprise only)
Partial Writes
By default a batch write is all-or-nothing: one invalid line causes InfluxDB to reject the entire batch. With Partial writes enabled, InfluxDB writes the valid lines and reports the rejected ones. The node then:
  • shows a yellow partial write status instead of an error
  • logs a warning listing each rejected line and the reason
  • forwards the message with the details attached as msg.partialWriteErrors, an array of { lineNumber, errorMessage, originalLine } objects
Enabling Partial writes or No sync routes the write through the InfluxDB v3 API endpoint, which is only available on InfluxDB 3 Core and Enterprise. On other deployments (Cloud Serverless/Dedicated, Clustered) leave both options disabled — writes there use the v2-compatible endpoint, where these options are not supported and would cause writes to fail. When No sync is enabled without Partial writes, the node keeps the all-or-nothing write semantics.
Input Message Formats
The write node accepts data in multiple formats:
1. Line Protocol String
Send data as a string in InfluxDB line protocol format:
msg.payload = "temperature,location=room1 value=21.5";
Note: raw line protocol strings are passed through unmodified (each line is only sanity-checked). When data comes from an untrusted source, prefer the object formats below — the node escapes measurement, tag and field values automatically.
2. Object with Fields and Tags
Send an object with explicit fields and tags properties:
msg.measurement = "temperature";
msg.payload = {
    fields: {
        value: 21.5,
        humidity: 65
    tags: {
        sensor: "dht22"
    timestamp: Date.now() // optional
3. Simplified Object Format
Send an object where all properties are treated as fields, except the reserved keys measurement, fields, tags, timestamp and integers:
msg.measurement = "environment";
msg.payload = {
    temperature: 21.5,
    humidity: 65,
    pressure: 1013.25,
    tags: {
        room: "bedroom",
        floor: "2"
4. Array of Multiple Measurements
Send an array to write multiple measurements in a single message:
// Array of objects
msg.payload = [
        measurement: "temperature",
        fields: { value: 21.5 },
        tags: { location: "room1" }
        fields: { value: 19.8 },
        tags: { location: "room2" }
        measurement: "humidity",
        fields: { value: 65 },
// Array of line protocol strings
msg.payload = [
    "temperature,location=room1 value=21.5",
    "temperature,location=room2 value=19.8",
    "humidity,location=room1 value=65"
// Mixed array (objects and strings)
msg.payload = [
Data Types
Important: By default, all numbers are written as floats to avoid schema conflicts in InfluxDB. This is because JavaScript doesn't distinguish between 1.0 and 1 (both equal 1), which can cause issues when InfluxDB expects a float but receives an integer.
When using object format, the node handles data types as follows:
  • Numbers: Written as float fields by default
  • Integers: Must be explicitly marked (see below)
  • Booleans: Written as boolean fields
  • Strings: Written as string fields
  • Tags: Always converted to strings
Writing Integer Fields
To write integers explicitly, use one of these methods:
Method 1: Using the integers array
msg.payload = {
    fields: {
        temperature: 21.5,   // float
        count: 42,           // will be float by default
        total: 100           // will be float by default
    integers: ['count', 'total']  // mark these as integers
Method 2: Using the i suffix
msg.payload = {
    fields: {
        count: "42i",        // integer (note the string with 'i' suffix)
        total: "100i"        // integer
Example with both floats and integers:
msg.measurement = "sensor_data";
msg.payload = {
    humidity: 65.0,         // float (even though it looks like an integer)
    event_count: "50i",     // integer
    tags: {
Message Properties
The following message properties can be used to override node configuration:
  • msg.measurement - Override the measurement name
  • msg.database - Override the database name
  • msg.timestamp - Set the timestamp for the data point (Date object or milliseconds)
  • msg.payload.integers - Array of field names to write as integers (e.g., ['count', 'total'])
Examples
Example 1: Temperature Sensor
// Function node
msg.payload = {
    value: 21.5,
    tags: {
        sensor_id: "temp_001"
Example 2: Multi-Sensor Data
// Function node
msg.payload = {
    fields: {
        temperature: 22.3,
        humidity: 58,
        co2: 412,
        light: 850
    tags: {
        room: "office",
        floor: "3",
        building: "A"
Example 3: MQTT to InfluxDB
[MQTT In] --> [JSON Parse] --> [Function] --> [InfluxDB v3 Write]
Function node:
// Parse MQTT topic for location
const location = msg.topic.split('/')[1];
msg.payload = {
    temperature: msg.payload.temp,
    humidity: msg.payload.hum,
    tags: {
Example 4: Using Line Protocol
// Function node - direct line protocol
const location = "warehouse";
const temp = 18.5;
const humidity = 72;
msg.payload = `climate,location=${location} temperature=${temp},humidity=${humidity}`;
Example 5: Multiple Databases
// Write to different databases based on data type
if (msg.payload.type === "critical") {
    msg.database = "critical-events";
} else {
    msg.database = "general-logs";
msg.measurement = "events";
msg.payload = {
    severity: msg.payload.severity,
    message: msg.payload.msg,
    tags: {
        type: msg.payload.type
Sample Flow
Import this flow into Node-RED to get started:
        "id": "influxdb3-config-node",
        "type": "influxdb3-config",
        "name": "My InfluxDB v3",
        "host": "https://us-east-1-1.aws.cloud2.influxdata.com",
        "database": "my-database"
        "id": "inject-node",
        "type": "inject",
        "name": "Generate Data",
        "props": [{"p": "payload"}],
        "repeat": "5",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 140,
        "y": 100,
        "wires": [["function-node"]]
        "id": "function-node",
        "type": "function",
        "name": "Format Data",
        "func": "msg.measurement = 'temperature';\nmsg.payload = {\n    value: 20 + Math.random() * 10,\n    tags: {\n        location: 'office'\n    }\n};\nreturn msg;",
        "x": 320,
        "y": 100,
        "wires": [["influxdb3-write-node"]]
        "id": "influxdb3-write-node",
        "type": "influxdb3-write",
        "name": "Write to InfluxDB",
        "influxdb": "influxdb3-config-node",
        "measurement": "",
        "database": "",
        "x": 530,
        "y": 100,
        "wires": [["debug-node"]]
        "id": "debug-node",
        "type": "debug",
        "name": "Debug",
        "x": 730,
        "y": 100,
Configuration with Environment Variables
You can use environment variables in the configuration node:
  • INFLUX_HOST - InfluxDB v3 host URL
  • INFLUX_TOKEN - Authentication token
  • INFLUX_DATABASE - Default database name
Simply reference them in the Node-RED UI using ${INFLUX_HOST} syntax (if using Node-RED environment variable substitution).
Troubleshooting
Connection Issues
  • Verify your host URL is correct and includes https://
  • Check that your token has write permissions for the database
  • Ensure the database name exists in your InfluxDB v3 instance
TLS / Custom Certificates
If you are connecting to a local InfluxDB v3 instance with a custom certificate:
  • Set CA Cert Path in the config node to the PEM file containing your root CA. The certificate is read when the connection is first used and applied to this connection only.
  • As a last resort, disable Verify TLS. This skips certificate verification for this connection only (it does not affect other connections or the rest of the Node-RED process).
Data Not Appearing
  • Check the node status - it should show "written" briefly after successful writes
  • Verify at least one field is provided (InfluxDB requires at least one field)
  • Check that field values are not null or undefined
Error Messages
The node will display error status and log details to the Node-RED debug panel:
  • "no config" - The InfluxDB v3 config node is not selected
  • "error" - Check the debug panel for details
Requirements
  • Node.js v24.0.0 or higher
  • Node-RED v3.0.0 or higher
  • InfluxDB v3 instance (Cloud or Edge)
MIT
Links
Contributing
Contributions are welcome! Please feel free to submit a Pull Request.
Version: 1.1.1
Updated 3 months, 1 week ago
282 in the last week
  • influxdb3-config
  • influxdb3-write
  • influxdb
  • influxdb3
  • time-series
  • database
