node-red-contrib-image-generation-ubos 1.0.5
A Node-RED node that interacts with OpenAI machine learning models to generate image outputs like 'DALL·E 2'.
npm install node-red-contrib-image-generation-ubos
Ubos - End-to-End Software Development Platform
UBOS • Community • Youtube • Discord • GitHub
flow npm
Quick Start
Install with the built in Node-RED Palette manager or using npm:
Setup
When editing the nodes properties, to get your OPENAI_API_KEY log in to ChatGPT and then visit https://platform.openai.com/account/api-keys click "+ Create new secret key" then copy and paste the "API key" into the nodes API_KEY property value.
To get your Organization visit https://platform.openai.com/account/org-settings then copy and paste the "OrganizationID" into the nodes Organization property value.
Properties
  • [Required] msg.OPENAI_API_KEY: This is the API key provided by OpenAI. It is necessary for authentication when making requests to the OpenAI API.
  1. When msg.type is set to create_image:
    • [Required] msg.prompt: A text description of the desired image(s). The maximum length is 1000 characters.
    • msg.n: The number of images to generate. Must be between 1 and 10.
    • msg.size: The size of the generated images. Must be one of 256x256, 512x512, or 1024x1024.
    • msg.response_format: The format in which the generated images are returned. Must be one of url or b64_json.
    • msg.user: A unique identifier representing your end-user, which can help OpenAI to monitor and detect abuse. Learn more
  2. When msg.type is set to create_image_edit:
    • [Required] msg.image: The image to edit. Must be a valid PNG file, less than 4MB, and square. If mask is not provided, image must have transparency, which will be used as the mask. For example:
     msg.image = {
         "value": msg.req.files[0].buffer,
         "options": {
             "filename": msg.req.files[0].originalname
    • msg.mask: An additional image whose fully transparent areas (e.g. where alpha is zero) indicate where image should be edited. Must be a valid PNG file, less than 4MB, and have the same dimensions as image. For example
     msg.mask = {
         "value": msg.req.files[1].buffer,
         "options": {
             "filename": msg.req.files[1].originalname
  3. When msg.type is set to create_image_variation:
    • [Required] msg.image: The image to use as the basis for the variation(s). Must be a valid PNG file, less than 4MB, and square. For example
     msg.image = {
         "options": {
Demo
Create image
Group 21
Image edit
Group 21
Image variation
Group 21 (1)
Bugs reports and feature requests
Please report any issues or feature requests at GitHub.
MIT License
Version: 1.0.5
Updated 3 years, 8 months ago
Rating: 4.0 2
6 in the last week
  • chatgpt
  • nodejs
  • javascript
  • api
  • flow
  • npm
  • machine-learning
  • node
  • example
  • image-generation
  • openai
  • conversational-ai
  • gpt-3
  • gpt-4
  • dall-e
  • ai
