node-red-contrib-homie-home-assistant-discovery 1.0.11
Node-RED node that publishes Home Assistant MQTT discovery from Homie MQTT metadata.
npm install node-red-contrib-homie-home-assistant-discovery
Node-RED Contrib Homie Home Assistant Discovery
npm Node-RED Library npm downloads CI Node.js Latest Release License
works with MQTT Homie
Use this Node-RED node to publish Home Assistant MQTT discovery for Homie MQTT devices.
The node fits the normal Node-RED MQTT flow: put it between the built-in mqtt in and mqtt out nodes. It reads Homie metadata from MQTT, emits retained Home Assistant discovery messages, and can send subscription-control messages back to the same mqtt in node.
It does not open its own broker connection. Node-RED's MQTT nodes already handle credentials, TLS, reconnect behavior and broker configuration; this node focuses on Homie parsing, Home Assistant mapping, diagnostics and editor configuration.
Node-RED Homie Home Assistant Discovery flow
Quick Start
  1. Install from the Node-RED Palette Manager.
  2. Add an mqtt in node and point it to the broker used by your Homie devices.
  3. Leave the mqtt in topic empty if you want dynamic subscriptions, or use homie/# for a broad manual subscription.
  4. Wire mqtt in into homie-ha-discovery.
  5. Wire output 1 of homie-ha-discovery into an mqtt out node on the same broker.
  6. Optional: wire output 4 back into the same mqtt in node so the discovery node can manage Homie subscriptions dynamically.
Output 4 is the bottom port so that, in a normal left-to-right flow, the feedback wire can return to the MQTT input without crossing the discovery, diagnostic or debug wires.
Outputs
Output Name Connect it to
1 Discovery mqtt out, same broker, publishes retained discovery.
2 Diagnostics debug, useful warnings and lifecycle logs.
3 Debug debug, original input passthrough for inspection.
4 Subscriptions the same mqtt in, for dynamic subscriptions.
Discovery messages already contain topic, payload, qos and retain, so the mqtt out node can publish them directly.
Basic Configuration
For most installations, start with the defaults:
  • Home Assistant prefix: homeassistant
  • Homie v5: homie
  • Homie v3/v4: homie
  • Versions: v3, v4 and v5 enabled
  • Subscriptions: enabled
  • Boolean mapping: Auto
Use Auto unless you want to force one fallback. It maps clear light and fan names/types, then falls back to switch for generic commandable booleans. Read-only booleans are always binary_sensor.
What Gets Discovered
The mapper uses Homie metadata first:
  • read-only booleans become binary_sensor;
  • commandable booleans become switch, light or fan;
  • commandable numbers become number;
  • commandable enums become select when options are available;
  • commandable strings and similar values become text;
  • read-only values become sensor;
  • Homie lifecycle and optional v5 attributes become diagnostic entities.
The mapper is conservative. It will not invent climate, cover, lock, vacuum, alarm panels or other complex Home Assistant domains from generic Homie metadata alone. Use overrides when you know the real device semantics.
Practical Overrides
Start without overrides. Add them only when Home Assistant needs clearer names, stable historical IDs, a different platform for one property or additional MQTT discovery fields.
A common pattern is a device with many nodes, each exposing a boolean state property. This example maps named state entities to lights, except one fan:
  // Shared identity for discovered Home Assistant devices.
  "deviceDefaults": {
    // Generates predictable device discovery object IDs.
    "objectId": "home_{deviceId}",
    // Keeps the Home Assistant device identity stable.
    "identifiers": ["homie:{baseTopic}"],
  // Shortcut: listed node/state entities are lights by default.
  "namedNodeState": {
    "platform": "light",
    "objectId": "home_{deviceId}_{nodeId}",
  // Device-specific names and exceptions.
  "devices": {
    "homie/5/kitchen-board": {
      "name": "Kitchen board",
      "nodeNames": {
        "ceiling": "Ceiling light",
        "extractor": {
          "name": "Extractor fan",
          "platform": "fan",
          "icon": "mdi:fan",
The Overrides field accepts strict JSON, not JSON with comments. Use the commented example to understand the shape, then paste a comment-free version:
  "deviceDefaults": {
  "namedNodeState": {
  "devices": {
      "nodeNames": {
        "extractor": {
          "platform": "fan",
          "icon": "mdi:fan"
Exact device, node and property overrides take precedence over broad rules. That lets you set a shared default for a fleet, then make one entity a fan, switch, renamed sensor or disabled diagnostic without changing the shared configuration.
Documentation
The full documentation map is in DOCS.md. Start there for Node-RED wiring, dynamic subscriptions, entity mapping, overrides and Homie compatibility.
Core Package
This package wraps homie-home-assistant-discovery. The shared core provides Homie parsing and Home Assistant mapping. This Node-RED package provides the editor UI, runtime status, diagnostics and Node-RED message wiring.
Local Development
npm ci
npm run check
For sibling-repository development, keep the core homie-home-assistant-discovery package built locally before running the wrapper checks. Published installs resolve the same dependency from npm.
Apache-2.0. See LICENSE.
Version: 1.0.11
Updated 2 hours ago
26 in the last week
  • homie-ha-discovery
  • mqtt
  • homie
  • homie-iot
  • homie-convention
  • homie-mqtt
  • home-assistant
  • homeassistant
  • home-assistant-discovery
  • mqtt-discovery
  • discovery
  • smart-home
  • home-automation
  • iot
  • typescript
