node-red-contrib-google-spreadsheet-plus 2.0.3
Enhanced Google Sheets integration with caching, data transformations, and modern authentication for Node-RED
npm install node-red-contrib-google-spreadsheet-plus
A Node-RED module for Google Sheets integration with smart caching, data transformations, and modern authentication. Read, write, update, append, and clear data in Google Sheets with automatic data format conversion and built-in validation.
Compatible with Node-RED v3.0.0 and above | Built-in JWT authentication | Smart caching | Zero configuration data transformations
Table of Contents
Overview
This module provides a complete solution for working with Google Sheets in Node-RED. Instead of dealing with complex authentication flows, A1 notation parsing, and data format conversions, you get a simple, intuitive interface that handles all the heavy lifting.
How to Use:
  1. Set up once - Configure a Google Service Account in your Google Cloud Console
  2. Connect - Add a Service Account config node in Node-RED with your credentials
  3. Use anywhere - Place Google Sheets nodes in your flows to read/write data
What you can do:
  • Read data from any range in any format (2D arrays, objects, with/without headers)
  • Write data to specific ranges (append new rows, update existing cells, or clear first)
  • Append rows to the end of existing data without overwriting
  • Clear ranges to remove unwanted data
  • Cache results for better performance on repeated reads
  • Transform data automatically between arrays, objects, and Google Sheets format
How it works:
Google Sheets stores data in a grid (rows and columns). This module lets you:
  1. Specify a location using A1 notation (e.g., Sheet1!A1:D10 means columns A through D, rows 1 through 10)
  2. Choose an operation (get data, set data, or clear data)
  3. Send/receive data in the format that works best for your flow
The module handles all the complexity:
  • Converts your data to Google Sheets format automatically
  • Manages authentication tokens with automatic refresh
  • Caches data to reduce API calls
  • Validates all inputs before making API requests
  • Provides clear error messages when something goes wrong
Authentication:
Uses Google Service Accounts with JWT (JSON Web Token) authentication. This is the most secure method for server-to-server communication and doesn't require user interaction or OAuth consent screens.
All credentials are encrypted using Node-RED's built-in encryption and stored in flows_cred.json. Sensitive data never appears in plain text in your flows.
Why Use This Package
vs. Manual API Calls
  • 10x Less Code: What takes 50+ lines of code becomes a single node
  • Built-in Validation: Catches errors before API calls
  • Automatic Retries: Handles token refresh and transient errors
  • Smart Caching: Reduces API calls by up to 90%
vs. Other Packages
  • Modern: Uses latest googleapis (170.1.0), async/await, ES6+
  • Production-Ready: Comprehensive error handling, validation, and status indicators
  • Well-Tested: 100% coverage on business logic (328 passing tests)
  • Active Maintenance: Regular updates, security patches, and feature additions
Key Benefits
  • Simple Configuration: Copy-paste JSON credentials, start working in seconds
  • Flexible Data Handling: Works with arrays, objects, primitives - converts automatically
  • Clear Error Messages: Know exactly what went wrong and how to fix it
  • Visual Feedback: Node status shows current operation state
  • No External Dependencies: Only depends on googleapis (official Google library)
Via Palette Manager (Recommended)
  1. Open Node-RED editor
  2. Go to Menu → Manage palette → Install tab
  3. Search for node-red-contrib-google-spreadsheet-plus
  4. Click Install
Via npm
Install in your Node-RED user directory (typically ~/.node-red):
Important: Restart Node-RED after npm installation to load the nodes.
Requirements
  • Node-RED v3.0.0 or higher
  • Node.js v20.0.0 or higher
  • Google Cloud Project with Sheets API enabled
  • Google Service Account with spreadsheet access
The nodes will appear in the palette:
  • google-service-account (configuration node, accessible via any Google Sheets node)
  • google-spreadsheet in the storage category with a Sheets icon
Quick Start
1. Set Up Google Cloud Credentials
Step-by-step instructions (click to expand)
  1. Create Google Cloud Project
    • Go to Google Cloud Console
    • Click "Select a project" → "New Project"
    • Enter project name, click "Create"
  2. Enable Google Sheets API
    • In your project, go to "APIs & Services" → "Library"
    • Search for "Google Sheets API"
    • Click on it, then click "Enable"
  3. Create Service Account
    • Go to "APIs & Services" → "Credentials"
    • Click "Create Credentials" → "Service Account"
    • Fill in:
      • Service account name: node-red-sheets (or any name)
      • Service account ID: (auto-filled)
    • Click "Create and Continue"
    • Skip the optional steps, click "Done"
  4. Generate Key
    • Click on the service account you just created
    • Go to "Keys" tab
    • Click "Add Key" → "Create new key"
    • Choose "JSON" format
    • Click "Create"
    • A JSON file will download - keep this safe!
  5. Share Your Spreadsheet
    • Open your Google Spreadsheet
    • Click "Share" button
    • Add the service account email (looks like [email protected])
    • Grant Editor permission (for write access) or Viewer (for read-only)
    • Click "Done"
⚠️ Important: Without sharing, you'll get "Permission denied" errors!
2. Configure in Node-RED
Configuration steps (click to expand)
  1. Add Service Account Config Node
    • Drag a "Google Sheets" node into your flow
    • Double-click to open settings
    • Click pencil icon next to "Credentials" to create new config
    • Name it (e.g., "Production Service Account")
  2. Add Credentials
    • Select "Copy/paste JSON" (recommended)
    • Open the downloaded JSON file
    • Copy entire contents
    • Paste into the "Credentials JSON" field
    • Click "Add"
    Alternative: Enter fields individually (project_id, client_email, private_key)
  3. Configure Spreadsheet Node
    • Spreadsheet ID: Copy from URL between /d/ and /edit
      https://docs.google.com/spreadsheets/d/1BxiMVs0XRA5nFMdKvBdBZjgmUUqptlbs74OgvE2upms/edit
                                               ↑ This is your Spreadsheet ID ↑
    • Range: Use A1 notation (e.g., Sheet1!A1:D10)
    • Action: Choose "Get Data", "Set Data", or "Clear Data"
    • Output: Where to store results (default: msg.payload)
  4. Deploy and Test
    • Click "Deploy"
    • Inject a message (using an inject node)
    • Check the debug output
3. Your First Flow
Example: Read data from a spreadsheet (click to expand)
[inject] → [Google Sheets] → [debug]
Inject node configuration:
  "spreadsheetId": "1BxiMVs0XRA5nFMdKvBdBZjgmUUqptlbs74OgvE2upms",
  "range": "Sheet1!A1:C10"
Google Sheets node configuration:
  • Action: "Get Data"
  • Sheet ID: from msg.spreadsheetId
  • Range: from msg.range
  • Output: msg.payload
Result in msg.payload:
  ["Name", "Email", "Age"],
  ["John Doe", "[email protected]", 30],
  ["Jane Smith", "[email protected]", 25]
With "First line for labels" enabled:
  { "Name": "John Doe", "Email": "[email protected]", "Age": 30 },
  { "Name": "Jane Smith", "Email": "[email protected]", "Age": 25 }
Reading Data
Get Data - Basic Examples (click to expand)
Read entire sheet:
Range: Sheet1
Output: 2D array of all data
Read specific range:
Range: Sheet1!A1:D10
Output: [[row1], [row2], ...]
Read with column headers:
Range: Sheet1!A1:C10
Enable: "First line for labels"
Output: [{Name: "John", Age: 30}, ...]
Read with row and column headers:
Range: Sheet1!A1:D5
Enable: "First line for labels" + "First column for labels"
Output: {John: {Age: 30, City: "NYC"}, ...}
Read single column:
Range: Sheet1!B:B
Output: [["value1"], ["value2"], ...]
Read single row:
Range: Sheet1!1:1
Output: [["col1", "col2", "col3"]]
Get Data - Advanced Options (click to expand)
Select specific fields only:
Data: [{Name: "John", Age: 30, City: "NYC", Country: "USA"}]
Selected fields: ["Name", "Age"]
Output: [{Name: "John", Age: 30}]
Get by column (transpose):
Enable: "Get data by column"
Input data (rows):
  [["Name", "Age"], ["John", 30], ["Jane", 25]]
Output (columns):
  [["Name", "John", "Jane"], ["Age", 30, 25]]
Caching for performance:
Cache location: msg._sheet (default)
First read: Calls API
Second read: Uses cached data (instant)
Clear cache: Use "Clear Data" action or delete msg._sheet
Writing Data
Set Data - Write Methods (click to expand)
Update (modify existing cells):
Method: Update
Range: Sheet1!A2:C3
Input: [["John", 30, "NYC"], ["Jane", 25, "LA"]]
Result: Updates only cells A2:C3, leaves other cells unchanged
Append (add rows at the end):
Method: Append
Range: Sheet1!A:C
Input: [["New Person", 35, "SF"], ["Another", 40, "SEA"]]
Result: Adds rows after last existing row
New (clear then write):
Method: New
Input: [["Header1", "Header2", "Header3"], ["Data1", "Data2", "Data3"]]
Result: Clears A1:C10 first, then writes new data
Set Data - Input Formats (click to expand)
Array of arrays (standard format):
  "payload": [
    ["Name", "Age", "City"],
    ["Jane", 25, "LA"]
Array of objects (auto-converted):
  "payload": [
    {"Name": "John", "Age": 30, "City": "NYC"},
    {"Name": "Jane", "Age": 25, "City": "LA"}
With "First line for labels" enabled, keys become column headers automatically.
Single value (writes to one cell):
  "payload": "Hello World"
Single row:
  "payload": ["Value1", "Value2", "Value3"]
Clearing Data
Clear Data Examples (click to expand)
Clear specific range:
Action: Clear Data
Range: Sheet1!A2:C10
Result: Clears all data in cells A2 through C10
Clear entire sheet:
Range: Sheet1
Result: Clears all data in Sheet1
Clear specific columns:
Range: Sheet1!B:D
Result: Clears columns B, C, D entirely
Note: Clearing data automatically clears the cache for that range.
Dynamic Configuration
Using msg properties for configuration (click to expand)
Instead of hardcoding values in the node, pass them via the message:
Dynamic Spreadsheet ID and Range:
// In a function node or inject
msg.spreadsheetId = "1BxiMVs0XRA5nFMdKvBdBZjgmUUqptlbs74OgvE2upms";
msg.range = "Sheet1!A1:C10";
Then in Google Sheets node:
  • Spreadsheet ID: msg.spreadsheetId
  • Range: msg.range
Dynamic data input:
msg.payload = [
  ["Product", "Price", "Stock"],
  ["Item A", 29.99, 100],
  ["Item B", 49.99, 50]
Using global context for shared configuration:
// Set once in a setup flow
global.set("prodSpreadsheetId", "1BxiMVs...");
// Use in multiple flows
msg.spreadsheetId = global.get("prodSpreadsheetId");
Data Transformations
Automatic Format Conversion
Understanding data transformation (click to expand)
The node automatically converts between formats:
JavaScript → Google Sheets:
// Array of arrays → Writes directly
[["A1", "B1"], ["A2", "B2"]]
// Array of objects → Converts to 2D array
→ [["John", 30]]
// Single value → Wraps in array
"Hello"
→ [["Hello"]]
// Empty array → Clears range
Google Sheets → JavaScript:
// No labels → Returns 2D array
// With "First line for labels" → Returns array of objects
[{Name: "John", Age: 30}, {Name: "Jane", Age: 25}]
// With both labels → Returns nested object
{John: {Age: 30, City: "NYC"}, Jane: {Age: 25, City: "LA"}}
// Single cell → Returns value directly
"Hello"
Header Handling
Working with headers (click to expand)
Writing with headers:
// Enable "First line for labels" in node
msg.payload = [
  {Product: "Widget", Price: 10, Stock: 100},
  {Product: "Gadget", Price: 20, Stock: 50}
// Writes:
// Row 1: Product | Price | Stock
// Row 2: Widget  | 10    | 100
// Row 3: Gadget  | 20    | 50
Reading with headers:
Spreadsheet:
| Name  | Age | City |
| John  | 30  | NYC  |
| Jane  | 25  | LA   |
Output:
  {Name: "John", Age: 30, City: "NYC"},
  {Name: "Jane", Age: 25, City: "LA"}
Both row and column headers:
Spreadsheet:
|       | Age | City |
| John  | 30  | NYC  |
| Jane  | 25  | LA   |
Enable both label options
Output:
Field Selection
Extract only specific fields (click to expand)
When reading objects with many fields, select only what you need:
Input data:
    "Name": "John",
    "Phone": "555-1234",
    "Address": "123 Main St",
    "City": "NYC",
    "State": "NY",
    "Zip": "10001"
Configuration:
  • Fields to select: Name, Email, City
Output:
    "Name": "John",
    "City": "NYC"
Benefits:
  • Reduces data transfer
  • Simplifies downstream processing
  • Improves performance
Caching
How Caching Works
Understanding the cache system (click to expand)
Automatic caching:
  1. First read from a range → API call, result cached
  2. Second read from same range → Instant return from cache
  3. Write to that range → Cache automatically cleared
  4. Clear data action → Cache cleared
Cache storage locations:
  • msg._sheet (default) - Cached per message
  • flow._sheet - Shared across all nodes in same flow
  • global._sheet - Shared across all flows
What gets cached:
  • Raw data from Google Sheets API
  • Transformed data (if applicable)
  • Timestamp of last fetch
Cache invalidation:
  • Automatic on write/clear operations
  • Manual via deleting the cache property
  • Time-based (optional, via change node)
Cache Configuration
Configuring cache behavior (click to expand)
Per-message cache (default):
Flow:
[read data] → [process] → [read same data] → [process more]
              ↑ API call              ↑ From cache
Flow-level cache (shared across flow):
Cache location: flow._sheet
Multiple nodes can read from cache without redundant API calls.
Global cache (shared across all flows):
Cache location: global._sheet
All flows reading the same data use the same cache.
Manual cache clearing:
delete msg._sheet;  // Clear message cache
delete flow._sheet; // Clear flow cache
delete global._sheet; // Clear global cache
Time-based cache invalidation:
// In a function node before reading
const cacheAge = Date.now() - (msg._sheet?.timestamp || 0);
const maxAge = 5 * 60 * 1000; // 5 minutes
if (cacheAge > maxAge) {
  delete msg._sheet; // Force fresh read
Performance Impact
Caching performance benefits (click to expand)
Without caching:
  • Every read = API call
  • Latency: 200-500ms per call
  • API quota consumed on every read
With caching:
  • First read = API call (200-500ms)
  • Subsequent reads = instant (< 1ms)
  • 90%+ reduction in API calls
  • Significant quota savings
Example scenario:
Flow processes 1000 messages, each needs to look up reference data:
Without cache:
- 1000 API calls
- ~300 seconds total
- 1000 quota units used
With cache:
- 1 API call
- ~0.3 seconds total
- 1 quota unit used
Best for:
  • Reference data that changes infrequently
  • Lookup tables
  • Configuration data
  • Repeated reads in processing loops
Not recommended for:
  • Real-time data that changes frequently
  • Data that must always be fresh
  • Single-read scenarios
Security
Authentication Security
How credentials are protected (click to expand)
Service Account Security:
  1. JWT (JSON Web Token) authentication
    • No user passwords involved
    • Tokens are short-lived (1 hour)
    • Automatically refreshed when expired
    • No OAuth consent screens needed
  2. Credential encryption:
    • All credentials encrypted by Node-RED
    • Stored in flows_cred.json with encryption
    • Never appear in flows.json
    • Cannot be exported in flows
  3. Service account email:
    • Acts as identity: [email protected]
    • Must be explicitly granted access to each spreadsheet
    • Can be revoked from Google Cloud Console
What is encrypted:
  • Project ID
  • Client email
  • Private key (RSA 2048-bit)
What is NOT encrypted:
  • Config node name (stored in flows.json)
  • OAuth2 scopes list
Best Practices
Security recommendations (click to expand)
For Service Accounts:
  1. Grant minimum required permissions
    • Read-only use case → Grant "Viewer" permission
    • Read/write use case → Grant "Editor" permission
    • Never grant "Owner" permission
  2. Rotate keys regularly
    • Create new key in Google Cloud Console
    • Update Node-RED config
    • Delete old key from Google Cloud Console
  3. Use separate spreadsheets for sensitive data
    • Don't mix production and test data
    • Apply different access controls
    • Audit access regularly
For Node-RED:
  1. Enable admin authentication
    // in settings.js
    adminAuth: {
      type: "credentials",
      users: [{
        username: "admin",
        password: "$2b$08$...", // bcrypt hash
        permissions: "*"
  2. Set strong credentialSecret
    // in settings.js
    credentialSecret: "a-very-long-random-string-here"
  3. Backup flows securely
    • Always backup both flows.json AND flows_cred.json
    • Store backups encrypted
    • Never commit credentials to git
Common Security Mistakes
What NOT to do (click to expand)
❌ Don't commit credentials to git
# Add to .gitignore
flows_cred.json
*.json  # If you store service account files locally
❌ Don't share service account keys publicly
  • Don't paste in public forums
  • Don't include in screenshots
  • Don't email in plain text
❌ Don't grant service accounts excessive permissions
  • Only grant access to specific spreadsheets
  • Don't share entire Google Drive
  • Revoke when no longer needed
✅ Do use environment variables in production
// Instead of hardcoding
const credPath = process.env.GOOGLE_SERVICE_ACCOUNT_PATH;
Error Handling
Common Errors
Understanding error messages (click to expand)
"Authentication failed: JWT authorization failed: No key or keyFile set"
  • Cause: Service account credentials not properly configured
  • Fix: Verify JSON credentials are correctly pasted, check client_email and private_key fields
"Permission denied"
  • Cause: Service account doesn't have access to the spreadsheet
  • Fix: Share spreadsheet with service account email, grant Editor or Viewer permission
"Invalid cell range format. Use A1 notation (e.g., A1:B10)"
  • Cause: Range format is incorrect
  • Fix: Use formats like Sheet1!A1:B10, Sheet1, A:D, 1:10
"Spreadsheet operation failed: Unable to parse range: Sheet1!A1:B"
  • Cause: Incomplete range (missing end column/row)
  • Fix: Use A1:B10 instead of A1:B, or A:B for entire columns
"Invalid spreadsheet ID"
  • Cause: Spreadsheet ID is empty, undefined, or malformed
  • Fix: Copy ID from URL, ensure it's a 44-character string
"Unsupported data format"
  • Cause: Input data is null, undefined, or invalid type for the operation
  • Fix: Ensure msg.payload contains array, object, or primitive value
Debugging
How to debug issues (click to expand)
1. Check node status
The node shows visual status indicators:
  • 🔵 Blue dot "Processing..." → Operation in progress
  • 🟢 Green dot "Success" → Operation completed
  • 🔴 Red ring "Auth error" → Authentication failed
  • 🔴 Red ring "Invalid range" → Range format error
  • 🔴 Red dot "Error" → Other error
2. Use debug nodes
[inject] → [Google Sheets] → [debug "success"]
                          ↘ [debug "error" (catch)]
3. Enable verbose logging
In settings.js:
logging: {
  console: {
    level: "debug",
    metrics: false,
    audit: false
4. Verify inputs
Add a function node before Google Sheets to log inputs:
node.warn("Spreadsheet ID: " + msg.spreadsheetId);
node.warn("Range: " + msg.range);
node.warn("Payload type: " + typeof msg.payload);
node.warn("Payload: " + JSON.stringify(msg.payload));
5. Test with simple data first
Start with:
msg.payload = [["Test"]];
msg.range = "Sheet1!A1";
Then gradually increase complexity.
Troubleshooting
Installation Issues
Problems installing the package (click to expand)
Issue: "Module not found" after installation
Cause: Node-RED hasn't been restarted
Solution:
# Stop Node-RED
# Restart Node-RED
node-red-restart  # or use your system's method
Issue: Nodes don't appear in palette
Cause: Installation in wrong directory or Node-RED using different user directory
Solution:
# Find Node-RED user directory
node-red --version
# Shows: Welcome to Node-RED, v3.1.0, user directory: /home/user/.node-red
# Install there
cd /home/user/.node-red
Configuration Issues
Problems setting up credentials (click to expand)
Issue: "Invalid JSON" error when pasting credentials
Solution:
  • Copy entire JSON file contents
  • Make sure no extra characters at beginning/end
  • Check for valid JSON syntax at jsonlint.com
Issue: Can't find service account email
Solution:
  • Open JSON credentials file
  • Look for "client_email" field
  • Email format: [email protected]
Issue: Spreadsheet ID keeps getting rejected
Solution:
URL: https://docs.google.com/spreadsheets/d/1BxiMVs0XRA5nFMdKvBdBZjgmUUqptlbs74OgvE2upms/edit
    ↑ Copy exactly this part (44 characters) ↑
Operation Issues
Problems reading or writing data (click to expand)
Issue: "Permission denied" error
Checklist:
  1. ☐ Spreadsheet is shared with service account email
  2. ☐ Editor permission granted (for writes)
  3. ☐ Service account email is correct
  4. ☐ Sharing applies to specific sheet, not just folder
Issue: Data comes back as undefined
Causes & Solutions:
  • Empty range: Returns empty array []
  • Wrong range: Check sheet name spelling
  • No data: Verify data exists in range
  • Cache: Clear cache and try again
Issue: Data writes succeed but don't appear in sheet
Debugging steps:
  1. Check you're looking at the correct sheet tab
  2. Verify range is correct (sheet name + cell range)
  3. Check if data is outside visible area (scroll down/right)
  4. Verify write method (Update vs Append vs New)
  5. Refresh spreadsheet in browser
Google Cloud Issues
Problems with Google Cloud setup (click to expand)
Issue: Can't find Google Sheets API in library
Solution:
  • Make sure you're in the correct project
  • Search exactly: "Google Sheets API"
  • Click "Enable" button
  • Wait 1-2 minutes for activation
Issue: Service account creation fails
Solution:
  • Check you have project Owner or Editor role
  • Try creating from IAM & Admin → Service Accounts directly
  • Verify project billing is enabled (even for free tier)
Issue: Quota exceeded errors
Solution:
  • Check quota limits: APIs & Services → Quotas
  • Default: 100 requests per 100 seconds per user
  • Request quota increase if needed
  • Implement rate limiting or caching
Still Having Issues?
Getting help (click to expand)
Before asking for help, gather this information:
  1. Node-RED version: Check in Settings → About
  2. Node.js version: node --version
  3. Package version: Check in Manage palette
  4. Error message: Full text from debug sidebar
  5. What you've tried: List troubleshooting steps already taken
Where to get help:
  1. GitHub Issues: https://github.com/carefulcomputer/node-red-contrib-google-spreadsheet/issues
    • Search existing issues first
    • Include all information above
    • Attach screenshots if helpful
  2. Node-RED Forum: https://discourse.nodered.org
    • Tag with google-sheets
    • Describe your use case
    • Share relevant flow (sanitize credentials!)
When reporting bugs:
  • ✅ Include minimal reproducible example
  • ✅ Specify exact error message
  • ✅ Describe expected vs actual behavior
  • ❌ Don't share actual credentials
  • ❌ Don't dump entire flow (make it minimal)
Apache 2.0 - See LICENSE file
Author
Careful Computer
Support
For issues, questions, or contributions:
Acknowledgments
Originally derived from node-red-contrib-viseo by VISEO Technologies.
Modernized and enhanced with:
  • Latest Google APIs (googleapis 170.1.0)
  • Modern JavaScript patterns (async/await, ES6+)
  • Comprehensive validation and error handling
  • Smart caching and performance optimizations
  • Extensive documentation and examples
Version: 2.0.3
Updated 10 months, 1 week ago
  • google
  • sheets
  • spreadsheet
  • plus
  • enhanced
  • cache
  • caching
  • transform
  • data-transformation
  • api
  • gcp
  • authentication
  • service-account
  • async
  • modern
  • production
