node-red-contrib-freya-nodes 0.2.3
Custom nodes for Freya Vivarium Control System
npm install node-red-contrib-freya-nodes
Freya Banner
Node-RED is a visual programming tool that lets you wire together hardware, APIs, and online services by connecting blocks in a flow-based editor. The Freya Node-RED nodes lorem ipsum...
Node-RED
Node-RED flow editor
Navigate to Settings > Manage Palette, then in the Install tab, search for node-red-contrib-freya-nodes and click the Install button.
Manually using NPM
On your device, navigate to the nodered folder (on a Freya system, it's at /opt/Freya/), and run
License & Collaboration
Copyright© 2025 Sanne 'SpuQ' Santens. The Freya NodeRED nodes project is licensed under the GNU General Public License v3.0. The Rules & Guidelines apply to the usage of the Freya Vivariums™ brand.
Collaboration
If you'd like to contribute to this project, please follow these guidelines:
  1. Fork the repository and create your branch from main.
  2. Make your changes and ensure they adhere to the project's coding style and conventions.
  3. Test your changes thoroughly.
  4. Ensure your commits are descriptive and well-documented.
  5. Open a pull request, describing the changes you've made and the problem or feature they address.
Version: 0.2.3
Updated 4 months, 1 week ago
License: GPL-3.0
278 in the last week
  • environment sensor
  • system actuators
  • circadian core
  • location-config
  • humidity controller
  • lighting controller
  • precipitation controller
  • temperature controller
  • status aggregator
  • node-red-node
  • freya
  • vivarium
  • control system
  • paludarium
  • terrarium
  • greenhouse
