node-red-contrib-foxess 0.1.6
Node-RED nodes for polling real-time data from the FoxESS Cloud Open API
npm install node-red-contrib-foxess
Node-RED nodes that poll the FoxESS Cloud Open API for real-time inverter data. They also work out how much power is going to the grid, so you can automate loads (e.g. an air conditioner) around your solar surplus.
It only reads data. It doesn't change inverter settings or schedules.
In the Node-RED editor, open Menu > Manage palette > Install, search for node-red-contrib-foxess and click Install.
Or from the command line, then restart Node-RED:
The real-time node appears under the FoxESS palette category. See it in the Node-RED Flow Library.
Setup
  1. In FoxESS Cloud go to User Profile > API Management and generate an API key (36 characters).
  2. Add a real-time node, and create a FoxESS Cloud config node with your API key. Leave Inverter SN blank if your account has only one inverter.
real-time node
Polls /op/v1/device/real/query every n seconds (default 300, minimum 10), or whenever it gets a message.
Output:
msg.payload = {
  pvPower: 5.1,               // kW
  loadsPower: 1.2,            // kW
  feedinPower: 3.4,           // kW exported
  gridConsumptionPower: 0,    // kW imported
  SoC: 92,                    // %
  gridPower: 3.4              // feedinPower - gridConsumptionPower: + exporting, - importing
msg.units    = { pvPower: "kW", SoC: "%", ... }
msg.time     = "2026-11-13 14:05:12 AEDT+1100"   // when the inverter last reported
msg.deviceSN = "..."
Leave Variables blank to get everything your inverter reports.
Only polling while the sun is up
Set Sun above (e.g. 20) to only poll on the timer while the sun is at least that many degrees above the horizon. The location is read from an environment variable, location by default (Settings > Environment, or on the flow or group). It accepts -33.86,151.21, -33.86 151.21, [-33.86,151.21] or {"lat":-33.86,"lon":151.21}.
Each output message then includes msg.sun = { elevation, up }. When the sun drops below the threshold the node sends one message with an empty payload and msg.sun.up = false, so a flow can switch things off, then stops polling until the sun is back above the threshold. Messages sent to the node's input always poll, whatever the sun is doing.
Rate limits and data freshness
The Open API allows about 1440 calls per inverter per day. At the start of each day the node works out the shortest interval that keeps that day's polling within Calls per day (default 1440), and uses it if it's longer than your interval:
  • polling around the clock: 60 seconds
  • with Sun above set: the hours of sun above the threshold divided by the budget, e.g. 10 hours at 1440 calls is about 25 seconds
It logs a warning when it lengthens your interval. Polls triggered by input messages aren't counted, so lower Calls per day to leave room for them, and for anything else using the same inverter (e.g. FreePowerMaximiser).
Current data loggers upload every few seconds, so each poll returns close to live values. msg.time shows when the inverter last reported, in case the logger drops offline.
Example: air conditioner on surplus
Import examples/ac-control-by-surplus.json (Menu > Import > Examples > node-red-contrib-foxess). It feeds gridPower into a function node with hysteresis:
  • on after 2 polls in a row exporting ≥ 2.5 kW
  • off after 2 polls in a row importing ≥ 0.3 kW, or when the sun drops below 20° and polling stops
It sends "on" or "off" only when the state changes. Swap the final debug node for whatever controls your AC (Home Assistant service call, Tasmota/MQTT, a Broadlink IR blaster, etc.).
Once the AC is running, its draw comes out of the export. Set ON_EXPORT above the AC's draw, otherwise it will turn on, use up the surplus, and turn straight off again. The thresholds are at the top of the function node.
Development
npm test
The API signing is ported from FreePowerMaximiser's openapi.py. The signature is md5(path + "\r\n" + apiKey + "\r\n" + timestampMs), where \r\n is the literal four characters, not CR LF.
Version: 0.1.6
Updated 1 day ago
License: Unlicense
  • foxess-config
  • foxess-real
  • foxess
  • solar
  • inverter
  • battery
