node-red-contrib-esphome 0.3.7
Node-RED nodes to ESPhome devices
About
!!! Alpha, Alpha, Alpha release
!!! Need help writing documentation
Prerequisites
Your ESPHome device must be configured with the ESPHome API enabled.
In your device.yaml configuration file:
# Example configuration entry
api:
See ESPHome documentation on api configuration for more information.
$ npm i node-red-contrib-esphome
Inputs
Inputs are sent to the node as JSON payloads. The list below provides a list of keys and values (and their expected value type) that may be sent to the "esphome out" nodes. It is helpful to watch the "esphome in" messages to learn which type and range of commands are expected by your device.
Some example message payloads are:
// to set a light on:
msg.payload = {'state': true}
// set a door lock to unlock:
msg.payload = {'command':0}
// to toggle a light to 42% brightness:
msg.payload = {'brightness': 42}
// to press a button:
msg.payload = true
Button
Button inputs may be triggered with any payload in the input message. Simply send a timestamp, true, or other payload to the button node. Button type nodes provide no messages into Node-RED.
Climate
mode- optional. 0 - OFF, 1 - AUTO, 2 - COOL, 3 - HEAT, 4 - FAN_ONLY, 5 - DRY. SeesupportedModesListattr in configtargetTemperature- optional. floattargetTemperatureLow- optional. floattargetTemperatureHigh- optional. floatlegacyAway- optional. Boolean. Deprecated: usepresetwith AWAYfanMode- optional. 0 - ON, 1 - OFF, 2 - AUTO, 3 - LOW, 4 - MEDIUM, 5 - HIGH, 6 - MIDDLE, 7 - FOCUS, 8 - DIFFUSE, 9 - QUIET. SeesupportedFanModesListattr in configswingMode- optional. 0 - OFF, 1 - BOTH, 2 - VERTICAL, 3 - HORIZONTAL. SeesupportedSwingModesListattr in configcustomFanMode- optional. string. SeesupportedCustomFanModesListattr in configpreset- optional. 0 - NONE, 1 - HOME, 2 - AWAY, 3 - BOOST, 4 - COMFORT, 5 - ECO, 6 - SLEEP, 7 - ACTIVITY. SeesupportedPresetsListattr in configcustomPreset- optional. string. SeesupportedCustomPresetsListattr in config
Cover
legacyCommand- optional. 0 - OPEN, 1 - CLOSE, 2 - STOP. Deprecated: usepositionposition- optional. float. 0.0 - CLOSED, 1.0 - OPEN. SeesupportsPositionattr in configtilt- optional. float. 0.0 - CLOSED, 1.0 - OPEN. SeesupportsTiltattr in configstop- optional. boolean
Fan
state- optional. booleanspeed- optional. 0 - LOW, 1 - MEDIUM, 2 - HIGHoscillating- optional. booleandirection- optional. 0 - FORWARD, 1 - REVERSEspeedLevel- optional. integer. SeesupportedSpeedLevelsattr in config
Light
state- optional. booleanbrightness- optional. floatred- optional. integer 0-255green- optional. integer 0-255blue- optional. integer 0-255colorMode- optional. integer. SeesupportedColorModesListattr in configcolorBrightness- optional. floatwhite- optional. integer 0-255colorTemperature- optional. integercoldWhite- optional. floatwarmWhite- optional. floatflashLength- optional. integereffect- optional. string. effect from effects array in config list
Lock
command- REQUIRED. 0 - UNLOCK, 1 - LOCK, 2 - OPENcode- optional. string. SeerequiresCodeattr in config
MediaPlayer
command- REQUIRED. 0 - MEDIA_PLAYER_COMMAND_PLAY, 1 - MEDIA_PLAYER_COMMAND_PAUSE, 2 - MEDIA_PLAYER_COMMAND_STOP, 3 - MEDIA_PLAYER_COMMAND_MUTE, 4 - MEDIA_PLAYER_COMMAND_UNMUTEvolume- optional. floatmediaUrl- optional. string
Number
state- REQUIRED. float. SeeminValue,maxValue, andstepattrs in config
Select
state- REQUIRED. string. SeeoptionsListattr in config
Siren
state- REQUIRED. booleantone- optional. string. SeetonesListattr in configduration- optional. integer. SeesupportsDurationattr in configvolume- optional. integer. SeesupportsVolumeattr in config
Switch
Text
state- REQUIRED. string. SeeminLength,maxLengthattrs in config
Pictures
