node-red-contrib-energenie-ener314rt 0.7.0
Node-red module for energenie ENER314-RT board for raspberry pi
npm install node-red-contrib-energenie-ener314rt
A node-red module to control the Energenie MiHome line of products via the ENER314-RT add-on board for the Raspberry Pi.
Maintenance Downloads node Release NPM
node-red module
IMPORTANT: UPGRADING FROM PREVIOUS RELEASE
v0.7.x requires additional software dependencies that must be manually installed first.
If you are upgrading from version 0.6.x or below, please ensure that you install node.js v18.2+, gpiod and libgpiod first (see Getting Started below).
Purpose
You can use this node-red module to control and monitor the Energenie MiHome radio based smart devices such as adapters, sockets, lights, thermostats and relays on a Raspberry Pi with an ENER314-RT board installed using node-red (see below for full list). This is instead of operating the devices using a MiHome Gateway, so this node does not require an internet connection.
'Control', 'Monitor' and 'Control & Monitor' radio based devices are supported from the legacy and MiHome range.
There are 4 types of node to match the colour coding of the Energenie MiHome devices:
  • Blue for switching 'Control' OOK based devices
  • Pink for monitoring MiHome 'Monitor' FSK/OpenThings devices
  • Purple for monitoring and controlling 'Control & Monitor' FSK/OpenThings devices
  • Green for sending any OOK or FSK raw byte array (Advanced node)
Within the 4 types there are these nodes available to use:
Node Created For
Blue Control All Blue, Green & Legacy (OOK) Energenie Devices
Blue Dimmer MIHO010 - MiHome Dimmer
Pink Monitor All Pink Monitor Only Devices
Pink PIR Sensor MIHO032 - MiHome Motion sensor
Pink Open Sensor MIHO033 - MiHome Open Door/Window sensor
Pink MiHome Click MIHO089 - MiHome Click
Purple eTRV MIHO013 - MiHome Radiator Valve
Purple Smart Plug+ MIHO005 - MiHome Smart Plug+ / Adaptor+
Purple Thermostat MIHO069 - MiHome Thermostat
Green Raw Transmit Non-Energenie 433Mhz Radio Controlled Devices
The number of individual devices this node can control is over 4 million, so it should be suitable for most installations!
NOTE: This module does not currently support the older boards (ENER314/Pi-Mote), the Energenie WiFi sockets or the MiHome Gateway (see below for the full supported list).
Supported Devices
These nodes are designed for energenie RF radio devices in the OOK & FSK (OpenThings) ranges.
Here is a table showing which node is recommended for each energenie device, and a tick showing if it has been tested (please let me know of any successful tests, and I'll update the table):
Device Description Type Recommend Node Tested OK
ENER002 Green Button Adapter OOK Blue: Control ✓
ENER010 MiHome 4 gang Multi-plug OOK Blue: Control ✓
MIHO002 MiHome Smart Plug OOK Blue: Control ✓
MIHO004 MiHome Smart Monitor Plug FSK Pink: Monitor ✓
MIHO005 MiHome Smart Plug+ FSK Purple: Smart Plug+ ✓
MIHO006 MiHome House Monitor FSK Pink: Monitor ✓
MIHO007 MiHome Socket OOK Blue: Control ✓
MIHO008 MiHome Single Light OOK Blue: Control
MIHO009 Double Gang MiHome Light OOK Blue: Control
MIHO010 MiHome Dimmer Switch OOK Blue: Dimmer
MIHO013 MiHome Radiator Valve FSK Cached Purple: eTRV ✓
MIHO014 Single Pole Relay (inline) OOK Blue: Control
MIHO015 MiHome Relay OOK Blue: Control
MIHO021
MIHO022
MIHO023
MiHome Double Socket OOK Blue: Control ✓
MIHO024
MIHO025
MIHO026
MIHO032 MiHome Motion sensor FSK Pink: PIR Sensor ✓
MIHO033 MiHome Open Sensor FSK Pink: Open Sensor
MIHO069 MiHome Heating Thermostat FSK Purple: Thermostat ✓
MIHO071
MIHO072
MIHO073
MIHO076
MIHO077
MIHO087
MIHO089 MiHome Click - Smart Button FSK Pink: MiHome Click ✓
NOT SUPPORTED:
Specific nodes may be required for new energenie devices. Please let me know, via github, if you identify any 'unknown' devices, commands or parameters.
The use of these nodes within the Node-RED add-on for Home Assistant (aka hassio) is not supported. A new MQTT / Home Assistant integration is now available at mqtt-energenie-ener314rt, please use this instead.
Getting Started
  1. Plug in your ENER314-RT-VER01 board from Energenie onto the 26 pin or 40 pin connector of your Raspberry Pi.
  2. Install gpiod and libgpiod dependencies (as of v0.7.x) : For example (Debian):
sudo apt-get install gpiod libgpiod-dev
  1. Install this module as you would any node-red module using the 'Manage palette' option in Node-Red GUI or by using npm.
  2. If you have any 'Control' only devices, perform a one-time only setup to teach your devices to operate with your selected zone code(s) switch number(s) combinations:
  • Drag a blue node onto the canvas
  • Open the node by double clicking
  • If required, add a board config (only done once for all devices), by clicking pencil next to board, and then clicking 'add'
  • Set the parameters in the Control node that you wish to uniquely reference your device (following the zone rules below).
  • You can test the zone/device combination by clicking the learn button to switch on the device, or continue these steps to 'teach' your device
  • Hold the button on your device until it starts to flash.
  • Click the teach (mortar board) icon in the control node properties.
  • The device should learn the zone code being broadcast by the teach request, the light should stop flashing when successful.
  • All subsequent calls using the same zone/switch number will cause your device to switch.
  • Pressing the teach button again will cause the device to switch on, and pressing the 'power' button will cause the same device to switch off.
TIP: Usually each energenie 'Control' only devices can be assigned 2 separate zone codes, so you could operate them across this and another system (e.g RF hand controller). There is one downside though, in that the on/off state will not be reflected on the other system for these devices.
  1. If you have any 'Monitor' or 'Control & Monitor' devices perform one-time only setup to discover the devices
  • Drag the appropriate pink or purple node onto the canvas (see Supported Devices table below, if you are unsure which one to use)
  • Click 'pencil' icon to add a new device
  • The device config node will open and perform an auto-scan; after 10 seconds it returns a list of devices that it has found. If your device is not found you can force it to transmit a 'join' request by holding the button on the device for 5 seconds. You can click the search button as many times as you like if the device is not found. If you find that it is still not working, please raise a bug request.
  • Select the device in the 'Devices' drop down
  • The Product name, ID and type will populate
  • (Optional) Change the 'Name' of the device if desired
  • Click 'Add' to finish configuration of the device
  • Click 'Done'
Hardware based SPI driver - NEW In Version 0.6
To increase reliability a new hardware SPI driver has been added. The hardware SPI driver version can be enabled using sudo raspi-config choosing Interface Options and SPI to enable the hardware SPI mode, do this whilst this software is not running. The module tries to use the hardware driver on start-up, if it has not been enabled it falls back to using the software SPI driver.
'Control Only' OOK Zone Rules
  • Each Energenie 'Control' or OOK based device can be assigned to a specific zone (or house code) and a switch number.
  • Each zone is encoded as a 20-bit address (1-1048575 decimal).
  • Each zone can contain up to 6 switches (1-6) - NOTE: officially energenie state this is only 4 devices (1-4)
  • All devices within the same zone can be switched at the same time using a switch number of '0'.
  • A default zone '0' can be used to use Energenie's default zone (0x6C6C6).
  • If you have a MiHome 4 gang Multi-plug, the same zone must be used for controlling all 4 switches, use switch #0 to control all, 1-4 for each socket
  • If you have a MiHome 2 gang socket or light switch, the same zone must be used for controlling the 2 switches
Light Dimmer Support
Each Energenie Light Dimmer requires a dedicated OOK zone allocating to it, as internally it uses the switch numbers to set the brightness level of the dimmer. This node works slightly differently to the standard 'Control' node. The payload determines the light level required as follows:
payload Brightness Level Action
0 OR false OFF Switch light off, remembering light level
1 OR true last Switch on at the previous light level set
2 or 20 20% Switch light on at 20%
3 or 30 30% Switch light on at 30%
4 or 40 40% Switch light on at 40%
5 or 60 60% Switch light on at 60%
6 or 80 80% Switch light on at 80%
7 or 100 100% Switch light on at 100%
Processing Monitor Messages
The Pink and Purple nodes receive monitoring information from the devices and emit the received parameter values on their output. These messages conform to the OpenThings parameter standard.
All OpenThings parameters received from the device are decoded and returned in the msg.payload. Some of the values are used to set the node.status for the specific nodes, for example SWITCH_STATE is used to indicate if a device is 'ON' or 'OFF', and the TEMPERATURE value is used on the eTRV node to show the current temperature.
Some example msg.payloads are shown below. I have provided parameter name and type mapping for the known values for received messages. Connect up a debug node to see what your specific devices output.
A full parameter list can be found in C/src/achronite/openThings.c if required.
Example msg.payload - Smart Plug+ (MIHO005)
Every 10 seconds:
deviceId: <device number>
mfrId: 4
productId: 2
timestamp: <numeric 'epoch based' timestamp, of when message was read>
REAL_POWER: <power in Watts being consumed>
REACTIVE_POWER: <Power in volt-ampere reactive (VAR)>
VOLTAGE: <Power in Volts>
FREQUENCY: <Radio Frequency in Hz>
SWITCH_STATE: <Device State, 0 = off, 1 = on
Example msg.payload - Whole House Energy Monitor (MIHO006)
mfrId: 4
productId: 5
APPARENT_POWER: 612
VOLTAGE: 4.566406
CURRENT: 2.179688
Example msg.payload - Motion Sensor (MIHO032)
mfrId: 4
productId: 12
MOTION_DETECTOR: <Sensor state, 0 = no motion, 1 = motion>
Example msg.payload - Door Sensor (MIHO033)
mfrId: 4
productId: 13
DOOR_SENSOR: <Sensor state, 0 = closed, 1 = open>
Example msg.payload - Heating Thermostat (MIHO069)
mfrId: 4
productId: 18
TEMPERATURE: 23.06
REL_HUMIDITY: 72
BATTERY_LEVEL: 3.08
MOTION_DETECTOR: <Motion detector state, 0 = no motion, 1 = motion>
THERMOSTAT_MODE: <Thermostat mode, 0 = off, 1 = temp controlled, 2= always on>
TARGET_TEMP: <Target set temperature>
SWITCH_STATE: <Current state of the heating 0 = off, 1 = heating (when pressed)>
Example msg.payload - MiHome Click (MIHO089)
mfrId: 4
productId: 19
VOLTAGE: <battery voltage>
BUTTON: <1=Single press, 2=Double press, 255=long press>
MiHome Heating Device Support
The MiHome Thermostatic Radiator valve (eTRV) and MiHome Thermostat are battery powered devices that do not constantly listen for commands. This required specific code to be written to 'cache' commands for these devices. As a result there may be a delay from when a command is sent to it being processed by the device. See Command Caching below.
Sending Commands (purple nodes)
Single commands are sent as a numeric value within a JSON request as shown in the tables below. For example to Request Diagnostics you can use a template node (Output as Parsed JSON) to send the following msg.payload:
    "command": 226,
    "data": 0
Example for setting temperature to 20C using command mode:
    "command": 244,
    "data": 20
eTRV Commands
The MiHome Thermostatic Radiator valve (eTRV) accepts commands to perform operations, provide diagnostics or perform self tests. The documented commands are provided in the table below, there may also be other undocumented commands.
Command # Description .data Response Msg
CANCEL 0 Cancel existing cached command (set retries to 0) Yes
EXERCISE_VALVE 163 Send exercise valve command, recommended once a week to calibrate eTRV DIAGNOSTICS
SET_LOW_POWER_MODE 164 This is used to enhance battery life by limiting the hunting of the actuator, ie it limits small adjustments to degree of opening, when the room temperature is close to the TEMP_SET point. A consequence of the Low Power mode is that it may cause larger errors in controlling room temperature to the set temperature. 0=Off
1=On
No*
SET_VALVE_STATE 165 Set valve state 0=Open
1=Closed
2=Auto (default)
No
REQUEST_DIAGNOSTICS 166 Request diagnostic data from device, if all is OK it will return 0. Otherwise see additional monitored values for status messages DIAGNOSTICS
IDENTIFY 191 Identify the device by making the green light flash on the selected eTRV for 60 seconds No
SET_REPORTING_INTERVAL 210 Update reporting interval to requested value 300-3600 seconds No
REQUEST_VOLTAGE 226 Report current voltage of the batteries VOLTAGE
TARGET_TEMP 244 Send new target temperature for eTRV in 0.5 increments.
NOTE: The VALVE_STATE must be set to 'Auto' for this to work.
int No
* Although this will not auto-report, a subsequent call to REQUEST_DIAGNOSTICS will confirm the LOW_POWER_MODE setting
Thermostat Commands
The MiHome Thermostat accepts the following commands to perform operations.
WARNING: If you are using a MiHome gateway to control your thermostat command clash may occur by issuing command within node-red.
Command # Description .data Tested
THERMOSTAT_MODE 170 Change mode of thermostat where
0 = OFF
1 = Temp Controlled
2 = ON
0-2 Yes
RELAY_POLARITY 171 Polarity of the boiler relay 0=Normally Open,1=Normally Closed Yes
HUMID_OFFSET 186 Humidity Calibration -20 to 20 Yes
TEMP_OFFSET 189 Temperature Calibration -20.0 to 20.0 Yes
HYSTERESIS 254 The difference between the current temperature and target temperature before the thermostat triggers 0.5-10 Yes
In order for the Thermostat to provide updates for it's telemetry data when used without a MiHome gateway, auto messaging has been enabled within this module. To start this auto-messaging you will need to send a command that returns the THERMOSTAT_MODE to the application (a THERMOSTAT_MODE command will do). The result of the most recent THERMOSTAT_MODE value will be stored and periodically replayed (until a restart) to prompt the thermostat into providing it's telemetry data.
Command Caching
Battery powered energenie devices, such as the eTRV or Room Thermostat do not constantly listen for commands. For example, the eTRV reports its temperature at the SET_REPORTING_INTERVAL (default 5 minutes) after which the receiver is then activated to listen for commands. The receiver only remains active for 200ms or until a message is received.
To cater for these hardware limitations the 'eTRV' and 'Thermostat' nodes use command caching and dynamic polling. Any command sent using these nodes will be held until a TEMPERATURE (for eTRV) or WAKEUP (for Thermostat) message is received; at this point the most recent cached message (only 1 is supported) will be sent to the device. Messages will continue to be resent until they have been successful received or until the number of retries has reached 0.
Sometimes a specific command may be resent multiple times. This is particularly a problem for the eTRV devices, as they do not send an acknowledgement for every command type (indicated by a 'No' in the Response column in the above table). This includes the TEMP_SET command! So these commands are always resent for the full number of retries. ** NEW v0.6.x ** - When a device has acknowledged a command the 'command' and 'retries' topics are reset to 0.
Be careful when sending multiple commands to the same device, as the most recent command will overwrite any existing cached command for that device (check the retries is 0 first).
NOTE: The performance of node-red may decrease when a command is cached due to dynamic polling. The frequency that the radio device is polled by the monitor thread automatically increases by a factor of 200 when a command is cached (it goes from checking every 0.5 seconds to every 25 milliseconds) this dramatically increases the chance of a message being correctly received by the device sooner.
eTRV Monitor Messages
To support the MiHome Radiator Valve (MIHO013) aka 'eTRV' in v0.3 and above, additional code has been added to store the received and set information for these devices. An example of the values are shown below, only 'known' values are returned when the eTRV regularly reports the TEMPERATURE. See table for types and determining when field was last updated:
    "deviceId":3989,
    "mfrId":4,
    "productId":3,
    "timestamp":1567932119,
    "TEMPERATURE":19.7,
    "EXERCISE_VALVE":"success",
    "VALVE_TS":1567927343,
    "DIAGNOSTICS":512,
    "DIAGNOSTICS_TS":1567927343,
    "LOW_POWER_MODE":false,
    "TARGET_TEMP": 10,
    "VOLTAGE": 3.19,
    "VOLTAGE_TS": 1568036414,
    "ERRORS": true,
    "ERROR_TEXT": ...
Parameter Description Data Type Update time
command number of current command being set to eTRV int timestamp
retries The number of remaining retries for 'command' to be sent to eTRV> int timestamp
DIAGNOSTICS Numeric diagnostic code, see "ERRORS" for interpretation int DIAGNOSTIC_TS
DIAGNOSTICS_TS timestamp of when diagnostics were last received epoch DIAGNOSTIC_TS
ERRORS true if an error condition has been detected boolean DIAGNOSTIC_TS
ERROR_TEXT error information string DIAGNOSTIC_TS
EXERCISE_VALVE The result of the EXERCISE_VALVE command success or fail DIAGNOSTIC_TS
LOW_POWER_MODE eTRV is in low power mode state> boolean DIAGNOSTIC_TS
TARGET_TEMP Target temperature in celcius int TEMP_SET command
TEMPERATURE The current temperature in celcius float timestamp
VALVE_STATE Current valve mode/state open, closed, auto, error VALVE_STATE command or DIAGNOSTIC_TS on error
VALVE_TS timestamp of when last EXERCISE_VALVE took place epoch DIAGNOSTIC_TS
VOLTAGE Current battery voltage float VOLTAGE_TS
VOLTAGE_TS Timestamp of when battery voltage was last received epoch VOLTAGE_TS
TIP: To get up-to-date information for a specific eTRV parameter you will need to request the device for an update by sending the appropriate command (see eTRV Commands above),
Changing the Icons
The icon as displayed on the node within the flows can be changed using the 'Icon' dropdown in the 'Appearance' tab in the node properties. I have created icons for a few of the energenie devices. Use the search button and enter 'ener' to find them.
Troubleshooting
If you have any issues with the code, particularly if your board is not initialising, please try ener314rt-debug, which has been created as a standalone node.js application with full debug enabled. Node-red is not required to execute these tests.
  • Unable to initialise Energenie ENER314-RT board error: -n: Check that your card is installed correctly.
  • Compile errors during install: 'unknown type/function napi_...': This node module requires node.js v10 or above to work, upgrade your node.js version and retry.
Package Details
Change History
See CHANGELOG.md
Dependencies
Built With
  • Node-RED - for wiring together hardware devices, APIs and online services.
Authors
  • Achronite - Node-Red wrappers, and dependent node module - Achronite
This project is licensed under the MIT License - see the LICENSE.md file for details
Bugs and Future Work
Future work is detailed on the github issues page. Please raise any bugs, questions, queries or enhancements you have using this page.
I am currently working on a new node.js implementation of ENER314-RT that uses MQTT for Home Assistant - mqtt-energenie-ener314rt.
https://github.com/Achronite/node-red-contrib-energenie-ener314rt/issues
@Achronite - February 2024
Version: 0.7.0
Updated 2 years, 11 months ago
Rating: 4.5 2
22 in the last week
  • ook-switch
  • ook-dimmer
  • openThings-monitor
  • openThings-pir
  • openThings-door
  • openThings-click
  • openThings-switch
  • openThings-trv
  • openThings-thermostat
  • ener314rt-raw
  • openThings-device
  • energenie-board
  • energenie
  • radio
  • ener314
  • ener314rt
  • ener314-rt
  • MiHome
  • rf433
  • Achronite
