node-red-contrib-dataops 2.0.0
Node-RED nodes for industrial data pipelines: tag cache, AI-assisted and heuristic normalization, second-resolution cron, and run-time tracking
npm install node-red-contrib-dataops
Node-RED nodes for industrial data pipelines. Cache incoming tags in a context dictionary, normalize them with AI-generated or heuristic rules, schedule work to the second, and track machine or batch run times.
Or use the Node-RED palette manager and search for node-red-contrib-dataops.
Requires Node.js >= 18 and Node-RED >= 2.0. The Claude nodes are optional and need an Anthropic API key. Everything else works without one.
Upgrading from 1.x? Version 2.0 removes dataops-split, dataops-combine and dataops-table. See CHANGELOG.md for replacements.
How it fits together
Nodes share data through context dictionaries: plain objects in Node-RED global or flow context, at a key you choose (the Spec Key). You can inspect them in the editor's Context sidebar.
  • dataops-in writes a cache dictionary: { <topic>: latest value or sample }.
  • dataops-claude reads the cache and writes a spec dictionary: { <topic>: JSONata rules }.
  • dataops-transform reads specs, and dataops-runtime reads the cache.
Keys are sanitized (my cache → my_cache), so the same name typed into different nodes always lines up.
To merge or explode messages, use the core join and split nodes. To inspect output, use the core debug node.
All nodes are in the data ops palette category.
cache (dataops-in)
Stores msg.payload in a context dictionary keyed by msg.topic (configurable). The message passes through unchanged.
  • wrapped mode stores {payload, ts, metadata, previous}. Use it as the sample source for dataops-claude.
  • flat mode stores the payload as-is, as a clean latest-value cache for runtime.
  • Optional Max Entries (LRU eviction) and TTL (wrapped mode only).
transform (dataops-transform)
Normalizes each message with its topic's spec from the spec dictionary:
{ "plant/HWS/temp": { type: "number", value: "payload.value.value",
                      timestamp: "$toMillis(payload.sourceTimestamp)", quality: "payload.statusCode = 0" } }
  • value, timestamp and quality are JSONata expressions evaluated against msg. The value is coerced to type.
  • $toMillis accepts common device timestamp formats, and $eval/$fromJSON work on parsed objects.
  • Without a spec, the heuristic fallback walks payload.value.value → payload.value → payload.v → payload. That covers OPC UA, Kepware and Sparkplug B payloads with no setup. The other fallbacks are passthrough and error.
  • Output is configurable:
    • record (default): msg.payload = {name, type, timestamp, value, quality}.
    • value: msg.payload is the value, with msg.topic, msg.timestamp, msg.quality and msg.type set. This form works directly with core join (key/value mode).
  • Spec changes take effect on the next message, with no redeploy.
cron (dataops-cron)
Fires on a 6-field cron schedule (sec min hour dom mon dow), for example */10 * * * * * for every 10 seconds. Core inject can only schedule to the minute. Output times fall exactly on the second, and msg.timestamp (ISO) and msg._epoch carry the tick time. The payload can be a timestamp, date, string, number, boolean or JSON.
runtime (dataops-runtime)
For batch and run tracking. While a run-flag topic in the cache is true, it emits a row at most once per sampling seconds. Each row has:
  • timestamp
  • runtime: seconds since the flag went true
  • label: optional, e.g. a batch id
  • the fields you selected
Trigger and label are topics such as line/1/running. Wrapped or normalized entries are unwrapped automatically.
claude (dataops-claude)
Sends cache samples to Claude and writes the per-topic normalization specs it returns into the spec dictionary for transform.
  • Built-in prompt: used when the System Prompt box is empty. It's a structured rulebook covering payload styles (OPC UA, Kepware, Sparkplug B, nested and array JSON), timestamps (date strings, epoch s/ms/µs) and quality (OPC UA status codes, OPC DA numeric quality, quality text), with a worked example. Load default copies it into the box to read or customize, and Reset to built-in clears it.
  • Each spec also gets a unit and a short description for reference. Transform ignores both.
  • Samples are encoded as TOON, a compact table format, to save tokens. Existing specs for other topics are kept.
  • Uses the official Anthropic SDK with streaming and automatic retries. API errors, refusals and truncated replies are reported on output 2.
  • An empty source dictionary is reported as an error, without an API call.
  • A string in msg.payload overrides the generated prompt.
Claude API config (dataops-claude-api)
Holds the Anthropic API key (encrypted) and request settings:
  • Model: default claude-opus-5-5.
  • Effort: optional thinking depth.
  • Max tokens: default 16384.
  • Refusal fallback: on by default for the Anthropic API; retries a policy decline on a fallback model, server-side.
  • Base URL: only needed for a proxy or gateway.
  • Temperature: optional and sent only when set. Leave it empty for current models, which reject it.
DataOps AI sidebar: once a config node is deployed, open the DataOps AI sidebar tab, describe a pipeline in plain English, and import the generated flow onto the canvas.
Quick Start
Heuristic normalization (no API key)
[mqtt in] → transform (heuristic) → debug
AI-assisted normalization
[mqtt in] → cache (wrapped, key: rawCache)
[inject]  → claude (source: rawCache, spec: dataopsSpecs)
[mqtt in] → transform (spec: dataopsSpecs) → [database]
Merge normalized tags into one object
[mqtt in] → transform (output: value) → join (key/value, count N) → [database]
Batch runtime tracking
[mqtt in] → transform → cache (flat, key: line1)
cron (* * * * * *) → runtime (trigger: line/1/running, label: line/1/batch, sampling: 60) → [database]
Example Flows
File Description
examples/dataops-claude-pipeline.json AI: sensor injects → wrapped cache → claude generates specs → transform applies them
examples/dataops-manual-specs.json Hand-written spec dictionary (no API key): lenient $toMillis, bad OPC UA status → quality false, string → integer, unknown topic → error output
examples/dataops-runtime-tracking.json Simulated line (60 s run / 30 s stop) → cache; cron every 1 s → runtime rows with batch label every 10 s
examples/dataops-cron-schedules.json Five common 6-field cron expressions with different payload types
examples/dataops-cache-modes.json Wrapped (TTL 30 s) vs flat (max 3, LRU) caches side by side, with a button to inspect both
Import them with Import → Examples → node-red-contrib-dataops in the editor, or import a file from examples/. Each flow has a comment node explaining what to click and what to look for.
Tip: heuristic mode infers each value's type separately, so a float reading of 1013.0 comes out as integer. When downstream types must stay stable (such as database columns), declare the types in a spec dictionary.
Development
npm run deploy            # npm link into Node-RED
npm run deploy:patch      # bump patch + link
npm test                  # unit + node tests (node:test, no Node-RED instance or API key needed)
npm run examples:install  # add the examples as disabled tabs in the Node-RED at :1880
Restart Node-RED after code changes. See ARCHITECTURE.md for internals.
Publishing
Pushing a v* tag (or publishing a GitHub release) runs .github/workflows/publish.yml. The workflow publishes to npm with the dist-tag taken from the version: -beta → beta, -rc → next, otherwise latest. You can also publish locally:
npm run publish:dry    # dry run
npm run publish:patch  # bump patch + publish
After publishing, resubmit at flows.nodered.org/add/node.
MIT, see LICENSE
Version: 2.0.0
Updated 3 weeks, 6 days ago
1 in the last week
  • dataops-in
  • dataops-cron
  • dataops-runtime
  • dataops-claude-api
  • dataops-claude
  • dataops-transform
  • dataops
  • iiot
  • opc-ua
  • sparkplug
  • mqtt
  • normalization
  • jsonata
  • time-series
  • cron
  • claude
