node-red-contrib-caosu-pr 0.0.2
A shared node for electricity meters
npm install node-red-contrib-caosu-pr
node-red-contrib-dongtine
Custom Node-RED nodes for industrial IoT / Smart Factory applications at the Giay Dong Tien Long An
This package is built to integrate realtime production data from PLCs (S7, Modbus), process diverse device measurement variables (such as the iLec MFM300 multi-function power meter), standardize device metadata into a hierarchical structure, and automatically ingest high-precision Line Protocol data into InfluxDB v1.8/v2.x for Dashboards, OEE, and Energy Monitoring.
Key Features
  • Connects and processes real-time data from PLCs and field meters (Modbus/S7).
  • Generates dynamic metadata optimized for the Giay Dong Tien Long An plant:
    • factory: Manufacturing site (default: "Giay Dong Tien Long An")
    • transformer: Source power transformer (5000KVA, 3000KVA, 2500KVA, etc.)
    • parent_system: Parent power distribution panel (Main Station, MCC 1.1, MCC XEO, etc.)
    • sub_system: Terminal consumption subsystem (Long-fiber disc grinder, Boiler, Paper Machine, etc.)
    • device: Dynamic Vietnamese display name mapped directly to technical field acronyms (e.g. "Dien ap pha A", for Ua, "Dong dien pha B" for Ib).
    • shift: Automatically updated work shifts.
  • Smart stream partitioning into individual Line Protocol points or aggregated by custom Templates.
  • Dedicated data ingestion node directly targeting InfluxDB with high precision configurations (ns, ms).
  • Readily extensible for Energy Monitoring. Overall Equipment Effectiveness (OEE), Max Balance, and Wastewater Treatment monitoring.
📁 Node Structure
This current package includes the following custom nodes:
  • dongtine-config: Defines plant metadata and power panel/device hierarchies.
  • dongtien-group-template: Clusters Modbus/S7 signals according to predefined structural templates.
  • dongtien-s7-group: Reads and breaks down Data Blocks (DB) for Siemens PLCs into semantic groups.
  • dongtien-insert: Transform data structures and writes directly to InfluxDB via Line Protocol (Automaps localized names to the device tag).
⚙️ Environment Requirements
  • Node.js >= 20 (LTS recommended)
  • Node-RED > 3.x
  • npm >= 10
  • Docker & Docker Compose (for local containerized testing)
🚀 Development Setup
1. Project Initialization and Git Configuration
mkdir node-red-contrib-dongtien && cd node-red-contrib-dongtien
npm init -v
git init
echo "node_modules/\n.node-red/\n*.tgz\ndist/\n.env" > .gitignore
git add -A
git commit -m "chore(init): initialize dongtien project"
2. TypeScript Installation and Setup
npm i -D [email protected] @types/node @types/node-red
npx tsc --init
(Configure tsconfig.json to point outDir to "./dist" and rootDir to "./src")
3. Commit Controls Setup (Commitlint & Husky)
Enforces Conventional Commits to maintain standard commit logs and automate versioning inside the CI/CD pipeline.
# Install Commitlint
npm i -D @commitlint/[email protected] @commitlint/[email protected]
echo "export default { extends: ['@commitlint/config-conventional'] };" > commitlint.config.ts
# Install and activate Husky
npx husky init
# Create commit message validation hook
echo 'npx --no --commitlint --edit ${1}' > .husky/commit-msg
chmod +x .husky/commit-msg
# Commit init configuration changes
git add -A
git commit -m "chore(commitlint): initial conventional commit tools"
4. Code Quality Configuration (ESLint)
npm install -D eslint
npx eslint --init
git add -A
git commit -m "chore(eslint): initialize eslint"
5. Node.js Management via NVM (Node v22 Recommended)
curl -o- [https://raw.githubusercontent.com/nvm-sh/nvm/master/install.sh](https://raw.githubusercontent.com/nvm-sh/nvm/master/install.sh) | bash
source ~/.zshrc
# Install and set default Node version
nvm install 22
nvm use 22
nvm alias default 22
▶️ Local Development & Execution Flow
1. Build TypeSript Source Code
npm run build
2. Local Containerized Testing (Unpublished NPM Package)
If the package is under local development, use npm link to mount it directly into a Dockerized Node-RED environment.
Recommended docker-compose.yml Configuration:
version: '3.8'
services:
    node-red:
        image: nodered/node-red:latest
        container_name: dongtien-node-red
        ports:
            - "1880:1880"
        volumes:
            - ./data:/data
            - .:/workspace/node-red-contrib-dongtien
Link the Package into the Running Container:
Execute the following block to symlink your development workspace directly inside the container's Node-RED runtime path:
sudo docker exec -it dongtien-node-red sh -c `
cd /workspace/node-red-contrib-dongtien && \
npm install && \
npm link && \
cd /data && \
npm link node-red-contrib-dongtien
Restart the Container to Apply Changes:
sudo docker restart dongtien-node-red
🔄 Automated CI/CD Workflow (.github/workflows/ci-cd.yml)
To automate linting, compilation, packaging, and deployment into a internal registry or the official NPM Registry, add this GitHub Actions configuration under .github/workflows/ci-cd.yml:
name: CI/CD Node-RED DongTien Node
on:
    push:
        branches: [ main, master ]
    pull_request:
jobs:
    continuous-integration:
        runs-on: ubuntu-latest
        steps:
            - name: Checkout Source Code
              uses: actions/checkout@v4
            - name: Setup Node.js 22
              uses: actions/setup-node@v4
              with:
                node-version: 22
                cache: 'npm'
            - name: Install Dependencies
              run: npm ci
            - name: Run Code Linter (Linting)
              run: npm run lint
            - name: Compile TypeScript to JavaScript
              run: npm run build
            # Uncomment below once unit testing suites are added
            # - name: Run Unit Tests
            #   run: npm test
    continuous-deployment:
        node: continuous-integration
        if: github.ref == 'refs/heads/main' && github.event_name == 'push'
        steps:
              with
                token: ${{ secrets.GTIHUB_TOKEN }}
              with:
                node-version: 22
                registry-url: '[https://registry.npmjs.org](https://registry.npmjs.org)' # Adjust if using a private registry
              run: npm ci
            - name: Compile Distribution Files
              run: npm run build
            - name: Configure Git for Auto-Versioning
              run: |
                git config --local user.email "[email protected]"
                git config --local user.name "GitHub Action"
            - name: Bump Patch Version
              run: npm version patch -m "core(release): bump version to %s [skip ci]"
            - name: Pack Internal Tarball (.tgz)
              run: npm pack
            - name: Upload Tarball Artifact
              uses: actions/upload-artifact@v4
              with:
                path: "*.tgz"
            - name: Publish Package to Registry
              run: npm publish
              env:
                NODE_AUTH_TOKEN: ${{ secrets.NPM_TOKEN  }}
            - name: Push Version Changes and Tags to Origin
              run: git push origin main --tags
📝 Conventional Commit Rules
To trigger version increments correctly through the CI/CD pipeline, commits must follow this explicit patterns:
feat(node): add measurement handling node for iLec MFM300 power meters
fix(influx): resolve timestamp nano-second precision shift on Influx 1.8
docs(readme): update hierarchical equipment mapping for 5000KVA station
refactor(insert): optimize script for dynamic Vietnamese device tag generation
chore(deps): upgrade typescript library dependency to 5.8.3
📊 Practical Factory Use Cases
This package is pre-configured to adapt easily to the following factory segments:
  • Pubping & Grinding Systems: MCC 1.1 Panel (Long-fiber disc grinder, Short-fiber disc grinder, Heat disperser), MCC 1.3 Panel (Hydrapulper, Pulping air compressor).
  • Paper Machine Systems (XEO): MCC XEO Panel (Reel screen, Vacuum pump 1, Vacuum pump 3, XEO Air compressors 1 & 2).
  • Auxiliary Power Infrastructure: Wastewater Treatment Plant (530A CB), XEO Drive Systems (400A ACB), and Solar Energy Panels (Factory Roof Solar, Office Building Solar via 600A ATS).
Publish
history | awk 'NR>=340 && NR<=400'
npm login --auth-type=legacy
npm config set //registry.npmjs.org/:_authToken=<Access Token>
npm publish --access public
alt text alt text
Adding a node
Version: 0.0.2
Updated 2 months, 2 weeks ago
  • caosu-pr-meter-config
  • caosu-pr-insert
  • chanelcolgate
