node-red-contrib-alarm-ultimate 2.1.6
Alarm System node for Node-RED. Integrates also with Home Assistant, MQTT, KNX-Ultimate. Completed with web interface for fast configuration and control. With zone import wizard.
npm install node-red-contrib-alarm-ultimate
Alarm Ultimate for Node-RED
A complete alarm system for Node-RED, with a ready-to-use web control panel.
Create zones, arm/disarm with optional code, entry/exit delays, bypass, chime, panic, siren, 24h/fire/tamper zones and an event log — all configured from a friendly editor, no programming required.
NPM version NPM downloads Node-RED Flows License GitHub issues
Alarm Ultimate - Max Supervibe
▶ Watch the Alarm Ultimate video playlist on YouTube
Works great with
Home Assistant     MQTT
Built‑in Home Assistant and MQTT support: the alarm can appear in Home Assistant automatically (alarm panel + a sensor per zone) without writing any configuration. See Home Assistant & MQTT.
Table of contents
In Node-RED: Menu → Manage palette → Install, then search for alarm ultimate and click install.
That's it — the alarm nodes and the web panel are now available.
Quick start
  1. Drag an Alarm System node into your flow.
  2. Double‑click it, click Manage zones, and add at least one zone (give it a name and a topic, e.g. sensor/frontdoor). Click Done.
  3. Click Deploy (top right).
  4. Open the web Alarm Panel to arm/disarm and see the status (see below).
To make the alarm react to your real sensors, send each sensor's state to the Alarm node:
  • door/window opened → message with topic = sensor/frontdoor and payload = true (also accepts open, on, 1)
  • closed → same topic with payload = false (also closed, off, 0)
Using Home Assistant, MQTT or KNX? You usually don't need to build this by hand — see the sections and examples below.
The web Alarm Panel
A full keypad‑style panel is included and opens right from your browser:
  • Alarm Panel: http://<your-node-red>/alarm-ultimate/alarm-panel
  • Zones helper (visual zone editor): http://<your-node-red>/alarm-ultimate/alarm-json-mapper
When Node-RED runs as the Home Assistant add-on, open these pages from the buttons in the Node-RED editor. Home Assistant Ingress adds a session-specific prefix to the URL; a manually typed URL such as http://<home-assistant>:8123/alarm-ultimate/... targets Home Assistant itself and returns 404. The editor buttons preserve the Ingress prefix automatically.
From the panel you can arm/disarm (with code if enabled), bypass zones, trigger panic, and read the event log. It can also be embedded in the Node-RED Dashboard — see the ready‑made flows in Examples.
Alarm Panel
Open the Alarm node and go to the MQTT / HA tab:
  1. Tick Enable MQTT and select (or create) an Alarm MQTT broker configuration with your Broker URL (e.g. mqtt://192.168.1.10:1883) and, if needed, username/password.
  2. Leave HA discovery and Publish zones enabled.
  3. Deploy.
Your alarm now appears automatically in Home Assistant (same MQTT broker) as an Alarm panel entity, with one sensor per zone, all grouped under a single device. Arm/disarm from Home Assistant and the state stays in sync both ways.
Have more than one Alarm node? Point them all at the same broker configuration: they share a single MQTT connection, and you enter the broker settings only once.
Prefer to wire it yourself, or already use the Home Assistant Add‑on? There are ready‑to‑import example flows for both — see Examples.
Zones
Each zone is a sensor the alarm watches. From Manage zones you can set, per zone:
  • Type: perimeter, motion, 24h, fire or tamper (24h/fire/tamper always trigger, even when disarmed).
  • Entry zone: starts the entry countdown instead of triggering immediately.
  • Bypassable / Chime and more.
  • Sensor supervision (optional): if a sensor stops reporting for a while, the panel shows it as MISSING and can block arming — useful to catch dead batteries.
Zones can be exported/imported for backup from the Settings page, and there is a visual Zones helper to build them from a sample message (e.g. KNX) or an ETS group‑address list.
Examples
Import any of these from Menu → Import (or see examples/):
  • alarm-ultimate-basic.json — a minimal working flow to try it out.
  • alarm-ultimate-mqtt.json — connect the alarm to an MQTT broker.
  • alarm-ultimate-home-assistant-alarm-panel.json — use it with the Home Assistant Add‑on and the HA Alarm Panel card.
  • alarm-ultimate-dashboard.json / -controls.json / -v2.json — embed the panel in the Node-RED Dashboard.
Help & support
Version: 2.1.6
Updated 3 months, 1 week ago
63 in the last week
  • AlarmSystemUltimate
  • AlarmUltimateMqtt-config
  • AlarmUltimateState
  • AlarmUltimateZone
  • AlarmUltimateSiren
  • node-red-contrib
  • alarm
  • alarm-system
  • security
  • intrusion
  • zone
  • siren
  • home-assistant
  • mqtt
  • knx
  • iot
  • smarthome
  • home-automation
