node-red-contrib-abb-gofa 2.6.4
Node-RED nodes for controlling an ABB GoFa (CRB 15000) collaborative robot via RWS and a RAPID TCP socket server
npm install node-red-contrib-abb-gofa
Node-RED nodes for controlling an ABB GoFa (CRB 15000) collaborative robot with an OmniCore controller over the local network. Motion, telemetry, I/O, RAPID program control, saved-point teach & replay — no extra ABB licenses required.
Developed and live-tested against a GoFa 12 (CRB 15000-12/1.27) on an OmniCore C30, RobotWare 7.21.
⚠️ Safety and security
This package moves a real robot arm.
  • The software STOP command and Node-RED itself are not safety functions. The robot's own safety controller, reduced-speed collaborative limits, and the physical emergency stop are the only real safety layer. Never rely on a flow to keep people safe.
  • The RAPID socket server (port 1025) accepts motion commands from anyone who can reach the robot's IP — there is no authentication on that port. Run the robot on an isolated or firewalled network segment. The same goes for RWS credentials sent over HTTPS with certificate checking disabled (the controller uses a self-signed certificate).
  • Jog/rotate step limits (50 mm / 30°) are enforced in the RAPID module, not in Node-RED — if you edit MainModule.mod, keep them.
  • The node property panels have live-action buttons (jog, move, motors on/off, …) backed by Node-RED admin HTTP endpoints. The browser confirmation dialogs are convenience only, not a security control. Configure adminAuth on any Node-RED instance controlling a real robot — it is required, not optional. As of 2.4.10 these motion endpoints are refused (HTTP 403) when adminAuth is not configured, so an unauthenticated editor port can no longer trigger motion. If your instance has no adminAuth but is genuinely protected another way (isolated cell network / firewall / reverse proxy), tick Allow insecure live control on the gofa-robot config node to re-enable them at your own risk. Deployed flows are unaffected either way — this guard only covers the editor buttons.
Upgrading
Node removals in this package are replacements, not aliases — a flow built with an older version shows "unknown node" for a removed type and has to be edited. The two most likely to affect you: gofa-joint-jog was merged into gofa-jog (2.6.0), and gofa-save-point/ gofa-go-point/gofa-point-list/gofa-delete-point were merged into gofa-points (2.5.0, which also moved point storage from the Node-RED host onto the robot). Full details and migration tables: CHANGELOG.md.
How it works
Two transports, one rule — motion goes through a TCP socket, everything else goes through RWS:
  • TCP socket (port 1025) — a small RAPID program (rapid/MainModule.mod, bundled with this package) runs a socket server on the controller. Each motion node opens a connection, sends one newline-terminated command (HOME, GOTOJ…, J1+10, …), reads one OK:/ERR: reply, and closes.
  • Robot Web Services (HTTPS, port 443) — OmniCore's built-in REST API, used for telemetry (pose, joints, state), motor on/off, RAPID start/stop, I/O read/write, file transfer, and WebSocket subscriptions.
RWS-only nodes (status, pose, joints, I/O, …) work without the RAPID module; motion nodes need it loaded and running.
Requirements
  • ABB GoFa CRB 15000 with an OmniCore controller, RobotWare 7.x (must run RWS 2.0)
  • Node-RED ≥ 3.0, Node.js ≥ 18
  • Network access to the controller (HTTPS 443 + TCP 1025)
  • RobotStudio (free) — once, to create an RWS user with the right grants
From your Node-RED user directory (usually ~/.node-red):
(or Menu → Manage palette → Install inside the Node-RED editor.)
Restart Node-RED — a gofa-robot config node and 37 gofa-* nodes appear under the ABB-GoFa-12 category in the palette sidebar. The package has no runtime dependencies.
Controller setup (once)
1. Create an RWS user. The built-in Admin account cannot start/stop RAPID remotely. In RobotStudio: connect to the controller → Authenticate → Edit User Accounts → add a role with the Remote Start and Remote Stop grants → create a user with that role. Read-only nodes work with any account.
2. Upload the RAPID module. The module ships in this package. Easiest path: add a gofa-file node (action upload) and set its Local Path to the absolute path of the bundled file (e.g. /home/pi/.node-red/node_modules/node-red-contrib-abb-gofa/rapid/MainModule.mod — a relative path resolves against the Node-RED process directory, not your user dir). It uploads over RWS and automatically patches the module's SERVER_IP constant to your robot's IP (the RAPID socket server cannot bind a wildcard address, so this must match). Or upload manually:
curl -sk -u <user>:<password> -X PUT -H "Content-Type: text/plain;v=2.0" \
  --data-binary @rapid/MainModule.mod \
  "https://<ROBOT_IP>/fileservice/\$HOME/Programs/MainModule.mod"
(If you upload manually, edit SERVER_IP in the file to your robot's IP first.)
3. Load and start it on the FlexPendant. Code → ⋮ → Load Module → HOME/Programs/MainModule.mod, then Debug → PP to Main, switch to Auto mode, Motors on, Play (▶). The controller now answers on port 1025 (test: send PING\n, expect OK:PING).
  1. Open any gofa-* node → add a gofa-robot config node: robot IP, ports (443 / 1025), the username/password from step 1.
  2. Wire an inject into e.g. gofa-status or gofa-ping to verify connectivity, then go from there.
  3. Every node has full usage docs in the Node-RED sidebar help.
Ready-made example flows ship with the package — Menu → Import → Examples → node-red-contrib-abb-gofa: a one-inject-per-node demo, one-click setup, a pick-and-place sorting cell, a physical-button teach workflow, a socket-wedge watchdog, an MQTT bridge, an EGM conveyor demo, and a brake-check reminder. They're also in the GitHub repo's flows/ directory.
Every node below (except the gofa-robot config node) has an Output payload (debug) checkbox, unchecked by default. Unchecked, a node still fires on completion to trigger the next node in the flow, but with an empty payload instead of full debug data — no change node needed just to silence output. Check it to get the full msg.payload described per node below.
Node Transport Description
gofa-robot config Shared connection settings (IP, ports, credentials, points storage)
gofa-status RWS Controller state, operating mode, speed ratio, RAPID execution state
gofa-connection-status RWS + Socket + Background Checks RWS, the TCP socket server, and the Background task independently — reachable? reply time? — without assuming any one already works; also reports each layer's module version and whether an EGM session is active
gofa-pose RWS Current TCP pose (position + quaternion + config flags)
gofa-joints RWS All 6 joint angles
gofa-system-info RWS RobotWare version, controller identity
gofa-elog RWS Controller event log — Domain (category) + Min Severity (info/warning+/error-only) filters
gofa-motor RWS Motors on/off
gofa-move Socket Go home / set home
gofa-movej Socket Absolute joint move ("Move Joints") — Move type: Joint (default) / Linear. Validates each target angle against the robot's Joint Limits (CRB 15000-12 defaults) before sending — an out-of-range target returns a clean error instead of faulting RAPID
gofa-jog Socket Relative jog — Target: X/Y/Z (±mm, base frame), RX/RY/RZ (±°, tool frame) or J1–J6 (±°, single joint). Replaces the separate gofa-joint-jog node, removed in 2.6.0
gofa-zone-set Socket Path blend zone (FINE…Z100)
gofa-speed-set Socket Speed override via VelSet — set or read current (C_MOTSET.vel.oride); see CLAUDE.md for why SpeedRefresh doesn't work here
gofa-stop-motion RWS + Socket Motion halt. Mode: immediate (default) halts an in-progress HOME/GOTOJ/GOTOL/MOVEJ/MOVEL now via an RWS execution-stop + auto resetPP/start (arm stays put, socket recovers; needs Auto + motors on); queued is the legacy socket STOP that only cancels a not-yet-started move
gofa-ping Socket Connectivity test with round-trip time
gofa-grip RWS Digital output on/off (gripper-style)
gofa-points RWS + Socket + RWS fileservice Combined point node — Action: save / go / list / delete (per-point, on the robot controller's disk — no local storage) / export / import (backup/restore that same on-robot list to/from a file, import replaces the whole list)
gofa-sequencer / gofa-stop-seq Socket + RWS fileservice Visit saved points (on the robot controller's disk) in order (dwell, loops, ping-pong) / stop the sequence
gofa-setup RWS + Socket One-click first-run init for T_ROB1: upload the bundled RAPID module (SERVER_IP auto-synced), load, reset PP, motors on, start, verify socket — with a per-step report. Also reloads T_LED/BackgroundLed.mod if that task already exists, best-effort. Cannot create the T_LED task itself — see the Background task section below for that one-time step
gofa-rapid-exec RWS Start / stop / reset-PP / load / unload / activate RAPID program
gofa-rapid-var-read / gofa-rapid-var-write Socket Read/write RAPID PERS variables
gofa-rapid-tasks RWS List RAPID tasks and modules
gofa-file RWS Upload / download / delete controller files (action dropdown; upload auto-syncs SERVER_IP)
gofa-mod-edit RWS Edit a .mod (or any text) file on the controller's disk right in the node's edit dialog — pick a file in $HOME/Programs (or name a new one), Load/Save to robot, SERVER_IP auto-synced
gofa-io-list / gofa-di-read RWS List signals, read inputs
gofa-do-write RWS, Socket, or Background Write outputs — Transport dropdown: RWS /set-value (default, needs Access: All), Socket SETDO (needs RAPID running), or Background task (works while T_ROB1 is stopped)
gofa-leadthrough Socket + RWS Hand-guiding (lead-through) on/off (action: enable / disable)
gofa-asi-led Socket, RWS, or Background Arm status-light color and blink — Transport dropdown, same three options as gofa-do-write above
gofa-subscribe-state / gofa-subscribe-io RWS WebSocket Push on controller-state / I/O-signal changes
gofa-subscribe-var / gofa-subscribe-pose RWS poll Poll a RAPID variable / TCP pose on an interval
gofa-subscribe-elog RWS WebSocket Push new event log entries in real time; same Domain/Min Severity filters as gofa-elog
gofa-egm / gofa-egm-move UDP (EGM) Sub-10ms joint-position streaming — see EGM (optional) below, requires MainModuleEGM.mod
Full documentation
Getting started Controller setup, install, and your first robot move
Node reference Every node, msg.payload conventions, EGM, background task
Troubleshooting Symptoms and fixes
Manual control Drive the robot with curl / raw TCP
Each node also has its own help page in the Node-RED sidebar — select the node and open the Help tab.
EGM (optional)
gofa-egm + gofa-egm-move stream joint positions over EGM (Externally Guided Motion) — a UDP/protobuf channel capable of sub-10ms closed-loop motion, unlike the TCP socket protocol or RWS (which tops out around 500ms). It needs its own RAPID module and a one-time controller config, so it's opt-in rather than part of the default setup above.
Two nodes, split by job. gofa-egm only starts/stops the EGM session and emits telemetry — it has an Action dropdown (Start EGM / Stop EGM), same pattern as gofa-motor/ gofa-rapid-exec. gofa-egm-move is a separate node that sets the movement target: send it a [j1..j6] array and it checks whether a gofa-egm session is active on the same Robot — if so, it updates the live target (output 1); if not, it routes the message unchanged to a fallback output (output 2) instead of erroring, e.g. to wire straight into gofa-movej for a normal non-EGM move.
Two RAPID modules, one choice at a time:
Module Use when
rapid/MainModule.mod Default. Everything in this README works. No EGM support.
rapid/MainModuleEGM.mod A full clone of MainModule.mod plus one added command, EGMJOINT, that switches the controller into a blocking EGM session. Load this instead when a flow needs gofa-egm.
Only one can run at a time — whichever is loaded on the controller. Switching requires unloading the currently-loaded module first — loadmod's replace option only replaces a module with the same name, and MainModule/MainModuleEGM are different names, so loading one while the other is still loaded leaves both loaded and RAPID rejects start with "Global routine name main ambiguous" (both declare PROC main()). Full switch sequence either direction: gofa-rapid-exec (stop) → gofa-rapid-exec (unloadmod, naming the module currently loaded — this only detaches it from the task, the file stays on the controller's disk) → gofa-file upload (the other file) → gofa-rapid-exec (loadmod → resetpp → start). gofa-egm detects the wrong module itself (start fails with a clear "load MainModuleEGM.mod first" error instead of hanging) — but there is no way to run without one or the other, so mixing them up just costs a reload, not a broken robot.
Why two modules instead of one: an EGM session (EGMRunJoint) blocks the RAPID task for its whole duration, so the same task can't also be running the plain TCP socket server that every other node in this package depends on — while gofa-egm is streaming, gofa-jog, gofa-points (go action), and the rest simply can't connect. Keeping EGM support in a separate module means the default MainModule.mod — and everything that depends on it — is completely unaffected by this feature; it's not merged into the file every other node already relies on.
One-time controller setup, not done by any node: a UDP Unicast Device named EGM_PC (RobotStudio → Controller → Configuration → Communication → UDP Unicast Device → right-click → New UDP Unicast Device...; Remote Address = the Node-RED host's IP on the robot's subnet, Remote Port Number = the gofa-egm node's configured UDP port, default 6510, Local Port Number = 0; requires a controller restart), and — on the Node-RED host — a firewall rule allowing inbound UDP on that port.
Caution — tool load data: per ABB's EGM Application Manual, the robot should have correct tool load data (LoadIdentify) before starting EGM — incorrect load data can cause servo torque overruns or safety halts when EGM issues fast corrections. With no tool physically mounted, MainModuleEGM.mod/MainModule.mod both target tool0 (RAPID's built-in empty-flange tool) rather than a placeholder tooldata, so there's no false load data to worry about right now. Once a real gripper is mounted, run LoadIdentify (or otherwise measure its real mass/CoG/ inertia/TCP offset) and update both .mod files to use it before relying on EGM (or any motion) with that tooling attached.
Background task (optional)
Not required for anything above — every node in this package works without it. It exists to keep LED feedback and digital-output writes working during a hand-guiding session (or any other time T_ROB1 is stopped), by running a small second RAPID module (rapid/BackgroundLed.mod) in its own task. It backs the Background transport option on gofa-do-write/gofa-asi-led, and the background field on gofa-connection-status. Setting it up needs one manual, one-time RobotStudio step (creating a new RAPID task isn't possible over RWS at all) — see the node reference's "Background task" section for the exact steps. After that one-time setup, gofa-setup reloads BackgroundLed.mod automatically on every run, right alongside T_ROB1 — no further manual steps needed.
Full node help (input/output shapes, config) is in the Node-RED sidebar for gofa-egm and gofa-egm-move.
Test
From a git checkout (the test suite is not included in the npm package):
npm test
Runs test.js — unit tests for the pure helpers (gotoToken, parseXhtml, points persistence, LED payload resolution, the hand-rolled EGM protobuf codec) plus integration-style tests that drive node input handlers against a minimal Node-RED harness.
MIT
Version: 2.6.4
Updated 3 months ago
434 in the last week
  • gofa-robot
  • gofa-setup
  • gofa-status
  • gofa-connection-status
  • gofa-pose
  • gofa-joints
  • gofa-move
  • gofa-motor
  • gofa-jog
  • gofa-sequencer
  • gofa-stop-seq
  • gofa-rapid-exec
  • gofa-rapid-var-read
  • gofa-rapid-var-write
  • gofa-rapid-tasks
  • gofa-elog
  • gofa-system-info
  • gofa-speed-set
  • gofa-file
  • gofa-do-write
  • gofa-di-read
  • gofa-io-list
  • gofa-leadthrough
  • gofa-points
  • gofa-movej
  • gofa-zone-set
  • gofa-grip
  • gofa-ping
  • gofa-stop-motion
  • gofa-subscribe-state
  • gofa-subscribe-io
  • gofa-subscribe-var
  • gofa-subscribe-pose
  • gofa-subscribe-elog
  • gofa-asi-led
  • gofa-egm
  • gofa-egm-move
  • gofa-mod-edit
  • abb
  • robot
  • gofa
  • crb15000
  • omnicore
  • rws
