@theotherwillembotha/node-red-traccar 0.4.6
Traccar GPS tracking integration nodes for Node-RED
npm install @theotherwillembotha/node-red-traccar
Node-RED integration for Traccar - an open-source GPS tracking server. Provides live position event streaming and on-demand location queries for tracked devices and groups.
Prerequisites
  • Node-RED >= 3.0.0
  • Node.js >= 18.0.0
  • A running Traccar server (self-hosted or cloud)
[!IMPORTANT] This plugin requires @theotherwillembotha/node-red-plugincore to be installed.
node-red-plugincore is declared as a dependency and npm will install it automatically alongside this package. However, due to a known Node-RED limitation, packages that arrive as transitive npm dependencies are only discovered by the Node-RED runtime on the next startup.
You have two options:
  • Install @theotherwillembotha/node-red-plugincore via the palette manager or npm install first, then install this plugin - both will be available immediately without a restart.
  • Install this plugin directly - node-red-plugincore will be installed automatically alongside it. Restart Node-RED once and both packages will be fully loaded.
Traccar Server Config
A shared configuration node that holds the connection details for a Traccar server. All Traccar nodes reference one of these.
Fields:
Field Description
Name Display label
URL Base URL of the Traccar server, e.g. http://traccar.example.com
Username Traccar account email address
Password Traccar account password
Cache Timeout How long (in minutes) to cache device and group data. Default: 5. Set to 0 to always fetch fresh data.
Buttons:
  • Test Connection - verifies the URL and credentials against the live server. Reports the number of visible devices on success or a specific error (authentication failure, URL not found, timeout) on failure.
  • Reload Cache - forces an immediate refresh of the device and group cache without waiting for the timeout to expire. Useful after adding or renaming devices or groups in Traccar.
On deployment the node connects to the Traccar server, loads devices and groups into its internal cache, and opens a persistent WebSocket subscription for live position updates. All Event and Get Device Location nodes that reference this config share the same connection and cache.
Traccar Event
Subscribes to the Traccar server and emits a message for every incoming position update that matches the configured filter.
Fields:
Field Description
Name Display label
Server The Traccar Server Config node to connect to
Filter Optional filter expression (see Filter Syntax below). Leave blank to receive all position updates.
Get positions on connect If enabled, fetches the last known position for all matched devices immediately when the WebSocket connects, before waiting for live updates.
Output:
Each matching position update produces one message:
msg.payload.position  -  the Traccar position object
The position object includes (among other fields):
Field Description
latitude Latitude in decimal degrees
longitude Longitude in decimal degrees
altitude Altitude in metres
speed Speed in knots
course Heading in degrees
valid Whether the GPS fix is valid
fixTime Timestamp of the GPS fix
serverTime Timestamp when the server received the update
deviceId Traccar device ID
device Enriched device object (name, uniqueId, status, groups, etc.)
attributes Device-reported attributes (battery level, ignition, distance, etc.)
The node status shows connected (green dot) when the WebSocket is open, or disconnected (red dot) if the connection drops.
Traccar Get Device Location
Fetches the last known position for one or more devices when triggered by an incoming message. Useful for polling workflows or for enriching a message with current device location on demand.
Fields:
Field Description
Name Display label
Server The Traccar Server Config node to query
Filter A filter expression. Can be set as a literal string or resolved dynamically from msg, flow, or global. See Filter Syntax below.
Output Path The msg property to write results to (e.g. msg.payload). Always an array - empty if no devices match.
Input:
Any incoming message triggers a location lookup. The message is forwarded with the results written to the configured output path.
Output:
msg.<outputPath>  -  array of matching position objects (same structure as above)
The array is empty if no devices match the filter. The original message properties are preserved.
Filter Syntax
Both the Traccar Event and Traccar Get Device Location nodes share the same filter syntax. A filter is a comma-separated list of matchers. Each matcher takes the form:
<selector>:<pattern>
Supported selectors:
Selector Matches against
device The device name
group Any group the device belongs to
Patterns support * as a wildcard (matches any sequence of characters).
Examples:
device:MyPhone                exact match - device named "MyPhone"
device:Truck*                 prefix wildcard - any device starting with "Truck"
device:*Van*                  substring wildcard - any device whose name contains "Van"
group:Fleet                   all devices in the group named "Fleet"
group:Fleet,device:MyPhone    union - devices in "Fleet" OR the device "MyPhone"
Multiple matchers are evaluated with OR logic - a position passes if any one matcher matches.
Group matching is hierarchical. If device A belongs to group Child, and Child is a sub-group of Parent, then group:Parent will also match device A.
Auto-complete is available in the editor: type a selector name (e.g. dev) and press the auto-complete key to expand it to device:, then continue typing a device name to see matching suggestions fetched live from the server.
When the filter field on Traccar Get Device Location is set to msg, flow, or global, the resolved value is used as-is as the filter string.
Caching
Device and group data is cached locally to avoid repeated API calls on every position event. The cache timeout is configured per server (default 5 minutes).
  • When the timeout expires, data is re-fetched automatically on the next event.
  • Set timeout to 0 to disable caching (always fetch live data).
  • Use the Reload Cache button on the server config to force an immediate refresh - for example after adding a new device or changing group memberships in Traccar.
References
Version: 0.4.6
Updated 3 weeks, 1 day ago
2 in the last week
  • DelegatedConfigReferenceNode
  • TraccarServerConfigNode
  • TraccarGetDeviceLocationNode
  • TraccarEventNode
  • traccar
  • gps
  • tracking
  • location
