ChaBot Multi-language and voice with Watson on Telegram
This ChatBot is multi-language and uses voice on telegram, using IBM Watson Assistant, Watson Speech To Text, Watson Text to Speech and Watson Translator
[{"id":"8c07c84c901460eb","type":"tab","label":"WA no Telegram (VOZ + Ing + Port)","disabled":false,"info":"","env":[]},{"id":"3e0a95af.e5f08a","type":"function","z":"8c07c84c901460eb","name":"Obtem mensagem","func":"msg.payload = msg.telegram.content;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":170,"y":300,"wires":[["f3d75d6899402a57"]]},{"id":"24ebd36b.04d1e4","type":"watson-conversation-v1","z":"8c07c84c901460eb","name":"Watson Assistant","workspaceid":"26244031-2713-4977-86b4-dbb6dc3763b3","multiuser":false,"context":true,"empty-payload":false,"service-endpoint":"https://api.us-south.assistant.watson.cloud.ibm.com/instances/81b32a79-de24-4f06-957b-f191bc7c1246","timeout":"","optout-learning":false,"x":870,"y":380,"wires":[["a6817c9855f6c4a6","043689058277f981"]]},{"id":"10222f18.29e139","type":"function","z":"8c07c84c901460eb","name":"Not authorized user","func":"msg.payload.content = \"You're not authorized user\";\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":290,"y":780,"wires":[["106e3553196519f9"]]},{"id":"c61665b5.dc1d8","type":"comment","z":"8c07c84c901460eb","name":"Read.me","info":"1) Create a Watson Conversation on IBM Cloud (https://www.bluemix.net)\n2) Create a Telegram Bot:\n   Open web.telegram.org\n   find BotFather (contact)\n   send /newbot\n   Give a name for your bot (Botfather will ask it)\n   Give a user name for it, which should have in the end \"Bot\"\n   The BotFather will give you a token.\n3) Baixe o nó node-red-contrib-telegrambot\n   Configure o nó receiver com o token dado\n   pelo Botfather\n   ","x":120,"y":100,"wires":[]},{"id":"fe94e8a123af9817","type":"telegram receiver","z":"8c07c84c901460eb","name":"","bot":"802e8986a91412bf","saveDataDir":"","filterCommands":false,"x":140,"y":140,"wires":[["154167cd2f04b0b1"],["10222f18.29e139"]]},{"id":"106e3553196519f9","type":"telegram sender","z":"8c07c84c901460eb","name":"","bot":"802e8986a91412bf","haserroroutput":false,"outputs":1,"x":880,"y":780,"wires":[[]]},{"id":"f3d75d6899402a57","type":"watson-language-translator-identify","z":"8c07c84c901460eb","name":"","service-endpoint":"https://api.us-south.language-translator.watson.cloud.ibm.com/instances/e0759a16-77f3-44c8-a30b-5348a4c9a54e","x":410,"y":300,"wires":[["9fc9fa33a06fc9c2"]]},{"id":"2848f6e5809c8456","type":"watson-translator","z":"8c07c84c901460eb","name":"","action":"translate","basemodel":"ar-en","domain":"general","srclang":"en","destlang":"pt","apikey":"O83UUiHvp4mbjTtTapzMiZ8b_7IW234oWr8tIe19P1yf","custom":"","domainhidden":"general","srclanghidden":"en","destlanghidden":"pt","basemodelhidden":"ar-en","customhidden":"","filetype":"forcedglossary","trainid":"","lgparams2":true,"service-endpoint":"https://api.us-south.language-translator.watson.cloud.ibm.com/instances/e0759a16-77f3-44c8-a30b-5348a4c9a54e","x":570,"y":380,"wires":[["24ebd36b.04d1e4"]]},{"id":"9fc9fa33a06fc9c2","type":"function","z":"8c07c84c901460eb","name":"Traduz?","func":"flow.set(\"language\", msg.lang.confidence > .3 ? msg.lang.language : flow.get(\"language\") || \"pt\");\nif (msg.lang.language == \"en\")\n    {\n        flow.set(\"language\",\"en\");\n        return [null, msg];\n    }\nreturn [msg,null];","outputs":2,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":300,"wires":[["24ebd36b.04d1e4"],["2848f6e5809c8456"]]},{"id":"855d2d1224166199","type":"function","z":"8c07c84c901460eb","name":"Traduz?","func":"if(flow.get(\"language\") == \"en\") {\n    msg.payload = msg.payload.output.generic[0].text;\n    return [null,msg];\n}\nmsg.payload = msg.payload.output.generic[0].text;\nreturn [msg,null];","outputs":2,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":520,"wires":[["b242e40d33b392b5"],["a15c68b14274ea08"]]},{"id":"a15c68b14274ea08","type":"watson-translator","z":"8c07c84c901460eb","name":"","action":"translate","basemodel":"ar-en","domain":"general","srclang":"pt","destlang":"en","apikey":"O83UUiHvp4mbjTtTapzMiZ8b_7IW234oWr8tIe19P1yf","custom":"","domainhidden":"general","srclanghidden":"pt","destlanghidden":"en","basemodelhidden":"ar-en","customhidden":"","filetype":"forcedglossary","trainid":"","lgparams2":true,"service-endpoint":"https://api.us-south.language-translator.watson.cloud.ibm.com/instances/e0759a16-77f3-44c8-a30b-5348a4c9a54e","x":370,"y":580,"wires":[["b242e40d33b392b5"]]},{"id":"287d451bd9039101","type":"switch","z":"8c07c84c901460eb","name":"Audio?","property":"telegram.type","propertyType":"msg","rules":[{"t":"eq","v":"voice","vt":"str"},{"t":"eq","v":"message","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":540,"y":140,"wires":[["6c07fa78d82ada85"],["3e0a95af.e5f08a"]]},{"id":"154167cd2f04b0b1","type":"change","z":"8c07c84c901460eb","name":"Salva estado","rules":[{"t":"move","p":"payload","pt":"msg","to":"telegram","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"history","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":140,"wires":[["287d451bd9039101"]]},{"id":"a6817c9855f6c4a6","type":"switch","z":"8c07c84c901460eb","name":"Retornar audio?","property":"telegram.type","propertyType":"msg","rules":[{"t":"eq","v":"voice","vt":"str"},{"t":"eq","v":"message","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":440,"y":500,"wires":[["5620e152a30bea0e"],["855d2d1224166199"]]},{"id":"b242e40d33b392b5","type":"change","z":"8c07c84c901460eb","name":"Restaura estado","rules":[{"t":"move","p":"payload","pt":"msg","to":"telegram.content","tot":"msg"},{"t":"move","p":"telegram","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"history","pt":"flow","to":"history","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":580,"wires":[["106e3553196519f9"]]},{"id":"5620e152a30bea0e","type":"function","z":"8c07c84c901460eb","name":"Pega resposta","func":"msg.payload = msg.payload.output.generic[0].text;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":480,"wires":[["5a0b5809c2ab5afa","75c4f2320d83605c"]]},{"id":"6c07fa78d82ada85","type":"change","z":"8c07c84c901460eb","name":"Pega URL do audio","rules":[{"t":"move","p":"telegram.weblink","pt":"msg","to":"url","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":120,"wires":[["8ae26b9fe21b8597"]]},{"id":"8ae26b9fe21b8597","type":"http request","z":"8c07c84c901460eb","name":"GET URL Audio","method":"GET","ret":"bin","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":840,"y":180,"wires":[["716f7a75d6b0720c"]]},{"id":"716f7a75d6b0720c","type":"watson-speech-to-text","z":"8c07c84c901460eb","name":"","alternatives":1,"speakerlabels":true,"smartformatting":false,"lang":"pt-BR","langhidden":"pt-BR","langcustom":"NoCustomisationSetting","langcustomhidden":"","custom-weight":"0.5","band":"NarrowbandModel","bandhidden":"NarrowbandModel","keywords":"","keywords-threshold":"0.5","word-confidence":false,"password":"","apikey":"Jegc_ewvuqESEdef65wJUPjaT_39TlAAMxIZElUFEH4H","payload-response":true,"streaming-mode":false,"streaming-mute":true,"auto-connect":false,"discard-listening":false,"disable-precheck":false,"service-endpoint":"https://api.us-south.speech-to-text.watson.cloud.ibm.com/instances/94e42c1e-33c9-4a78-8747-3f8b95f5277a","x":840,"y":240,"wires":[["24ebd36b.04d1e4"]]},{"id":"5a0b5809c2ab5afa","type":"watson-text-to-speech","z":"8c07c84c901460eb","name":"","lang":"pt-BR","langhidden":"pt-BR","langcustom":"NoCustomisationSetting","langcustomhidden":"","voice":"pt-BR_IsabelaV3Voice","voicehidden":"pt-BR_IsabelaV3Voice","format":"audio/ogg; codecs=opus","password":"","apikey":"0oqR26ZhJeLA6tK6rA8ZnP9MaWBnLY6uY8FfLZIGM_CN","payload-response":true,"service-endpoint":"https://api.us-south.text-to-speech.watson.cloud.ibm.com/instances/0135093c-20b6-4d86-8c23-1f6b8fe072a7","x":880,"y":480,"wires":[["b242e40d33b392b5"]]},{"id":"75c4f2320d83605c","type":"change","z":"8c07c84c901460eb","name":"Restaura estado","rules":[{"t":"move","p":"payload","pt":"msg","to":"telegram.content","tot":"msg"},{"t":"set","p":"telegram.type","pt":"msg","to":"message","tot":"str"},{"t":"move","p":"telegram","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"history","pt":"flow","to":"history","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":700,"wires":[["106e3553196519f9"]]},{"id":"043689058277f981","type":"debug","z":"8c07c84c901460eb","name":"debug 10","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1120,"y":260,"wires":[]},{"id":"802e8986a91412bf","type":"telegram bot","botname":"diaana_bot","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksprotocol":"socks5","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","botpath":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false}]
Created 2 years, 9 months ago
Rating: 5 1
  • change (x4)
  • function (x5)
  • http request (x1)
  • switch (x2)
  • Telegram
  • IBMWatson
  • WatsonAssistant
  • WatsonSTT
  • WatsonTTS
  • WatsonTranslator
  • AI
  • NLP
