Get Devices - Ikea Home smart - Dirigera
This is an Unofficial Proof of concept to link the new Ikea Dirigera gateway with Node-Red
Based on https://github.com/mattias73andersson/dirigera-client-poc
...and remember, this is proof-of-concept to test the local interface of the IKEA Dirigera gateway. Allows simple control of a light (On/Off,Dim) and an Outlet (On/Off)
The purpose was just to see if it was possible to connect to the gateway. There's not much error checking
Other endpoints of the Dirigera gateway can be found by decompiling the IKEA Smart Home App. Totally unofficial, not affiliated with IKEA in any way.
[{"id":"a0cf3fb6bfd251c5","type":"tab","label":"Dirigera Proof of concept ","disabled":false,"info":"Proof of concept to link Dirigera Hub with Node-Red\n\nBased on https://github.com/mattias73andersson/dirigera-client-poc\n","env":[]},{"id":"1fbd9c480caef5b2","type":"group","z":"a0cf3fb6bfd251c5","name":"Get Authentication Token","style":{"stroke":"#0070c0","fill":"#ffffbf","label":true,"label-position":"n","color":"#0070c0"},"nodes":["a61c8273af0e0587","4efe7e84ff28e2af","fe3e9c2b6ea4cbf9","cd485db1810bce8c","2192938724486b81","a06ffce08fefea60","bc6a5e643c471d4f","bdb11fa9321a05ce","2a1e5b6fb94fceb3","9c6fd4055a360814","e8b498a728ae58ed","c01859a5aa79644b","4bdc89b5157374e2","4070d5d653cf174a","d5ccd7f986d79e34","3cd515a8d5156bb4","60844753b6101e43","feb5d902c9976fa1","c066a33ea56157f3","684b0a3a0ca9806a","fab37d011216ee7e","65f4b7f1cfe37209","ab6ea2497fc0536a"],"x":54,"y":39,"w":1692,"h":382},{"id":"271885d7e12005ea","type":"group","z":"a0cf3fb6bfd251c5","name":"Build Device Object (used in control flows below)","style":{"stroke":"#0070c0","fill":"#ffffbf","label":true,"label-position":"n","color":"#0070c0"},"nodes":["2235593008aada8d","261b4c65e7f3595a","bf8a16452be0edd4","36a0b40741a12650","f67c395cf5424748","aeb83352d3322310"],"x":74,"y":479,"w":1612,"h":82},{"id":"a655cfd1dd64e9fa","type":"group","z":"a0cf3fb6bfd251c5","name":"Control Devices / Get info from Hub","style":{"stroke":"#ffff00","fill":"#bfdbef","label":true,"label-position":"n","color":"#0070c0"},"nodes":["5f8f29931f7b2a0b","07cfb580b6453288","301cf90c89e39b1b","fe5836c181e9585c","0402b8474932f07d","832a8c846e69800d","d9e55eacd765eee5","a7c5c0c45fe0437f","ef0e098535e400fe","8077493bb2f87d96","41c4d9b78cb2a6f3","7ffbc53e8a65e9f8","7d0837807afd9091","9a95a0a8172869b0","ce8c1f452c2b3195","bf46f2b3705f563a","f9047fc778b2d706","fa8f13238310b8ef","7f236f109ca63411"],"x":94,"y":719,"w":1552,"h":622},{"id":"a61c8273af0e0587","type":"http request","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","method":"GET","ret":"obj","paytoqs":"query","url":"https://192.168.0.168:8443/v1/oauth/authorize","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[{"keyType":"other","keyValue":"Content-Type","valueType":"other","valueValue":"application/x-www-form-urlencoded"}],"x":830,"y":220,"wires":[["cd485db1810bce8c","4070d5d653cf174a"]]},{"id":"4efe7e84ff28e2af","type":"debug","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"debug 22","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1640,"y":220,"wires":[]},{"id":"fe3e9c2b6ea4cbf9","type":"function","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"function 15","func":"//code_challenge = Buffer.from( msg.payload ).toString('base64url')\nmsg.ip=flow.get(\"dirigeraIP\")\n\n\nmsg.url= \"https://\"+msg.ip+\":8443/v1/oauth/authorize\"\n\n\n\n\n\n\n\n\ncode_challenge = msg.payload \n\nnode.warn(\"BASE64 \"+code_challenge)\n\n\nmsg.payload= {}\n\n\nmsg.payload.audience= \"homesmart.local\"\nmsg.payload.response_type= \"code\"\nmsg.payload.code_challenge= code_challenge\nmsg.payload.code_challenge_method= \"S256\"\n\n\nmsg.rejectUnauthorized = false\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":220,"wires":[["a61c8273af0e0587","d5ccd7f986d79e34"]]},{"id":"cd485db1810bce8c","type":"switch","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","property":"payload.code","propertyType":"msg","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":1030,"y":220,"wires":[["2192938724486b81"]]},{"id":"2192938724486b81","type":"change","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","rules":[{"t":"set","p":"dirigeraResponseCode","pt":"flow","to":"payload.code","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1230,"y":220,"wires":[["a06ffce08fefea60"]]},{"id":"a06ffce08fefea60","type":"change","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"'Wait for button pressed (actionbutton on Dirigera)...'","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1480,"y":220,"wires":[["4efe7e84ff28e2af"]]},{"id":"bc6a5e643c471d4f","type":"inject","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"4) Click after pressing Dirigera Action Button (on base)","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":300,"y":380,"wires":[["bdb11fa9321a05ce"]]},{"id":"bdb11fa9321a05ce","type":"function","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"function 16","func":"msg.ip=flow.get(\"dirigeraIP\")\n\n\nmsg.url= \"https://\"+msg.ip+\":8443/v1/oauth/token\"\n\n\n\ndirigeraResponseCode = flow.get(\"dirigeraResponseCode\")\nhostname=flow.get(\"hostname\")\n\ncodeVerifier = flow.get(\"Dirigera128Code\")\nnode.warn(\"Cv\" + codeVerifier)\n\nmsg.rejectUnauthorized = false\n\nmsg.payload = \"code=\" + dirigeraResponseCode\nmsg.payload += \"&name=\" + hostname\nmsg.payload += \"&grant_type=authorization_code\"\nmsg.payload += \"&code_verifier=\" + codeVerifier\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":380,"wires":[["9c6fd4055a360814"]]},{"id":"2a1e5b6fb94fceb3","type":"debug","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"debug 26","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.access_token","targetType":"msg","statusVal":"","statusType":"auto","x":1300,"y":380,"wires":[]},{"id":"9c6fd4055a360814","type":"http request","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","method":"POST","ret":"obj","paytoqs":"body","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[{"keyType":"other","keyValue":"Content-Type","valueType":"other","valueValue":"application/x-www-form-urlencoded"}],"x":790,"y":380,"wires":[["ab6ea2497fc0536a"]]},{"id":"e8b498a728ae58ed","type":"debug","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"digest","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":550,"y":280,"wires":[]},{"id":"c01859a5aa79644b","type":"function","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"function 18","func":"\nCodeAlphabet = \"ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789-._~\"\nCodeLength = 128\n\nfunction generateRandomLetter() {\n    //node.warn(\"random\")\n    return CodeAlphabet[Math.floor(Math.random() * CodeAlphabet.length)]\n}\n\nfunction getCodeVerifier() {\n\n    //node.warn(\"getCodeVerifier\")\n    s = \"\"\n    for (let i = 0; i < CodeLength; i++) {\n        s += generateRandomLetter()\n    }\n    return s\n}\n\n//var crypto = require('crypto');\n\ns=getCodeVerifier ()\n\nflow.set(\"Dirigera128Code\", s); \n\nmsg.payload = crypto.createHash('sha256').update(s).digest('base64').replace(/=+$/, \"\");\n\nmsg.payload = msg.payload.replace(/\\+/g, '-').replace(/\\//g, '_').replace(/=+$/, '');\n\n\n\nnode.warn(\"DIGEST\"+msg.payload)\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"crypto","module":"crypto"}],"x":430,"y":220,"wires":[["e8b498a728ae58ed","fe3e9c2b6ea4cbf9"]]},{"id":"4bdc89b5157374e2","type":"inject","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"3) Start Authentication","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":220,"wires":[["c01859a5aa79644b"]]},{"id":"4070d5d653cf174a","type":"debug","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"debug 27","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1020,"y":280,"wires":[]},{"id":"d5ccd7f986d79e34","type":"debug","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"debug 28","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":780,"y":280,"wires":[]},{"id":"3cd515a8d5156bb4","type":"inject","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"1) Add Dirigera IP address to function node","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":80,"wires":[["fab37d011216ee7e"]]},{"id":"60844753b6101e43","type":"debug","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"debug 29","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.hostname","targetType":"msg","statusVal":"","statusType":"auto","x":1200,"y":140,"wires":[]},{"id":"feb5d902c9976fa1","type":"OS","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","x":410,"y":140,"wires":[["684b0a3a0ca9806a"]]},{"id":"c066a33ea56157f3","type":"inject","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"2) Determine hostname","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":140,"wires":[["feb5d902c9976fa1"]]},{"id":"684b0a3a0ca9806a","type":"change","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","rules":[{"t":"set","p":"hostname","pt":"flow","to":"payload.hostname","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":140,"wires":[["60844753b6101e43"]]},{"id":"fab37d011216ee7e","type":"function","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"function 19","func":"msg.ip = \"ADD IP ADDRESS HERE\" // e.g. \"192.168.0.2\"\nmsg.ip = \"192.168.0.168\"\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":570,"y":80,"wires":[["65f4b7f1cfe37209"]]},{"id":"65f4b7f1cfe37209","type":"change","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","rules":[{"t":"set","p":"dirigeraIP","pt":"flow","to":"ip","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":80,"wires":[[]]},{"id":"ab6ea2497fc0536a","type":"change","z":"a0cf3fb6bfd251c5","g":"1fbd9c480caef5b2","name":"","rules":[{"t":"set","p":"dirigeraAccess_token","pt":"global","to":"payload.access_token","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":380,"wires":[["2a1e5b6fb94fceb3"]]},{"id":"5f8f29931f7b2a0b","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"devices","payloadType":"str","x":230,"y":1120,"wires":[["0402b8474932f07d"]]},{"id":"07cfb580b6453288","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"hub/status","payloadType":"str","x":240,"y":1180,"wires":[["0402b8474932f07d"]]},{"id":"301cf90c89e39b1b","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"scenes","payloadType":"str","x":230,"y":1240,"wires":[["0402b8474932f07d"]]},{"id":"fe5836c181e9585c","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"music","payloadType":"str","x":230,"y":1300,"wires":[["0402b8474932f07d"]]},{"id":"0402b8474932f07d","type":"function","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"function 25","func":"dirigeraAccess_token=global.get(\"dirigeraAccess_token\")\n\nmsg.rejectUnauthorized = false\n\nmsg.ip=flow.get(\"dirigeraIP\")\n\n\nmsg.url= \"https://\"+msg.ip+\":8443/v1/\"+msg.payload\n\n\n\nmsg.headers = { \"Authorization\": \"Bearer \"+dirigeraAccess_token}\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":570,"y":1180,"wires":[["832a8c846e69800d"]]},{"id":"832a8c846e69800d","type":"http request","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":790,"y":1180,"wires":[["a7c5c0c45fe0437f"]]},{"id":"d9e55eacd765eee5","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"home","payloadType":"str","x":230,"y":1060,"wires":[["0402b8474932f07d"]]},{"id":"a7c5c0c45fe0437f","type":"debug","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"debug 35","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1040,"y":1180,"wires":[]},{"id":"2235593008aada8d","type":"inject","z":"a0cf3fb6bfd251c5","g":"271885d7e12005ea","name":"5) Build device ID flow ","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"devices","payloadType":"str","x":220,"y":520,"wires":[["261b4c65e7f3595a"]]},{"id":"261b4c65e7f3595a","type":"function","z":"a0cf3fb6bfd251c5","g":"271885d7e12005ea","name":"function 28","func":"dirigeraAccess_token=global.get(\"dirigeraAccess_token\")\n\nmsg.rejectUnauthorized = false\n\nmsg.ip=flow.get(\"dirigeraIP\")\n\n\nmsg.url= \"https://\"+msg.ip+\":8443/v1/\"+msg.payload\n\n\n\nmsg.headers = { \"Authorization\": \"Bearer \"+dirigeraAccess_token}\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":520,"wires":[["bf8a16452be0edd4"]]},{"id":"bf8a16452be0edd4","type":"http request","z":"a0cf3fb6bfd251c5","g":"271885d7e12005ea","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":730,"y":520,"wires":[["f67c395cf5424748"]]},{"id":"36a0b40741a12650","type":"debug","z":"a0cf3fb6bfd251c5","g":"271885d7e12005ea","name":"debug 37","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1580,"y":520,"wires":[]},{"id":"f67c395cf5424748","type":"function","z":"a0cf3fb6bfd251c5","g":"271885d7e12005ea","name":"function 29","func":"connectedDevices ={}\n \n    for (index = 0; index < msg.payload.length; index++)\n    {\n       deviceAttributes = {}\n       \n       deviceType=msg.payload[index].type\n       \n      \n       if (!connectedDevices.hasOwnProperty(deviceType)) {\n           connectedDevices[deviceType]=[]\n       }\n     \n     deviceAttributes.id = msg.payload[index].id\n     deviceAttributes.customName = msg.payload[index].attributes.customName\n     \n       \n       connectedDevices[deviceType].push(deviceAttributes);\n    }\n\n\n\nmsg.payload = connectedDevices\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1110,"y":520,"wires":[["aeb83352d3322310"]]},{"id":"aeb83352d3322310","type":"change","z":"a0cf3fb6bfd251c5","g":"271885d7e12005ea","name":"","rules":[{"t":"set","p":"connectedDevices","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":520,"wires":[["36a0b40741a12650"]]},{"id":"ef0e098535e400fe","type":"function","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"function 23","func":"dirigeraAccess_token=global.get(\"dirigeraAccess_token\")\n\nmsg.ip=flow.get(\"dirigeraIP\")\n\nconnectedDevices=flow.get(\"connectedDevices\")\n\nmsg.device= connectedDevices.light[0]\n\nmsg.url= \"https://\"+msg.ip+\":8443/v1/devices/\"+msg.device.id\n\nmsg.rejectUnauthorized = false\n\nmsg.method=\"PATCH\"\nmsg.method.toUpperCase()\n\nmsg.headers = { \"Authorization\": \"Bearer \"+dirigeraAccess_token}\n\nmsg.payload =[]\nmsg.payload[0] ={}\nmsg.payload[0].attributes ={}\nmsg.payload[0].attributes.isOn = true\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":760,"wires":[["ce8c1f452c2b3195"]]},{"id":"8077493bb2f87d96","type":"http request","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"","method":"use","ret":"txt","paytoqs":"query","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":1250,"y":760,"wires":[["7ffbc53e8a65e9f8"]]},{"id":"41c4d9b78cb2a6f3","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"Turn On Light","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":230,"y":760,"wires":[["ef0e098535e400fe"]]},{"id":"7ffbc53e8a65e9f8","type":"debug","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"debug 33","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1540,"y":760,"wires":[]},{"id":"7d0837807afd9091","type":"function","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"function 27","func":"dirigeraAccess_token=global.get(\"dirigeraAccess_token\")\n\nmsg.ip=flow.get(\"dirigeraIP\")\n\nconnectedDevices=flow.get(\"connectedDevices\")\n\nmsg.device= connectedDevices.light[0]\n\nmsg.url= \"https://\"+msg.ip+\":8443/v1/devices/\"+msg.device.id\n\nmsg.rejectUnauthorized = false\n\nmsg.method=\"PATCH\"\nmsg.method.toUpperCase()\n\nmsg.headers = { \"Authorization\": \"Bearer \"+dirigeraAccess_token}\n\nmsg.payload =[]\nmsg.payload[0] ={}\nmsg.payload[0].attributes={}\n\nmsg.payload[0].attributes.lightLevel = 35\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":840,"wires":[["ce8c1f452c2b3195"]]},{"id":"9a95a0a8172869b0","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"Dim Light","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":840,"wires":[["7d0837807afd9091"]]},{"id":"ce8c1f452c2b3195","type":"switch","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"Check if device is in array","property":"device","propertyType":"msg","rules":[{"t":"hask","v":"id","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":930,"y":760,"wires":[["8077493bb2f87d96"],[]]},{"id":"bf46f2b3705f563a","type":"function","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"function 30","func":"dirigeraAccess_token=global.get(\"dirigeraAccess_token\")\n\nmsg.ip=flow.get(\"dirigeraIP\")\n\nconnectedDevices=flow.get(\"connectedDevices\")\n\nmsg.device= connectedDevices.outlet[0]\n\nmsg.url= \"https://\"+msg.ip+\":8443/v1/devices/\"+msg.device.id\n\nmsg.rejectUnauthorized = false\n\nmsg.method=\"PATCH\"\nmsg.method.toUpperCase()\n\nmsg.headers = { \"Authorization\": \"Bearer \"+dirigeraAccess_token}\n\nmsg.payload =[]\nmsg.payload[0] ={}\nmsg.payload[0].attributes ={}\nmsg.payload[0].attributes.isOn = true\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":920,"wires":[["ce8c1f452c2b3195"]]},{"id":"f9047fc778b2d706","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"Turn On Socket","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":240,"y":920,"wires":[["bf46f2b3705f563a"]]},{"id":"fa8f13238310b8ef","type":"function","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"function 31","func":"dirigeraAccess_token=global.get(\"dirigeraAccess_token\")\n\nmsg.ip=flow.get(\"dirigeraIP\")\n\nconnectedDevices=flow.get(\"connectedDevices\")\n\nmsg.device= connectedDevices.outlet[0]\n\nmsg.url= \"https://\"+msg.ip+\":8443/v1/devices/\"+msg.device.id\n\nmsg.rejectUnauthorized = false\n\nmsg.method=\"PATCH\"\nmsg.method.toUpperCase()\n\nmsg.headers = { \"Authorization\": \"Bearer \"+dirigeraAccess_token}\n\nmsg.payload =[]\nmsg.payload[0] ={}\nmsg.payload[0].attributes ={}\nmsg.payload[0].attributes.isOn = false\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":980,"wires":[["ce8c1f452c2b3195"]]},{"id":"7f236f109ca63411","type":"inject","z":"a0cf3fb6bfd251c5","g":"a655cfd1dd64e9fa","name":"Turn Off Socket","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":980,"wires":[["fa8f13238310b8ef"]]}]
Created 4 years, 2 months ago
  • change (x6)
  • debug (x9)
  • function (x11)
  • http request (x5)
  • inject (x14)
  • switch (x2)
  • OS (x1)
  • group (x3)
