Monitoring and controller Pump Station
Monitoring and controller Pump Station project mini use Delta PLC DVP 12SE . Interface modbus
[{"id":"b25bb5b8.fbec98","type":"tab","label":"Controller","disabled":false,"info":"Modbus serverIP address:192.168.1.10 port 502, you have to use yours\nPLC bits and coils: M, X, Y.\nPLC registers: D, T, C.\nFunctions: FC1, FC2, FC3."},{"id":"51c6c4df.a6893c","type":"tab","label":"Pump Station","disabled":false,"info":""},{"id":"798e3124.c0ca8","type":"modbus-client","name":"modbus TCP client","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.1.39","tcpPort":"6000","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":false,"reconnectTimeout":"2000","parallelUnitIdsAllowed":false},{"id":"45be09fc.842b38","type":"ui_group","name":"Server","tab":"","order":1,"disp":true,"width":"6","collapse":false},{"id":"943bcf0f.6a904","type":"ui_base","theme":{"name":"theme-dark","lightTheme":{"default":"#0094CE","baseColor":"#cc6300","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#f78b26","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#097479","value":"#f78b26","edited":true},"page-titlebar-backgroundColor":{"value":"#f78b26","edited":false},"page-backgroundColor":{"value":"#111111","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#fab270","edited":false},"group-borderColor":{"value":"#555555","edited":false},"group-backgroundColor":{"value":"#333333","edited":false},"widget-textColor":{"value":"#eeeeee","edited":false},"widget-backgroundColor":{"value":"#f78b26","edited":false},"widget-borderColor":{"value":"#333333","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey"}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","lockMenu":"false","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"ac63ef8c.32c11","type":"MC Protocol Connection","name":"","host":"192.168.1.39","port":"6000","protocol":"TCP","frame":"3E","plcType":"Q","ascii":false,"PLCStation":"","PCStation":"","PLCModuleNo":"","network":"","octalInputOutput":false},{"id":"59987088.b0836","type":"PLC MC config","name":"misubishi","host":"192.168.1.39","port":"6000"},{"id":"1f5894f7.5861bb","type":"ui_group","name":"Simulated Operator's Panel","tab":"","order":2,"disp":true,"width":"6","collapse":false},{"id":"d6caabb5.09a3d8","type":"ui_group","name":"Simulation Outputs","tab":"","order":3,"disp":true,"width":"6","collapse":false},{"id":"8b42adca.7805b","type":"ui_group","name":"Default","tab":"","order":1,"disp":false,"width":"6","collapse":false},{"id":"583f4d36.50aae4","type":"eth-ip endpoint","address":"192.168.98.1","slot":"0","cycletime":"100","name":"","vartable":{"":{"Local:3:O.Data.0":{"type":"BOOL"},"Local:3:O.Data.1":{"type":"BOOL"},"Local:3:O.Data.2":{"type":"BOOL"},"Local:3:O.Data.3":{"type":"BOOL"},"Local:2:I.Data.0":{"type":"BOOL"},"Local:2:I.Data.1":{"type":"BOOL"},"Local:2:I.Data.2":{"type":"BOOL"},"Local:2:I.Data.3":{"type":"BOOL"},"Local:2:I.Data.4":{"type":"BOOL"},"Local:2:I.Data.5":{"type":"BOOL"},"Local:2:I.Data.6":{"type":"BOOL"},"Local:2:I.Data.7":{"type":"BOOL"},"Local:2:I.Data.8":{"type":"BOOL"},"Local:2:I.Data.9":{"type":"BOOL"},"Local:2:I.Data.10":{"type":"BOOL"},"Local:2:I.Data.11":{"type":"BOOL"},"Local:2:I.Data.12":{"type":"BOOL"},"Local:2:I.Data.13":{"type":"BOOL"},"Local:2:I.Data.14":{"type":"BOOL"},"Local:2:I.Data.15":{"type":"BOOL"},"Local:2:I.Data.16":{"type":"BOOL"},"Local:4:I.Ch0Data":{"type":"REAL"}}}},{"id":"c9dd4a4b.74b4e8","type":"modbus-client","name":"modbus TCP client","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"tcpHost":"192.168.0.24","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectTimeout":"2000"},{"id":"b81936bb.a4e838","type":"ui_group","name":"Controler","tab":"80f737c5.0293f8","order":1,"disp":true,"width":"6","collapse":false},{"id":"80f737c5.0293f8","type":"ui_tab","name":"Home","icon":"dashboard"},{"id":"423dc5ec.a6a4fc","type":"ui_group","name":"Pump Station","tab":"80f737c5.0293f8","order":2,"disp":true,"width":"6","collapse":false},{"id":"a2e0dbf6.f0d768","type":"ui_button","z":"b25bb5b8.fbec98","name":"","group":"b81936bb.a4e838","order":6,"width":0,"height":0,"passthru":false,"label":"Start Pump","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":210,"y":140,"wires":[["59617d92.4d8354"]]},{"id":"59617d92.4d8354","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write m10 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2058","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":420,"y":140,"wires":[[],[]]},{"id":"ac7be418.61c398","type":"ui_button","z":"b25bb5b8.fbec98","name":"","group":"b81936bb.a4e838","order":7,"width":0,"height":0,"passthru":false,"label":"Stop Pump","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":200,"y":200,"wires":[["2cf454d9.cf4cec"]]},{"id":"2cf454d9.cf4cec","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write m11 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2059","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":410,"y":200,"wires":[[],[]]},{"id":"bf602680.204db8","type":"ui_button","z":"b25bb5b8.fbec98","name":"","group":"b81936bb.a4e838","order":8,"width":0,"height":0,"passthru":false,"label":"Start solenoild","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":210,"y":280,"wires":[["22e39963.cc60a6"]]},{"id":"22e39963.cc60a6","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write m16 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2064","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":410,"y":280,"wires":[[],[]]},{"id":"6790338.ef6cbcc","type":"ui_button","z":"b25bb5b8.fbec98","name":"","group":"b81936bb.a4e838","order":9,"width":0,"height":0,"passthru":false,"label":"Stop Solenoild","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":210,"y":360,"wires":[["42de3ecd.468f6"]]},{"id":"42de3ecd.468f6","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write m17 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2065","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":410,"y":360,"wires":[[],[]]},{"id":"e051852b.342178","type":"modbus-read","z":"b25bb5b8.fbec98","name":"Y0 lamp pump","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"1280","quantity":"1","rate":"500","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"c9dd4a4b.74b4e8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":220,"y":480,"wires":[["b352b262.01245"],["c9110af6.1c7868"]]},{"id":"c9110af6.1c7868","type":"modbus-response","z":"b25bb5b8.fbec98","name":"","registerShowMax":20,"x":440,"y":520,"wires":[]},{"id":"b352b262.01245","type":"ui_led","z":"b25bb5b8.fbec98","group":"b81936bb.a4e838","order":11,"width":0,"height":0,"label":"Pump","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"red","value":"false","valueType":"bool"},{"color":"green","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":440,"y":480,"wires":[]},{"id":"38ef5223.86211e","type":"modbus-read","z":"b25bb5b8.fbec98","name":"Y1 lamp solenoild","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"1281","quantity":"1","rate":"500","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"c9dd4a4b.74b4e8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":240,"y":660,"wires":[["1de811ca.39e7be"],["c1acd894.614d28"]]},{"id":"c1acd894.614d28","type":"modbus-response","z":"b25bb5b8.fbec98","name":"","registerShowMax":20,"x":520,"y":700,"wires":[]},{"id":"1de811ca.39e7be","type":"ui_led","z":"b25bb5b8.fbec98","group":"b81936bb.a4e838","order":12,"width":0,"height":0,"label":"Solenoild","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"red","value":"false","valueType":"bool"},{"color":"green","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":500,"y":640,"wires":[]},{"id":"24dbbc5b.bb82d4","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write d580 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4676","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":780,"wires":[[],[]]},{"id":"eb237883.72ca68","type":"ui_numeric","z":"b25bb5b8.fbec98","name":"","label":"Set hight level","tooltip":"","group":"b81936bb.a4e838","order":0,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":210,"y":786,"wires":[["24dbbc5b.bb82d4"]]},{"id":"b553cad.8a88f38","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write d582 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4678","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":840,"wires":[[],[]]},{"id":"c1499f4.0bd2e6","type":"ui_numeric","z":"b25bb5b8.fbec98","name":"","label":"Set low level","tooltip":"","group":"b81936bb.a4e838","order":0,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":200,"y":846,"wires":[["b553cad.8a88f38"]]},{"id":"a48adb7c.dfd008","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write d310 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4406","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":920,"wires":[[],[]]},{"id":"87be16b5.95ab18","type":"ui_numeric","z":"b25bb5b8.fbec98","name":"","label":"Tần số","tooltip":"","group":"b81936bb.a4e838","order":0,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":180,"y":926,"wires":[["a48adb7c.dfd008"]]},{"id":"c50edbcc.af0098","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write d502 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4598","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":980,"wires":[[],[]]},{"id":"6fe7805b.3ef11","type":"ui_numeric","z":"b25bb5b8.fbec98","name":"","label":"Kp","tooltip":"","group":"b81936bb.a4e838","order":0,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":180,"y":986,"wires":[["c50edbcc.af0098"]]},{"id":"1d57eb70.607335","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write d504 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4600","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":440,"y":1040,"wires":[[],[]]},{"id":"4afe3c71.51ddf4","type":"ui_numeric","z":"b25bb5b8.fbec98","name":"","label":"Ti","tooltip":"","group":"b81936bb.a4e838","order":0,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":180,"y":1046,"wires":[["1d57eb70.607335"]]},{"id":"e1b86b4.56d9498","type":"modbus-write","z":"b25bb5b8.fbec98","name":"write d506 register","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4602","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":420,"y":1100,"wires":[[],[]]},{"id":"18a310b9.746cff","type":"ui_numeric","z":"b25bb5b8.fbec98","name":"","label":"Td","tooltip":"","group":"b81936bb.a4e838","order":0,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"","format":"{{value}}","min":0,"max":"1000","step":1,"x":160,"y":1106,"wires":[["e1b86b4.56d9498"]]},{"id":"c45d2bc5.547fc8","type":"modbus-read","z":"b25bb5b8.fbec98","name":"M90 connect station pump","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2138","quantity":"1","rate":"500","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"c9dd4a4b.74b4e8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":221,"y":1198,"wires":[["414633d5.f7768c"],["6f871386.8cf8ac"]]},{"id":"6f871386.8cf8ac","type":"modbus-response","z":"b25bb5b8.fbec98","name":"","registerShowMax":20,"x":481,"y":1238,"wires":[]},{"id":"414633d5.f7768c","type":"ui_led","z":"b25bb5b8.fbec98","group":"b81936bb.a4e838","order":12,"width":0,"height":0,"label":"Connect","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"red","value":"false","valueType":"bool"},{"color":"green","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"","x":421,"y":1178,"wires":[]},{"id":"ae71653e.51a438","type":"modbus-read","z":"51c6c4df.a6893c","name":"D700","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4796","quantity":"1","rate":"500","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"c9dd4a4b.74b4e8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":630,"y":140,"wires":[["499fae43.4a6af"],["2199a37e.7dc95c"]]},{"id":"2199a37e.7dc95c","type":"modbus-response","z":"51c6c4df.a6893c","name":"","registerShowMax":20,"x":948,"y":121,"wires":[]},{"id":"499fae43.4a6af","type":"ui_gauge","z":"51c6c4df.a6893c","name":"","group":"423dc5ec.a6a4fc","order":7,"width":0,"height":0,"gtype":"gage","title":"Temperature","label":"units","format":"{{value}}","min":0,"max":"1000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":950,"y":180,"wires":[]},{"id":"2325163b.7d1a7a","type":"ui_button","z":"51c6c4df.a6893c","name":"","group":"423dc5ec.a6a4fc","order":1,"width":0,"height":0,"passthru":false,"label":"Pump On","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":140,"y":60,"wires":[["89df0a18.69eac8"]]},{"id":"89df0a18.69eac8","type":"modbus-write","z":"51c6c4df.a6893c","name":"write m20 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2068","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":360,"y":60,"wires":[[],[]]},{"id":"63d28f92.edbb3","type":"ui_button","z":"51c6c4df.a6893c","name":"","group":"423dc5ec.a6a4fc","order":2,"width":0,"height":0,"passthru":false,"label":"Pump Off","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":130,"y":120,"wires":[["2ed0258a.8cd9fa"]]},{"id":"2ed0258a.8cd9fa","type":"modbus-write","z":"51c6c4df.a6893c","name":"write m21 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2069","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":350,"y":120,"wires":[[],[]]},{"id":"873bff94.ebaa","type":"ui_button","z":"51c6c4df.a6893c","name":"","group":"423dc5ec.a6a4fc","order":3,"width":0,"height":0,"passthru":false,"label":"Lamp On","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":130,"y":200,"wires":[["7e9e55c.fced3ac"]]},{"id":"7e9e55c.fced3ac","type":"modbus-write","z":"51c6c4df.a6893c","name":"write m22 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2070","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":350,"y":200,"wires":[[],[]]},{"id":"d936d6b3.efe148","type":"ui_button","z":"51c6c4df.a6893c","name":"","group":"423dc5ec.a6a4fc","order":4,"width":0,"height":0,"passthru":false,"label":"Lamp Off","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":130,"y":280,"wires":[["e866cc6d.8abae"]]},{"id":"e866cc6d.8abae","type":"modbus-write","z":"51c6c4df.a6893c","name":"write m23 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2071","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":350,"y":280,"wires":[[],[]]},{"id":"26021c9b.d7b7d4","type":"ui_button","z":"51c6c4df.a6893c","name":"","group":"423dc5ec.a6a4fc","order":5,"width":0,"height":0,"passthru":false,"label":"Fan On","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":140,"y":360,"wires":[["d1b3a23a.529ea"]]},{"id":"d1b3a23a.529ea","type":"modbus-write","z":"51c6c4df.a6893c","name":"write m24 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2072","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":360,"y":360,"wires":[[],[]]},{"id":"151dd7c6.430738","type":"ui_button","z":"51c6c4df.a6893c","name":"","group":"423dc5ec.a6a4fc","order":6,"width":0,"height":0,"passthru":false,"label":"Fan Off","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":140,"y":440,"wires":[["1fb6fdb7.121d32"]]},{"id":"1fb6fdb7.121d32","type":"modbus-write","z":"51c6c4df.a6893c","name":"write m25 bit","showStatusActivities":true,"showErrors":true,"unitid":"1","dataType":"Coil","adr":"2073","quantity":"1","server":"c9dd4a4b.74b4e8","emptyMsgOnFail":false,"keepMsgProperties":false,"x":360,"y":440,"wires":[[],[]]},{"id":"993cb229.2cbfa","type":"modbus-read","z":"51c6c4df.a6893c","name":"D702","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"1","dataType":"HoldingRegister","adr":"4798","quantity":"1","rate":"500","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"c9dd4a4b.74b4e8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":610,"y":320,"wires":[["a2bd41e6.1eda7"],["c961100c.b8d27"]]},{"id":"c961100c.b8d27","type":"modbus-response","z":"51c6c4df.a6893c","name":"","registerShowMax":20,"x":928,"y":301,"wires":[]},{"id":"a2bd41e6.1eda7","type":"ui_gauge","z":"51c6c4df.a6893c","name":"","group":"423dc5ec.a6a4fc","order":8,"width":0,"height":0,"gtype":"gage","title":"Humidity","label":"units","format":"{{value}}","min":0,"max":"1000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":920,"y":360,"wires":[]}]
Created 5 years, 1 month ago
  • MC Protocol Connection (x1)
  • PLC MC config (x1)
  • eth-ip endpoint (x1)
  • modbus-client (x2)
  • modbus-read (x5)
  • modbus-response (x5)
  • modbus-write (x16)
  • tab (x2)
  • ui_base (x1)
  • ui_button (x10)
  • ui_gauge (x2)
  • ui_group (x6)
  • ui_led (x3)
  • ui_numeric (x6)
  • Delta
  • plc
  • DPV
  • 12SE
  • Modbus
