node-red-contrib-mcprotocol 1.2.1
Mode-red nodes to Read from & Write to MITSUBISHI PLC over Ethernet using MC Protocol
npm install node-red-contrib-mcprotocol
About
Overview
This is a Node-RED node module to directly interface with MITSUBISHI PLCs over Ethernet using MC Protocol.
  • Both TCP and UDP connections are possible
  • frames 1E, 3E and 4E are possible
  • works for PLC types
    • A (See Note 1)
    • QnA
    • Q
    • L
    • R
  • ASCII and BINARY mode (See Note 2)
Recommendation
If your PLC suports UDP + 4E, this is by far most reliable.
NOTES
  1. For A series PLC, only 1E frames are supported
  2. ASCII mode is currently not supported for frames 3E and 4E
Prerequisites
  • node.js (runtime for Node-RED)
  • Node-RED
  • [optional] git (Used for repository cloning/downloads)
Easy install
Use the Manage Palette > Install option from the menu inside node-red
NPM install
GIT install Direct
npm install Steve-Mcl/node-red-contrib-mcprotocol
GIT Install
Make a directory for the base files on the disk (somewhere secure) and open the created folder and open PowerShell (SHIFT + right_click) or "Git Bash Here" with right mouse inside the folder. Now enter the following:
cd c:/tempsourcefolder
git clone https://github.com/Steve-Mcl/node-red-contrib-mcprotocol.git
npm install c:/tempsourcefolder/node-red-contrib-mcprotocol
Credits
  • plcpeople for the original implementation of mcprotocol
Version: 1.2.1
Updated 6 years, 3 months ago
Rating: 4.0 12
119 in the last week
  • MC Read
  • MC Write
  • MC Protocol Connection
  • MITSUBISHI
  • MC PROTOCOL
  • MELSEC
  • PLC
