Network Monitoring / latency/Rack Status Dashboard V2
This is the updated version of flow(https://flows.nodered.org/flow/ed47511832dfd79d6bf416f6a8a056da) As recent updates in node-js version now ui-led node disappearing from ui...
This new flow uses different ui-led package and added rack status indicator using CSS template.
Tested on Windows system
Node-RED version: v1.0.6 Latest
Node.js version: v12.18.0 LTS Latest
Note-- first remove node-red-contrib-ui-led package and install node-red-contrib-ui-led-fork 0.3.1
Output-https://github.com/vaibhavarduino/Automate-with-Node-Red-/blob/master/PING_Network_Latency_Status_Dashboard_V2.jpg
[{"id":"8684aa2d.4ad3c8","type":"tab","label":"Vaibhav","disabled":false,"info":""},{"id":"7d9c6645.877658","type":"ui_gauge","z":"8684aa2d.4ad3c8","name":"","group":"b9fef2ae.a8e5b","order":2,"width":"2","height":"2","gtype":"gage","title":"FWALL 8.8.8.8","label":"ms","format":"{{value}}","min":0,"max":"1000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":300,"y":100,"wires":[]},{"id":"b952481d.c99a38","type":"catch","z":"8684aa2d.4ad3c8","name":"","scope":null,"uncaught":false,"x":2200,"y":3480,"wires":[[]]},{"id":"e26cbe4d.6377f","type":"ui_gauge","z":"8684aa2d.4ad3c8","name":"","group":"b9fef2ae.a8e5b","order":1,"width":"2","height":"2","gtype":"gage","title":"OpenDNS 4.2.2.2","label":"ms","format":"{{value}}","min":0,"max":"1000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":310,"y":40,"wires":[]},{"id":"adce75ee.338db8","type":"function","z":"8684aa2d.4ad3c8","name":"","func":"\nvar trueMsg = { payload: true };\nvar falseMsg = { payload: false };\n\n\nif(msg.payload===false)\n{\n    return falseMsg; \n}\nelse{\n        return trueMsg; \n\n}\n\n\n","outputs":1,"noerr":0,"x":290,"y":320,"wires":[["88b46885.343c08","15125a35.8558a6"]]},{"id":"4b3d6809.f3cb38","type":"function","z":"8684aa2d.4ad3c8","name":"","func":"\nvar trueMsg = { payload: true };\nvar falseMsg = { payload: false };\n\n\nif(msg.payload===false)\n{\n    return falseMsg; \n}\nelse{\n        return trueMsg; \n\n}\n\n\n","outputs":1,"noerr":0,"x":290,"y":380,"wires":[["1e38e7b9.dc44d8","15125a35.8558a6"]]},{"id":"f1ddca2e.6b6b78","type":"ping","z":"8684aa2d.4ad3c8","name":"FIREWALL","host":"8.8.8.8","timer":"5","inputs":0,"x":80,"y":120,"wires":[["7d9c6645.877658","4b3d6809.f3cb38"]]},{"id":"b9d23c06.abb49","type":"ping","z":"8684aa2d.4ad3c8","name":"OpenDNS","host":"4.2.2.2","timer":"5","inputs":0,"x":80,"y":60,"wires":[["e26cbe4d.6377f","adce75ee.338db8"]]},{"id":"5a693225.73570c","type":"ui_gauge","z":"8684aa2d.4ad3c8","name":"","group":"b9fef2ae.a8e5b","order":4,"width":"2","height":"2","gtype":"gage","title":"FWALL google","label":"ms","format":"{{value}}","min":0,"max":"1000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":300,"y":220,"wires":[]},{"id":"a0bd4086.6bc19","type":"ui_gauge","z":"8684aa2d.4ad3c8","name":"","group":"b9fef2ae.a8e5b","order":3,"width":"2","height":"2","gtype":"gage","title":"Local IP 192.168.123.1","label":"ms","format":"{{value}}","min":0,"max":"1000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":330,"y":160,"wires":[]},{"id":"ba970080.cb87c","type":"function","z":"8684aa2d.4ad3c8","name":"","func":"\nvar trueMsg = { payload: true };\nvar falseMsg = { payload: false };\n\n\nif(msg.payload===false)\n{\n    return falseMsg; \n}\nelse{\n        return trueMsg; \n\n}\n\n\n","outputs":1,"noerr":0,"x":290,"y":440,"wires":[["801ba502.59c728","15125a35.8558a6"]]},{"id":"2a761261.8e489e","type":"function","z":"8684aa2d.4ad3c8","name":"","func":"\nvar trueMsg = { payload: true };\nvar falseMsg = { payload: false };\n\n\nif(msg.payload===false)\n{\n    return falseMsg; \n}\nelse{\n        return trueMsg; \n\n}\n\n\n","outputs":1,"noerr":0,"x":290,"y":500,"wires":[["4af1d0de.5a49a","15125a35.8558a6"]]},{"id":"a4cfae68.b91a3","type":"ping","z":"8684aa2d.4ad3c8","name":"FIREWALL2","host":"www.google.com","timer":"5","inputs":0,"x":90,"y":240,"wires":[["5a693225.73570c","2a761261.8e489e"]]},{"id":"a438fa55.5dc958","type":"ping","z":"8684aa2d.4ad3c8","mode":null,"name":"local IP","host":"192.168.123.1","timer":"5","inputs":0,"x":70,"y":180,"wires":[["a0bd4086.6bc19","ba970080.cb87c"]]},{"id":"801ba502.59c728","type":"ui_led","z":"8684aa2d.4ad3c8","group":"9511c355.41f6c","order":4,"width":"4","height":"1","label":"Local IP 192.168.123.1","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"red","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"Local IP 192.168.123.1","x":510,"y":440,"wires":[],"info":"HELLO"},{"id":"4af1d0de.5a49a","type":"ui_led","z":"8684aa2d.4ad3c8","group":"9511c355.41f6c","order":5,"width":"4","height":"1","label":"FWALL google","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"red","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"FWALL google","x":480,"y":500,"wires":[],"info":"HELLO"},{"id":"88b46885.343c08","type":"ui_led","z":"8684aa2d.4ad3c8","group":"9511c355.41f6c","order":2,"width":"4","height":"1","label":"OpenDNS 4.2.2.2","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"red","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"OpenDNS 4.2.2.2","x":490,"y":320,"wires":[],"info":"HELLO"},{"id":"1e38e7b9.dc44d8","type":"ui_led","z":"8684aa2d.4ad3c8","group":"9511c355.41f6c","order":3,"width":"4","height":"1","label":"FWALL 8.8.8.8","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"red","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"FWALL 8.8.8.8","x":480,"y":380,"wires":[],"info":"HELLO"},{"id":"15125a35.8558a6","type":"ui_template","z":"8684aa2d.4ad3c8","group":"9511c355.41f6c","name":"Overall status","order":1,"width":0,"height":0,"format":"<style>\n #btn2 {\n -moz-border-radius: 10px;\n -webkit-border-radius: 10px;\n display: inline;\n}\n</style>\n\n<div id = \"btn2\" style=\"font-size:10px;width: 100px; margin:0 auto;height: 15px;padding-top:5px;\"\n ng-style=\"{'background-color': msg.payload === false ? 'red' : 'green'}\">\n <center>{{msg.payload === false ? 'DOWN' : '&nbsp;&nbsp;&nbsp;UP&nbsp;&nbsp;&nbsp;'}}</center>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":720,"y":380,"wires":[[]]},{"id":"b9fef2ae.a8e5b","type":"ui_group","z":"","name":"Latency Guage","tab":"ca0f03cd.f639c","order":2,"disp":true,"width":"4","collapse":true},{"id":"9511c355.41f6c","type":"ui_group","z":"","name":"SERVER RACK","tab":"ca0f03cd.f639c","order":1,"disp":true,"width":"4","collapse":true},{"id":"ca0f03cd.f639c","type":"ui_tab","z":"","name":"Quick Overview","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Created 5 years, 6 months ago
Rating: 5 3
  • catch (x1)
  • function (x4)
  • ping (x4)
  • ui_gauge (x4)
  • ui_group (x2)
  • ui_led (x4)
  • ui_template (x1)
  • ping
  • monitoring
  • networking
  • status
  • system
  • admin
  • network
  • IT
