PING Network Monitoring / latency Dashboard
The flow checks whether the device answers to ping. If it does not, it will show a red indication in front of the device name. and in another group, the same devices show real-time latency. The default ping is every 5 seconds but can be configured.
tested on Centos7, windows and raspberry pi 3 mod-b devices
Pre-requisites
Node-RED version: v0.20.8
Node.js version: v10.16.3
Nodes install commands:
             npm install node-red-node-ping  (version 0.1.0)
             npm install node-red-dashboard  (version 2.19.4)
             npm install node-red-contrib-ui-led  (version 0.3.1)
[{"id":"975cc394.0dc9d","type":"tab","label":"Vaibhav","disabled":false,"info":""},{"id":"6b5e487.f8ab7b8","type":"ui_gauge","z":"975cc394.0dc9d","name":"","group":"a61c1d23.04fe3","order":2,"width":"2","height":"2","gtype":"gage","title":"FWALL 8.8.8.8","label":"ms","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":300,"y":100,"wires":[]},{"id":"4065334a.cd382c","type":"catch","z":"975cc394.0dc9d","name":"","scope":null,"uncaught":false,"x":2200,"y":3480,"wires":[[]]},{"id":"b890c1fc.c7d9d","type":"ui_gauge","z":"975cc394.0dc9d","name":"","group":"a61c1d23.04fe3","order":1,"width":"2","height":"2","gtype":"gage","title":"OpenDNS 4.2.2.2","label":"ms","format":"{{value}}","min":0,"max":"1000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":310,"y":40,"wires":[]},{"id":"245b55ba.395b5a","type":"function","z":"975cc394.0dc9d","name":"","func":"\nvar trueMsg = { payload: true };\nvar falseMsg = { payload: false };\n\n\nif(msg.payload===false)\n{\n    return falseMsg; \n}\nelse{\n        return trueMsg; \n\n}\n\n\n","outputs":1,"noerr":0,"x":290,"y":320,"wires":[["5bb29bd3.6d22f4"]]},{"id":"fe9fd4c4.a97df8","type":"function","z":"975cc394.0dc9d","name":"","func":"\nvar trueMsg = { payload: true };\nvar falseMsg = { payload: false };\n\n\nif(msg.payload===false)\n{\n    return falseMsg; \n}\nelse{\n        return trueMsg; \n\n}\n\n\n","outputs":1,"noerr":0,"x":290,"y":380,"wires":[["e072e428.bb8108"]]},{"id":"194fcb7e.1d3eb5","type":"ping","z":"975cc394.0dc9d","name":"FIREWALL","host":"8.8.8.8","timer":"5","x":80,"y":120,"wires":[["6b5e487.f8ab7b8","fe9fd4c4.a97df8"]]},{"id":"3b5466f7.65b8aa","type":"ping","z":"975cc394.0dc9d","name":"OpenDNS","host":"4.2.2.2","timer":"5","x":80,"y":60,"wires":[["b890c1fc.c7d9d","245b55ba.395b5a"]]},{"id":"ffbb13bb.41a35","type":"ui_gauge","z":"975cc394.0dc9d","name":"","group":"a61c1d23.04fe3","order":4,"width":"2","height":"2","gtype":"gage","title":"FWALL google","label":"ms","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":300,"y":220,"wires":[]},{"id":"10801da9.cd9532","type":"ui_gauge","z":"975cc394.0dc9d","name":"","group":"a61c1d23.04fe3","order":3,"width":"2","height":"2","gtype":"gage","title":"Local IP 192.168.15.1","label":"ms","format":"{{value}}","min":0,"max":"1000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":320,"y":160,"wires":[]},{"id":"7f853d21.fd0414","type":"function","z":"975cc394.0dc9d","name":"","func":"\nvar trueMsg = { payload: true };\nvar falseMsg = { payload: false };\n\n\nif(msg.payload===false)\n{\n    return falseMsg; \n}\nelse{\n        return trueMsg; \n\n}\n\n\n","outputs":1,"noerr":0,"x":290,"y":440,"wires":[["5c788d61.af2a44"]]},{"id":"ad6ffb85.286928","type":"function","z":"975cc394.0dc9d","name":"","func":"\nvar trueMsg = { payload: true };\nvar falseMsg = { payload: false };\n\n\nif(msg.payload===false)\n{\n    return falseMsg; \n}\nelse{\n        return trueMsg; \n\n}\n\n\n","outputs":1,"noerr":0,"x":290,"y":500,"wires":[["eeae252c.594298"]]},{"id":"fe6e4659.0b64f8","type":"ping","z":"975cc394.0dc9d","name":"FIREWALL2","host":"www.google.com","timer":"5","x":90,"y":240,"wires":[["ffbb13bb.41a35","ad6ffb85.286928"]]},{"id":"d38bccae.c1b68","type":"ping","z":"975cc394.0dc9d","name":"local IP","host":"192.168.15.1","timer":"5","x":70,"y":180,"wires":[["10801da9.cd9532","7f853d21.fd0414"]]},{"id":"5c788d61.af2a44","type":"ui_led","z":"975cc394.0dc9d","group":"5eaca1a3.15e28","order":3,"width":"4","height":"1","label":"Local IP 192.168.15.1","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"red","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"Local IP 192.168.15.1","x":500,"y":440,"wires":[],"info":"HELLO"},{"id":"eeae252c.594298","type":"ui_led","z":"975cc394.0dc9d","group":"5eaca1a3.15e28","order":4,"width":"4","height":"1","label":"FWALL google","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"red","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"FWALL google","x":480,"y":500,"wires":[],"info":"HELLO"},{"id":"5bb29bd3.6d22f4","type":"ui_led","z":"975cc394.0dc9d","group":"5eaca1a3.15e28","order":1,"width":"4","height":"1","label":"OpenDNS 4.2.2.2","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"red","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"OpenDNS 4.2.2.2","x":490,"y":320,"wires":[],"info":"HELLO"},{"id":"e072e428.bb8108","type":"ui_led","z":"975cc394.0dc9d","group":"5eaca1a3.15e28","order":2,"width":"4","height":"1","label":"FWALL 8.8.8.8","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"green","value":"true","valueType":"bool"},{"color":"red","value":"false","valueType":"bool"}],"allowColorForValueInMessage":false,"name":"FWALL 8.8.8.8","x":480,"y":380,"wires":[],"info":"HELLO"},{"id":"a61c1d23.04fe3","type":"ui_group","z":"","name":"Latency Guage","tab":"2806402b.f11e7","order":2,"disp":true,"width":"4","collapse":true},{"id":"5eaca1a3.15e28","type":"ui_group","z":"","name":"SERVER RACK","tab":"2806402b.f11e7","order":1,"disp":true,"width":"4","collapse":true},{"id":"2806402b.f11e7","type":"ui_tab","z":"","name":"Quick Overview","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Created 7 years, 1 month ago
Updated 6 years, 9 months ago
Rating: 5 2
  • catch (x1)
  • function (x4)
  • ping (x4)
  • ui_gauge (x4)
  • ui_group (x2)
  • ui_led (x4)
  • ping
  • uiled
  • led
  • monitoring
  • NMS
  • latency
  • real-time
  • system
  • admin
  • IT
  • check
  • dashboard
  • home-network
  • rpi-monitoring
  • administrator
  • PING Network Monitoring
  • latency Dashboard
  • Ping Dashboard
