node-red-contrib-socketio-server example
An example for node-red-contrib-socketio-server.
[{"id":"d182129b.0ef54","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"2797025b.47d87e","type":"socket.io-on","z":"d182129b.0ef54","name":"","instance":"d523a6c7.23b758","event":"connection","namespace":"","x":220,"y":140,"wires":[["fa31eb65.c8e018"]]},{"id":"dd59181e.c873e8","type":"socket.io-emit","z":"d182129b.0ef54","name":"","instance":"d523a6c7.23b758","event":"onConnection","namespace":"","room":"","x":630,"y":80,"wires":[]},{"id":"fa31eb65.c8e018","type":"function","z":"d182129b.0ef54","name":"say-hi","func":"const message = msg.socket.handshake.query.message;\nmsg.payload = \"Hi, You have successfully connected\";\n\n// override event in emit node\nmsg.event = \"onConnection\";\n\n// override namespace in emit node\nmsg.namespace = \"custom_namespace\";\n\n// override room in emit node\nmsg.room = \"custom_room\";\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":410,"y":140,"wires":[["dd59181e.c873e8","692a6683.1a5eb8"]]},{"id":"b7d0a68c.beef48","type":"comment","z":"d182129b.0ef54","name":"On Event & Emit Event","info":"","x":240,"y":100,"wires":[]},{"id":"692a6683.1a5eb8","type":"socket.io-emit","z":"d182129b.0ef54","name":"Emit by override options","instance":"d523a6c7.23b758","event":"","namespace":"","room":"","x":650,"y":180,"wires":[]},{"id":"6736ceee.179b3","type":"socket.io-join-room","z":"d182129b.0ef54","name":"","room":"My_Room","x":440,"y":340,"wires":[["260e5606.6ae7fa"]]},{"id":"42852907.575238","type":"socket.io-on","z":"d182129b.0ef54","name":"","instance":"6c1d57b3.cf4308","event":"connection","namespace":"","x":220,"y":340,"wires":[["6736ceee.179b3"]]},{"id":"260e5606.6ae7fa","type":"function","z":"d182129b.0ef54","name":"do something","func":"msg.room = 'My_Room';\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":640,"y":340,"wires":[["495fb56.3cc5a4c"]]},{"id":"495fb56.3cc5a4c","type":"socket.io-leave-room","z":"d182129b.0ef54","name":"leave room by override option","room":"","x":890,"y":340,"wires":[[]]},{"id":"5a25d72f.f02a68","type":"comment","z":"d182129b.0ef54","name":"Join & Leave Room","info":"","x":230,"y":300,"wires":[]},{"id":"787fd325.fab90c","type":"socket.io-middleware-start","z":"d182129b.0ef54","name":"","instance":"d523a6c7.23b758","namespace":"","x":250,"y":520,"wires":[["76390e1b.1df0b"]]},{"id":"76390e1b.1df0b","type":"function","z":"d182129b.0ef54","name":"middleware logic","func":"// Your middleware logic\n\n// Allows the client to connect\nmsg.payload = true;\n\n// Block client connections\n// msg.payload = false;\n\n\n// Do not override or delete\n// msg.next\n// msg.socket\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":520,"wires":[["223753da.1f3c8c"]]},{"id":"223753da.1f3c8c","type":"socket.io-middleware-end","z":"d182129b.0ef54","name":"","x":760,"y":520,"wires":[]},{"id":"1b9dbbab.118dc4","type":"comment","z":"d182129b.0ef54","name":"Middleware","info":"","x":210,"y":480,"wires":[]},{"id":"d523a6c7.23b758","type":"socket.io-instance","name":"MyInstance1","port":"3000","options":"{\n    \"cors\": {\n        \"origin\": \"*\",\n        \"credentials\": false\n    }\n}"},{"id":"6c1d57b3.cf4308","type":"socket.io-instance","name":"MyInstance2","port":"3001","options":"{\n    \"cors\": {\n        \"origin\": \"*\",\n        \"credentials\": false\n    }\n}"}]
Created 4 years, 5 months ago
  • comment (x3)
  • function (x3)
  • socketio
  • websocket
