node-red-contrib-socketio-server 0.1.5
A Node-Red node for Socket.IO server
npm install node-red-contrib-socketio-server
A Node-Red node for Socket.IO server.
  • socket.io-instance: create a Socket.IO server instance.
  • socket.io-on: listen for specific event.
  • socket.io-emit: send data for a specific event to clients.
  • socket.io-join-room: join a room.
  • socket.io-leave-room: leave a room.
  • socket.io-middleware-start & socket.io-middleware-end: for middleware.
Note: Do not print any msg that contains the msg.socket. Otherwise it will cause "RangeError: Maximum call stack size exceeded" error. see issues #1.
Tutorial
You can find tutorial here.
The code in this project is licensed under MIT license.
Version: 0.1.5
Rating: 5.0 2
7 in the last week
  • socket.io-on
  • socket.io-emit
  • socket.io-middleware-end
  • socket.io
  • websocket
  • namespace
