Import all historic GasUsage data from Nefit-Easy into InfluxDB
Starting with version 2.0.0 of https://flows.nodered.org/node/node-red-contrib-nefit-easy2 the node now also supports extracting GasUsage data from Nefit-Easy.
The extracts all data from the Nefit-Easy by first determining the max-pagenr of GasUsage data, and then enumerating all pages to the newest.
You only have to run this once. After that you can use the daily import flow to keep the InfluxDB up-to-date.
migrateflow
[{"id":"cc842a3e.278718","type":"nefit-easy","z":"76f4e759.530ae8","easyconfig":"f28ada3e.a49d18","name":"","topic":"nefit-easy","command":"getval-gasusage","value":"","x":560,"y":320,"wires":[["1c3890ae.f046ff"]]},{"id":"713e2984.e48828","type":"inject","z":"76f4e759.530ae8","name":"Trigger All Pages","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":60,"wires":[["b66a472b.d9b848"]]},{"id":"d60b59b1.759198","type":"influxdb batch","z":"76f4e759.530ae8","influxdb":"","precision":"","retentionPolicy":"","name":"","x":860,"y":460,"wires":[]},{"id":"1c3890ae.f046ff","type":"function","z":"76f4e759.530ae8","name":"Map Nefit to influx","func":"var result = msg.payload.map(v => {\n    return { \n        timestamp : v.date,\n        measurement : \"nefit_easy\",\n        fields: {\n            hot_water : v[\"hot water\"],\n            central_heating : v[\"central heating\"],\n            average_outdoor_temperature : v[\"average outdoor temperature\"]\n        }\n    };\n});\n\nmsg.payload = result;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":610,"y":460,"wires":[["d60b59b1.759198","3f9ad713.4f3f08"]]},{"id":"3f9ad713.4f3f08","type":"function","z":"76f4e759.530ae8","name":"Loop all pages","func":"\nvar newPage =  flow.get(\"page\");\nnewPage++;\nflow.set(\"page\", newPage);\n\nvar maxPage = flow.get(\"maxpage\");\n\nif(newPage <= maxPage)\n{\nmsg.payload = newPage;\nreturn msg;\n}\nelse\n{\n    return null;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":340,"y":460,"wires":[["cc239a8b.da7928"]]},{"id":"b66a472b.d9b848","type":"change","z":"76f4e759.530ae8","name":"Reset Page","rules":[{"t":"set","p":"page","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":140,"y":140,"wires":[["b8d14a60.24f6d8"]]},{"id":"cc239a8b.da7928","type":"delay","z":"76f4e759.530ae8","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":380,"y":320,"wires":[["cc842a3e.278718"]]},{"id":"b8d14a60.24f6d8","type":"nefit-easy","z":"76f4e759.530ae8","easyconfig":"f28ada3e.a49d18","name":"","topic":"nefit-easy","command":"gasusagepage","value":"","x":300,"y":140,"wires":[["3b13e1ab.b6e4ae"]]},{"id":"3b13e1ab.b6e4ae","type":"function","z":"76f4e759.530ae8","name":"Get Max Page Nr","func":"flow.set(\"maxpage\", msg.payload || 0);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":190,"y":240,"wires":[["80d6e6e5.ec7d58","3f9ad713.4f3f08"]]},{"id":"80d6e6e5.ec7d58","type":"debug","z":"76f4e759.530ae8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":510,"y":200,"wires":[]},{"id":"f28ada3e.a49d18","type":"nefit-easy-config","z":"","timeout":"30"}]
Collection Info
Created 6 years, 8 months ago
  • change (x1)
  • delay (x1)
  • function (x3)
  • influxdb batch (x1)
  • nefit-easy (x2)
  • nefit-easy-config (x1)
  • nefit-easy
  • influxdb
  • migrate
  • historic
  • gasusage
