STT TEST IBM Watson
SST Test to IBM Watson / SST Test to IBM Watson
[{"id":"a557f018.fd4b5","type":"watson-conversation-v1","z":"f84437b3.8311d8","name":"","workspaceid":"45d04fe2-f92f-43f4-a168-0e7116383694","multiuser":true,"context":true,"empty-payload":false,"default-endpoint":true,"service-endpoint":"https://gateway.watsonplatform.net/assistant/api","timeout":"","optout-learning":false,"x":680,"y":160,"wires":[["ee40c7f5.e0c4d8","bde027c5.152118"]]},{"id":"bd4be952.4447b8","type":"watson-speech-to-text","z":"f84437b3.8311d8","name":"","alternatives":1,"speakerlabels":false,"smartformatting":false,"lang":"pt-BR","langhidden":"pt-BR","langcustom":"NoCustomisationSetting","langcustomhidden":"","custom-weight":"0.5","band":"NarrowbandModel","bandhidden":"NarrowbandModel","keywords":"","keywords-threshold":"0.5","word-confidence":false,"password":"","apikey":"abszCIRwsx_k0zrXZTNAjSkLWsCISbRr-QUg0nhRA3-E","payload-response":true,"streaming-mode":false,"streaming-mute":true,"auto-connect":false,"discard-listening":false,"disable-precheck":false,"default-endpoint":true,"service-endpoint":"https://stream.watsonplatform.net/speech-to-text/api","x":368,"y":160,"wires":[["e7c11c04.2dacf"]]},{"id":"f42b53f1.04a11","type":"watson-text-to-speech","z":"f84437b3.8311d8","name":"","lang":"pt-BR","langhidden":"pt-BR","langcustom":"NoCustomisationSetting","langcustomhidden":"","voice":"pt-BR_IsabelaVoice","voicehidden":"","format":"audio/wav","password":"","apikey":"PDtZz0reYmMhkL_9Ko6tqul2auhkiJ55oPal6tNJ58Jm","payload-response":true,"default-endpoint":true,"service-endpoint":"https://stream.watsonplatform.net/text-to-speech/api","x":126,"y":325,"wires":[["b2037020.c1f38"]]},{"id":"6480505c.5d1c9","type":"http in","z":"f84437b3.8311d8","name":"","url":"/chat","method":"get","upload":false,"swaggerDoc":"","x":77.5,"y":98,"wires":[["d88d2219.e302e"]]},{"id":"b0d0d041.46667","type":"http response","z":"f84437b3.8311d8","name":"","statusCode":"","headers":{},"x":771,"y":233,"wires":[]},{"id":"d88d2219.e302e","type":"change","z":"f84437b3.8311d8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"req.query.mensagem","tot":"msg"},{"t":"set","p":"user","pt":"msg","to":"req.query.usuario","tot":"msg"},{"t":"set","p":"res","pt":"flow","to":"res","tot":"msg"},{"t":"set","p":"audio","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":243,"y":98,"wires":[["63e78b55.07ed04"]]},{"id":"41882423.7c973c","type":"function","z":"f84437b3.8311d8","name":"Response","func":"response = [];\nfor(x=0;x<msg.payload.output.text.length;x++)\n{\n    response[x] = {\"text\":msg.payload.output.text[x]};\n}\nmsg.payload =response;\nreturn msg;","outputs":1,"noerr":0,"x":434,"y":233,"wires":[["16ad8a9e.cd9595"]]},{"id":"63e78b55.07ed04","type":"switch","z":"f84437b3.8311d8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"https://cdn.fbsbx.com","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":406,"y":98,"wires":[["61e38676.5c3fe8"],["e7c11c04.2dacf"]]},{"id":"6556b496.655f2c","type":"link out","z":"f84437b3.8311d8","name":"Convert","links":["3e6a0ec9.0e88f2"],"x":680,"y":92,"wires":[]},{"id":"3e6a0ec9.0e88f2","type":"link in","z":"f84437b3.8311d8","name":"Convert-in","links":["6556b496.655f2c"],"x":37,"y":160,"wires":[["b11cda91.a12978"]]},{"id":"61e38676.5c3fe8","type":"function","z":"f84437b3.8311d8","name":"Audio=true","func":"flow.set(\"audio\",true);\nreturn msg;","outputs":1,"noerr":0,"x":569,"y":92,"wires":[["6556b496.655f2c"]]},{"id":"bde027c5.152118","type":"switch","z":"f84437b3.8311d8","name":"","property":"audio","propertyType":"flow","rules":[{"t":"false"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":80,"y":241,"wires":[["41882423.7c973c"],["5403f57.20f160c"]]},{"id":"b2037020.c1f38","type":"function","z":"f84437b3.8311d8","name":"Create Unique ID","func":"flow.set(\"idAudio\",0);\nflow.set(\"idAudio\", Math.floor((Math.random() * 100000000000) + 1));\nreturn msg;","outputs":1,"noerr":0,"x":320,"y":325,"wires":[["1fdafd88.928932"]]},{"id":"5967a5ea.23956c","type":"http in","z":"f84437b3.8311d8","name":"","url":"/facebook/speech","method":"get","upload":false,"swaggerDoc":"","x":129.5,"y":445,"wires":[["8c60b21a.9dd98"]]},{"id":"d8124a67.15c1c8","type":"http response","z":"f84437b3.8311d8","name":"","statusCode":"","headers":{"content-type":"audio/mpeg3"},"x":637.5000038146973,"y":445.42852687835693,"wires":[]},{"id":"8c60b21a.9dd98","type":"change","z":"f84437b3.8311d8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"req.query.audioid","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":340.2142639160156,"y":445.07142543792725,"wires":[["1914aa9b.b3dd45"]]},{"id":"1914aa9b.b3dd45","type":"function","z":"f84437b3.8311d8","name":"Response","func":"for(var k in flow.get(\"speech\")) {\n  if (flow.get(\"speech\")[k]._id == msg.payload) \n    {\n      msg.payload = flow.get(\"speech\")[k].speech;\n// Delete an item\n      flow.get(\"speech\").splice(k,1);\n      break;\n    } \n  }\nreturn msg;\n\n//msg.payload = Buffer.from(msg.payload.audio, 'utf8');\n//return msg;","outputs":1,"noerr":0,"x":505.61905670166016,"y":445.4285430908203,"wires":[["d8124a67.15c1c8"]]},{"id":"414b2da9.3db3f4","type":"function","z":"f84437b3.8311d8","name":"Save in session","func":"var url = \"https://\" + msg.req.headers.host;\n\nif(!flow.get(\"speech\"))\n{\n    flow.set(\"speech\",[]);\n    flow.set(\"speech[0]\",{_id:flow.get(\"idAudio\").toString(),speech:msg.payload});\n}\nelse\n{\n    var pos;\n    pos = flow.get(\"speech\").length;\n    flow.set(\"speech[\" + pos + \"]\",{_id:flow.get(\"idAudio\").toString(),speech:msg.payload});\n}\n\nmsg.payload = [{\"attachment\":{\n    \"type\":\"audio\",\n    \"payload\":{\"url\":url+ \"/facebook/speech?audioid=\"+flow.get(\"idAudio\").toString()}\n    }\n}];\nreturn msg;","outputs":1,"noerr":0,"x":681,"y":325,"wires":[["16ad8a9e.cd9595"]]},{"id":"16ad8a9e.cd9595","type":"function","z":"f84437b3.8311d8","name":"Restore state","func":"msg.res = flow.get(\"res\");\nflow.set(\"audio\",false);\nreturn msg;","outputs":1,"noerr":0,"x":608,"y":233,"wires":[["b0d0d041.46667"]]},{"id":"f3665349.0e58c","type":"comment","z":"f84437b3.8311d8","name":"Callback for facebook","info":"","x":131,"y":408,"wires":[]},{"id":"e7c11c04.2dacf","type":"function","z":"f84437b3.8311d8","name":"","func":"msg.additional_context = \n{\"nome\":msg.req.query.nome,\n \"sobrenome\":msg.req.query.sobrenome};\nreturn msg;","outputs":1,"noerr":0,"x":540,"y":140,"wires":[["a557f018.fd4b5"]]},{"id":"ee40c7f5.e0c4d8","type":"debug","z":"f84437b3.8311d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":768,"y":38,"wires":[]},{"id":"b11cda91.a12978","type":"ffmpeg-conversion","z":"f84437b3.8311d8","name":"MP3 -> WAV","format":"wav","audiochannels":"mono","x":150,"y":160,"wires":[["bd4be952.4447b8"]]},{"id":"1fdafd88.928932","type":"ffmpeg-conversion","z":"f84437b3.8311d8","name":"WAV -> MP3","format":"mp3","audiochannels":"mono","x":504,"y":325,"wires":[["414b2da9.3db3f4"]]},{"id":"5403f57.20f160c","type":"function","z":"f84437b3.8311d8","name":"Response","func":"response = \"\";\nfor(x=0;x<msg.payload.output.text.length;x++)\n{\n    response += '<p><s>' + msg.payload.output.text[x] + '</s></p><break time=\"1000ms\"/>';\n}\nmsg.payload =response;\nreturn msg;","outputs":1,"noerr":0,"x":216,"y":274,"wires":[["f42b53f1.04a11"]]}]
Created 4 years, 8 months ago
  • change (x2)
  • function (x8)
  • http in (x2)
  • http response (x2)
  • link in (x1)
  • link out (x1)
  • switch (x2)
