Telegram ChatBot with Watson Assistant and STT to receive voice
This flow is to be used as orchestrator / controller of chatbot to be deployed on Telegrama, using as NLP Watson Assistant. Also this flow can receive voice from telegram, so uses Watson STT to convert voice to text.
[{"id":"65916592.4d718c","type":"watson-conversation-v1","z":"8ba8e00b.f51c6","name":"","workspaceid":"8da116df-ab65-4936-a04d-a4c6eaf40b89","multiuser":false,"context":true,"empty-payload":false,"default-endpoint":true,"service-endpoint":"https://gateway.watsonplatform.net/conversation/api","timeout":"","optout-learning":false,"x":320,"y":318,"wires":[["8cd4ff73.aa632"]]},{"id":"8cd4ff73.aa632","type":"function","z":"8ba8e00b.f51c6","name":"Restore context","func":"for(x=0;x<msg.payload.output.text.length;x++)\n{\n    msg.payload.chatId = flow.get(\"chatId\");\n    msg.payload.type = \"message\" //flow.get(\"type\");\n    msg.payload.content = msg.payload.output.text[x];\n    node.send(msg);\n}\nreturn null;","outputs":1,"noerr":0,"x":500,"y":318,"wires":[["f33f7435.01f528"]]},{"id":"822cfffc.0c69e","type":"function","z":"8ba8e00b.f51c6","name":"Not authorized user","func":"msg.payload.chatId = flow.get(\"chatId\");\nmsg.payload.type = \"message\" //flow.get(\"type\");\nmsg.payload.content = \"Você não está autorizado\";\nreturn msg;","outputs":1,"noerr":0,"x":508.125,"y":481.4375305175781,"wires":[["f33f7435.01f528"]]},{"id":"69ef2432.8f3f7c","type":"comment","z":"8ba8e00b.f51c6","name":"Read.me","info":"1) Create a Watson Assistant and Watson Speach to Text on IBM Cloud (https://www.bluemix.net)\n2) Create a Telegram Bot:\n   Open web.telegram.org\n   find BotFather (contact)\n   send /newbot\n   Give a name for your bot (Botfather will ask it)\n   Give a user name for it, which should have in the end \"Bot\"\n   The BotFather will give you a token.\n3) Install node-red-contrib-telegrambot   ","x":77,"y":55,"wires":[]},{"id":"f5df240c.5ae6d8","type":"watson-speech-to-text","z":"8ba8e00b.f51c6","name":"","alternatives":1,"speakerlabels":false,"smartformatting":false,"lang":"pt-BR","langhidden":"pt-BR","langcustom":"NoCustomisationSetting","langcustomhidden":"","custom-weight":"","band":"NarrowbandModel","bandhidden":"NarrowbandModel","keywords":"","keywords-threshold":"","word-confidence":false,"password":"","apikey":"josj9cmi9JBfDRSpxyQCR-VWniJ-rjZrH3tRMdXGP_n6","payload-response":true,"streaming-mode":false,"streaming-mute":false,"auto-connect":false,"discard-listening":false,"disable-precheck":false,"default-endpoint":true,"service-endpoint":"https://stream.watsonplatform.net/speech-to-text/api","x":480,"y":215,"wires":[["65916592.4d718c"]]},{"id":"7dbc3625.78c1e8","type":"switch","z":"8ba8e00b.f51c6","name":"","property":"type","propertyType":"flow","rules":[{"t":"eq","v":"voice","vt":"str"},{"t":"eq","v":"message","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":417,"y":83,"wires":[["2e274d4d.5a0f42"],["3c280c4d.20c974"]]},{"id":"2e274d4d.5a0f42","type":"change","z":"8ba8e00b.f51c6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.weblink","tot":"msg"},{"t":"set","p":"audio","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":579,"y":77,"wires":[["f5df240c.5ae6d8"]]},{"id":"342134d0.40ab8c","type":"function","z":"8ba8e00b.f51c6","name":"Save context","func":"flow.set(\"chatId\", msg.payload.chatId);\nflow.set(\"type\", msg.payload.type);\nflow.set(\"content\",msg.payload.content);\nflow.set(\"weblink\",msg.payload.weblink);\nflow.set(\"audio\",false);\nreturn msg;","outputs":1,"noerr":0,"x":275.125,"y":83.3125,"wires":[["7dbc3625.78c1e8"]]},{"id":"3c280c4d.20c974","type":"change","z":"8ba8e00b.f51c6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.content","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":140,"y":318,"wires":[["65916592.4d718c"]]},{"id":"50de1c4e.6ff4c4","type":"telegram receiver","z":"8ba8e00b.f51c6","name":"","bot":"19b68e7a.18b0e2","saveDataDir":"","x":96.125,"y":89.3125,"wires":[["342134d0.40ab8c"],["822cfffc.0c69e"]]},{"id":"f33f7435.01f528","type":"telegram sender","z":"8ba8e00b.f51c6","name":"","bot":"19b68e7a.18b0e2","x":698,"y":318,"wires":[[]]},{"id":"19b68e7a.18b0e2","type":"telegram bot","z":"","botname":"hdidemobot","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":true,"verboselogging":true}]
Created 7 years, 6 months ago
Rating: 4 3
  • change (x2)
  • function (x3)
  • switch (x1)
  • telegrambot
  • Watson
  • Assistant
  • STT
