homee-Statusmeldung-Sonos-Wemorückkanal
Mit Diesem Flow kannst du den Zustand deiner Sonos Box zurückmelden an homee. Verwendet wurde ein Wemoemu zum schalten in homee. Wenn die Sonos Box nun per App geschaltet wird, bekommt das homee über den Flow zurückgemeldet.
[{"id":"daaee97f.34d168","type":"better-sonos-status","z":"eeb0b50.5800748","confignode":"","name":"Sonos","x":690,"y":280,"wires":[["df199e75.74ccf"]]},{"id":"df199e75.74ccf","type":"function","z":"eeb0b50.5800748","name":"Prüfen des Zustandes der Sonos Box","func":"var nodeid = 0;  // node ID in homee vom Wemo\nvar attributid = 0; // attribut ID in homee vom Wemo\nconst attributes = global.get('homee.attributes');\nvar status = attributes.filter(attribute => attribute.id === attributid).map(a => a.current_value).reduce((a,c) => a+c);\n\nif (msg.state === \"stopped\" && status === 1)\n{return {payload: \"PUT:/nodes/\"+nodeid+\"/attributes/\"+attributid+\"?target_value=0\"}}\nif (msg.state === \"playing\" && status === 0)\n{return {payload: \"PUT:/nodes/\"+nodeid+\"/attributes/\"+attributid+\"?target_value=1\"}}\n","outputs":1,"noerr":0,"x":930,"y":280,"wires":[["cbc6ea51.199a68"]]},{"id":"8357cb52.17cfd8","type":"inject","z":"eeb0b50.5800748","name":"","topic":"","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"onceDelay":0.1,"x":490,"y":280,"wires":[["daaee97f.34d168"]]},{"id":"cbc6ea51.199a68","type":"homee","z":"eeb0b50.5800748","name":"","host":"","x":1170,"y":280,"wires":[[]]},{"id":"140dfba0.be6504","type":"wemo-emulator","z":"eeb0b50.5800748","name":"Sonos ","friendlyName":"Sonos ","serial":"554423","port":"34523","onTopic":"on","onPayload":"on","offTopic":"off","offPayload":"off","x":490,"y":400,"wires":[["2ea5c614.77b56a"]]},{"id":"2ea5c614.77b56a","type":"switch","z":"eeb0b50.5800748","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":788,"y":399,"wires":[["2d8b322e.66e04e"],["65bc5bce.538cb4"]],"outputLabels":["on",""]},{"id":"2d8b322e.66e04e","type":"sonos-control","z":"eeb0b50.5800748","playnode":"","name":"","mode":"play","track":"","volume":"empty","volume_value":"","x":1090,"y":357,"wires":[]},{"id":"65bc5bce.538cb4","type":"sonos-control","z":"eeb0b50.5800748","playnode":"","name":"","mode":"pause","track":"","volume":"","volume_value":"","x":1091,"y":417,"wires":[]}]
Created 8 years, 8 months ago
  • switch (x1)
