Alexa Text To Speech
Alexa Text-To-Speech using Home Assistant, Alexa Media Player add-on, and NodeRed Dashboard.
This flow REQUIRES the Home Assistant set of Nodes, Dashboard Nodes, and Alexa Media Player add-on from the Home Assistant Community Store. All of the nodes need to be configured for your preferred settings as well. If this flow isn't working than chances are you configured something incorrectly.
[{"id":"d9749d47.711508","type":"tab","label":"Alexa TTS and notifications","disabled":false,"info":""},{"id":"8a58f31c.c8bd8","type":"ui_text_input","z":"d9749d47.711508","name":"Text in-0","label":"","tooltip":"","group":"a9fe9af0.000d58","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":"1","topic":"","topicType":"str","x":180,"y":300,"wires":[["14746f10.1da411"]]},{"id":"14746f10.1da411","type":"change","z":"d9749d47.711508","name":"","rules":[{"t":"set","p":"textToSpeak0","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":300,"wires":[[]]},{"id":"43a269f.d5fe218","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":2,"width":0,"height":0,"passthru":false,"label":"Speak-0","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","topicType":"str","x":180,"y":340,"wires":[["500a0f09.9623f8"]]},{"id":"68ba6636.be93e","type":"ui_text_input","z":"d9749d47.711508","name":"Text in-1","label":"","tooltip":"","group":"a9fe9af0.000d58","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":"1","topic":"","topicType":"str","x":180,"y":460,"wires":[["36a6d58e.52274a"]]},{"id":"36a6d58e.52274a","type":"change","z":"d9749d47.711508","name":"","rules":[{"t":"set","p":"textToSpeak1","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":460,"wires":[[]]},{"id":"2787c4dd.cb40c4","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":2,"width":0,"height":0,"passthru":false,"label":"Speak-1","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","topicType":"str","x":180,"y":500,"wires":[["ccf2aee1.db2f9"]]},{"id":"bada6e73.1096b8","type":"ui_text_input","z":"d9749d47.711508","name":"Text in-2","label":"","tooltip":"","group":"a9fe9af0.000d58","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":"1","topic":"","topicType":"str","x":180,"y":620,"wires":[["2247df30.a6afd"]]},{"id":"2247df30.a6afd","type":"change","z":"d9749d47.711508","name":"","rules":[{"t":"set","p":"textToSpeak2","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":620,"wires":[[]]},{"id":"b1d5e1c1.07418","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":2,"width":0,"height":0,"passthru":false,"label":"Speak-2","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","topicType":"str","x":180,"y":660,"wires":[["186e35fb.2b022a"]]},{"id":"186e35fb.2b022a","type":"api-call-service","z":"d9749d47.711508","name":"Call tts-2","server":"","version":1,"debugenabled":false,"service_domain":"notify","service":"alexa_media","entityId":"","data":"{\"message\":\" {{flow.textToSpeak2}} \",\"data\":{\"type\":\"tts\"}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":660,"wires":[[]]},{"id":"464cd6b5.57898","type":"ui_text_input","z":"d9749d47.711508","name":"Text in-3","label":"","tooltip":"","group":"a9fe9af0.000d58","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":"1","topic":"","topicType":"str","x":180,"y":780,"wires":[["2a56ca83.a4bc3e"]]},{"id":"2a56ca83.a4bc3e","type":"change","z":"d9749d47.711508","name":"","rules":[{"t":"set","p":"textToSpeak3","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":780,"wires":[[]]},{"id":"fda55511.8a6628","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":2,"width":0,"height":0,"passthru":false,"label":"Speak-3","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","topicType":"str","x":180,"y":820,"wires":[["95e7de49.1e6fc"]]},{"id":"95e7de49.1e6fc","type":"api-call-service","z":"d9749d47.711508","name":"Call tts-3","server":"","version":1,"debugenabled":false,"service_domain":"notify","service":"alexa_media","entityId":"","data":"{\"message\":\" {{flow.textToSpeak3}} \",\"data\":{\"type\":\"tts\"}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":820,"wires":[[]]},{"id":"11f5b34b.1aa9c5","type":"ui_text_input","z":"d9749d47.711508","name":"","label":"","tooltip":"","group":"a9fe9af0.000d58","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":"300","topic":"","topicType":"str","x":180,"y":120,"wires":[["14746f10.1da411","36a6d58e.52274a","2247df30.a6afd","2a56ca83.a4bc3e","595bc4ae.f5b1ec","f897b540.48dda"]]},{"id":"5a8a8daf.8069bc","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":3,"width":0,"height":0,"passthru":false,"label":"Announce","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","topicType":"str","x":180,"y":160,"wires":[["500a0f09.9623f8","ccf2aee1.db2f9","186e35fb.2b022a","95e7de49.1e6fc","6cb35813.cbf828"]]},{"id":"f77d863e.4b03c8","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":3,"width":0,"height":0,"passthru":false,"label":"Volume up-0","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","topicType":"str","x":190,"y":380,"wires":[["77f59c0d.3f6c7c"]]},{"id":"e5febf72.9dbf5","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":4,"width":0,"height":0,"passthru":false,"label":"Volume down-0","tooltip":"","color":"","bgcolor":"","icon":"","payload":"-1","payloadType":"str","topic":"","topicType":"str","x":200,"y":420,"wires":[["73f3cea8.f6d808"]]},{"id":"10758e15.146192","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":3,"width":0,"height":0,"passthru":false,"label":"Volume up-1","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","topicType":"str","x":190,"y":540,"wires":[["c59a7458.fdbcd"]]},{"id":"74ceb119.3f25e","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":4,"width":0,"height":0,"passthru":false,"label":"Volume down-1","tooltip":"","color":"","bgcolor":"","icon":"","payload":"-1","payloadType":"str","topic":"","topicType":"str","x":200,"y":580,"wires":[["8549e34f.200a38"]]},{"id":"6cd06456.e2abbc","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":3,"width":0,"height":0,"passthru":false,"label":"Volume up-2","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","topicType":"str","x":190,"y":700,"wires":[["68ff2cf.20cf854"]]},{"id":"8614c791.1cd688","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":4,"width":0,"height":0,"passthru":false,"label":"Volume down-2","tooltip":"","color":"","bgcolor":"","icon":"","payload":"-1","payloadType":"str","topic":"","topicType":"str","x":200,"y":740,"wires":[["c758baf8.c7b178"]]},{"id":"68ff2cf.20cf854","type":"api-call-service","z":"d9749d47.711508","name":"Vol up-2","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_up","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":700,"wires":[[]]},{"id":"c758baf8.c7b178","type":"api-call-service","z":"d9749d47.711508","name":"Vol down-2","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_down","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":410,"y":740,"wires":[[]]},{"id":"6a33e50f.673fac","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":3,"width":0,"height":0,"passthru":false,"label":"Volume up-3","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","topicType":"str","x":190,"y":860,"wires":[["2bd68321.d4d8c4"]]},{"id":"1fe0fd1e.fc71ab","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":4,"width":0,"height":0,"passthru":false,"label":"Volume down-3","tooltip":"","color":"","bgcolor":"","icon":"","payload":"-1","payloadType":"str","topic":"","topicType":"str","x":200,"y":900,"wires":[["99c0d8d8.f318a"]]},{"id":"2bd68321.d4d8c4","type":"api-call-service","z":"d9749d47.711508","name":"Vol up-3","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_up","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":860,"wires":[[]]},{"id":"99c0d8d8.f318a","type":"api-call-service","z":"d9749d47.711508","name":"Vol down-3","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_down","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":410,"y":900,"wires":[[]]},{"id":"de111f50.161e2","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":4,"width":0,"height":0,"passthru":false,"label":"Master up","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","topicType":"str","x":180,"y":200,"wires":[["68ff2cf.20cf854","2bd68321.d4d8c4","c59a7458.fdbcd","77f59c0d.3f6c7c","14801113.e98427"]]},{"id":"99d8bdbd.2ac8c","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":5,"width":0,"height":0,"passthru":false,"label":"Master down","tooltip":"","color":"","bgcolor":"","icon":"","payload":"-1","payloadType":"str","topic":"","topicType":"str","x":190,"y":240,"wires":[["c758baf8.c7b178","99c0d8d8.f318a","73f3cea8.f6d808","8549e34f.200a38","a2d9b77d.295188"]]},{"id":"618b29a6.cc58a8","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":6,"width":0,"height":0,"passthru":false,"label":"Reset Text Boxes","tooltip":"","color":"","bgcolor":"","icon":"","payload":"0","payloadType":"str","topic":"","topicType":"str","x":150,"y":80,"wires":[["11f5b34b.1aa9c5","8a58f31c.c8bd8","68ba6636.be93e","bada6e73.1096b8","464cd6b5.57898","3b1b3aa7.d261fe"]]},{"id":"500a0f09.9623f8","type":"api-call-service","z":"d9749d47.711508","name":"Call tts-0","server":"","version":1,"debugenabled":false,"service_domain":"notify","service":"alexa_media","entityId":"","data":"{\"message\":\" {{flow.textToSpeak0}} \",\"data\":{\"type\":\"tts\"}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":340,"wires":[[]]},{"id":"77f59c0d.3f6c7c","type":"api-call-service","z":"d9749d47.711508","name":"Vol up-0","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_up","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":380,"wires":[[]]},{"id":"73f3cea8.f6d808","type":"api-call-service","z":"d9749d47.711508","name":"Vol down-0","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_down","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":410,"y":420,"wires":[[]]},{"id":"ccf2aee1.db2f9","type":"api-call-service","z":"d9749d47.711508","name":"Call tts-1","server":"","version":1,"debugenabled":false,"service_domain":"notify","service":"alexa_media","entityId":"","data":"{\"message\":\" {{flow.textToSpeak1}} \",\"data\":{\"type\":\"tts\"}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":500,"wires":[[]]},{"id":"c59a7458.fdbcd","type":"api-call-service","z":"d9749d47.711508","name":"Vol up-1","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_up","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":540,"wires":[[]]},{"id":"8549e34f.200a38","type":"api-call-service","z":"d9749d47.711508","name":"Vol down-1","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_down","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":410,"y":580,"wires":[[]]},{"id":"595bc4ae.f5b1ec","type":"change","z":"d9749d47.711508","name":"","rules":[{"t":"set","p":"announce","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":80,"wires":[[]]},{"id":"3b1b3aa7.d261fe","type":"ui_text_input","z":"d9749d47.711508","name":"Text in-4","label":"","tooltip":"","group":"a9fe9af0.000d58","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":"1","topic":"","topicType":"str","x":180,"y":940,"wires":[["f897b540.48dda"]]},{"id":"f897b540.48dda","type":"change","z":"d9749d47.711508","name":"","rules":[{"t":"set","p":"textToSpeak4","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":940,"wires":[[]]},{"id":"6c58ff4b.e891a","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":2,"width":0,"height":0,"passthru":false,"label":"Speak-4","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","topicType":"str","x":180,"y":980,"wires":[["6cb35813.cbf828"]]},{"id":"d415af5f.2866","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":3,"width":0,"height":0,"passthru":false,"label":"Volume up-4","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","topicType":"str","x":190,"y":1020,"wires":[["14801113.e98427"]]},{"id":"1229b874.d5f43","type":"ui_button","z":"d9749d47.711508","name":"","group":"a9fe9af0.000d58","order":4,"width":0,"height":0,"passthru":false,"label":"Volume down-4","tooltip":"","color":"","bgcolor":"","icon":"","payload":"-1","payloadType":"str","topic":"","topicType":"str","x":200,"y":1060,"wires":[["a2d9b77d.295188"]]},{"id":"6cb35813.cbf828","type":"api-call-service","z":"d9749d47.711508","name":"Call tts-4","server":"","version":1,"debugenabled":false,"service_domain":"notify","service":"alexa_media","entityId":"","data":"{\"message\":\" {{flow.textToSpeak4}} \",\"data\":{\"type\":\"tts\"}}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":980,"wires":[[]]},{"id":"14801113.e98427","type":"api-call-service","z":"d9749d47.711508","name":"Vol up-4","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_up","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":400,"y":1020,"wires":[[]]},{"id":"a2d9b77d.295188","type":"api-call-service","z":"d9749d47.711508","name":"Vol down-4","server":"","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_down","entityId":"media_player","data":"{}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":410,"y":1060,"wires":[[]]},{"id":"a9fe9af0.000d58","type":"ui_group","name":"Reset Values","tab":"","order":1,"disp":true,"width":"6","collapse":false}]
Created 5 years, 8 months ago
Rating: 5 1
  • change (x6)
  • Alexa
  • HomeAssistant
  • Dashboard
  • Text-To-Speech
  • TTS
