Climate Control
Use node red to create a climate automation based on various input booleans created through home assistant.
[{"id":"6360d3b8.6f440c","type":"tab","label":"Climate Control","disabled":false,"info":""},{"id":"5f3d5949.175df8","type":"comment","z":"6360d3b8.6f440c","name":"Changes Outside Temperature Input Select","info":"","x":180,"y":60,"wires":[]},{"id":"fcb9e943.03a768","type":"inject","z":"6360d3b8.6f440c","name":"Hourly Update","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"3600","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":100,"wires":[["5fd1fa79.4fcd74"]]},{"id":"e691515e.8a0ef","type":"switch","z":"6360d3b8.6f440c","name":"","property":"data.attributes.forecast[0].temperature","propertyType":"msg","rules":[{"t":"lt","v":"45","vt":"num"},{"t":"btwn","v":"45","vt":"num","v2":"64","v2t":"num"},{"t":"btwn","v":"65","vt":"num","v2":"80","v2t":"num"},{"t":"btwn","v":"81","vt":"num","v2":"94","v2t":"num"},{"t":"gt","v":"94","vt":"num"}],"checkall":"true","repair":false,"outputs":5,"x":395,"y":100,"wires":[["5c11edcb.4622f4"],["dad3e6c0.cb3a18"],["cdcebe96.4c1ed"],["833f8f28.c279f"],["837348e.840d9b8"]],"l":false},{"id":"5c11edcb.4622f4","type":"change","z":"6360d3b8.6f440c","name":"Cold","rules":[{"t":"set","p":"payload","pt":"msg","to":"Cold","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":20,"wires":[["f133eef4.84edb"]]},{"id":"dad3e6c0.cb3a18","type":"change","z":"6360d3b8.6f440c","name":"Cool","rules":[{"t":"set","p":"payload","pt":"msg","to":"Cool","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":60,"wires":[["f133eef4.84edb"]]},{"id":"cdcebe96.4c1ed","type":"change","z":"6360d3b8.6f440c","name":"Warm","rules":[{"t":"set","p":"payload","pt":"msg","to":"Warm","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":100,"wires":[["f133eef4.84edb"]]},{"id":"833f8f28.c279f","type":"change","z":"6360d3b8.6f440c","name":"Hot","rules":[{"t":"set","p":"payload","pt":"msg","to":"Hot","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":140,"wires":[["f133eef4.84edb"]]},{"id":"837348e.840d9b8","type":"change","z":"6360d3b8.6f440c","name":"Very Hot","rules":[{"t":"set","p":"payload","pt":"msg","to":"Very Hot","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":180,"wires":[["f133eef4.84edb"]]},{"id":"f133eef4.84edb","type":"api-call-service","z":"6360d3b8.6f440c","name":"Outside Temperature Input_Select","server":"4e34de6f.20a5d","version":5,"debugenabled":true,"domain":"input_select","service":"select_option","areaId":[],"deviceId":[],"entityId":["input_select.outside_temperature"],"data":"{\"option\":\"{{payload}}\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":780,"y":100,"wires":[[]]},{"id":"5fd1fa79.4fcd74","type":"api-current-state","z":"6360d3b8.6f440c","name":"Accu","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.home_realfeel_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":290,"y":100,"wires":[["e691515e.8a0ef"]]},{"id":"765eb573.0fdd6c","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Very Hot","vt":"str"},{"t":"eq","v":"Hot","vt":"str"},{"t":"eq","v":"Warm","vt":"str"},{"t":"eq","v":"Cool","vt":"str"},{"t":"eq","v":"Cold","vt":"str"}],"checkall":"false","repair":false,"outputs":5,"x":1055,"y":520,"wires":[["b44f5994.c041e8"],["b44f5994.c041e8"],["c48c2427.adb168"],["4ce281e195ad9ad6"],["45da942042b9b65a"]],"l":false},{"id":"9c6c937b.85da3","type":"api-current-state","z":"6360d3b8.6f440c","name":"Outside Climate","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.outside_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":920,"y":520,"wires":[["765eb573.0fdd6c"]]},{"id":"ab622a57.9baa48","type":"inject","z":"6360d3b8.6f440c","name":"15m","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"300","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":760,"wires":[["563c2245.645fdc"]]},{"id":"cc65b5df.16e3f8","type":"server-state-changed","z":"6360d3b8.6f440c","name":"Inside Temp","server":"4e34de6f.20a5d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.1st_floor_thermostat_air_temperature_2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":800,"wires":[["563c2245.645fdc"]]},{"id":"5fcba865.2f5368","type":"server-state-changed","z":"6360d3b8.6f440c","name":"House Occupied - Thomas","server":"4e34de6f.20a5d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"person.thomas","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":840,"wires":[["563c2245.645fdc"]]},{"id":"d5518389.0ee23","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Very Hot","vt":"str"},{"t":"eq","v":"Hot","vt":"str"},{"t":"eq","v":"Warm","vt":"str"},{"t":"eq","v":"Cool","vt":"str"},{"t":"eq","v":"Cold","vt":"str"}],"checkall":"false","repair":false,"outputs":5,"x":1215,"y":1120,"wires":[["e89aaf4c960ec90c"],["e89aaf4c960ec90c"],["d8a9cb29.7d8cc8"],["d8a9cb29.7d8cc8"],["97070e72283a1c0c"]],"l":false},{"id":"aa01effb.f6b1f","type":"api-current-state","z":"6360d3b8.6f440c","name":"Outside Climate","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.outside_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":1100,"y":1120,"wires":[["d5518389.0ee23"]]},{"id":"3fabd989.e08766","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"68","vt":"str"},{"t":"gte","v":"74","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1655,"y":1120,"wires":[["31e82cf6.161c24"],["87b73570.c93e48"],["8c28a6c8.5daa98"]],"l":false},{"id":"1a3cc18a.1e5d6e","type":"api-current-state","z":"6360d3b8.6f440c","name":"House Temp","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.1st_floor_thermostat_air_temperature_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":1550,"y":1120,"wires":[["3fabd989.e08766"]]},{"id":"48ec038.20922fc","type":"api-current-state","z":"6360d3b8.6f440c","name":"Vacation Mode OFF","server":"4e34de6f.20a5d","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.vacation_mode","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":900,"y":1280,"wires":[["aa01effb.f6b1f"],["76d9508f.cc725"]]},{"id":"d8a9cb29.7d8cc8","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"06:30","endTime":"20:00","startOffset":0,"endOffset":0,"x":1390,"y":1180,"wires":[["1a3cc18a.1e5d6e"],["97070e72283a1c0c"]]},{"id":"f964ef70.b81fd","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"64","vt":"str"},{"t":"gte","v":"77","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1285,"y":1360,"wires":[["7c1a896f.e3ea58"],["605363e5.f1686c"],["325bd8dd8ca784bc"]],"l":false},{"id":"76d9508f.cc725","type":"api-current-state","z":"6360d3b8.6f440c","name":"House Temp","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.1st_floor_thermostat_air_temperature_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":1180,"y":1360,"wires":[["f964ef70.b81fd"]]},{"id":"e283a490.b29248","type":"comment","z":"6360d3b8.6f440c","name":"Thermostat Temperature Adjustments","info":"","x":170,"y":720,"wires":[]},{"id":"b44f5994.c041e8","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"06:30","endTime":"20:00","startOffset":0,"endOffset":0,"x":1250,"y":360,"wires":[["ed1fbaa4.0f0348"],["83eda839.a2fe78"]]},{"id":"563c2245.645fdc","type":"delay","z":"6360d3b8.6f440c","name":"","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":410,"y":840,"wires":[["7ae958bb.d0b0e8"]]},{"id":"7ae958bb.d0b0e8","type":"api-current-state","z":"6360d3b8.6f440c","name":"Thermostat Override ON","server":"4e34de6f.20a5d","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.thermostat_override","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":630,"y":840,"wires":[["3e79033b5e6a7e3c"],["ac9c3b10a6731b3f"]]},{"id":"f91c6689.eb17a8","type":"server-state-changed","z":"6360d3b8.6f440c","name":"Thermostat Override","server":"4e34de6f.20a5d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.thermostat_override","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":110,"y":920,"wires":[["563c2245.645fdc"]]},{"id":"d4ca240e.a53818","type":"inject","z":"6360d3b8.6f440c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":700,"y":500,"wires":[["9c6c937b.85da3"]]},{"id":"394a42d4.5419ee","type":"server-state-changed","z":"6360d3b8.6f440c","name":"Sleep Mode Boolean","server":"4e34de6f.20a5d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.sleep_mode","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":110,"y":960,"wires":[["563c2245.645fdc"]]},{"id":"ed1fbaa4.0f0348","type":"change","z":"6360d3b8.6f440c","name":"Cool 72","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"72","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":340,"wires":[["ca45e67f.16d748"]]},{"id":"83eda839.a2fe78","type":"change","z":"6360d3b8.6f440c","name":"Cool 69","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"69","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":380,"wires":[["ca45e67f.16d748"]]},{"id":"c496029.c6df","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"68","vt":"str"},{"t":"gte","v":"72","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1535,"y":460,"wires":[["2aff51e9.02642e"],["83256f76.0f901"],["1f8fae8f.84e871"]],"l":false},{"id":"a26bc1d2.8ddab","type":"api-current-state","z":"6360d3b8.6f440c","name":"House Temp","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.1st_floor_thermostat_air_temperature_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":1430,"y":460,"wires":[["c496029.c6df"]]},{"id":"c48c2427.adb168","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"06:30","endTime":"21:00","startOffset":0,"endOffset":0,"x":1250,"y":480,"wires":[["a26bc1d2.8ddab"],["6eb4c3f.450363c"]]},{"id":"2aff51e9.02642e","type":"change","z":"6360d3b8.6f440c","name":"Heat 68","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"68","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1640,"y":420,"wires":[["d07e1644.6ddd08"]]},{"id":"83256f76.0f901","type":"change","z":"6360d3b8.6f440c","name":"Cool 72","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"72","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1640,"y":460,"wires":[["d07e1644.6ddd08"]]},{"id":"6eb4c3f.450363c","type":"change","z":"6360d3b8.6f440c","name":"Cool 71","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"71","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":500,"wires":[["81b179fd.cc4878"]]},{"id":"f48a0ee2.94548","type":"change","z":"6360d3b8.6f440c","name":"Heat 69","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"69","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1400,"y":800,"wires":[["c4ab30f9.dd2fa"]]},{"id":"d07e1644.6ddd08","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","mode":"link","links":["4c23b0d2.6350c"],"x":1735,"y":440,"wires":[]},{"id":"4c23b0d2.6350c","type":"link in","z":"6360d3b8.6f440c","name":"Call Service","links":["04d7e513150c9719","2d88fa21cd7c7a94","4f7339e9.712ac8","58f848d83a6a51ce","6d37bae3.8f84e4","70090c425abbb77d","81b179fd.cc4878","8eed7c0145befad3","b9cf7e1f.66a9a","c4ab30f9.dd2fa","c7141f588980e093","ca45e67f.16d748","d07e1644.6ddd08"],"x":2035,"y":920,"wires":[["6174d999.bdb568","6601bb9c01fc3014"]]},{"id":"c4ab30f9.dd2fa","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","mode":"link","links":["4c23b0d2.6350c"],"x":1665,"y":820,"wires":[]},{"id":"81b179fd.cc4878","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1515,"y":500,"wires":[]},{"id":"aabb81b3.2f426","type":"link in","z":"6360d3b8.6f440c","name":"HVAC OFF","links":["06f6260613914a52","1f8fae8f.84e871","325bd8dd8ca784bc","49a4aec0d5e02382","8c28a6c8.5daa98","e56030ccda9ec6ba","e648e73a5931a69a"],"x":2035,"y":980,"wires":[["79157f7b977b46d1"]]},{"id":"1f8fae8f.84e871","type":"link out","z":"6360d3b8.6f440c","name":"HVAC OFF","links":["aabb81b3.2f426"],"x":1595,"y":500,"wires":[]},{"id":"ca45e67f.16d748","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1515,"y":360,"wires":[]},{"id":"8c28a6c8.5daa98","type":"link out","z":"6360d3b8.6f440c","name":"HVAC OFF","links":["aabb81b3.2f426"],"x":1715,"y":1160,"wires":[]},{"id":"31e82cf6.161c24","type":"change","z":"6360d3b8.6f440c","name":"Heat 67","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"67","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1760,"y":1080,"wires":[["b9cf7e1f.66a9a"]]},{"id":"87b73570.c93e48","type":"change","z":"6360d3b8.6f440c","name":"Cool 75","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"75","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1760,"y":1120,"wires":[["b9cf7e1f.66a9a"]]},{"id":"b9cf7e1f.66a9a","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1855,"y":1100,"wires":[]},{"id":"7c1a896f.e3ea58","type":"change","z":"6360d3b8.6f440c","name":"Heat 66","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"66","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1390,"y":1320,"wires":[["6d37bae3.8f84e4"]]},{"id":"605363e5.f1686c","type":"change","z":"6360d3b8.6f440c","name":"Cool 77","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"77","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1390,"y":1360,"wires":[["6d37bae3.8f84e4"]]},{"id":"6d37bae3.8f84e4","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1485,"y":1340,"wires":[]},{"id":"6174d999.bdb568","type":"delay","z":"6360d3b8.6f440c","name":"","pauseType":"delay","timeout":"750","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":2210,"y":960,"wires":[["c338309d2f9ec5b5"]]},{"id":"4f7339e9.712ac8","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1665,"y":1020,"wires":[]},{"id":"3e79033b5e6a7e3c","type":"api-call-service","z":"6360d3b8.6f440c","name":"Turn ON HVAC","server":"4e34de6f.20a5d","version":5,"debugenabled":false,"domain":"climate","service":"turn_on","areaId":[],"deviceId":[],"entityId":["climate.1st_floor_thermostat_2","climate.house_hvac"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":900,"y":800,"wires":[[]]},{"id":"4ce281e195ad9ad6","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"06:30","endTime":"21:30","startOffset":0,"endOffset":0,"x":1230,"y":660,"wires":[["f40f8858214cb369"],["d05a72ac4b1d495d"]]},{"id":"f40f8858214cb369","type":"api-current-state","z":"6360d3b8.6f440c","name":"House Temp","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.1st_floor_thermostat_air_temperature_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":1430,"y":600,"wires":[["fa347b5878802b55"]]},{"id":"fa347b5878802b55","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"68","vt":"str"},{"t":"gte","v":"72","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1535,"y":600,"wires":[["6be56416837957d7"],["30a62c213b9a7f5c"],["e56030ccda9ec6ba"]],"l":false},{"id":"6be56416837957d7","type":"change","z":"6360d3b8.6f440c","name":"Heat 68","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"69","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1640,"y":560,"wires":[["8eed7c0145befad3"]]},{"id":"e56030ccda9ec6ba","type":"link out","z":"6360d3b8.6f440c","name":"HVAC OFF","links":["aabb81b3.2f426"],"x":1595,"y":640,"wires":[]},{"id":"8eed7c0145befad3","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1735,"y":580,"wires":[]},{"id":"d05a72ac4b1d495d","type":"api-current-state","z":"6360d3b8.6f440c","name":"House Temp","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.1st_floor_thermostat_air_temperature_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":1430,"y":720,"wires":[["efcfec6ea19515e5"]]},{"id":"30a62c213b9a7f5c","type":"change","z":"6360d3b8.6f440c","name":"Cool 72","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"72","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1640,"y":600,"wires":[["8eed7c0145befad3"]]},{"id":"efcfec6ea19515e5","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"68","vt":"str"},{"t":"gt","v":"70","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1535,"y":720,"wires":[["a79005a8f9058553"],["302b44d90f9be21e"],["06f6260613914a52"]],"l":false},{"id":"a79005a8f9058553","type":"change","z":"6360d3b8.6f440c","name":"Heat 68","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"68","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1640,"y":680,"wires":[["04d7e513150c9719"]]},{"id":"04d7e513150c9719","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1735,"y":700,"wires":[]},{"id":"06f6260613914a52","type":"link out","z":"6360d3b8.6f440c","name":"HVAC OFF","links":["aabb81b3.2f426"],"x":1595,"y":760,"wires":[]},{"id":"302b44d90f9be21e","type":"change","z":"6360d3b8.6f440c","name":"Cool 71","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"71","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1640,"y":720,"wires":[["04d7e513150c9719"]]},{"id":"325bd8dd8ca784bc","type":"link out","z":"6360d3b8.6f440c","name":"HVAC OFF","links":["aabb81b3.2f426"],"x":1345,"y":1400,"wires":[]},{"id":"e9230831986bd404","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"68","vt":"str"},{"t":"gte","v":"70","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1515,"y":1240,"wires":[["c64f2d50e90e1d4c"],["49867fa8427883be"],["49a4aec0d5e02382"]],"l":false},{"id":"97070e72283a1c0c","type":"api-current-state","z":"6360d3b8.6f440c","name":"House Temp","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.1st_floor_thermostat_air_temperature_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":1410,"y":1240,"wires":[["e9230831986bd404"]]},{"id":"49a4aec0d5e02382","type":"link out","z":"6360d3b8.6f440c","name":"HVAC OFF","links":["aabb81b3.2f426"],"x":1575,"y":1280,"wires":[]},{"id":"c64f2d50e90e1d4c","type":"change","z":"6360d3b8.6f440c","name":"Heat 67","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temperature","pt":"msg","to":"67","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1620,"y":1200,"wires":[["58f848d83a6a51ce"]]},{"id":"49867fa8427883be","type":"change","z":"6360d3b8.6f440c","name":"Cool 75","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temperature","pt":"msg","to":"75","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1620,"y":1240,"wires":[["58f848d83a6a51ce"]]},{"id":"58f848d83a6a51ce","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1715,"y":1220,"wires":[]},{"id":"ac9c3b10a6731b3f","type":"api-current-state","z":"6360d3b8.6f440c","name":"Guest Mode","server":"4e34de6f.20a5d","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.guest_mode","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":810,"y":880,"wires":[["ee060e21325c17f9"],["d61443c6dbde0f10"]]},{"id":"ee060e21325c17f9","type":"api-current-state","z":"6360d3b8.6f440c","name":"House Temp","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.1st_floor_thermostat_air_temperature_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":690,"y":1520,"wires":[["c0fc8e170342ff36"]]},{"id":"c0fc8e170342ff36","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"68","vt":"str"},{"t":"gte","v":"72","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":795,"y":1520,"wires":[["4484cd0f3979a758"],["df470d999a7afdea"],["e648e73a5931a69a"]],"l":false},{"id":"4484cd0f3979a758","type":"change","z":"6360d3b8.6f440c","name":"Heat 68","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"68","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":1480,"wires":[["70090c425abbb77d"]]},{"id":"df470d999a7afdea","type":"api-current-state","z":"6360d3b8.6f440c","name":"Outside Climate","server":"4e34de6f.20a5d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.outside_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":920,"y":1520,"wires":[["9d24c5e23bd8460d"]]},{"id":"9d24c5e23bd8460d","type":"switch","z":"6360d3b8.6f440c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Very Hot","vt":"str"},{"t":"eq","v":"Hot","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1035,"y":1520,"wires":[["ec3b423a969cb434"],["ec3b423a969cb434"],["0033b219f65f1ab8"]],"l":false},{"id":"7eb3425d0c7c628b","type":"change","z":"6360d3b8.6f440c","name":"Cool 72","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"72","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":1500,"wires":[["c7141f588980e093"]]},{"id":"0033b219f65f1ab8","type":"change","z":"6360d3b8.6f440c","name":"Cool 70","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"70","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":1540,"wires":[["c7141f588980e093"]]},{"id":"e648e73a5931a69a","type":"link out","z":"6360d3b8.6f440c","name":"HVAC OFF","links":["aabb81b3.2f426"],"x":855,"y":1560,"wires":[]},{"id":"c7141f588980e093","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":1405,"y":1520,"wires":[]},{"id":"ec3b423a969cb434","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"08:00","endTime":"19:30","startOffset":0,"endOffset":0,"x":1150,"y":1500,"wires":[["7eb3425d0c7c628b"],["0033b219f65f1ab8"]]},{"id":"70090c425abbb77d","type":"link out","z":"6360d3b8.6f440c","name":"Call Service","links":["4c23b0d2.6350c"],"x":995,"y":1480,"wires":[]},{"id":"e89aaf4c960ec90c","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"06:30","endTime":"20:00","startOffset":0,"endOffset":0,"x":1400,"y":1020,"wires":[["d72e4607dbc783ea"],["2f09d7d9d93ffbe3"]]},{"id":"d72e4607dbc783ea","type":"change","z":"6360d3b8.6f440c","name":"Cool 77","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"77","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1570,"y":1000,"wires":[["4f7339e9.712ac8"]]},{"id":"2f09d7d9d93ffbe3","type":"change","z":"6360d3b8.6f440c","name":"Cool 72","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"cool","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"72","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1570,"y":1040,"wires":[["4f7339e9.712ac8"]]},{"id":"45da942042b9b65a","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"07:00","endTime":"21:30","startOffset":0,"endOffset":0,"x":1250,"y":840,"wires":[["f48a0ee2.94548"],["45e13dcd62c29707","f20bd3d695894d99"]]},{"id":"304c3a743885fdcc","type":"change","z":"6360d3b8.6f440c","name":"Heat 68","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"68","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1560,"y":840,"wires":[["c4ab30f9.dd2fa"]]},{"id":"45e13dcd62c29707","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"21:30","endTime":"23:00","startOffset":0,"endOffset":0,"x":1410,"y":840,"wires":[["304c3a743885fdcc"],[]]},{"id":"e85a73da3c439662","type":"change","z":"6360d3b8.6f440c","name":"Heat 67","rules":[{"t":"set","p":"set_hvac_mode","pt":"msg","to":"heat","tot":"str"},{"t":"set","p":"set_temp","pt":"msg","to":"67","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1560,"y":880,"wires":[["c4ab30f9.dd2fa"]]},{"id":"f20bd3d695894d99","type":"time-range-switch","z":"6360d3b8.6f440c","name":"","lat":"","lon":"","startTime":"23:00","endTime":"07:00","startOffset":0,"endOffset":0,"x":1410,"y":880,"wires":[["e85a73da3c439662"],[]]},{"id":"af5189e11ec0ef0c","type":"server-state-changed","z":"6360d3b8.6f440c","name":"House Occupied - Lindy","server":"4e34de6f.20a5d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"person.lindy","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":880,"wires":[[]]},{"id":"d61443c6dbde0f10","type":"api-current-state","z":"6360d3b8.6f440c","name":"","server":"4e34de6f.20a5d","version":3,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is","entity_id":"person.lindy","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1060,"y":920,"wires":[["9c6c937b.85da3"],["17d907689e7efc3b"]]},{"id":"17d907689e7efc3b","type":"api-current-state","z":"6360d3b8.6f440c","name":"","server":"4e34de6f.20a5d","version":3,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is","entity_id":"person.thomas","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1060,"y":980,"wires":[["9c6c937b.85da3"],["48ec038.20922fc"]]},{"id":"fdcc56ca2bfe1e8e","type":"server-state-changed","z":"6360d3b8.6f440c","name":"Guest Mode Boolean","server":"4e34de6f.20a5d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.guest_mode","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":1040,"wires":[["563c2245.645fdc"]]},{"id":"702f947ffe8fe311","type":"server-state-changed","z":"6360d3b8.6f440c","name":"Overnight Guest Mode","server":"4e34de6f.20a5d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.overnight_guest_mode","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":1000,"wires":[["563c2245.645fdc"]]},{"id":"6601bb9c01fc3014","type":"api-call-service","z":"6360d3b8.6f440c","name":"Set HVAC Mode","server":"4e34de6f.20a5d","version":5,"debugenabled":false,"domain":"climate","service":"set_hvac_mode","areaId":[],"deviceId":["6d427c71238faf58442e17e62a847285","b9a024efef69c14a0b0864c5dafd2e18"],"entityId":["climate.1st_floor_thermostat_2","climate.2nd_floor_thermostat"],"data":"{\"hvac_mode\":set_hvac_mode}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2240,"y":880,"wires":[["39ba09db2e34ed8b"]]},{"id":"c338309d2f9ec5b5","type":"api-call-service","z":"6360d3b8.6f440c","name":"Set temp","server":"4e34de6f.20a5d","version":5,"debugenabled":false,"domain":"climate","service":"set_temperature","areaId":[],"deviceId":[],"entityId":["climate.1st_floor_thermostat_2","climate.2nd_floor_thermostat"],"data":"{\"temperature\":\"{{set_temp}}\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2400,"y":960,"wires":[["6749951c59538ec1"]]},{"id":"79157f7b977b46d1","type":"api-call-service","z":"6360d3b8.6f440c","name":"Turn OFF HVAC","server":"4e34de6f.20a5d","version":5,"debugenabled":false,"domain":"climate","service":"turn_off","areaId":[],"deviceId":[],"entityId":["climate.1st_floor_thermostat_2","climate.2nd_floor_thermostat","climate.t6_pro_z_wave_programmable_thermostat_3"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2240,"y":1020,"wires":[[]]},{"id":"3006c21d930f28cc","type":"comment","z":"6360d3b8.6f440c","name":"3rd Floor","info":"\"UI automation - if 1st floor is on heat,\n3rd is on heat. If 1st is on cool,\n3rd is on cool.\"","x":2400,"y":760,"wires":[]},{"id":"39ba09db2e34ed8b","type":"debug","z":"6360d3b8.6f440c","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2500,"y":880,"wires":[]},{"id":"6749951c59538ec1","type":"debug","z":"6360d3b8.6f440c","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2640,"y":940,"wires":[]},{"id":"4e34de6f.20a5d","type":"server","name":"Home Assistant","addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false}]
Created 3 years, 4 months ago
Rating: 4 1
  • change (x28)
  • comment (x3)
  • debug (x2)
  • delay (x2)
  • inject (x3)
  • link in (x2)
  • link out (x19)
  • switch (x11)
