Using Trained model with Smartthings IoTcam and mediapipe flow
main_flow
This flow is make predict using pre-trained model using SamsungSmartThings Home camera and mediapipe.
Requirement
installation
  • Node-Red
  • ffmpeg
  • python
npm
  • SamsungAutomationStudio
    npm install node-red-contrib-samsung-automation-studio-nodes
  • ffmpeg-iotcam
    npm install node-red-contrib-ffmpeg-iotcam
  • mediapipe
    npm install node-red-contrib-mediapipe
  • tfjs-node
    npm install @tensorflow/tfjs-node
    • Add tf-js in GlobalContext PATH: user_home_directory\\.node-red\setting.js
      functionGlobalContext: {
          tfnModule: require("@tensorflow/tfjs-node"),
  • tfmodel
    npm install node-red-contrib-tf-model
Value setting
  1. Start node-red
  2. Set PAT in Mydevice Node
  3. Set status node's device to your smartthings device
  4. Set command node's capability to startStrema
  5. Fill out iotcam2img node
    • smartThingMnid, PAT, saveURL, is necessary
  6. Set path that your model.json located in tfmodel node.
  7. If you want to send result to galaxy home mini, set http request node's deviceId and bearer token(smartthings PAT)
execute
  1. Open Mediapipe server
  2. Click the smart button connected in status Node.
    • If you don't have device, Flow trigger can be replaced to inject node.
  3. You can see result in debug console.
[{"id":"11d78d2f.d6c8e3","type":"tab","label":"empty flow","disabled":true,"info":""},{"id":"2ed165ee.67ec8a","type":"installed-device","z":"11d78d2f.d6c8e3","name":"","alias":"token:194798e1","device":"","devices":["1b17f114-acff-4c25-a4cf-2459af69f369","51d084c2-a8d2-4966-9624-18b8adaab221","236ab083-eecf-101c-e230-286ed126ef06","ecc14b61-c49d-9e25-7087-fd0dc9ecbc3b","7ea0eda7-101d-2896-d7f8-57997ee022f0","91205853-dab4-3e5f-c009-e621b9824b1c","4e083c8b-4a4f-4518-2eeb-887c5a7131c6","7182a570-8e4f-2112-2c20-a10916f9bd56","158cf65e-dc2d-c58b-6506-f02595f6d98c","7e5f6017-2a28-6b82-1ab3-7b16e8ee7727","6b429d72-b358-1c5f-9fea-745ea3780439","cc5f82f5-f6d5-16a3-ccdb-1baf7a345629","1e2418e2-6009-f156-6c99-bc5964af63a6","c20b8fa0-ba57-41be-963e-e5669788afb3","e0161013-412b-4a33-a3b6-c6a42ec0f95e"],"profileId":"2ed165ee.67ec8a","credentials":{"stAccessToken":""},"x":240,"y":140,"wires":[]},{"id":"d0be07df.a12318","type":"status-device","z":"11d78d2f.d6c8e3","name":"Get camera status","alias":"홈카메라 360 집","deviceNodeId":"2ed165ee.67ec8a","deviceType":"installed-device","deviceId":"51d084c2-a8d2-4966-9624-18b8adaab221","componentId":"","capabilityId":"audioStream_v1","attributeId":"uri","rules":[],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":650,"y":300,"wires":[["6e03412c.0cb24"]]},{"id":"5f53ff8.2e504","type":"command-device","z":"11d78d2f.d6c8e3","name":"Start Stream","alias":"startStream","deviceNodeId":"2ed165ee.67ec8a","deviceType":"installed-device","deviceId":"51d084c2-a8d2-4966-9624-18b8adaab221","componentId":"","capabilityId":"videoStream_v1","attributeId":"startStream","rules":[],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":450,"y":300,"wires":[["d0be07df.a12318"]]},{"id":"d71c4404.d710c8","type":"open","z":"11d78d2f.d6c8e3","x":1170,"y":420,"wires":[["9fc13c2147688f80"]]},{"id":"b66b02c9.4db5f","type":"inject","z":"11d78d2f.d6c8e3","name":"Start server","props":[],"repeat":"","crontab":"","once":false,"onceDelay":"0.5","topic":"","x":1030,"y":420,"wires":[["d71c4404.d710c8"]]},{"id":"68a90614.543788","type":"inject","z":"11d78d2f.d6c8e3","name":"Close server","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":1030,"y":460,"wires":[["4233833a.a19dac"]]},{"id":"4233833a.a19dac","type":"close","z":"11d78d2f.d6c8e3","x":1170,"y":460,"wires":[["697f6c5fe867b5f5"]]},{"id":"b98de526.755cb8","type":"iotcam2img","z":"11d78d2f.d6c8e3","rtspURL":"","saveURL":"","totalFrame":"","timer":"","name":"Iotcam2img Node","x":1110,"y":300,"wires":[[],[],[]]},{"id":"6e03412c.0cb24","type":"function","z":"11d78d2f.d6c8e3","name":"Parse rtspURL","func":"msg.rtspURL = msg.payload.components.main.videoStream.stream.value.OutHomeURL;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":840,"y":300,"wires":[["b98de526.755cb8"]]},{"id":"d1ba3c0c.982d7","type":"inject","z":"11d78d2f.d6c8e3","name":"Polling button status","props":[],"repeat":"0.2","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":260,"y":220,"wires":[["d494e4d8.8f6178"]]},{"id":"691f7fad.e39b4","type":"function","z":"11d78d2f.d6c8e3","name":"Check button pushed","func":"const value = msg.payload.components.main.button.button.value;\nconst timestamp = msg.payload.components.main.button.button.timestamp;\nconst gTimestamp = flow.get(\"buttonTime\");\n\nif(gTimestamp && value === 'pushed' && timestamp != gTimestamp){\n    flow.set(\"buttonTime\", timestamp);\n    return {payload: null};\n} \n\nflow.set(\"buttonTime\", timestamp);","outputs":1,"noerr":0,"initialize":"","finalize":"","x":660,"y":220,"wires":[["5f53ff8.2e504"]]},{"id":"d494e4d8.8f6178","type":"status-device","z":"11d78d2f.d6c8e3","name":"Button status","alias":"Button 2","deviceNodeId":"2ed165ee.67ec8a","deviceType":"installed-device","deviceId":"53d6a638-9733-484d-9e56-ccdf4bf9228b","componentId":"","capabilityId":"battery_v1","attributeId":"battery","rules":[],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":470,"y":220,"wires":[["691f7fad.e39b4"]]},{"id":"a6781e38.413f4","type":"function","z":"11d78d2f.d6c8e3","name":"Accumulate keypoints","func":"let landmarks = flow.get(\"landmarks\");\n\nlandmarks.push(msg.payload);\n\nflow.set(\"landmarks\", landmarks);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":260,"y":500,"wires":[["71c4cec.da0263"]]},{"id":"71c4cec.da0263","type":"function","z":"11d78d2f.d6c8e3","name":"Check ready to predict","func":"if(flow.get(\"landmarks\").length == flow.get(\"totalFrame\")){\n    msg.payload = [flow.get('landmarks')];\n    \n    return msg;    \n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":500,"wires":[["ff32ba59.a00468"]]},{"id":"d4e104eb.352bf8","type":"watch","z":"11d78d2f.d6c8e3","name":"Capturing watcher","files":"","recursive":"","x":250,"y":440,"wires":[["52684c5d.0efa24"]]},{"id":"ff32ba59.a00468","type":"function","z":"11d78d2f.d6c8e3","name":"Convert landmarks to tensor","func":"const tf = global.get('tfnModule')\n\nreturn {payload : tf.tensor3d(msg.payload)};\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":760,"y":500,"wires":[["978952e7.a0414"]]},{"id":"2683b81b.79a338","type":"function","z":"11d78d2f.d6c8e3","name":"Parse predict result","func":"const tf = global.get('tfnModule')\n\nconst data = msg.payload.dataSync();\nconsole.log(data);\nmsg.payload = data.indexOf(Math.max(...data));\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":490,"y":560,"wires":[["2261b5f8.7f550a","aa6972ccf8c2eefa"]]},{"id":"2261b5f8.7f550a","type":"function","z":"11d78d2f.d6c8e3","name":"Trans index to sentence","func":"const actions = [\"CallThePolice\",\"CanMyFamilyGetIt\",\"CanTheAgentPickItUp\",\"CanYouSpeakSlowly\",\"GoOutNow\",\"HaveToDoSign\",\"HoldOnASecondPlz\",\"INeverOrderedIt\",\"NeverOrderedAPackage\",\"No\",\"NotAtHomeNow\",\"OpenTheDoorForYou\",\"PlzComeBackNextTime\",\"PlzLeaveItInFrontOfTheDeliveryHouse\",\"PlzLeaveYourContactNumber\",\"PlzUnderstandIfTheAnswerIsSlow\",\"PressTheButtonAgain\",\"ThxPlzLeaveItAtTheDoor\",\"ThxUDeliveryMan\",\"WhatsTheContentsOfThePackage\",\"WhatsTheMatter\",\"WhereIsThisRegisteredMailFrom\",\"WhoRU\",\"WillBeCareful\",\"Yes\",\"YouCameToWrongPlace\"];\n\n\nmsg.payload = actions[msg.payload];\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":560,"wires":[["ebd1918c.fafbe"]]},{"id":"fc35417.32f3ac","type":"http request","z":"11d78d2f.d6c8e3","name":"Send to speaker","method":"POST","ret":"obj","paytoqs":"ignore","url":"https://api.smartthings.com/v1/devices/{devide_id}/commands","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"bearer","senderr":false,"headers":[],"x":1200,"y":560,"wires":[[]]},{"id":"ebd1918c.fafbe","type":"change","z":"11d78d2f.d6c8e3","name":"Make result format","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"commands\":[\t       {\t           \"component\":\"main\",\t           \"capability\":\"samsungim.announcement\",\t           \"command\":\"announce\",\t           \"arguments\":[\t               \"text\",\t               \"text/plain\",\t               \"\",\t               \"none\",\t               $.payload\t           ]\t       }\t   ]\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":560,"wires":[["fc35417.32f3ac"]]},{"id":"978952e7.a0414","type":"tf-model","z":"11d78d2f.d6c8e3","modelURL":"file://","outputNode":"","name":"","x":250,"y":560,"wires":[["2683b81b.79a338"]]},{"id":"52684c5d.0efa24","type":"holistic","z":"11d78d2f.d6c8e3","x":460,"y":440,"wires":[["a6781e38.413f4"]]},{"id":"9fc13c2147688f80","type":"debug","z":"11d78d2f.d6c8e3","name":"debug 17","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1300,"y":420,"wires":[]},{"id":"697f6c5fe867b5f5","type":"debug","z":"11d78d2f.d6c8e3","name":"debug 18","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1300,"y":460,"wires":[]},{"id":"ddcd381ed91b4e89","type":"inject","z":"11d78d2f.d6c8e3","name":"Start capturing","props":[],"repeat":"","crontab":"","once":false,"onceDelay":"0.5","topic":"","x":260,"y":300,"wires":[["5f53ff8.2e504"]]},{"id":"aa6972ccf8c2eefa","type":"debug","z":"11d78d2f.d6c8e3","name":"result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":690,"y":620,"wires":[]}]
Created 4 years ago
  • change (x1)
  • debug (x3)
  • function (x7)
  • http request (x1)
  • inject (x4)
  • watch (x1)
  • node-red-contrib-ffmpeg-iotcam
  • node-red-contrib-mediapipe
  • ffmpeg
  • mediapipe
  • samsung-smartthings
  • rtsp
  • socket
