node-red-contrib-mediapipe 0.0.2
Mediapipe hands and pose detection in real-time in Node-RED
npm install node-red-contrib-mediapipe
There is a problem that mediapipe cannot be used in nodejs. We present a new solution to solve this problem.
This module provides a set of nodes of node-RED for recognizing poses and hands using mediapipe.
In this module, Node receives the image and returns the result of detection with mediapipe.
Description
The module consists of three nodes. Open/Close/Holistic.
In this module, the mediapipe is executed in python and the result is received.
Therefore, use the Open/Close node to execute Mediapipe Python server.
After opening, the Holistic Node sends the requested image to Python and receives execution results.
These nodes require Node.js version 16.16.0 and Node-RED 1.2.9.
Principle
Nodes runs Mediapipe on Python and nodes exchange requests and responses through socket communication.
This node offers fewer features, but there are many areas that developers can add.
Detailed usage and internal code can be found here Wiki.
Pre-requisites
  • The Mediapipe-Node requires Node-RED to be installed.
  • Python must be installed. Download
  • run the following command in you Node-RED user directory - typically ~/.node-red :
npm i node-red-contrib-mediapipe
  • Install the Python packages below.
pip install opencv-python==4.6.0.66
pip install mediapipe==0.8.11
pip install numpy==1.21.6
Authors
TeamWildWest in SSAFY(Samsung Software Academy for Youth)
Copyright and license
Copyright Samsung Automation Studio Team under the Apache 2.0 license.
Reference
Version: 0.0.2
Updated 4 years, 5 months ago
License: Apache 2.0
2 in the last week
  • open
  • close
  • holistic
  • Mediapipe
