Octopus Energy API
Get 30min meter date for a specified date from the Octopus Energy (UK) API
You will need to set your MPAN and Meter Serial Number and Octopus API Key in the Initial Inject Node along with the appropriate date period.
[{"id":"010402d423958e86","type":"http request","z":"588471cd.c1fe18","name":"GET Import","method":"GET","ret":"obj","paytoqs":"query","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"credentials":{},"x":430,"y":140,"wires":[["108fff787f41944e"]]},{"id":"f72551ba820dc87e","type":"inject","z":"588471cd.c1fe18","name":"","props":[{"p":"payload.period_from","v":"2022-01-01T00:00:00+0100","vt":"str"},{"p":"payload.period_to","v":"2022-01-01T23:59:00+0100","vt":"str"},{"p":"payload.page_size","v":"25000","vt":"str"},{"p":"mpan","v":"2200123456","vt":"str"},{"p":"meter","v":"19P987654","vt":"str"},{"p":"apikey","v":"sk_live_12345667980","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":140,"wires":[["5f637811b82bdf02"]]},{"id":"93203cac3d97bf12","type":"debug","z":"588471cd.c1fe18","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":910,"y":140,"wires":[]},{"id":"f0b71ef7a3aa5f4d","type":"split","z":"588471cd.c1fe18","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":770,"y":140,"wires":[["93203cac3d97bf12"]]},{"id":"108fff787f41944e","type":"change","z":"588471cd.c1fe18","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.results","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":140,"wires":[["f0b71ef7a3aa5f4d"]]},{"id":"5f637811b82bdf02","type":"template","z":"588471cd.c1fe18","name":"","field":"url","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"https://{{apikey}}:@api.octopus.energy/v1/electricity-meter-points/{{mpan}}/meters/{{meter}}/consumption","output":"str","x":280,"y":140,"wires":[["010402d423958e86"]]}]
Created 4 years, 9 months ago
Rating: 3.6666666666666665 3
  • change (x1)
  • http request (x1)
  • split (x1)
  • template (x1)
