@d5mi/node-red-contrib-object-detection-notification-flow
Notification_flow
Pre-requisites
  • node-red-contrib-samsung-automation-studio-nodes
  • node-red-node-ui-list
  • node-red-contrib-mongodb4
  • node-red-dashboard
Notification Setting Flow
Create an alarm by setting the location, pose, time, and device to be controlled and register it in MongoDB.
  • You can select Object, Pose, Smart Things, running time.
  • If you press button, the notification will be registered
Notification call Flow
The log record stored in the database is called and when the time set in the notification comes, the user is notified through the device connected to SmartThings according to the conditions that match the option.
[{"id":"61769f8b354516d0","type":"inject","z":"f81ca60cb491eedf","name":"알람Flow","props":[{"p":"time","v":"","vt":"date"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":310,"y":700,"wires":[["be3571a33fced222"]]},{"id":"b62f78e11f6e893d","type":"ui_dropdown","z":"f81ca60cb491eedf","name":"","label":"장소","tooltip":"","place":"Select option","group":"233dcae6ee954e70","order":1,"width":6,"height":1,"passthru":false,"multiple":false,"options":[],"payload":"","topic":"optionSetLocation","topicType":"msg","className":"","x":950,"y":300,"wires":[["cc94f3f6dedb7f8b"]]},{"id":"e40e2fd525e61af4","type":"inject","z":"f81ca60cb491eedf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":450,"y":360,"wires":[["6db8b3e2572e16ce"]]},{"id":"6db8b3e2572e16ce","type":"function","z":"f81ca60cb491eedf","name":"MongoDB Database Request For Bar Chart","func":"\n\n        msg.payload = [\n            [{ $group: { \"_id\": \"$location\"} }]\n        ];\n        return msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":300,"wires":[["5163a08f78975d7d"]]},{"id":"5163a08f78975d7d","type":"mongodb4","z":"f81ca60cb491eedf","clientNode":"e4c17237ec481b9e","collection":"test3","operation":"aggregate","output":"toArray","name":"","x":660,"y":300,"wires":[["d8e1ef2673ca1459"]]},{"id":"d8e1ef2673ca1459","type":"function","z":"f81ca60cb491eedf","name":"parsing","func":"var jsonfile = msg.payload;\nvar labelArray = new Array();\n\nvar label =\"\";\n\nvar resultArray = jsonfile.map(elm => ((elm._id)));\n\n\n\nmsg.options = resultArray;\nreturn msg;\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":300,"wires":[["b62f78e11f6e893d"]]},{"id":"13f677558a820e4c","type":"ui_button","z":"f81ca60cb491eedf","name":"","group":"233dcae6ee954e70","order":5,"width":6,"height":1,"passthru":false,"label":"Submit","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"str","topic":"go","topicType":"str","x":940,"y":180,"wires":[["9ab40f04c3ccabcb"]]},{"id":"0c2be4a7050f8fe3","type":"ui_dropdown","z":"f81ca60cb491eedf","name":"","label":"포즈","tooltip":"","place":"Select option","group":"233dcae6ee954e70","order":2,"width":6,"height":1,"passthru":false,"multiple":true,"options":[],"payload":"","topic":"optionSetPose","topicType":"msg","className":"","x":950,"y":260,"wires":[["03bf5c2cfd1a6a5f"]]},{"id":"9ab40f04c3ccabcb","type":"function","z":"f81ca60cb491eedf","name":"Store Data","func":"var locationData = flow.get(\"locationData\") || 0; //get from context or default to 0\nvar timeData = flow.get(\"timeData\") || 0; //get from context or default to 0\nvar poseData = flow.get(\"poseData\") || [];\nvar deviceData = flow.get(\"deviceData\")|| 0;\n\nvar alarmDataArray = flow.get(\"alarmDataArray\") || [];\n\nswitch (msg.topic){\n\n    case \"optionSetTime\":\n        timeData = msg.payload;\n        if(timeData < 1){\n            node.warn(\"1분 이상으로 설정해 주세요!\");\n            return;\n        }\n           \n        flow.set(\"timeData\", timeData);//store in context for next time \n        return;\n        \n    case \"optionSetPose\":\n        poseData =msg.payload;\n        flow.set(\"poseData\", poseData); //store in context for next time \n        return;\n\n    case \"optionSetLocation\":\n        locationData = msg.payload;\n        flow.set(\"locationData\", locationData); //store in context for next time \n        return; \n\n    case \"optionSetDevice\":\n        deviceData = msg.payload;\n        flow.set(\"deviceData\", deviceData);\n        return;\n    case \"go\":\n    {\n            if (locationData === 0 || timeData === 0 || poseData === 0 || deviceData === 0){\n                node.warn(\"드롭 다운 데이터를 모두 입력해주세요!\");\n            }else{\n\n                msg.payload = [{ \"location\": locationData, \"setTime\": Number(timeData) * 60, \"poseData\": poseData, \"timestamp\": new Date(), \"deviceData\": deviceData}];\n\n\n            }\n\n    }\n\n      \n    \n}\n\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1290,"y":280,"wires":[["17a25196ad918e9e"]]},{"id":"3f82db868256c0fd","type":"change","z":"f81ca60cb491eedf","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"optionSetTime","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1110,"y":220,"wires":[["9ab40f04c3ccabcb"]]},{"id":"03bf5c2cfd1a6a5f","type":"change","z":"f81ca60cb491eedf","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"optionSetPose","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1110,"y":260,"wires":[["9ab40f04c3ccabcb"]]},{"id":"cc94f3f6dedb7f8b","type":"change","z":"f81ca60cb491eedf","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"optionSetLocation","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1110,"y":300,"wires":[["9ab40f04c3ccabcb"]]},{"id":"9ee27c965f06d4a3","type":"ui_list","z":"f81ca60cb491eedf","group":"233dcae6ee954e70","name":"","order":6,"width":6,"height":8,"lineType":"three","actionType":"check","allowHTML":true,"outputs":1,"topic":"","x":1330,"y":500,"wires":[["43964845227f8522"]]},{"id":"43964845227f8522","type":"function","z":"f81ca60cb491eedf","name":"function 20","func":"var selectedObject = msg.payload;\n\nif (selectedObject.isChecked){\n    var selectedIdx = selectedObject._id;\n\n    msg.payload = [{ \"_id\": selectedIdx }];\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1330,"y":540,"wires":[["0d62df9b1b58c023"]]},{"id":"17a25196ad918e9e","type":"mongodb4","z":"f81ca60cb491eedf","clientNode":"e5eea5fa320c8736","collection":"optionSave","operation":"insert","output":"toArray","name":"","x":1450,"y":280,"wires":[["f5f08f431c515551"]]},{"id":"0d62df9b1b58c023","type":"mongodb4","z":"f81ca60cb491eedf","clientNode":"e5eea5fa320c8736","collection":"optionSave","operation":"remove","output":"toArray","name":"","x":1540,"y":460,"wires":[["f5f08f431c515551"]]},{"id":"7c7845482ee591f7","type":"inject","z":"f81ca60cb491eedf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":470,"y":200,"wires":[["5dbbc13bb7644c79"]]},{"id":"5dbbc13bb7644c79","type":"function","z":"f81ca60cb491eedf","name":"MongoDB Database Request For Bar Chart","func":"\n\n        msg.payload = [\n            [{ $group: { \"_id\": \"$pose\"} }]\n        ];\n        return msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":260,"wires":[["7fabe84bdbb87fc9"]]},{"id":"7fabe84bdbb87fc9","type":"mongodb4","z":"f81ca60cb491eedf","clientNode":"e4c17237ec481b9e","collection":"test3","operation":"aggregate","output":"toArray","name":"","x":660,"y":260,"wires":[["9103b91432ff4133"]]},{"id":"9103b91432ff4133","type":"function","z":"f81ca60cb491eedf","name":"parsing","func":"var jsonfile = msg.payload;\nvar labelArray = new Array();\n\nvar label =\"\";\n\nvar resultArray = jsonfile.map(elm => ((elm._id)));\n\n\n\nmsg.options = resultArray;\nreturn msg;\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":260,"wires":[["0c2be4a7050f8fe3"]]},{"id":"8240322e0d6c8f9c","type":"ui_text_input","z":"f81ca60cb491eedf","name":"","label":"분","tooltip":"","group":"233dcae6ee954e70","order":4,"width":0,"height":0,"passthru":true,"mode":"number","delay":"0","topic":"topic","sendOnBlur":true,"className":"","topicType":"msg","x":950,"y":220,"wires":[["3f82db868256c0fd"]]},{"id":"f5f08f431c515551","type":"function","z":"f81ca60cb491eedf","name":"findAll","func":"\nmsg.payload=[{}];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1470,"y":360,"wires":[["c2d30e5c6961712b"]]},{"id":"c2d30e5c6961712b","type":"mongodb4","z":"f81ca60cb491eedf","clientNode":"e5eea5fa320c8736","collection":"optionSave","operation":"find","output":"toArray","name":"","x":1610,"y":360,"wires":[["9218fe3cdd7a9190"]]},{"id":"9218fe3cdd7a9190","type":"function","z":"f81ca60cb491eedf","name":"function 21","func":"var alarmDataArray = msg.payload;\nvar alarmHtmlArray = [];\n\nfor (var i = 0; i < alarmDataArray.length;i++){\n    var locationDataHtml = \"<b>\" + alarmDataArray[i].location + \"</b>\";\n    var description = alarmDataArray[i].setTime / 60 + \" 분 동안 \" + alarmDataArray[i].poseData + \" 동작을 할때 알림 \\n\" + \"동작 기기 \"+alarmDataArray[i].deviceData;\n    alarmHtmlArray.push({ \"title\": locationDataHtml, \"description\": description, \"_id\": alarmDataArray[i]._id, \"isChecked\": false});\n    }\n\nmsg.payload = alarmHtmlArray;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1330,"y":460,"wires":[["9ee27c965f06d4a3"]]},{"id":"68a37468861af23f","type":"inject","z":"f81ca60cb491eedf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1270,"y":360,"wires":[["f5f08f431c515551"]]},{"id":"be3571a33fced222","type":"function","z":"f81ca60cb491eedf","name":"findAll","func":"msg.payload=[{}];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":450,"y":700,"wires":[["48fa44773719e1ad"]]},{"id":"48fa44773719e1ad","type":"mongodb4","z":"f81ca60cb491eedf","clientNode":"e5eea5fa320c8736","collection":"optionSave","operation":"find","output":"toArray","name":"","x":570,"y":700,"wires":[["0d8b5c97ac484a33"]]},{"id":"0d8b5c97ac484a33","type":"split","z":"f81ca60cb491eedf","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":710,"y":700,"wires":[["137045f2d05fbfb9"]]},{"id":"137045f2d05fbfb9","type":"function","z":"f81ca60cb491eedf","name":"function 29","func":"var t = new Date(msg.time);\n\nvar alarmData = msg.payload ;\nvar startDate = alarmData.timestamp;\nstartDate = new Date(startDate);\n\n\n\nt = new Date();\n////\n\nt.setMilliseconds(0);\n\n\n\nmsg.payload = [\n    [\n    \n        { $match: { \"location\": alarmData.location ,\"timestamp\": { $gte: new Date(startDate), $lte: t },\"pose\": { \"$in\": alarmData.poseData}}},\n        { $group: { _id: alarmData._id, payload: { $sum: 1 } } }\n    ]\n];\n\nmsg.data =alarmData;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":850,"y":700,"wires":[["c111de47c49e5145"]]},{"id":"c111de47c49e5145","type":"mongodb4","z":"f81ca60cb491eedf","clientNode":"e4c17237ec481b9e","collection":"test3","operation":"aggregate","output":"forEach","name":"","x":1020,"y":700,"wires":[["3c2fedaf23f7700e"]]},{"id":"3c2fedaf23f7700e","type":"function","z":"f81ca60cb491eedf","name":"function 30","func":"//aggregation을 통해 가져온 데이터\nvar sumData = msg.payload;\n\n//현재 입력되어있는 옵션 데이터\nvar curData = msg.data;\n\n//알람 울리는 조건 만족\nif(sumData.payload >= curData.setTime){\n\n    msg.alarm = curData.deviceData;\n    msg.payload = [{ \"_id\": curData._id }, { \"$set\": { timestamp: new Date() }}];\n    return msg;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1190,"y":700,"wires":[["ac865ed73016e0c2","84adecf89d4f6803"]]},{"id":"df864e103623bc71","type":"switch","z":"f81ca60cb491eedf","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"가상스위치","vt":"str"},{"t":"eq","v":"가상스위치2","vt":"str"},{"t":"eq","v":"전구","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":1690,"y":700,"wires":[[],[],[]]},{"id":"ac865ed73016e0c2","type":"mongodb4","z":"f81ca60cb491eedf","clientNode":"e4c17237ec481b9e","collection":"optionSave","operation":"update","output":"forEach","name":"","x":1190,"y":780,"wires":[[]]},{"id":"d2fad0547015f6d3","type":"ui_dropdown","z":"f81ca60cb491eedf","name":"","label":"기기","tooltip":"","place":"Select option","group":"233dcae6ee954e70","order":3,"width":0,"height":0,"passthru":false,"multiple":true,"options":[{"label":"가상스위치","value":"가상스위치","type":"str"},{"label":"가상스위치2","value":"가상스위치2","type":"str"},{"label":"전구","value":"전구","type":"str"}],"payload":"","topic":"topic","topicType":"msg","className":"","x":910,"y":400,"wires":[["030087f07e012030"]]},{"id":"030087f07e012030","type":"change","z":"f81ca60cb491eedf","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"optionSetDevice","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1070,"y":400,"wires":[["9ab40f04c3ccabcb"]]},{"id":"55f03bb28bceb677","type":"split","z":"f81ca60cb491eedf","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":1550,"y":700,"wires":[["df864e103623bc71"]]},{"id":"84adecf89d4f6803","type":"function","z":"f81ca60cb491eedf","name":"function 31","func":"\nmsg.payload = msg.alarm\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1390,"y":700,"wires":[["55f03bb28bceb677"]]},{"id":"233dcae6ee954e70","type":"ui_group","name":"Alarm","tab":"deebf5652e8a622b","order":4,"disp":true,"width":"6","collapse":false,"className":""},{"id":"e4c17237ec481b9e","type":"mongodb4-client","name":"AWS mongoDB","protocol":"mongodb","hostname":"J7S005.p.ssafy.io","port":"","dbName":"flow_db","authSource":"","authMechanism":"DEFAULT","tls":false,"tlsCAFile":"","tlsInsecure":false,"uri":"","advanced":"","uriTabActive":"tab-uri-simple"},{"id":"e5eea5fa320c8736","type":"mongodb4-client","name":"","protocol":"mongodb","hostname":"J7S005.p.ssafy.io","port":"","dbName":"flow_db","authSource":"","authMechanism":"DEFAULT","tls":false,"tlsCAFile":"","tlsInsecure":false,"uri":"","advanced":"","uriTabActive":"tab-uri-simple"},{"id":"deebf5652e8a622b","type":"ui_tab","name":"Alarm","icon":"dashboard","disabled":false,"hidden":false}]
Created 3 years, 8 months ago
Rating: 5 2
  • change (x4)
  • function (x12)
  • inject (x4)
  • split (x2)
  • switch (x1)
  • @d5mi/node-red-contrib-object-detection
  • dashboard
