mqtt and Homekit for Shelly RGBW2
This flow can control the Shelly RGBW2 and sets the user interface accordingly. Some text might be in Dutch, sorry.
The flow does multiple things:
  1. It sets the values using Homekit or Node-RED UI and send the mqtt commands.
  2. It listens to the mqtt commands and set the switches and HSL & HSL values in the Home app & Node-RED UI accordingly.
  3. It converts from RGB to HSL and visa versa.
  4. It prevents an infinite loop which seems to be a feature of homekit-service.
  5. It works with RGB and the White channel, in Homekit this creates 1 dimmer light and 1 RGB light.
  6. All the debug nodes are still in the flow
This flow has some custom javascript because that is my preferred way to handle the message (msg) flow. As you will see, I prefer to set the msg.topic within my function node.
There is a funny rounding 'error' when converting HSL to RGB and back. Not dealing with this makes the luminosity go down every 30 seconds (when the RGBW2 sends its periodic status). I 'fixed' it using Math.round, it works but is not the most elegant solution.
It also stores the HSL values for this flow (flow.get, flow.set) to use them to supplement the incomplete homekit-service messages which sometimes only contain 'Brightness', or 'Hue & Saturation'.
The device in this example is called Regenboog (which is Dutch for rainbow). Personally I use a text editor to rename the device in the JSON file to give it a new name. I guess using an inject node could also work.
Let me know if you have improvements.
Have fun,
Bas Nelissen
[{"id":"506075f2.fc33c4","type":"comment","z":"4d2d578e.6cea28","name":"README Shelly RGBW 2","info":"// README in Dutch\nIk moest even uitvogelen wat precies wat is. Zoals ik het nu begrijp:\n\nJe kan de RGB kleuren mixen door de waardes van red, green, blue een waarde te geven van 0...255. Nu kan je met de gain 0...100 bepalen hoe vel de red, green, blue moet branden.\n\nVerder is er nog een white kanaal, dit kanaal stuurt de apparte strook witte leds aan. White kan je instellen van 0...255.\n\nMeer is het niet.\n\n{\n    \"mode\": \"color\",\n    \"red\": 255,\n    \"green\": 255,\n    \"blue\": 255,\n    \"gain\": 100,\n    \"white\": 255,\n    \"effect\": 0,\n    \"turn\": \"on\"\n}\n\nApple's homekit gebruikt HSL\n\nHSL (hue, saturation, lightness) or HSB (hue, saturation, brightness) are similar.\n\n- Hue (Nederlands: tint), is wat we gewoonlijk 'kleur' noemen, zeg een punt op de regenboog.\n    In het HSV-model wordt de kleur uitgezet op een cirkel, en wordt de plek aangeduid in graden: Hue loopt dus van 0 tot 360 (graden).\n\n- Saturation (Nederlands: verzadiging) dit geeft een hoeveelheid (of felheid) van een kleur aan.\n    Wordt uitgedrukt in procenten, en loopt van 0% (flets, grijs) naar 100% (volle kleur).\n\n- Value of Brightness (Nederlands: intensiteit): staat voor de lichtheid van de kleur.\n    Wordt uitgedrukt in procenten, en loopt van 0% (zwart) naar 100% (wit).","x":170,"y":1700,"wires":[]},{"id":"d84ed564.16e178","type":"mqtt in","z":"4d2d578e.6cea28","name":"Regenboog RGB","topic":"shellies/regenboog/color/0/status","qos":"0","datatype":"auto","broker":"707b233c.d0ad2c","x":140,"y":1740,"wires":[["ff38dc1e.bb4e1"]]},{"id":"ff38dc1e.bb4e1","type":"json","z":"4d2d578e.6cea28","name":"","property":"payload","action":"","pretty":false,"x":275,"y":1740,"wires":[["3eda36df.27cf82"]],"l":false},{"id":"92d9884c.6977f8","type":"homekit-service","z":"4d2d578e.6cea28","isParent":true,"bridge":"93e1fd.7adf2e","parentService":"","name":"🌈 Regenboog","serviceName":"Lightbulb","topic":"","filter":false,"manufacturer":"Default Manufacturer","model":"Default Model","serialNo":"Default Serial Number","cameraConfigVideoProcessor":"ffmpeg","cameraConfigSource":"","cameraConfigStillImageSource":"","cameraConfigMaxStreams":2,"cameraConfigMaxWidth":1280,"cameraConfigMaxHeight":720,"cameraConfigMaxFPS":10,"cameraConfigMaxBitrate":300,"cameraConfigVideoCodec":"libx264","cameraConfigAudioCodec":"libfdk_aac","cameraConfigAudio":false,"cameraConfigPacketSize":1316,"cameraConfigVerticalFlip":false,"cameraConfigHorizontalFlip":false,"cameraConfigMapVideo":"0:0","cameraConfigMapAudio":"0:1","cameraConfigVideoFilter":"scale=1280:720","cameraConfigAdditionalCommandLine":"-tune zerolatency","cameraConfigDebug":false,"cameraConfigSnapshotOutput":"disabled","cameraConfigInterfaceName":"","characteristicProperties":"{\"Name\":\"🌈 Regenboog\", \"Brightness\":true, \"Hue\":true, \"Saturation\":true}","x":620,"y":2000,"wires":[["c4a71908.de05d","1f4ac2c.0b63ebd"],[]]},{"id":"5f0061da.774fa8","type":"debug","z":"4d2d578e.6cea28","name":"input","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":250,"y":1800,"wires":[]},{"id":"3eda36df.27cf82","type":"function","z":"4d2d578e.6cea28","name":"∞","func":"// fix repeated messages\nlet millisecondsBetweenMessages = 200;\nlet previousTime=context.get('time') || 0;\nlet currentTime=Math.round(Date.now());\nlet timeDifference=currentTime-previousTime;\n\n// set variable for next round\ncontext.set('time', currentTime);\n\nif (timeDifference < millisecondsBetweenMessages){\n    node.warn('To fast: '+timeDifference+'ms');\n    msg = null; // stop msg from sending\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":335,"y":1740,"wires":[["5f0061da.774fa8","396bdb58.3a6554","b6da17f1.206948","82771e64.77a57","473256d6.641858","ab3bf9d.85b4108","8c7a3254.d34138"]],"icon":"node-red/timer.svg","l":false},{"id":"ae269011.b4365","type":"ui_colour_picker","z":"4d2d578e.6cea28","name":"Regenboog RGB","label":"","group":"efa9c015.d79758","format":"rgb","outformat":"object","showSwatch":false,"showPicker":true,"showValue":false,"showHue":false,"showAlpha":false,"showLightness":false,"square":"false","dynOutput":"false","order":11,"width":0,"height":0,"passthru":true,"topic":"","x":710,"y":1700,"wires":[["605e4d0c.6aaf3c","b5e3fbc4.8217c8"]]},{"id":"3049ca84.56d01e","type":"ui_switch","z":"4d2d578e.6cea28","name":"Regenboog","label":"Regenboog","tooltip":"","group":"efa9c015.d79758","order":9,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","x":690,"y":1600,"wires":[["af8189c2.2aa778"]]},{"id":"285f1a5a.377e46","type":"mqtt out","z":"4d2d578e.6cea28","name":"","topic":"","qos":"","retain":"","broker":"707b233c.d0ad2c","x":1530,"y":1700,"wires":[]},{"id":"605e4d0c.6aaf3c","type":"function","z":"4d2d578e.6cea28","name":"prep RGB","func":"let red = msg.payload.r\nlet green = msg.payload.g\nlet blue = msg.payload.b\n\n// create message\nmsg.payload = {\"red\": red, \"green\": green, \"blue\": blue}\n\n// return message\nreturn msg;","outputs":1,"noerr":0,"x":960,"y":1700,"wires":[["f240d7bd.42308","b5e3fbc4.8217c8"]]},{"id":"e1ac9d4b.ec0e28","type":"ui_slider","z":"4d2d578e.6cea28","name":"Regenboog Helderheid","label":"Helderheid","tooltip":"","group":"efa9c015.d79758","order":10,"width":"0","height":"0","passthru":true,"outs":"end","topic":"","min":0,"max":"100","step":1,"x":730,"y":1800,"wires":[["5db26680.ea692"]]},{"id":"5db26680.ea692","type":"function","z":"4d2d578e.6cea28","name":"prep gain","func":"// create message\nmsg.payload = {\"gain\": msg.payload}\n\n// return message\nreturn msg;","outputs":1,"noerr":0,"x":960,"y":1800,"wires":[["f240d7bd.42308","2ec6f3f6.80e3a4"]]},{"id":"396bdb58.3a6554","type":"function","z":"4d2d578e.6cea28","name":"on/off","func":"msg.payload = msg.payload.ison ? 'on' : 'off';\nreturn msg;","outputs":1,"noerr":0,"x":490,"y":1600,"wires":[["3049ca84.56d01e","3dae9441.f72184"]]},{"id":"3dae9441.f72184","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":455,"y":1640,"wires":[],"l":false},{"id":"f240d7bd.42308","type":"function","z":"4d2d578e.6cea28","name":"complete payload & set topic","func":"// b.nelissen\n// 2020 augustus\n// get the default payload\n// add the payload of the flow\n// add the new values to the flow payload\n// safe the new payload\n// return the new payload\n\n// a bug in the colorpicker:\n//   when the colorpicker gets a 0,0,0 it stops sending changes in color signal\n//   therefor I send 123, 123, 123 by default\n\nmsg.topic = \"shellies/regenboog/color/0/set\"\n\n// msg.payload[\"On\"]\n\ndefaultPayload = {\n    \"mode\": \"color\",\n    \"red\": 123,\n    \"green\": 123,\n    \"blue\": 123,\n    \"gain\": 0,\n    \"white\": 0,\n    \"effect\": 0,\n    \"turn\": \"off\"\n}\n\n// merge payloads & remove all unneeded keys\nfunction mergePayloads(dest, src) {\n    for(var key in src) {\n        if (key in defaultPayload){\n            dest[key] = src[key];\n        }\n    } \n    return dest; \n}\n\n// default + flow\nvar newPayload = mergePayloads(defaultPayload, flow.get('flowPayload'));\n\n// flow + new\nnewPayload = mergePayloads(newPayload, msg.payload);\n\n// store new payload in flow\nflow.set('flowPayload', newPayload)\n\n// get the data from the flow variable (so we get we stored)\nmsg.payload = flow.get('flowPayload')\n\n// return the new payload\nreturn msg;","outputs":1,"noerr":0,"x":1300,"y":1700,"wires":[["1f279ef3.a277d9","285f1a5a.377e46"]]},{"id":"1f279ef3.a277d9","type":"debug","z":"4d2d578e.6cea28","name":"output","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1290,"y":1780,"wires":[]},{"id":"af8189c2.2aa778","type":"function","z":"4d2d578e.6cea28","name":"prep ison","func":"// create message\nmsg.payload = {\"turn\": msg.payload}\n\n// return message\nreturn msg;","outputs":1,"noerr":0,"x":960,"y":1600,"wires":[["f240d7bd.42308","766035b2.e88514"]]},{"id":"b6da17f1.206948","type":"function","z":"4d2d578e.6cea28","name":"Helderheid","func":"msg.payload = msg.payload.gain;\nreturn msg;","outputs":1,"noerr":0,"x":510,"y":1800,"wires":[["e1ac9d4b.ec0e28","9f50d198.1dac4"]]},{"id":"9f50d198.1dac4","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":455,"y":1840,"wires":[],"l":false},{"id":"7504975a.a1e1d","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":455,"y":1740,"wires":[],"l":false},{"id":"82771e64.77a57","type":"function","z":"4d2d578e.6cea28","name":"rgb","func":"msg.payload = { \"r\" : msg.payload.red,\n                \"g\" : msg.payload.green,\n                \"b\" : msg.payload.blue\n                };\nreturn msg;","outputs":1,"noerr":0,"x":490,"y":1700,"wires":[["7504975a.a1e1d","ae269011.b4365"]]},{"id":"dd0a5f34.e89268","type":"ui_slider","z":"4d2d578e.6cea28","name":"Regenboog Wit","label":"Wit","tooltip":"","group":"efa9c015.d79758","order":12,"width":0,"height":0,"passthru":true,"outs":"end","topic":"","min":0,"max":"255","step":1,"x":700,"y":1900,"wires":[["49a4579c.35cf4"]]},{"id":"49a4579c.35cf4","type":"function","z":"4d2d578e.6cea28","name":"prep white","func":"// create message\nmsg.payload = {\"white\": msg.payload}\n\n// return message\nreturn msg;","outputs":1,"noerr":0,"x":970,"y":1900,"wires":[["f240d7bd.42308","b4a3ea6a.519b4"]]},{"id":"473256d6.641858","type":"function","z":"4d2d578e.6cea28","name":"white","func":"msg.payload = msg.payload.white;\nreturn msg;","outputs":1,"noerr":0,"x":490,"y":1900,"wires":[["dd0a5f34.e89268","cb8850d7.0965d"]]},{"id":"cb8850d7.0965d","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":455,"y":1940,"wires":[],"l":false},{"id":"b4a3ea6a.519b4","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":915,"y":1940,"wires":[],"l":false},{"id":"2ec6f3f6.80e3a4","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":915,"y":1840,"wires":[],"l":false},{"id":"b5e3fbc4.8217c8","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":915,"y":1740,"wires":[],"l":false},{"id":"766035b2.e88514","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":915,"y":1640,"wires":[],"l":false},{"id":"c4a71908.de05d","type":"function","z":"4d2d578e.6cea28","name":"Complete msg","func":"// defaultPayload = {\n//     \"mode\": \"color\",\n//     \"red\": 123,\n//     \"green\": 123,\n//     \"blue\": 123,\n//     \"gain\": 0,\n//     \"white\": 0,\n//     \"effect\": 0,\n//     \"turn\": \"off\"\n// }\n\n// create complete message, fill with buffer from the previous messages\nlet Hue = msg.payload.Hue || flow.get(\"Hue\");\nlet Saturation = msg.payload.Saturation || flow.get(\"Saturation\");\nlet Brightness = msg.payload.Brightness || flow.get(\"Brightness\");\n\n// store variables\nflow.set(\"Hue\", Hue);\nflow.set(\"Saturation\", Saturation);\nflow.set(\"Brightness\", Brightness);\n\n// prep hsl message\nlet hsl = {\"payload\": [Hue, Saturation, Brightness]}\n\n// prep gain\n// brightness of 100 makes the RGB go white\nif ( Brightness >= 100 ){\n    Brightness = 99;\n}\nmsg.payload[\"gain\"] = Brightness;\n\n// set on/off\nif (msg.payload.On === true){\n    msg.payload[\"turn\"]=\"on\"\n}\nif (msg.payload.On === false){\n    msg.payload[\"turn\"]=\"off\"\n}\n\n// return message\nreturn [msg, hsl];","outputs":2,"noerr":0,"x":755,"y":2000,"wires":[["5ba540d6.f3b59"],["b4c6a5b1.1b65c8"]],"inputLabels":["homekit"],"outputLabels":["msg","hsl"],"icon":"font-awesome/fa-list","l":false},{"id":"b4c6a5b1.1b65c8","type":"color-convert","z":"4d2d578e.6cea28","input":"hsl","output":"rgb","outputType":"object","scaleInput":false,"x":815,"y":2020,"wires":[["ac05db56.788c48","5ba540d6.f3b59"]],"inputLabels":["homekit"],"outputLabels":["rgb"],"l":false},{"id":"ac05db56.788c48","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":875,"y":2040,"wires":[],"l":false},{"id":"fc05e859.2b22f","type":"comment","z":"4d2d578e.6cea28","name":"Homekit bugs","info":"The HomeKit node has a problem when ever it is deployed. If you have to deploy it more than once (hint: you will have to) then you’ll want to restart node-red for HomeKit to keep working. \n\nReload the browser window\n\n```\ncommand-R\n```\n\n\nEasiest restart:\n\n```\nsudo systemctl restart nodered.service\n```\n\n[source:](https://community.openhab.org/t/my-node-red-homekit-openhab-setup/54577)","x":130,"y":1660,"wires":[]},{"id":"5ba540d6.f3b59","type":"join","z":"4d2d578e.6cea28","name":"merge","mode":"custom","build":"merged","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"0.2","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":950,"y":2000,"wires":[["3563ac62.a322dc","f240d7bd.42308"]]},{"id":"3563ac62.a322dc","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1035,"y":2020,"wires":[],"l":false},{"id":"ab3bf9d.85b4108","type":"function","z":"4d2d578e.6cea28","name":"prep homekit","func":"// convert RGB to HSL for Homekit\nfunction rgbToHsl(r, g, b) {\n  r /= 255, g /= 255, b /= 255;\n\n  var max = Math.max(r, g, b), min = Math.min(r, g, b);\n  var h, s, l = (max + min) / 2;\n\n  if (max == min) {\n    h = s = 0; // achromatic\n  } else {\n    var d = max - min;\n    s = l > 0.5 ? d / (2 - max - min) : d / (max + min);\n    switch (max) {\n      case r: h = (g - b) / d + (g < b ? 6 : 0); break;\n      case g: h = (b - r) / d + 2; break;\n      case b: h = (r - g) / d + 4; break;\n    }\n    h /= 6;\n  }\n  // rounding to whole numbers prevents decline due to decimal rounding in loops.\n  h = Math.round(h*360);\n  s = Math.round(s*100);\n  l = Math.round(l*100);\n  return [ h, s, l ];\n}\n\n// set hsl\nlet hsl = rgbToHsl( msg.payload.red,\n                    msg.payload.green,\n                    msg.payload.blue\n                    )\n\n// brightness of 100 makes the RGB go white\nif ( msg.payload.gain >= 100 ){\n    msg.payload.gain = 99;\n}\n\nvar homekitMsg = { payload:{    \"Hue\": hsl[0],\n                                \"Saturation\": hsl[1],\n                                \"Brightness\": msg.payload.gain}\n                };\n\nhomekitMsg.payload[\"On\"]=msg.payload.ison\n\nreturn homekitMsg;","outputs":1,"noerr":0,"x":455,"y":2000,"wires":[["92d9884c.6977f8","c2653069.94d33"]],"icon":"node-red-contrib-homekit-bridged/homekit.png","l":false},{"id":"c2653069.94d33","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":455,"y":2040,"wires":[],"l":false},{"id":"1f4ac2c.0b63ebd","type":"debug","z":"4d2d578e.6cea28","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":675,"y":2040,"wires":[],"l":false},{"id":"2ecc8160.9aeb2e","type":"homekit-service","z":"4d2d578e.6cea28","isParent":true,"bridge":"93e1fd.7adf2e","parentService":"","name":"🌻 Zonnebloem","serviceName":"Lightbulb","topic":"","filter":false,"manufacturer":"Default Manufacturer","model":"Default Model","serialNo":"Default Serial Number","cameraConfigVideoProcessor":"ffmpeg","cameraConfigSource":"","cameraConfigStillImageSource":"","cameraConfigMaxStreams":2,"cameraConfigMaxWidth":1280,"cameraConfigMaxHeight":720,"cameraConfigMaxFPS":10,"cameraConfigMaxBitrate":300,"cameraConfigVideoCodec":"libx264","cameraConfigAudioCodec":"libfdk_aac","cameraConfigAudio":false,"cameraConfigPacketSize":1316,"cameraConfigVerticalFlip":false,"cameraConfigHorizontalFlip":false,"cameraConfigMapVideo":"0:0","cameraConfigMapAudio":"0:1","cameraConfigVideoFilter":"scale=1280:720","cameraConfigAdditionalCommandLine":"-tune zerolatency","cameraConfigDebug":false,"cameraConfigSnapshotOutput":"disabled","cameraConfigInterfaceName":"","characteristicProperties":"{\"name\":\"🌻 Zonnebloem\", \"Brightness\":true, \"On\": false}","x":900,"y":2120,"wires":[["b8541a02.9c2918"],[]]},{"id":"be6b91e3.bbe8a8","type":"inject","z":"4d2d578e.6cea28","name":"debug","topic":"","payload":"{\"see\":\"options\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":750,"y":2100,"wires":[["2ecc8160.9aeb2e"]]},{"id":"8c7a3254.d34138","type":"function","z":"4d2d578e.6cea28","name":"prep homekit","func":"// set payload\nvar homekitMsg = { payload:{ \"Brightness\": msg.payload.white,\n                                \"On\": msg.payload.ison }};\nreturn homekitMsg;","outputs":1,"noerr":0,"x":455,"y":2120,"wires":[["2ecc8160.9aeb2e"]],"icon":"node-red-contrib-homekit-bridged/homekit.png","l":false},{"id":"60104f0d.7edd58","type":"debug","z":"4d2d578e.6cea28","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":1035,"y":2180,"wires":[],"l":false},{"id":"b8541a02.9c2918","type":"function","z":"4d2d578e.6cea28","name":"Complete msg","func":"// defaultPayload = {\n//     \"mode\": \"color\",\n//     \"red\": 123,\n//     \"green\": 123,\n//     \"blue\": 123,\n//     \"gain\": 0,\n//     \"white\": 0,\n//     \"effect\": 0,\n//     \"turn\": \"off\"\n// }\n\n// homekit calles it Brightness, Shelly calls it White.\nlet white = msg.payload.Brightness || flow.get(\"white\");\n\n// prep gain\nmsg.payload[\"white\"] = white;\n\n// set on/off\nif (msg.payload.Brightness != flow.get(\"white\") ){\n    // brightness changed\n    msg.payload[\"turn\"]=\"on\"\n}\nif (msg.payload.On === true){\n    msg.payload[\"turn\"]=\"on\"\n}\nif (msg.payload.On === false){\n    msg.payload[\"turn\"]=\"off\"\n}\n\n// store variables\nflow.set(\"white\", white);\n\n// delete Brightness\ndelete msg.payload.Brightness;\n\n// return message\nreturn msg;","outputs":1,"noerr":0,"x":1035,"y":2120,"wires":[["60104f0d.7edd58","f240d7bd.42308"]],"inputLabels":["homekit"],"outputLabels":["msg"],"icon":"font-awesome/fa-list","l":false},{"id":"707b233c.d0ad2c","type":"mqtt-broker","z":"","name":"KoekoekPi","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","willTopic":"","willQos":"0","willRetain":"false","willPayload":""},{"id":"93e1fd.7adf2e","type":"homekit-bridge","z":"","bridgeName":"Koekoek Home","pinCode":"111-11-111","port":"","allowInsecureRequest":false,"manufacturer":"Koekoek","model":"Model","serialNo":"Serial Number","customMdnsConfig":false,"mdnsMulticast":true,"mdnsInterface":"","mdnsPort":"","mdnsIp":"","mdnsTtl":"","mdnsLoopback":true,"mdnsReuseAddr":true,"allowMessagePassthrough":true},{"id":"efa9c015.d79758","type":"ui_group","z":"","name":"Woonkamer","tab":"f529ddcc.a47f8","order":1,"disp":true,"width":"6","collapse":true},{"id":"f529ddcc.a47f8","type":"ui_tab","z":"","name":"Lichten","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 6 years, 10 months ago
Updated 6 years, 7 months ago
  • comment (x2)
  • debug (x15)
  • function (x14)
  • join (x1)
  • json (x1)
  • mqtt in (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • shelly
  • rgbw2
  • ui
  • homekit
  • homekit-service
  • mqtt
