node-red-contrib-color-convert 0.0.8
Node-RED node to convert between Color representations (e.g. RGB to HSV)
npm install node-red-contrib-color-convert
NODE-RED-CONTRIB-COLOR-CONVERT
Install via the pallet manager or by running the following in the Node-RED user directory (usually ~/.node-red):
This node converts between different color representations, it can convert between the following systems.
  • RGB - Red, Green, Blue
  • HSL - Hue, Saturation, Level
  • HSV - Hue, Saturation, Value (brightnes)
  • CSS - CSS color names
  • HEX - A Hex RGB string #ff00ff
Inputs
For the first 3 input modes the node will attempt to determine the input format of msg.payload from the 3 following:
  • a 3 segment array with values between 0-255 for RGB.
  • a 3 segment array for HSL and HSV with Hue is between 0-360 and Saturation, Level, values 0-100.
  • a object with keys red,green,blue with values between 0-255.
  • a object with keys hue,saturation,lightness or value,brightness with values between 0-360 for hue and 0-100 for the others.
For the CSS or HEX input mode the msg.payload should be a string containing the name of a CSS color.
For HSV and HSL inputs the "Scale Sat/Bri/Val" check box will convert values from 0-1 to 0-100
Outputs
Output type can be configured to be either a 3 element array, an object or a string. The 3 element array will contian the aproprate values in the same order as expected. Objects will have matching keys and the string will be the values from the array joined with a comma.
If the CSS or HEX output mode is selected then the output type will be forced to be a string.
Version: 0.0.8
Updated 6 years, 6 months ago
Rating: 5.0 3
34 in the last week
  • color-convert
  • color
  • colour
  • rgb
  • hsl
  • hsv
  • css
