FritzBox DECT Thermostate bei An- & Abwesenheit nach Zeitplan steuern.
Dieser Flow setzt nach dem Präsenzerkennungs-Flow "Home_Presence Detection mit FritzBox" (https://flows.nodered.org/flow/757c410dc9d4b7aae2139670428f8e81) an.
Der Flow kann bekommt eine Meldung über An- & Abwesenheit der Handys im WLAN.
Bei Abwesenheit wird die Temperatur auf Nacht gestellt.
Bei Anwesenheit wird die Temperatur nach dem in der FritzBox eingestellten Zeitplan eingestellt, also entweder Komfort oder Absenk.
[{"id":"f715c5e8.e9cf48","type":"tab","label":"Heizungsteuerung","disabled":false,"info":""},{"id":"335b2c80.8f1f34","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"119610691960\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":360,"wires":[["c8d8c63c.5aa298"]]},{"id":"aedc360f.306ff8","type":"switch","z":"f715c5e8.e9cf48","name":"Zuhause oder nicht Zuhause","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":180,"y":480,"wires":[["335b2c80.8f1f34","3eb12ea9.8acf72","edad7e40.2658","cf5d24c3.041538","c617f398.d52db"],["4a000247.76189c","bb6a9334.7e8fe","77549b7c.d4dbe4","9da7bb60.130fc8","b2b8d0ec.aa361"]]},{"id":"3eb12ea9.8acf72","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"119610732552\";\nmsg.thermostat=\"Küche\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":240,"wires":[["c8d8c63c.5aa298"]]},{"id":"f31634c7.03b278","type":"fritz-thermostat","z":"f715c5e8.e9cf48","connection":"a5b34dc9.8fbbf","name":"setTargetTemperature","action":"setTempTarget","x":1300,"y":420,"wires":[["990640d7.c26b2"]]},{"id":"edad7e40.2658","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"119600226064\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":300,"wires":[["c8d8c63c.5aa298"]]},{"id":"cf5d24c3.041538","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"117951024816\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":420,"wires":[["c8d8c63c.5aa298"]]},{"id":"c617f398.d52db","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"119600231896\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":480,"wires":[["c8d8c63c.5aa298"]]},{"id":"77549b7c.d4dbe4","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"119610691960\";\nmsg.thermostat=\"Kaminzimmer\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":700,"wires":[["381587aa.f62fa8"]]},{"id":"557a4c3d.138e74","type":"debug","z":"f715c5e8.e9cf48","name":"Abwesend: Temperatur eingestellt auf","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1230,"y":700,"wires":[]},{"id":"4a000247.76189c","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"119610732552\";\nmsg.thermostat=\"Küche\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":580,"wires":[["381587aa.f62fa8"]]},{"id":"6b767ce8.ad03f4","type":"fritz-thermostat","z":"f715c5e8.e9cf48","connection":"a5b34dc9.8fbbf","name":"adjustToNightTemperature","action":"setTempNight","x":930,"y":700,"wires":[["557a4c3d.138e74"]]},{"id":"bb6a9334.7e8fe","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"119600226064\";\nmsg.thermostat=\"Kinderbad\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":640,"wires":[["381587aa.f62fa8"]]},{"id":"9da7bb60.130fc8","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"117951024816\";\nmsg.thermostat=\"Flur unten\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":760,"wires":[["381587aa.f62fa8"]]},{"id":"b2b8d0ec.aa361","type":"function","z":"f715c5e8.e9cf48","name":"Set AIN","func":"msg.ain=\"119600231896\";\nmsg.thermostat=\"Gästebad\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":820,"wires":[["381587aa.f62fa8"]]},{"id":"f34a296d.3394a8","type":"fritz-thermostat","z":"f715c5e8.e9cf48","connection":"a5b34dc9.8fbbf","name":"getDevice","action":"getDevice","x":880,"y":360,"wires":[["e3dcbda2.24e12"]]},{"id":"2282fc0a.18cbe4","type":"function","z":"f715c5e8.e9cf48","name":"getSollTemperatur","func":"//could be waaaay shorter, but works \nswitch(msg.payload) {\n  case \"16\":\n    msg.payload = 8\n    break;\n  case \"17\":\n    msg.payload = 8.5\n    break;\n  case \"19\":\n    msg.payload = 9\n    break;\n  case \"20\":\n    msg.payload = 9.5;\n    break;\n  case \"21\":\n    msg.payload=10;\n    break;\n  case \"22\":\n    msg.payload = 10.5\n    break;\n  case \"23\":\n    msg.payload = 11\n    break;\n  case \"24\":\n    msg.payload = 11.5\n    break;\n  case \"25\":\n    msg.payload = 12\n    break;\n  case \"26\":\n    msg.payload = 12.5\n    break;\n  case \"27\":\n    msg.payload = 13\n    break;\n  case \"28\":\n    msg.payload = 13.5\n    break;\n  case \"29\":\n    msg.payload = 14\n    break;\n  case \"30\":\n    msg.payload = 14.5\n    break;\n  case \"31\":\n    msg.payload = 15\n    break;\n  case \"32\":\n    msg.payload = 16\n    break;\n  case \"33\":\n    msg.payload = 16.5\n    break;\n  case \"34\":\n    msg.payload = 17\n    break;\n  case \"35\":\n    msg.payload = 17.5\n    break;\n  case \"36\":\n    msg.payload = 18\n    break;\n  case \"37\":\n    msg.payload = 18.5\n    break;  \n  case \"38\":\n    msg.payload = 19\n    break;\n  case \"39\":\n    msg.payload = 19.5\n    break;\n  case \"40\":\n    msg.payload = 20\n    break;\n  case \"41\":\n    msg.payload = 20.5\n    break;\n  case \"42\":\n    msg.payload = 21\n    break;\n  case \"43\":\n    msg.payload = 21.5\n    break;\n  case \"44\":\n    msg.payload = 22\n    break;\n  case \"45\":\n    msg.payload = 22.5\n    break;\n  case \"46\":\n    msg.payload = 23\n    break;\n  case \"47\":\n    msg.payload = 23.5\n    break;\n  case \"48\":\n    msg.payload = 24\n    break;\n  case \"49\":\n    msg.payload = 24.5\n    break;\n  case \"50\":\n    msg.payload = 25\n    break;\n  case \"51\":\n    msg.payload = 25.5\n    break;\n  case \"52\":\n    msg.payload = 26\n    break;\n  case \"53\":\n    msg.payload = 26.5\n    break;\n  case \"54\":\n    msg.payload = 27\n    break;\n  case \"55\":\n    msg.payload = 27.5\n    break;\n  case \"56\":\n    msg.payload = 28\n    break;\n  case \"254\":\n    msg.payload=\"An\";\n    break;\n  case \"253\":\n    msg.payload=\"Aus\";\n    break;\n  default:\n    msg.payload=\"Error\"\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1130,"y":360,"wires":[["f31634c7.03b278"]]},{"id":"e41c243e.0d92a8","type":"comment","z":"f715c5e8.e9cf48","name":"Zuhause","info":"","x":240,"y":300,"wires":[]},{"id":"dedd715.df07d9","type":"comment","z":"f715c5e8.e9cf48","name":"Nicht Zuhause","info":"","x":230,"y":640,"wires":[]},{"id":"e3dcbda2.24e12","type":"function","z":"f715c5e8.e9cf48","name":"Set comfort or absenk","func":"if (msg.payload.hkr.nextchange.tchange === msg.payload.hkr.komfort) {\n    msg.payload = msg.payload.hkr.absenk\nreturn msg;\n} else {\n    msg.payload = msg.payload.hkr.komfort\nreturn msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1020,"y":420,"wires":[["2282fc0a.18cbe4"]]},{"id":"990640d7.c26b2","type":"debug","z":"f715c5e8.e9cf48","name":"Anwesend: Temperatur eingestellt auf","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1470,"y":360,"wires":[]},{"id":"d9589f31.f883c","type":"link in","z":"f715c5e8.e9cf48","name":"","links":["8ec39d6d.0e967"],"x":15,"y":480,"wires":[["aedc360f.306ff8"]]},{"id":"c8d8c63c.5aa298","type":"delay","z":"f715c5e8.e9cf48","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"3","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":700,"y":360,"wires":[["f34a296d.3394a8"]]},{"id":"381587aa.f62fa8","type":"delay","z":"f715c5e8.e9cf48","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"3","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":700,"y":700,"wires":[["6b767ce8.ad03f4"]]},{"id":"cc7a274.6308ed8","type":"comment","z":"f715c5e8.e9cf48","name":"Wir besitzen 5 Thermostate","info":"","x":440,"y":180,"wires":[]},{"id":"a5b34dc9.8fbbf","type":"fritz-api","name":"Fritz Box","host":"http://fritz.box","strictSSL":false}]
Created 5 years, 1 month ago
  • comment (x3)
  • debug (x2)
  • delay (x2)
  • function (x12)
  • link in (x1)
  • switch (x1)
  • fritzbox
  • dect
  • presence
  • thermostat
