HAW/DP/Batterie
doagudgsadggoaduogdauodgusoagdouasgdua
[{"id":"930284c8.e3c418","type":"tab","label":"Battery ","disabled":false,"info":""},{"id":"9b9a24d1.d91458","type":"inject","z":"930284c8.e3c418","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":120,"wires":[["fff7b8c8.4e6518"]]},{"id":"fff7b8c8.4e6518","type":"battery","z":"930284c8.e3c418","name":"","level":true,"charging":true,"x":300,"y":120,"wires":[["56764151.043638","33bd1cc4.6b1aa4"]]},{"id":"56764151.043638","type":"function","z":"930284c8.e3c418","name":"","func":"var percent = msg.payload.percent;\nmsg.payload = percent;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":80,"wires":[["bfa2bb67.5c6a58","a75866e8.300a4"]]},{"id":"33bd1cc4.6b1aa4","type":"function","z":"930284c8.e3c418","name":"","func":"var isCharging = msg.payload.isCharging;\nmsg.payload = isCharging;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":160,"wires":[["bfa2bb67.5c6a58","ce0810c.5a0df7"]]},{"id":"bfa2bb67.5c6a58","type":"mqtt out","z":"930284c8.e3c418","name":"","topic":"HAW/Batterie/Asus","qos":"0","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"e1d2467d.dc2388","x":730,"y":120,"wires":[]},{"id":"3ba57940.b0a6be","type":"mqtt in","z":"930284c8.e3c418","name":"","topic":"HAW/Batterie/Asus","qos":"2","datatype":"auto","broker":"e1d2467d.dc2388","nl":false,"rap":true,"rh":0,"x":130,"y":260,"wires":[["e7b72baa.54387"]]},{"id":"e7b72baa.54387","type":"debug","z":"930284c8.e3c418","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":350,"y":260,"wires":[]},{"id":"ce0810c.5a0df7","type":"ui_switch","z":"930284c8.e3c418","name":"","label":"Charging on / off","tooltip":"","group":"3ac5c232.3f0abe","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":730,"y":180,"wires":[[]]},{"id":"a75866e8.300a4","type":"ui_gauge","z":"930284c8.e3c418","name":"","group":"3ac5c232.3f0abe","order":2,"width":0,"height":0,"gtype":"gage","title":"Battery Precentage","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#ff0000","#e6e600","#00ff00"],"seg1":"20","seg2":"80","x":730,"y":60,"wires":[]},{"id":"e1d2467d.dc2388","type":"mqtt-broker","name":"HiveMQ Public","broker":"broker.hivemq.com","port":"1883","tls":"","clientid":"","usetls":false,"protocolVersion":"3","keepalive":"60","cleansession":true,"birthTopic":"Broker/Status","birthQos":"0","birthRetain":"true","birthPayload":"Connected","birthMsg":{},"closeTopic":"Broker/Status","closeQos":"0","closeRetain":"true","closePayload":"Disconnected","closeMsg":{},"willTopic":"Broker/Status","willQos":"0","willRetain":"true","willPayload":"Network interrupt","willMsg":{},"sessionExpiry":""},{"id":"3ac5c232.3f0abe","type":"ui_group","name":"Bat","tab":"3dca0418.29188c","order":1,"disp":true,"width":"6","collapse":false},{"id":"3dca0418.29188c","type":"ui_tab","name":"Flow 1","icon":"dashboard","disabled":false,"hidden":false}]
Created 4 years, 6 months ago
  • function (x2)
  • mqtt in (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • battery (x1)
  • ui_gauge (x1)
  • ui_group (x1)
  • ui_switch (x1)
