DroneMobile
The following flow will create a dashboard so you remotely start, stop, lock, or unlock your Dronemobile equipped vehicle. You can set schedules and a temperature threshold. I have it set so my Suburban won't start in the morning if the outside temp is above 35(F) and only on weekdays.
You will also need the following API wrapper installed. I did not create the API wrapper and have nothing to do with it.
"drone-mobile" by Hacksore "An unofficial nodejs API wrapper for DroneMobile" https://github.com/Hacksore/drone-mobile
[{"id":"30c39a3f1403cd31","type":"tab","label":"DroneMobile","disabled":false,"info":"","env":[]},{"id":"33f34f3a42b9b48c","type":"ui_text_input","z":"30c39a3f1403cd31","name":"","label":"UNLOCK PIN","tooltip":"","group":"a96510934745ea77","order":1,"width":"3","height":"1","passthru":false,"mode":"number","delay":"0","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":180,"y":80,"wires":[["516e7fe4d5d4725b","dbe711ca948028d2","e885a180ee0279e2"]]},{"id":"516e7fe4d5d4725b","type":"switch","z":"30c39a3f1403cd31","name":"PIN","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"3181","vt":"num"},{"t":"neq","v":"3181","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":80,"wires":[["4a3f2145c80f53ac"],["68c7f0f10d9595c2"]]},{"id":"68c7f0f10d9595c2","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"INCORRECT PIN","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":80,"wires":[["f2b866b80660af02"]]},{"id":"4a3f2145c80f53ac","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"CORRECT PIN","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":40,"wires":[["e00158cc1a8a0578"]]},{"id":"dbe711ca948028d2","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":180,"y":40,"wires":[["33f34f3a42b9b48c"]]},{"id":"5a93a93028ba35cb","type":"ui_button","z":"30c39a3f1403cd31","name":"","group":"a96510934745ea77","order":2,"width":"3","height":"1","passthru":true,"label":"Lock","tooltip":"","color":"","bgcolor":"","className":"","icon":"lock_outline","payload":"node /home/pi/node_modules/drone-mobile/dronelock.js","payloadType":"str","topic":"topic","topicType":"msg","x":150,"y":160,"wires":[["4b14677ecec5e6c0"]]},{"id":"f4c392e4950cd6e8","type":"ui_button","z":"30c39a3f1403cd31","name":"","group":"a96510934745ea77","order":3,"width":"3","height":"1","passthru":false,"label":"Stop","tooltip":"","color":"","bgcolor":"","className":"","icon":"sync_disabled","payload":"node /home/pi/node_modules/drone-mobile/dronestop.js","payloadType":"str","topic":"topic","topicType":"msg","x":150,"y":200,"wires":[["4b14677ecec5e6c0"]]},{"id":"e885a180ee0279e2","type":"change","z":"30c39a3f1403cd31","name":"Unlock","rules":[{"t":"set","p":"payload","pt":"msg","to":"node /home/pi/node_modules/drone-mobile/droneunlock.js","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":120,"wires":[["4b14677ecec5e6c0"]]},{"id":"8c3a727898a6f7b7","type":"ui_button","z":"30c39a3f1403cd31","name":"","group":"a96510934745ea77","order":4,"width":"3","height":"1","passthru":true,"label":"Start","tooltip":"","color":"","bgcolor":"","className":"","icon":"sync","payload":"node /home/pi/node_modules/drone-mobile/dronestart.js","payloadType":"str","topic":"topic","topicType":"msg","x":150,"y":240,"wires":[["4b14677ecec5e6c0"]]},{"id":"dd668e3e5a8d73d8","type":"chronos-scheduler","z":"30c39a3f1403cd31","name":"Morning Schedule","config":"7a8bc0d9dee80f55","schedule":[{"trigger":{"type":"time","value":"05:20","offset":0,"random":false},"output":{"type":"msg","property":{"name":"payload","type":"bool","value":"true"}}}],"multiPort":false,"disabled":false,"outputs":1,"x":170,"y":820,"wires":[["3672f397cf61cb71"]]},{"id":"3672f397cf61cb71","type":"gate","z":"30c39a3f1403cd31","name":"button gate","controlTopic":"control","defaultState":"open","openCmd":"enabled","closeCmd":"disabled","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":true,"storeName":"memory","x":450,"y":800,"wires":[["d14dace08903aa21"]]},{"id":"71afaf25d947a7cc","type":"ui_text","z":"30c39a3f1403cd31","group":"a96510934745ea77","order":13,"width":"6","height":"1","name":"return info","label":"","format":"{{msg.payload}}","layout":"col-center","className":"","x":1260,"y":500,"wires":[]},{"id":"3ed72ada3c3013d7","type":"link in","z":"30c39a3f1403cd31","name":"","links":["cf20f33460c8a8bb","9ee242c7e77c2b71","2a761e546a8168c2","c753f30e4a6fc706","37abf200f193332c","8baf9eb6a90b472f","e00158cc1a8a0578","f2b866b80660af02"],"x":1155,"y":520,"wires":[["71afaf25d947a7cc","82a364854dbec83a"]]},{"id":"2a761e546a8168c2","type":"link out","z":"30c39a3f1403cd31","name":"","mode":"link","links":["3ed72ada3c3013d7"],"x":415,"y":200,"wires":[]},{"id":"435e336e4b2f2d64","type":"ui_text","z":"30c39a3f1403cd31","group":"a96510934745ea77","order":14,"width":"6","height":"1","name":"return date","label":"","format":"{{msg.payload}}","layout":"col-center","className":"","x":1450,"y":540,"wires":[]},{"id":"82a364854dbec83a","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$now('[M01].[D01].[Y0001] [H01]:[m01]:[s01]', '-0600')","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":540,"wires":[["435e336e4b2f2d64"]]},{"id":"d9512fb358a1cc61","type":"link in","z":"30c39a3f1403cd31","name":"","links":["23104f4c9c07314c","9e8bcda01e31b416"],"x":55,"y":240,"wires":[["8c3a727898a6f7b7"]]},{"id":"9e8bcda01e31b416","type":"link out","z":"30c39a3f1403cd31","name":"","mode":"link","links":["d9512fb358a1cc61"],"x":895,"y":800,"wires":[]},{"id":"e00158cc1a8a0578","type":"link out","z":"30c39a3f1403cd31","name":"","mode":"link","links":["3ed72ada3c3013d7"],"x":655,"y":40,"wires":[]},{"id":"f2b866b80660af02","type":"link out","z":"30c39a3f1403cd31","name":"","mode":"link","links":["3ed72ada3c3013d7"],"x":655,"y":80,"wires":[]},{"id":"220f2f6d6a7365e3","type":"openweathermap in","z":"30c39a3f1403cd31","name":"","wtype":"current","lon":"-96.01616239311173","lat":"41.17828575845878","city":"","country":"","language":"en","x":180,"y":600,"wires":[["1e9eb04857b4decb"]]},{"id":"634fb3a46971c0ae","type":"ui_text","z":"30c39a3f1403cd31","group":"a96510934745ea77","order":9,"width":"3","height":"1","name":"","label":"Outside Temp:","format":"{{msg.payload}}","layout":"row-spread","className":"","x":600,"y":600,"wires":[]},{"id":"1e9eb04857b4decb","type":"unit-converter","z":"30c39a3f1403cd31","category":"temperature","inputUnit":"C","outputUnit":"F","inputField":"payload.tempc","outputField":"payload","inputFieldType":"msg","outputFieldType":"msg","roundOutputField":true,"outputFieldDecimals":"0","name":"","x":380,"y":600,"wires":[["634fb3a46971c0ae","05eb2cb481085907","6050bc5b87df7af1"]]},{"id":"4b14677ecec5e6c0","type":"exec","z":"30c39a3f1403cd31","command":"","addpay":"payload","append":"","useSpawn":"false","timer":"","winHide":true,"oldrc":false,"name":"","x":310,"y":180,"wires":[["2a761e546a8168c2"],[],[]]},{"id":"d0f4fd4621dab77e","type":"ui_button","z":"30c39a3f1403cd31","name":"","group":"a96510934745ea77","order":5,"width":"3","height":"1","passthru":false,"label":"Disable","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"Disabled","payloadType":"str","topic":"control","topicType":"str","x":200,"y":780,"wires":[["3672f397cf61cb71"]]},{"id":"1a1fe5adda137fa9","type":"ui_button","z":"30c39a3f1403cd31","name":"","group":"a96510934745ea77","order":6,"width":"3","height":"1","passthru":false,"label":"Enable","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"Enabled","payloadType":"str","topic":"control","topicType":"str","x":200,"y":740,"wires":[["3672f397cf61cb71"]]},{"id":"6f75928d64dd984e","type":"ui_text","z":"30c39a3f1403cd31","group":"a96510934745ea77","order":7,"width":"6","height":"1","name":"button text","label":"","format":"{{msg.payload}}","layout":"row-center","className":"","x":1450,"y":80,"wires":[]},{"id":"b655befd2b138625","type":"status","z":"30c39a3f1403cd31","name":"button gate status","scope":["3672f397cf61cb71"],"x":950,"y":80,"wires":[["1fdeb35a712fbd6e"]]},{"id":"1fdeb35a712fbd6e","type":"switch","z":"30c39a3f1403cd31","name":"","property":"status.text","propertyType":"msg","rules":[{"t":"eq","v":"open","vt":"str"},{"t":"eq","v":"closed","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1130,"y":80,"wires":[["307de79da3932acc"],["18c8a661c6c79ca8"]]},{"id":"307de79da3932acc","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Enabled","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":60,"wires":[["6f75928d64dd984e"]]},{"id":"18c8a661c6c79ca8","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Disabled","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":100,"wires":[["6f75928d64dd984e"]]},{"id":"16b4caa49a61355f","type":"status","z":"30c39a3f1403cd31","name":"Schedule Status","scope":["dd668e3e5a8d73d8"],"x":1280,"y":420,"wires":[["d5d3e2aa09ca93fc"]]},{"id":"d5d3e2aa09ca93fc","type":"ui_text","z":"30c39a3f1403cd31","group":"a96510934745ea77","order":11,"width":0,"height":0,"name":"next event","label":"","format":"{{msg.status.text}}","layout":"row-center","className":"","x":1490,"y":420,"wires":[]},{"id":"d14dace08903aa21","type":"weekday","z":"30c39a3f1403cd31","name":"weekdays","sun":false,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":false,"x":600,"y":800,"wires":[["20f27ea1f130e765"],[]]},{"id":"20f27ea1f130e765","type":"gate","z":"30c39a3f1403cd31","name":"temp gate","controlTopic":"control","defaultState":"open","openCmd":"enabled","closeCmd":"disabled","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":true,"storeName":"memory","x":780,"y":800,"wires":[["9e8bcda01e31b416"]]},{"id":"05eb2cb481085907","type":"switch","z":"30c39a3f1403cd31","name":"Temp Switch","property":"payload","propertyType":"msg","rules":[{"t":"lte","v":"35","vt":"num"},{"t":"gt","v":"35","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":570,"y":640,"wires":[["381d25279069cff0"],["4c808a4f1c79a141"]]},{"id":"a6e90048ede8b0c6","type":"ui_text","z":"30c39a3f1403cd31","group":"a96510934745ea77","order":10,"width":"3","height":"1","name":"temp disable","label":"","format":"{{msg.payload}}","layout":"row-center","className":"","x":1450,"y":240,"wires":[]},{"id":"487904a3dabd66e8","type":"status","z":"30c39a3f1403cd31","name":"temp gate status","scope":["20f27ea1f130e765"],"x":960,"y":240,"wires":[["46674f72a0e70188"]]},{"id":"46674f72a0e70188","type":"switch","z":"30c39a3f1403cd31","name":"","property":"status.text","propertyType":"msg","rules":[{"t":"eq","v":"open","vt":"str"},{"t":"eq","v":"closed","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1130,"y":240,"wires":[["03d22eb18a79517c"],["0da25ea1d1098789"]]},{"id":"03d22eb18a79517c","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Enabled","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":220,"wires":[["a6e90048ede8b0c6"]]},{"id":"0da25ea1d1098789","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"Disabled","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":260,"wires":[["a6e90048ede8b0c6"]]},{"id":"381d25279069cff0","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"enabled","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":680,"wires":[["20f27ea1f130e765"]]},{"id":"4c808a4f1c79a141","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"disabled","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":720,"wires":[["20f27ea1f130e765"]]},{"id":"6050bc5b87df7af1","type":"change","z":"30c39a3f1403cd31","name":"Format Temp","rules":[{"t":"set","p":"push.text","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":560,"wires":[["21ab66fd7c934542"]]},{"id":"21ab66fd7c934542","type":"chronos-repeat","z":"30c39a3f1403cd31","name":"","config":"7a8bc0d9dee80f55","mode":"simple","interval":"15","intervalUnit":"minutes","crontab":"","expression":"","untilType":"nextMsg","untilValue":"","untilDate":"","untilOffset":0,"untilRandom":false,"msgIngress":"forward","preserveCtrlProps":false,"ignoreCtrlProps":false,"x":810,"y":560,"wires":[["02d7a95673ca5ac6"]]},{"id":"02d7a95673ca5ac6","type":"link out","z":"30c39a3f1403cd31","name":"","mode":"link","links":["6cc30c341942306e","6f00610622ee80c0"],"x":975,"y":560,"wires":[]},{"id":"6cc30c341942306e","type":"link in","z":"30c39a3f1403cd31","name":"","links":["02d7a95673ca5ac6"],"x":355,"y":920,"wires":[["2af2c8343e32b238"]]},{"id":"2af2c8343e32b238","type":"change","z":"30c39a3f1403cd31","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"status","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":920,"wires":[["3672f397cf61cb71","20f27ea1f130e765"]]},{"id":"5982544ee0776c36","type":"chronos-scheduler","z":"30c39a3f1403cd31","name":"Afternoon Schedule","config":"7a8bc0d9dee80f55","schedule":[{"trigger":{"type":"time","value":"14:20","offset":0,"random":false},"output":{"type":"msg","property":{"name":"payload","type":"bool","value":"true"}}}],"multiPort":false,"disabled":false,"outputs":1,"x":170,"y":880,"wires":[["3672f397cf61cb71"]]},{"id":"aaabec120c16c126","type":"status","z":"30c39a3f1403cd31","name":"Schedule Status","scope":["5982544ee0776c36"],"x":1280,"y":460,"wires":[["679cdf20353a9772"]]},{"id":"679cdf20353a9772","type":"ui_text","z":"30c39a3f1403cd31","group":"a96510934745ea77","order":12,"width":0,"height":0,"name":"next event","label":"","format":"{{msg.status.text}}","layout":"row-center","className":"","x":1490,"y":460,"wires":[]},{"id":"a96510934745ea77","type":"ui_group","name":"Suburban","tab":"b6c8e28df787ad14","order":2,"disp":false,"width":"6","collapse":false,"className":""},{"id":"7a8bc0d9dee80f55","type":"chronos-config","name":"LAVISTA","sunPositions":[]},{"id":"b6c8e28df787ad14","type":"ui_tab","name":"Suburban","icon":"directions_car","order":3,"disabled":false,"hidden":false}]
