node-red-contrib-chronos 1.30.1
Time-based Node-RED scheduling, repeating, queueing, routing, filtering and manipulating nodes
npm install node-red-contrib-chronos
A collection of Node-RED nodes for date and time based scheduling, repeating, queueing, routing, filtering and manipulating. Automatically calculated times from sun events (sunrise, sunset, dusk, dawn, ...) or moon events (moonrise, moonset) are supported as well.
If you encountered a bug, would like to propose a new feature or simply want to share your opinion about the software, please have a look at the contribution guide on the GitHub repository to learn more about how to contribute to this project. If you need help or have questions, please check out the instructions for getting support.
To see what has changed in recent versions of the software, please have a look at the project's release notes.
Scheduler
Schedules the transmission of messages or setting of global/flow variables at specific times.
Scheduler
State
Maintains a state whose value is changed at specific times under consideration of specific conditions.
State
Repeat
Repeats each message passing through the node based on a configurable interval.
Repeat
Delay
Delays each message passing through the node for a configurable amount of time or until a specific point in time is reached.
Delay
Time Switch
Routes messages based on a specific time or duration.
Time Switch
Time Filter
Filters messages based on a specific time or duration.
Timer Filter
Time Change
Modifies time and duration values in messages or context stores.
Timer Change
Documentation
Each node has a built-in help that is displayed in the help tab of the Node-RED sidebar providing essential information about how to use the node. There is also a comprehensive and detailed (English-only) documentation available in the wiki of the GitHub repository.
→ Documentation
Copyright (c) 2020 - 2026 Jens-Uwe Rossbach
This code is licensed under the MIT License.
Attribution
The following icons have been taken from Node-RED provided nodes:
  • Timer icon (Node-RED delay node)
  • Switch icon (Node-RED switch node)
  • Flip icon (Node-RED change node)
The following icons have been taken from Flaticon:
For the calculation of sun and moon position based times, the nodes make use of the great Node.js library SunCalc from Vladimir Agafonkin. The processing of cron based schedules is done via the Node.js library CronosJS and date and time algorithms are provided by the Node.js library Moment.js.
The map for showing the location coordinates in the configuration node is provided by OpenStreetMap.
Version: 1.30.1
Updated 1 month ago
Rating: 4.6 12
185 in the last week
  • chronos-config
  • chronos-scheduler
  • chronos-state
  • chronos-repeat
  • chronos-delay
  • chronos-switch
  • chronos-filter
  • chronos-change
  • schedule
  • scheduler
  • scheduling
  • time
  • timestamp
  • timespan
  • time-switch
  • time-filter
  • time-change
  • timer
  • timers
  • timing
  • delay
  • repeat
  • repetition
  • cron
  • crontab
  • sun
  • suntime
  • moon
  • moontime
  • sunrise
  • sunset
  • smart-home
  • home-automation
