HueMagic dimmer (subflow)
(Disclaimer: this subflow might be outdated. I stopped using it myself after switching from hue bridge to deConz)
Subflow to be used with node-red-contrib-huemagic
Subflow subflow
Example flow
example flow
Copy the subflow below to your clipboard and then import into Node-RED using the Import From > Clipboard (Ctrl-I) menu option
[{"id":"e07b1600.952758","type":"subflow","name":"HueMagic dimmer","info":"","category":"","in":[{"x":40,"y":60,"wires":[{"id":"fddda787.df7248"}]}],"out":[{"x":860,"y":200,"wires":[{"id":"e5991875.4a2368","port":0},{"id":"d839dbf8.4fbda8","port":0},{"id":"87028dea.edc6","port":0}]}],"env":[{"name":"ButtonPressed","type":"num","value":"0"},{"name":"ButtonReleased","type":"num","value":"1"},{"name":"Step","type":"num","value":"5","ui":{"icon":"font-awesome/fa-percent","type":"input","opts":{"types":["num"]},"label":{}}}],"color":"#E6E0F8","inputLabels":["from trigger"],"outputLabels":["to hue light"],"icon":"node-red/light.svg","status":{"x":860,"y":140,"wires":[{"id":"87028dea.edc6","port":0},{"id":"d839dbf8.4fbda8","port":0},{"id":"e5991875.4a2368","port":0}]}},{"id":"fddda787.df7248","type":"switch","z":"e07b1600.952758","name":"pressed/released?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"ButtonReleased","vt":"env"},{"t":"eq","v":"ButtonPressed","vt":"env"}],"checkall":"true","repair":false,"outputs":2,"x":190,"y":60,"wires":[["9b2fca04.97ffd8","3c5b21f7.36c6ce"],["47aae127.8b73f","b7fdabcf.07e1d8"]]},{"id":"47aae127.8b73f","type":"trigger","z":"e07b1600.952758","op1":"","op2":"true","op1type":"nul","op2type":"bool","duration":"500","extend":false,"units":"ms","reset":"reset","bytopic":"all","name":"Button held?","x":410,"y":120,"wires":[["ec831b0a.31d458"]]},{"id":"e5991875.4a2368","type":"change","z":"e07b1600.952758","name":"{\"toggle\":1}","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"toggle\":1}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":100,"wires":[[]]},{"id":"234d2c25.d97894","type":"change","z":"e07b1600.952758","name":"flow.next = 0","rules":[{"t":"set","p":"next","pt":"flow","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":140,"wires":[[]]},{"id":"804c04c1.d35ce8","type":"change","z":"e07b1600.952758","name":"flow.next = 1","rules":[{"t":"set","p":"next","pt":"flow","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":260,"wires":[[]]},{"id":"a791a981.82a298","type":"trigger","z":"e07b1600.952758","op1":"Step","op2":"0","op1type":"env","op2type":"str","duration":"-400","extend":false,"units":"ms","reset":"reset","bytopic":"all","name":"","x":440,"y":180,"wires":[["234d2c25.d97894","87028dea.edc6"]]},{"id":"26d688ef.4aacf8","type":"trigger","z":"e07b1600.952758","op1":"Step","op2":"0","op1type":"env","op2type":"str","duration":"-400","extend":false,"units":"ms","reset":"reset","bytopic":"all","name":"","x":440,"y":220,"wires":[["804c04c1.d35ce8","d839dbf8.4fbda8"]]},{"id":"ec831b0a.31d458","type":"switch","z":"e07b1600.952758","name":"flow.next switch","property":"next","propertyType":"flow","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":180,"y":200,"wires":[["a791a981.82a298"],["26d688ef.4aacf8"]]},{"id":"87028dea.edc6","type":"template","z":"e07b1600.952758","name":"incrementBrightness","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\"incrementBrightness\":{{payload}}}","output":"json","x":680,"y":180,"wires":[[]]},{"id":"d839dbf8.4fbda8","type":"template","z":"e07b1600.952758","name":"decrementBrightness","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\"decrementBrightness\":{{payload}}}","output":"json","x":680,"y":220,"wires":[[]]},{"id":"9b2fca04.97ffd8","type":"change","z":"e07b1600.952758","name":"reset","rules":[{"t":"set","p":"payload","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":170,"y":120,"wires":[["a791a981.82a298","26d688ef.4aacf8","47aae127.8b73f"]]},{"id":"b7fdabcf.07e1d8","type":"change","z":"e07b1600.952758","name":"","rules":[{"t":"set","p":"PressedTime","pt":"flow","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":40,"wires":[[]]},{"id":"3c5b21f7.36c6ce","type":"change","z":"e07b1600.952758","name":"","rules":[{"t":"set","p":"ReleasedTime","pt":"flow","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":80,"wires":[["6df4edcd.364f64"]]},{"id":"6df4edcd.364f64","type":"function","z":"e07b1600.952758","name":"Short press?","func":"if (flow.get(\"ReleasedTime\") - flow.get(\"PressedTime\") < 500)\n{\n    msg.payload = \"Short press\";\n    return msg;\n}","outputs":1,"noerr":0,"x":630,"y":60,"wires":[["e5991875.4a2368"]]}]
Created 5 years, 9 months ago
Updated 4 years, 1 month ago
  • change (x6)
  • switch (x2)
  • template (x2)
  • trigger (x3)
  • subflow (x1)
  • HueMagic
  • dimmer
  • subflow
