Upload Files
On this flow we demonstrate how to use NR and Jquery to build some funcional screens and how to perform a upload of a file csv.
[{"id":"df7dfb16.097188","type":"file in","z":"faec0284.5e00d","name":"","filename":"","format":"utf8","x":126,"y":347,"wires":[["df773c62.724e"]]},{"id":"df773c62.724e","type":"csv","z":"faec0284.5e00d","name":"","sep":";","hdrin":true,"hdrout":"","multi":"mult","ret":"\\n","temp":"","x":126,"y":387,"wires":[["f21b5089.53da7"]]},{"id":"5731bb5.453ce44","type":"change","z":"faec0284.5e00d","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"req.files['csv'][0]","tot":"msg"},{"t":"set","p":"filename","pt":"msg","to":"payload.path","tot":"msg"},{"t":"set","p":"originalname","pt":"msg","to":"payload.originalname","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":156,"y":307,"wires":[["df7dfb16.097188"]]},{"id":"f6d5a469.13eb68","type":"httpInMultipart","z":"faec0284.5e00d","name":"","url":"/uploadRegras","method":"post","fields":"[{\"name\": \"csv\", \"maxCount\": 1}]","swaggerDoc":"","x":164,"y":267,"wires":[["5731bb5.453ce44"]]},{"id":"53b7bac.3297b44","type":"http response","z":"faec0284.5e00d","name":"","x":892,"y":418,"wires":[]},{"id":"e269e79f.ef1608","type":"template","z":"faec0284.5e00d","name":"","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"Upload de {{originalname}} feito com sucesso!\n\n{{output}}","x":772,"y":418,"wires":[["53b7bac.3297b44"]]},{"id":"220c22f4.d2318e","type":"join","z":"faec0284.5e00d","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","timeout":"","count":"","x":532,"y":418,"wires":[["55959bda.5a7f54"]]},{"id":"85cad0ed.2ba2b","type":"split","z":"faec0284.5e00d","name":"","splt":"","x":386,"y":467,"wires":[["220c22f4.d2318e","67bb1ea4.49d8f"]]},{"id":"55959bda.5a7f54","type":"function","z":"faec0284.5e00d","name":"","func":"msg.output = JSON.stringify(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":652,"y":418,"wires":[["e269e79f.ef1608"]]},{"id":"1e2af6d6.8c4879","type":"comment","z":"faec0284.5e00d","name":"Processamento do CSV","info":"","x":590,"y":380,"wires":[]},{"id":"cdc4c470.0d6118","type":"function","z":"faec0284.5e00d","name":"Criado_em e Valido_ate","func":"var arrProd = [];\n\nmsg.produtos.forEach(function(p){\n    \n    var validade = new Date();\n    \n    var qdadeDias = p.valido_ate;\n    validade.setDate(validade.getDate() + qdadeDias);\n    \n    validade.setHours(23);\n    validade.setMinutes(59);\n    validade.setSeconds(59);\n    \n    p.valido_ate = validade;\n});\n\nmsg.payload.forEach(function(prod){\n\n    prod.produtos = msg.produtos;\n    prod.criado_em = new Date();\n\n    arrProd.push(prod);\n    \n});\n\nreturn msg;","outputs":1,"noerr":0,"x":186,"y":467,"wires":[["85cad0ed.2ba2b"]]},{"id":"6f5cdc7f.6c1bb4","type":"http in","z":"faec0284.5e00d","name":"","url":"/uploadRegras","method":"get","swaggerDoc":"","x":166,"y":107,"wires":[["86b5dfab.9153f"]]},{"id":"c79d99a3.ec22f8","type":"template","z":"faec0284.5e00d","name":"TELA","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<!DOCTYPE html>\n<head>\n    <title>Sinapse - Porto Seguro</title>\n    <meta charset=\"utf-8\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n    <link rel=\"stylesheet\" href=\"vendor/bootstrap/css/bootstrap.min.css\">\n    \n    <script src=\"https://ajax.googleapis.com/ajax/libs/jquery/3.2.1/jquery.min.js\"></script>\n    <script src=\"https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/js/bootstrap.min.js\"></script>\n    <script src=\"https://cdnjs.cloudflare.com/ajax/libs/json2html/1.0.0/json2html.js\"></script>\n    <script src=\"https://cdnjs.cloudflare.com/ajax/libs/jquery.json2html/1.0.0/jquery.json2html.js\"></script>\n    <script type=\"text/javascript\">\n        $(function () {\n            var data = {{#payload}}{{{.}}}{{/payload}};\n            var transform = {\n                tag: 'tr',\n                children: [\n                    { 'tag': 'td', 'html': \"\", children: [\n                        {  'tag':'input','type': 'checkbox', 'value': '${id_produto}/${nome}', 'name': 'id_prod', 'class': 'check' }\n                    ]},\n                    { 'tag': 'td', 'html': \"${id_produto}\" },\n                    { 'tag': 'td', 'html': \"${nome}\" },\n                    { 'tag': 'td', 'html': \"\", children: [\n                        {  'tag':'input','type': 'number', 'name': '${id_produto}' }\n                    ]}\n                ]\n            };\n            $('#produtos > tbody').json2html(data, transform);\n        });\n        \n        function checar() {\n            var checado=false;\n            $(\".check\").each(function(){\n                if($(this).prop(\"checked\"))\n                    checado=true;\n            });\n            if(!checado){\n                $(\"#alert\").modal();\n                return false;\n            }\n        }\n  </script>\n</head>\n<body class=\"container\">\n    <form action=\"/uploadRegras\" method=\"post\" enctype=\"multipart/form-data\">\n    <section class=\"row\">\n        <div class=\"table-responsive\">\n        <h1>Produtos</h1>\n        <table id=\"produtos\" class=\"table table-striped table-bordered\">\n            <thead>\n                <tr>\n                    <th></th>\n                    <th>id_produto</th>\n                    <th>Nome</th>\n                    <th>Validade (dias)</th>\n                </tr>\n            </thead>\n            <tbody></tbody>\n        </table>\n        \n        <h1>Upload do CSV</h1>\n        <table id=\"csv\" class=\"table table-striped table-bordered\">\n            <thead>\n                <tr>\n                    <th><input type=\"file\" name=\"csv\" required /></th>\n                </tr>\n            </thead>\n            <tbody></tbody>\n        </table>\n        </div>\n    </section>\n    \n    <section class=\"row\" style=\"text-align: center;\" >\n        <input type=\"submit\" class=\"btn btn-secondary\" value=\"ENVIAR\" onclick=\"return checar()\"/>\n        <a href=\"localhost:1880/produtos\" > <input type=\"button\" class=\"btn btn-secondary\" value=\"Cadastro de Produtos\" /> </a>\n    </section>\n    </form>   \n    \n    <!-- Modal -->\n  <div class=\"modal fade\" id=\"alert\" role=\"dialog\">\n    <div class=\"modal-dialog\">\n    \n      <!-- Modal content-->\n      <div class=\"modal-content\">\n        <div class=\"modal-header\">\n          <button type=\"button\" class=\"close\" data-dismiss=\"modal\">&times;</button>\n          <h4 class=\"modal-title\">ATENÇÃO</h4>\n        </div>\n        <div class=\"modal-body\">\n          <p>Todas as cargas devem estar associadas a ao menos 1 produto. Por favor, selecione na listagem ou acione o botão 'Cadastro de Produtos' para inserir um novo Produto.</p>\n        </div>\n        <div class=\"modal-footer\">\n          <button type=\"button\" class=\"btn btn-default\" data-dismiss=\"modal\">OK</button>\n        </div>\n      </div>\n      \n    </div>\n  </div>\n  \n</body>\n</html>","x":490,"y":160,"wires":[["bf79fd07.96b56"]]},{"id":"bf79fd07.96b56","type":"http response","z":"faec0284.5e00d","name":"","x":630,"y":160,"wires":[]},{"id":"86b5dfab.9153f","type":"change","z":"faec0284.5e00d","name":"","rules":[{"t":"set","p":"projection","pt":"msg","to":"{ \"_id\": 0 }","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":170,"y":160,"wires":[["2148bb6.1508b44"]]},{"id":"f21b5089.53da7","type":"function","z":"faec0284.5e00d","name":"msg.produtos","func":"var arr = [];\n\nvar id_produtos = msg.req.body.id_prod;\n\nif(typeof(id_produtos) === \"string\"){\n    \n    var split = id_produtos.split(\"/\");\n    var temp = {};\n    \n    temp[\"id_produto\"] = split[0];\n    temp[\"nome\"] = split[1];\n    \n    Object.keys(msg.req.body).forEach(function(id){\n        \n        if(id === temp[\"id_produto\"]){\n            temp[\"valido_ate\"] = Number (msg.req.body[id]);\n        }\n    });\n\n    arr.push(temp);\n\n}else{\n    \n    id_produtos.forEach(function(item){\n    \n    var split = item.split(\"/\");\n    var temp = {};\n    \n    temp[\"id_produto\"] = split[0];\n    temp[\"nome\"] = split[1];\n    \n    Object.keys(msg.req.body).forEach(function(id){\n        \n        if(id === temp[\"id_produto\"]){\n            temp[\"valido_ate\"] = Number (msg.req.body[id]);\n        }\n    });\n\n    arr.push(temp);\n    \n});\n    \n}\n\nmsg.produtos = arr;\n\nreturn msg;","outputs":1,"noerr":0,"x":156,"y":427,"wires":[["cdc4c470.0d6118"]]},{"id":"a57d1970.a64868","type":"comment","z":"faec0284.5e00d","name":"URL de teste da tela : http://52.55.240.135:3002/uploadRegras","info":"","x":297,"y":66,"wires":[]},{"id":"2148bb6.1508b44","type":"template","z":"faec0284.5e00d","name":"Mock info","field":"payload","fieldType":"msg","format":"json","syntax":"plain","template":"[{\"id_produto\":\"93\",\"nome\":\"AUTO_SEGURO_NOVO\"},{\"id_produto\":\"67\",\"nome\":\"PORTATEIS\"},{\"id_produto\":\"31\",\"nome\":\"VIDA INDIVIDUAL\"},{\"id_produto\":\"10\",\"nome\":\"GRAOS\"},{\"id_produto\":\"11\",\"nome\":\"SAUDE\"},{\"id_produto\":\"12\",\"nome\":\"FINANCIAMENTO\"},{\"id_produto\":\"33\",\"nome\":\"HORTA E POMAR\"},{\"id_produto\":\"55\",\"nome\":\"PATRIMONIAL\"},{\"id_produto\":\"56\",\"nome\":\"CONSÓRCIO\"},{\"id_produto\":\"66\",\"nome\":\"INVESTIMENTO\"},{\"id_produto\":\"88\",\"nome\":\"PET\"}]","output":"str","x":360,"y":160,"wires":[["c79d99a3.ec22f8"]]},{"id":"67bb1ea4.49d8f","type":"debug","z":"faec0284.5e00d","name":"Database record ...","active":true,"console":"false","complete":"payload","x":560,"y":520,"wires":[]}]
Created 9 years, 5 months ago
  • change (x2)
  • comment (x2)
  • csv (x1)
  • file in (x1)
  • function (x3)
  • http in (x1)
  • http response (x2)
  • join (x1)
  • split (x1)
  • template (x3)
  • csv
  • upload
  • http
  • jquery
