MyQ Door and hub monitor
I use this flow to send text notifications to my phone via email. It monitors my garage door and the MyQ hub. A input number slider in Homeassistant sets time to wait until the notification email is sent. It also pulls the email address from an input text box in Homeassistant.
[{"id":"0cacce509fd241eb","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"6a28fe68a71e69b8","type":"server-state-changed","z":"0cacce509fd241eb","name":"Door","server":"8cd93e38.ec024","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"cover.garage_door","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"door","valueType":"str"}],"x":70,"y":120,"wires":[["c4edebda2b82a03f"]]},{"id":"1d24ee60216a8818","type":"delay","z":"0cacce509fd241eb","name":"delay","pauseType":"delayv","timeout":"1","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":590,"y":80,"wires":[["a83fe738859b5eda"]]},{"id":"80887417027fef5e","type":"switch","z":"0cacce509fd241eb","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"open","vt":"str"},{"t":"eq","v":"closed","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":310,"y":80,"wires":[["f03fee8c9aa4fa4a"],["38676a0709961cc8"]]},{"id":"38676a0709961cc8","type":"change","z":"0cacce509fd241eb","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":100,"wires":[["1d24ee60216a8818"]]},{"id":"f03fee8c9aa4fa4a","type":"change","z":"0cacce509fd241eb","name":"to millisecs","rules":[{"t":"set","p":"delay","pt":"msg","to":"msg.delay*60000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":60,"wires":[["1d24ee60216a8818"]]},{"id":"c4edebda2b82a03f","type":"api-current-state","z":"0cacce509fd241eb","name":"Alert","server":"8cd93e38.ec024","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_number.door_open_alert","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"delay","propertyType":"msg","value":"","valueType":"entityState"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":190,"y":100,"wires":[["80887417027fef5e"]]},{"id":"a83fe738859b5eda","type":"change","z":"0cacce509fd241eb","name":"to min","rules":[{"t":"set","p":"delay","pt":"msg","to":"msg.delay/60000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":80,"wires":[["e6afcb27dadb99d4"]]},{"id":"e6afcb27dadb99d4","type":"template","z":"0cacce509fd241eb","name":"format","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Garge door has been open for {{delay}} minutes","output":"str","x":830,"y":80,"wires":[["bfd10fddcde59782"]]},{"id":"9719659331225ef2","type":"server-state-changed","z":"0cacce509fd241eb","name":"email to","server":"8cd93e38.ec024","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_text.email","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"email","valueType":"str"}],"x":830,"y":120,"wires":[["bfd10fddcde59782"]]},{"id":"c9801a488bb5f3d3","type":"api-current-state","z":"0cacce509fd241eb","name":"email on/off","server":"8cd93e38.ec024","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.garage_door_email","state_type":"str","blockInputOverrides":false,"outputProperties":[],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1230,"y":100,"wires":[["6c835334fae6f766"],[]]},{"id":"bfd10fddcde59782","type":"join","z":"0cacce509fd241eb","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":950,"y":100,"wires":[["bd02bb854ed587c1"]]},{"id":"bd02bb854ed587c1","type":"change","z":"0cacce509fd241eb","name":"change","rules":[{"t":"move","p":"payload.email","pt":"msg","to":"to","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"ALERT! GARAGE DOOR LEFT OPEN","tot":"str"},{"t":"move","p":"payload.door","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":100,"wires":[["c9801a488bb5f3d3"]]},{"id":"556d5902cc76d4b4","type":"server-state-changed","z":"0cacce509fd241eb","name":"Hub","server":"8cd93e38.ec024","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.garage_door_hub_email","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"hub","valueType":"str"}],"x":70,"y":240,"wires":[["06d436d7319af8dc"]]},{"id":"ca15819913de4c5f","type":"delay","z":"0cacce509fd241eb","name":"delay","pauseType":"delayv","timeout":"1","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":590,"y":200,"wires":[["82ce960b6029a05c"]]},{"id":"cb2bd804b971d1f7","type":"switch","z":"0cacce509fd241eb","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"off","vt":"str"},{"t":"eq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":310,"y":200,"wires":[["7b3a6029806e4793"],["a483b3900e04b827"]]},{"id":"a483b3900e04b827","type":"change","z":"0cacce509fd241eb","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":220,"wires":[["ca15819913de4c5f"]]},{"id":"7b3a6029806e4793","type":"change","z":"0cacce509fd241eb","name":"to millisecs","rules":[{"t":"set","p":"delay","pt":"msg","to":"msg.delay*60000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":180,"wires":[["ca15819913de4c5f"]]},{"id":"06d436d7319af8dc","type":"api-current-state","z":"0cacce509fd241eb","name":"Alert","server":"8cd93e38.ec024","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_number.door_open_alert","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"delay","propertyType":"msg","value":"","valueType":"entityState"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":190,"y":220,"wires":[["cb2bd804b971d1f7"]]},{"id":"82ce960b6029a05c","type":"change","z":"0cacce509fd241eb","name":"to min","rules":[{"t":"set","p":"delay","pt":"msg","to":"msg.delay/60000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":200,"wires":[["1f640c647d53ec49"]]},{"id":"1f640c647d53ec49","type":"template","z":"0cacce509fd241eb","name":"format","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Garage door hub has been offline for {{delay}} minutes","output":"str","x":830,"y":200,"wires":[["429a2ca2769647b1"]]},{"id":"6dcc1c67c00df79c","type":"server-state-changed","z":"0cacce509fd241eb","name":"email to","server":"8cd93e38.ec024","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_text.email","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"topic","propertyType":"msg","value":"email","valueType":"str"}],"x":830,"y":240,"wires":[["429a2ca2769647b1"]]},{"id":"39fc1ee0f536bcb5","type":"api-current-state","z":"0cacce509fd241eb","name":"email on/off","server":"8cd93e38.ec024","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.garage_door_email","state_type":"str","blockInputOverrides":false,"outputProperties":[],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1230,"y":220,"wires":[["6c835334fae6f766"],[]]},{"id":"429a2ca2769647b1","type":"join","z":"0cacce509fd241eb","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":950,"y":220,"wires":[["a4f10a0061cfc15a"]]},{"id":"a4f10a0061cfc15a","type":"change","z":"0cacce509fd241eb","name":"change","rules":[{"t":"move","p":"payload.email","pt":"msg","to":"to","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"ALERT! GARAGE DOOR HUB OFFLINE","tot":"str"},{"t":"move","p":"payload.hub","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":220,"wires":[["39fc1ee0f536bcb5"]]},{"id":"6c835334fae6f766","type":"debug","z":"0cacce509fd241eb","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1310,"y":160,"wires":[]},{"id":"8cd93e38.ec024","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Created 3 years, 11 months ago
  • change (x8)
  • delay (x2)
  • join (x2)
  • switch (x2)
  • template (x2)
  • MyQ
  • garge
  • door
  • notification
  • email
