Telegram ChatBot, with voice using IBM Watson
Telegram ChatBot using IBM Watson Speech to Text, Watson text to Speech and Watson Assistant
[{"id":"792ac52b198f8bde","type":"subflow","name":"Tradutor","info":"","category":"","in":[{"x":50,"y":30,"wires":[{"id":"0d1af12374e7d750"}]}],"out":[{"x":760,"y":20,"wires":[{"id":"cffadc551a6b7dab","port":0},{"id":"ba1b8adfd3688e24","port":0},{"id":"6e88d8407d2857d4","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"97a2928aea0671ed","type":"watson-language-translator-identify","z":"792ac52b198f8bde","name":"","service-endpoint":"https://api.us-south.language-translator.watson.cloud.ibm.com/instances/e0759a16-77f3-44c8-a30b-5348a4c9a54e","x":330,"y":40,"wires":[["ba1b8adfd3688e24"]]},{"id":"ba1b8adfd3688e24","type":"function","z":"792ac52b198f8bde","name":"function 12","func":"if(msg.lang.language != \"en\"){\n    global.set(\"lang\",\"pt\");\n    return [msg,null];\n}\nelse {\n    global.set(\"lang\",\"en\");\n    msg.srclang = msg.lang.language;\n    msg.destlang = \"pt\";\n    return [null,msg];\n}\n","outputs":2,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":40,"wires":[[],["cffadc551a6b7dab"]]},{"id":"cffadc551a6b7dab","type":"watson-translator","z":"792ac52b198f8bde","name":"","action":"translate","basemodel":"ar-en","domain":"general","srclang":"en","destlang":"pt","apikey":"O83UUiHvp4mbjTtTapzMiZ8b_7IW234oWr8tIe19P1yf","custom":"","domainhidden":"general","srclanghidden":"en","destlanghidden":"pt","basemodelhidden":"ar-en","customhidden":"","filetype":"forcedglossary","trainid":"","lgparams2":true,"service-endpoint":"https://api.us-south.language-translator.watson.cloud.ibm.com/instances/e0759a16-77f3-44c8-a30b-5348a4c9a54e","x":470,"y":120,"wires":[[]]},{"id":"0d1af12374e7d750","type":"switch","z":"792ac52b198f8bde","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"Entrada","vt":"str"},{"t":"eq","v":"Saida","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":150,"y":100,"wires":[["97a2928aea0671ed"],["6e88d8407d2857d4"]]},{"id":"6e88d8407d2857d4","type":"function","z":"792ac52b198f8bde","name":"function 13","func":"var lang = global.get(\"lang\") || \"pt\";\nif(lang == \"pt\")\n    return [msg,null];\nelse {\n    msg.srclang = \"pt\";\n    msg.destlang = \"en\";\n    return [null,msg];\n}\n","outputs":2,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":450,"y":220,"wires":[[],["cffadc551a6b7dab"]]},{"id":"2283cac4a664dd57","type":"telegram receiver","z":"2167fdd22f20533b","name":"","bot":"e38982b38d4227f7","saveDataDir":"","filterCommands":false,"x":120,"y":360,"wires":[["02b267465ab11595"],["51589c96781b03f9"]]},{"id":"793036674f6b46b6","type":"telegram sender","z":"2167fdd22f20533b","name":"","bot":"e38982b38d4227f7","haserroroutput":false,"outputs":1,"x":940,"y":360,"wires":[[]]},{"id":"51589c96781b03f9","type":"function","z":"2167fdd22f20533b","name":"Usuário não autorizado","func":"msg.payload.type = \"message\";\nmsg.payload.content = \"Você não está autorizado, \" + msg.originalMessage.from.first_name;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":360,"wires":[["793036674f6b46b6"]]},{"id":"d509b1f713084493","type":"comment","z":"2167fdd22f20533b","name":"","info":"Instalar node-red-contrib-telegrambot\n\n","x":110,"y":100,"wires":[]},{"id":"5b77effbcf56edad","type":"watson-conversation-v1","z":"2167fdd22f20533b","name":"","workspaceid":"2a628c55-5c2c-4c91-af6d-7f109708b6af","multiuser":false,"context":true,"empty-payload":false,"service-endpoint":"https://api.us-south.assistant.watson.cloud.ibm.com/instances/81b32a79-de24-4f06-957b-f191bc7c1246","timeout":"","optout-learning":false,"x":540,"y":100,"wires":[["0fc3a2be3c49ab1d","3d8f4bc14d2667aa"]]},{"id":"7980bf96f59d88c0","type":"change","z":"2167fdd22f20533b","name":"Texto","rules":[{"t":"set","p":"telegram","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"telegram.content","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"Entrada","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":270,"y":100,"wires":[["1e332edaa4f10e24"]]},{"id":"f0f29353281a6339","type":"change","z":"2167fdd22f20533b","name":"Texto","rules":[{"t":"set","p":"telegram.content","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"telegram","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":950,"y":200,"wires":[["793036674f6b46b6"]]},{"id":"a41f1893c4694c22","type":"watson-speech-to-text","z":"2167fdd22f20533b","name":"Voz para texto","alternatives":1,"speakerlabels":true,"smartformatting":false,"lang":"pt-BR","langhidden":"pt-BR","langcustom":"NoCustomisationSetting","langcustomhidden":"","custom-weight":"0.5","band":"ShortForm","bandhidden":"","keywords":"","keywords-threshold":"0.5","word-confidence":false,"password":"","apikey":"Jegc_ewvuqESEdef65wJUPjaT_39TlAAMxIZElUFEH4H","payload-response":true,"streaming-mode":false,"streaming-mute":true,"auto-connect":false,"discard-listening":false,"disable-precheck":false,"service-endpoint":"https://api.us-south.speech-to-text.watson.cloud.ibm.com/instances/94e42c1e-33c9-4a78-8747-3f8b95f5277a","x":380,"y":140,"wires":[["5b77effbcf56edad"]]},{"id":"facbc5efc9732788","type":"watson-text-to-speech","z":"2167fdd22f20533b","name":"Texto para voz","lang":"pt-BR","langhidden":"pt-BR","langcustom":"NoCustomisationSetting","langcustomhidden":"","voice":"pt-BR_IsabelaV3Voice","voicehidden":"pt-BR_IsabelaV3Voice","format":"audio/wav","password":"","apikey":"0oqR26ZhJeLA6tK6rA8ZnP9MaWBnLY6uY8FfLZIGM_CN","payload-response":true,"service-endpoint":"https://api.us-south.text-to-speech.watson.cloud.ibm.com/instances/0135093c-20b6-4d86-8c23-1f6b8fe072a7","x":780,"y":200,"wires":[["773b63b81951c3aa"]]},{"id":"02b267465ab11595","type":"switch","z":"2167fdd22f20533b","name":"Tipo mensagem","property":"payload.type","propertyType":"msg","rules":[{"t":"eq","v":"message","vt":"str"},{"t":"eq","v":"voice","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":120,"y":160,"wires":[["7980bf96f59d88c0"],["c52e2c42050eb458"],["a8dadeabfb93ea0c"]]},{"id":"c52e2c42050eb458","type":"change","z":"2167fdd22f20533b","name":"Voz","rules":[{"t":"set","p":"telegram","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"url","pt":"msg","to":"telegram.weblink","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":330,"y":200,"wires":[["81a240c246b56e92"]]},{"id":"81a240c246b56e92","type":"http request","z":"2167fdd22f20533b","name":"Extrai audio","method":"GET","ret":"bin","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":550,"y":200,"wires":[["a41f1893c4694c22"]]},{"id":"0fc3a2be3c49ab1d","type":"switch","z":"2167fdd22f20533b","name":"Tipo resposta","property":"telegram.type","propertyType":"msg","rules":[{"t":"eq","v":"message","vt":"str"},{"t":"eq","v":"voice","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":700,"y":100,"wires":[["6d9d364d9e583d2b"],["44cd4786f89c8610"]]},{"id":"44cd4786f89c8610","type":"change","z":"2167fdd22f20533b","name":"Voz","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.output.generic[0].text","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":160,"wires":[["facbc5efc9732788"]]},{"id":"773b63b81951c3aa","type":"change","z":"2167fdd22f20533b","name":"Recupera estado","rules":[{"t":"set","p":"telegram.content","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"telegram","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":260,"wires":[["793036674f6b46b6"]]},{"id":"a8dadeabfb93ea0c","type":"function","z":"2167fdd22f20533b","name":"Formato não aceito","func":"msg.payload.type = \"message\";\nmsg.payload.content = \"Infelizmente não trato este tipo de mensagem\";\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":460,"wires":[["793036674f6b46b6"]]},{"id":"1e332edaa4f10e24","type":"subflow:792ac52b198f8bde","z":"2167fdd22f20533b","name":"","env":[{"name":"topic","value":"{\"uso\":\"Entrada\"}","type":"json"}],"x":400,"y":100,"wires":[["5b77effbcf56edad","3d8f4bc14d2667aa"]]},{"id":"630f71157e17c927","type":"subflow:792ac52b198f8bde","z":"2167fdd22f20533b","name":"","env":[{"name":"topic","value":"{\"uso\":\"Saida\"}","type":"json"}],"x":1040,"y":100,"wires":[["f0f29353281a6339"]]},{"id":"6d9d364d9e583d2b","type":"function","z":"2167fdd22f20533b","name":"function 14","func":"msg.payload = msg.payload.output.generic[0].text;\nmsg.topic = \"Saida\";\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":100,"wires":[["630f71157e17c927"]]},{"id":"3d8f4bc14d2667aa","type":"debug","z":"2167fdd22f20533b","name":"debug 17","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":300,"y":480,"wires":[]},{"id":"e38982b38d4227f7","type":"telegram bot","botname":"gama-fiap2","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksprotocol":"socks5","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","botpath":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false}]
Created 1 year, 6 months ago
Rating: 1 1
  • change (x5)
  • function (x5)
  • http request (x1)
  • switch (x3)
  • Watson
  • Telegram
  • STT
  • TTS
  • WatsonAssistant
  • WA
