Musiccast Control Dashboard
This flow provides display and basic playback and volume control functions for a Yamaha AV device. In addition to "node-red-contrib-musiccast", this flow also requires the installation of "node-red-dashboard".
To get up and running, import the flow to your palette and perform the following:
Open the Musiccast configuration "Example" and update the IP address of the "Living Room Audio" device with your own Musiccast device. Click [Save] and then deploy your updates.
If everything works ok, the dashboard should now have a new tab called "Musiccast". If you're not familiar with "node-red-dashboard", please review its documentation.
[{"id":"4d86fe720f2c76be","type":"tab","label":"Musiccast Dashboard","disabled":false,"info":"This example flow provides the display and basic playback and volume control functions.  The collection \"node-red-dashboard\" must also be added to the palette before this flow will work.\n\nTo configure this flow, open the configuration [Example] and update the IP address of the \"Living Room\" device to match your main Musiccast device.  \n\nAfter saving the configuration and deployment, the dashboard should now have a new tab called \"Musiccast\".","env":[]},{"id":"0d2facd591b5fc47","type":"inject","z":"4d86fe720f2c76be","name":"Update","props":[{"p":"payload"}],"repeat":"2","crontab":"","once":true,"onceDelay":"0.5","topic":"","payload":"{}","payloadType":"json","x":120,"y":40,"wires":[["72659015e91a5a1a","a53d4e95b11936ab"]]},{"id":"ef901590b8dd3fac","type":"ui_button","z":"4d86fe720f2c76be","name":"Up","group":"e62cf483d385fd0d","order":7,"width":"2","height":"1","passthru":false,"label":"","tooltip":"Volume up","color":"","bgcolor":"#A6BBCF","className":"","icon":"fa-volume-up fa-2x","payload":"{\"volume\":\"up\",\"step\":\"2\"}","payloadType":"json","topic":"","topicType":"str","x":930,"y":380,"wires":[["a11acbde6cf81ade"]]},{"id":"1e4f492ec3c122a7","type":"ui_button","z":"4d86fe720f2c76be","name":"Down","group":"e62cf483d385fd0d","order":5,"width":"2","height":"1","passthru":false,"label":"","tooltip":"Volume down","color":"","bgcolor":"#A6BBCF","className":"","icon":"fa-volume-down fa-2x","payload":"{\"volume\":\"down\",\"step\":\"2\"}","payloadType":"json","topic":"","topicType":"str","x":930,"y":420,"wires":[["a11acbde6cf81ade"]]},{"id":"58067e31e0f1ceca","type":"ui_switch","z":"4d86fe720f2c76be","name":"Mute","label":"","tooltip":"","group":"e62cf483d385fd0d","order":6,"width":"2","height":"1","passthru":false,"decouple":"true","topic":"","topicType":"str","style":"","onvalue":"{\"enable\":true}","onvalueType":"json","onicon":"fa-volume-off fa-2x","oncolor":"#C0C0C0","offvalue":"{\"enable\":false}","offvalueType":"json","officon":"fa-volume-off fa-2x","offcolor":"black","animate":true,"className":"","x":930,"y":40,"wires":[["8e49b06d97aec365"]]},{"id":"30a82fe078e3eef8","type":"ui_button","z":"4d86fe720f2c76be","name":"Previous","group":"e62cf483d385fd0d","order":8,"width":"2","height":"1","passthru":false,"label":"","tooltip":"Back","color":"","bgcolor":"#87A980","className":"","icon":"fa-step-backward fa-2x","payload":"{ \"playback\": \"previous\" }","payloadType":"json","topic":"","topicType":"str","x":940,"y":340,"wires":[["63eb6f6b87138382"]]},{"id":"3b0d06c89768df20","type":"ui_button","z":"4d86fe720f2c76be","name":"Next","group":"e62cf483d385fd0d","order":10,"width":"2","height":"1","passthru":false,"label":"","tooltip":"Next","color":"","bgcolor":"#87A980","className":"","icon":"fa-step-forward fa-2x","payload":"{ \"playback\": \"next\" }","payloadType":"json","topic":"","topicType":"str","x":930,"y":300,"wires":[["63eb6f6b87138382"]]},{"id":"d9f9f0d3fecd773b","type":"change","z":"4d86fe720f2c76be","name":"set vol","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.volume","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":80,"wires":[["f6b32b7d20131810"]]},{"id":"0c387d78d6d1aa18","type":"change","z":"4d86fe720f2c76be","name":"set mute","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.mute","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"bool","to":"{\"enable\":true}","tot":"json"},{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"bool","to":"{\"enable\":false}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":40,"wires":[["0d3ed8d889cd18b6"]]},{"id":"3e51a5cc3ac5ec1e","type":"change","z":"4d86fe720f2c76be","name":"set playback","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.playback","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"play","fromt":"str","to":"{\"playback\":\"play\"}","tot":"json"},{"t":"change","p":"payload","pt":"msg","from":"pause","fromt":"str","to":"{\"playback\":\"pause\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":260,"wires":[["0d70edea010745f8"]]},{"id":"212e2a3eb9e6f660","type":"ui_switch","z":"4d86fe720f2c76be","name":"Playback","label":"","tooltip":"Toggle play","group":"e62cf483d385fd0d","order":9,"width":"2","height":"1","passthru":false,"decouple":"true","topic":"","topicType":"str","style":"","onvalue":"{\"playback\":\"play\"}","onvalueType":"json","onicon":"fa-play fa-2x","oncolor":"black","offvalue":"{\"playback\":\"pause\"}","offvalueType":"json","officon":"fa-play fa-2x","offcolor":"#C0C0C0","animate":true,"className":"","x":940,"y":260,"wires":[["63eb6f6b87138382"]]},{"id":"6d7d91fb67b950fe","type":"ui_text","z":"4d86fe720f2c76be","group":"e62cf483d385fd0d","order":2,"width":"6","height":"1","name":"Artist","label":"","format":"{{msg.payload | limitTo:100}}","layout":"row-center","className":"","x":930,"y":180,"wires":[]},{"id":"5966828a7e3a04d3","type":"ui_text","z":"4d86fe720f2c76be","group":"e62cf483d385fd0d","order":1,"width":"6","height":"1","name":"Track","label":"","format":"{{msg.payload | limitTo:100}}","layout":"row-center","className":"","x":930,"y":220,"wires":[]},{"id":"aa618e84f133187a","type":"change","z":"4d86fe720f2c76be","name":"set artist","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.artist","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":180,"wires":[["62819c9c15b4d99a"]]},{"id":"8bbcba59a9d0e02b","type":"change","z":"4d86fe720f2c76be","name":"set track","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.track","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":220,"wires":[["5ccc79fdbcd8bc18"]]},{"id":"c5f2f8109d22042e","type":"change","z":"4d86fe720f2c76be","name":"set album","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.album","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":140,"wires":[["cb02327c1fdeab2e"]]},{"id":"54d7491278d03d04","type":"ui_gauge","z":"4d86fe720f2c76be","name":"Volume","group":"e62cf483d385fd0d","order":4,"width":"0","height":"0","gtype":"gage","title":"","label":"","format":"{{msg.payload}}","min":0,"max":"161","colors":["#00b500","#e6e600","#ca3838"],"seg1":"130","seg2":"150","className":"","x":940,"y":80,"wires":[]},{"id":"8e49b06d97aec365","type":"musiccast-zone","z":"4d86fe720f2c76be","mc":"84646cc8.5bcdc","name":"","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","zone":"main","type_zone":"zone","command":"setMute","type_command":"command","payload":"","type_payload":"msg","f_show_status":false,"x":1120,"y":40,"wires":[[]]},{"id":"a11acbde6cf81ade","type":"musiccast-zone","z":"4d86fe720f2c76be","mc":"84646cc8.5bcdc","name":"","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","zone":"main","type_zone":"zone","command":"setVolume","type_command":"command","payload":"","type_payload":"msg","f_show_status":false,"x":1130,"y":380,"wires":[[]]},{"id":"63eb6f6b87138382","type":"musiccast-input","z":"4d86fe720f2c76be","mc":"84646cc8.5bcdc","name":"","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","inp":"server","type_inp":"input","command":"setPlayback","type_command":"command","payload":"","type_payload":"msg","f_show_status":false,"x":1130,"y":260,"wires":[[]]},{"id":"3613fb6ab319a71d","type":"ui_text","z":"4d86fe720f2c76be","group":"e62cf483d385fd0d","order":3,"width":"6","height":"1","name":"Album","label":"","format":"{{msg.payload | limitTo:100}}","layout":"row-center","className":"","x":930,"y":140,"wires":[]},{"id":"f6b32b7d20131810","type":"rbe","z":"4d86fe720f2c76be","name":"Did change?","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":750,"y":80,"wires":[["54d7491278d03d04"]]},{"id":"0d3ed8d889cd18b6","type":"rbe","z":"4d86fe720f2c76be","name":"Did change?","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":750,"y":40,"wires":[["58067e31e0f1ceca"]]},{"id":"0d70edea010745f8","type":"rbe","z":"4d86fe720f2c76be","name":"Did change?","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":750,"y":260,"wires":[["212e2a3eb9e6f660"]]},{"id":"62819c9c15b4d99a","type":"rbe","z":"4d86fe720f2c76be","name":"Did change?","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":750,"y":180,"wires":[["6d7d91fb67b950fe"]]},{"id":"cb02327c1fdeab2e","type":"rbe","z":"4d86fe720f2c76be","name":"Did change?","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":750,"y":140,"wires":[["3613fb6ab319a71d"]]},{"id":"5ccc79fdbcd8bc18","type":"rbe","z":"4d86fe720f2c76be","name":"Did change?","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":750,"y":220,"wires":[["5966828a7e3a04d3"]]},{"id":"72659015e91a5a1a","type":"musiccast-input","z":"4d86fe720f2c76be","mc":"84646cc8.5bcdc","name":"Get play info","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","inp":"server","type_inp":"input","command":"getPlayInfo","type_command":"command","payload":"{}","type_payload":"json","f_show_status":false,"x":310,"y":140,"wires":[["c5f2f8109d22042e","aa618e84f133187a","8bbcba59a9d0e02b","3e51a5cc3ac5ec1e"]]},{"id":"a53d4e95b11936ab","type":"musiccast-zone","z":"4d86fe720f2c76be","mc":"84646cc8.5bcdc","name":"Get zone status","device":"cc796d12-2dd6-49db-9c09-1e971208ea9e","type_device":"device","zone":"main","type_zone":"zone","command":"getStatus","type_command":"command","payload":"{}","type_payload":"json","f_show_status":false,"x":320,"y":40,"wires":[["0c387d78d6d1aa18","d9f9f0d3fecd773b"]]},{"id":"e62cf483d385fd0d","type":"ui_group","name":"Control","tab":"3aae762477be33ee","order":2,"disp":false,"width":"6","collapse":false,"className":""},{"id":"84646cc8.5bcdc","type":"musiccast-config","name":"Example Configuration","device_list":{"cc796d12-2dd6-49db-9c09-1e971208ea9e":{"name":"Living Room Audio","address":"192.168.10.90","model":"RX-A2070","input_list":"{\"napster\":{\"id\":\"napster\"},\"siriusxm\":{\"id\":\"siriusxm\"},\"pandora\":{\"id\":\"pandora\"},\"spotify\":{\"id\":\"spotify\"},\"tidal\":{\"id\":\"tidal\"},\"deezer\":{\"id\":\"deezer\"},\"airplay\":{\"id\":\"airplay\"},\"mc_link\":{\"id\":\"mc_link\"},\"server\":{\"id\":\"server\"},\"net_radio\":{\"id\":\"net_radio\"},\"bluetooth\":{\"id\":\"bluetooth\"},\"usb\":{\"id\":\"usb\"},\"tuner\":{\"id\":\"tuner\"},\"av1\":{\"id\":\"av1\"},\"av2\":{\"id\":\"av2\"},\"av3\":{\"id\":\"av3\"},\"av4\":{\"id\":\"av4\"},\"av5\":{\"id\":\"av5\"},\"av6\":{\"id\":\"av6\"},\"av7\":{\"id\":\"av7\"},\"audio1\":{\"id\":\"audio1\"},\"audio2\":{\"id\":\"audio2\"},\"audio3\":{\"id\":\"audio3\"},\"phono\":{\"id\":\"phono\"},\"v_aux\":{\"id\":\"v_aux\"},\"main_sync\":{\"id\":\"main_sync\"}}","zone_list":"{\"main\":{\"id\":\"main\",\"input_list\":[\"napster\",\"siriusxm\",\"pandora\",\"spotify\",\"tidal\",\"deezer\",\"airplay\",\"mc_link\",\"server\",\"net_radio\",\"bluetooth\",\"usb\",\"tuner\",\"av1\",\"av2\",\"av3\",\"av4\",\"av5\",\"av6\",\"av7\",\"audio1\",\"audio2\",\"audio3\",\"phono\",\"v_aux\"],\"link_control_list\":[\"speed\",\"standard\",\"stability\"],\"link_audio_delay_list\":[\"audio_sync\",\"lip_sync\"],\"distribution\":{\"version\":2,\"compatible_client\":[2],\"client_max\":9,\"server_zone_list\":[\"main\",\"zone2\"]},\"sound_program_list\":[\"munich\",\"vienna\",\"amsterdam\",\"freiburg\",\"royaumont\",\"chamber\",\"village_vanguard\",\"warehouse_loft\",\"cellar_club\",\"roxy_theatre\",\"bottom_line\",\"sports\",\"action_game\",\"roleplaying_game\",\"music_video\",\"recital_opera\",\"standard\",\"spectacle\",\"sci-fi\",\"adventure\",\"drama\",\"mono_movie\",\"enhanced\",\"2ch_stereo\",\"9ch_stereo\",\"surr_decoder\",\"straight\"]},\"zone2\":{\"id\":\"zone2\",\"input_list\":[\"napster\",\"siriusxm\",\"pandora\",\"spotify\",\"tidal\",\"deezer\",\"airplay\",\"mc_link\",\"server\",\"net_radio\",\"bluetooth\",\"usb\",\"tuner\",\"av1\",\"av2\",\"av3\",\"av4\",\"av5\",\"av6\",\"av7\",\"audio1\",\"audio2\",\"audio3\",\"phono\",\"v_aux\",\"main_sync\"],\"link_control_list\":[\"speed\",\"standard\",\"stability\"],\"link_audio_delay_list\":[],\"distribution\":{\"version\":2,\"compatible_client\":[2],\"client_max\":9,\"server_zone_list\":[\"main\",\"zone2\"]},\"sound_program_list\":[]},\"zone3\":{\"id\":\"zone3\",\"input_list\":[\"napster\",\"siriusxm\",\"pandora\",\"spotify\",\"tidal\",\"deezer\",\"airplay\",\"mc_link\",\"server\",\"net_radio\",\"bluetooth\",\"usb\",\"tuner\",\"av1\",\"av2\",\"av3\",\"av4\",\"audio1\",\"audio2\",\"audio3\",\"phono\",\"v_aux\",\"main_sync\"],\"link_control_list\":[],\"link_audio_delay_list\":[],\"distribution\":{\"version\":2,\"compatible_client\":[2],\"client_max\":9,\"server_zone_list\":[\"main\",\"zone2\"]},\"sound_program_list\":[]},\"zone4\":{\"id\":\"zone4\",\"input_list\":[\"av1\",\"av2\",\"av3\",\"av4\",\"av5\",\"av6\",\"av7\",\"v_aux\"],\"link_control_list\":[],\"link_audio_delay_list\":[],\"distribution\":{\"version\":2,\"compatible_client\":[2],\"client_max\":9,\"server_zone_list\":[\"main\",\"zone2\"]},\"sound_program_list\":[]}}","serial":"AAAAAAAA","udn":"uuid:9ab0c000-f668-11de-9976-00a0defc5533","uuid":"cc796d12-2dd6-49db-9c09-1e971208ea9e","status":"seen","mod_date":"2022-07-31T00:58:56.624Z"}},"f_use_debug":false,"f_use_debug_api_resp":false,"list_language":"en","command_timeout":"2000","main":"Main","zone_2":"Zone 2","zone_3":"Zone 3","zone_4":"Zone 4","services_timeout":"5000"},{"id":"3aae762477be33ee","type":"ui_tab","name":"Musiccast","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Created 3 years, 2 months ago
  • change (x6)
  • rbe (x6)
  • musiccast
  • yamaha
