node-red-contrib-musiccast 4.5.2
A Node-RED collection for monitoring and controlling a Yamaha Musiccast network.
npm install node-red-contrib-musiccast
This collection can be used to monitor and control a Musiccast network. Actions for device playback, input selection, volume adjustment, and more can all be easily configured. This collection is also usable with many non-Musiccast AV units from Yamaha as long as the device in question is compatible with the YXC API.
General Concept
Designed to make control of a Musiccast system simple and straightforward. To achieve that goal, there is no reliance on technologies such as UPNP and DLNA*. The collection does not "listen" for changes from devices. Instead, devices must be polled on a regular basis to determine their status. An example flow is included to help demonstrates this process.
  • While this collection does not directly interact with DLNA sources, the Musiccast devices do and will continue to work as designed.
Quick Start
  1. Install the package using "Manage palette" on the hamburger icon at top right.
  2. Again using the hamburger icon, select [Import] then [Examples]. Expand the [node-red-contrib-musiccast] entry. Select [Toggling States] and click [Import].
  3. Click [Deploy].
  4. There will now be a demonstration flow on your palette showing basics of polling and controlling a system.
Feel free to tag the author shown below in the official Node-RED forums or email if any help is needed. If sending email, be sure to include "node-red-contrib-musiccast" in the subject to ensure the spam filters don't block it.
Release Notes
4.5.1
NEW FEATURES
  • Added missing command "setSurroundDecoderType" to [zone] node.
FIXES
  • [input] node editor pane will now display all available commands if the input selector is set to a variable.
  • Help content updates.
4.5.1
NEW FEATURES
  • None
FIXES
  • UI tweaks
  • NPM dependency updates
4.5.0
NEW FEATURES
  • Palette status messages can now be automatically cleared after 30 seconds. The setting is made on the config node and is applied to all nodes.
  • Compatibility with Node-RED 4.x confirmed.
FIXES
  • Separated out certain functions that have different attribute configuration possibilities depending on input source.
  • Updated NPM dependencies.
4.3.2
FIXES
  • Updated dependencies. Fixed packaging requirements to satisfy Node-RED audit requirements. No changes in functionality.
4.3.0
NEW FEATURES
Added a few new commands to complete the set from the Yamaha API V2:
  • requestNetworkReboot
  • requestSystemReboot
  • getAdvancedFeatures
  • getRemoteInfo
  • setAutoPlay
  • setSpeakerPattern
  • setPartyMode
  • setHdmiOut3
  • recallScene
  • setActualVolume
  • setContentsDisplay
  • setAudioSelect
  • controlCursor
  • controlMenu
  • setClearVoice
  • getSettings (netusb)
  • movePreset
  • startAutoPreset
  • cancelAutoPreset
  • startDabInitialScan
  • cancelDabInitialScan
  • setDabTuneAid
  • setRepeat (cd)
  • setShuffle (cd)
  • getSettings (clock)
  • setAutoSync (clock)
  • setDateAndTime (clock)
  • setClockFormat (clock)
  • setAlarmSettings (clock)
  • Added handling and documentation for additional response codes.
  • Added response code documentation s to the config node inline help.
FIXES
  • Help documentation clarifications.
  • Updated inline Basic API doc to version 2.0.
KNOWN ISSUES
  • Changes to devices or zones in the main Musiccast Configuration will not show in the configuration dialogs of other nodes until the changes are deployed.
4.2.4
FIXES
  • Fixed a typo in the package version. No other changes.
4.2.1
NEW FEATURES
  • Added 3 undocumented commands to the [list] node to facilitate working with Musiccast playlists directly: "getMcPlaylistName", "getMcPlaylist", and "manageMcPlaylist". Details are provided in the inline help.
Note: thanks goes out to SB for tracking these down!
FIXES
  • Help documentation cleanup.
4.2.0
NEW FEATURES
  • Any of the nodes can now work with the join/split functionality included with Node-RED. (msg.parts pass-through)
FIXES
  • Updated dependencies to address a high priority security vulnerability. (xml2js)
4.1.0
NEW FEATURES
  • Added new node [link] to use for establishing synchronized playback groups with common volume control. The example "Link Group Creation" has been added to help get started.
FIXES
  • Fixed major issue with API POST commands.
  • Some UI formatting changes have been mde for clarity.
KNOWN ISSUES
Additional Resources
Basic contextual help is available in Node-RED itself. Links to official Yamaha API documents can be found there as well.
The following devices and platforms are used in testing:
  • Node-RED version 2.2.2
  • Yamaha Aventage RX-A2070 receiver
  • Yamaha YXC-50 network streamer
  • Twonky Media Server 8.5.1 (DLNA/UPNP)
  • Tidal music streaming service
  • Various internet radio stations
  • Music files on USB thumb-drive plugged into above receivers
Note: Due to time constraints, testing is not possible with all potential command and command attribute combinations.
Authors
Created by: Vahdettin https://discourse.nodered.org/u/Vahdettin [email protected]
Copyright and license
Copyright Vahdettin under the Apache 2.0 license.
Version: 4.5.2
Updated 1 year, 10 months ago
Rating: 4.5 4
57 in the last week
  • musiccast-config
  • musiccast-zone
  • musiccast-input
  • musiccast-device
  • musiccast-list
  • musiccast-link
  • yamaha
  • musiccast
  • yxc
  • dlna
  • music
