Allow only the first message to pass from a burst
I needed to have only the first message from a burst of messages, for example in an RSS or email recollection were many messages are created, this flow lets only the first one to reach the target.
There are maybe better ways to do this, I've been unable to find them.
[{"id":"9a9d81c9ce8d3d49","type":"group","z":"e8c5f729a17793a1","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["8fb5c5ef63bb2a92","5951891e7061b9c6","81da6c6fb216348e","1f2f431e3da6bf76","1b9b2cf9ad7af168","fe78f31803b143fa","f48b8519d8ea03c0"],"x":134,"y":119,"w":702,"h":182},{"id":"8fb5c5ef63bb2a92","type":"q-gate","z":"e8c5f729a17793a1","g":"9a9d81c9ce8d3d49","name":"","controlTopic":"control","defaultState":"queueing","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","queueCmd":"queue","defaultCmd":"default","triggerCmd":"trigger","flushCmd":"flush","resetCmd":"reset","peekCmd":"peek","dropCmd":"drop","statusCmd":"status","maxQueueLength":"1","keepNewest":false,"qToggle":false,"persist":false,"storeName":"memory","x":690,"y":200,"wires":[["1b9b2cf9ad7af168"]]},{"id":"5951891e7061b9c6","type":"delay","z":"e8c5f729a17793a1","g":"9a9d81c9ce8d3d49","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":370,"y":260,"wires":[["81da6c6fb216348e"]]},{"id":"81da6c6fb216348e","type":"change","z":"e8c5f729a17793a1","g":"9a9d81c9ce8d3d49","name":"flush","rules":[{"t":"set","p":"payload","pt":"msg","to":"flush","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":260,"wires":[["8fb5c5ef63bb2a92"]]},{"id":"1f2f431e3da6bf76","type":"link in","z":"e8c5f729a17793a1","g":"9a9d81c9ce8d3d49","name":"get first message","links":[],"x":175,"y":200,"wires":[["f48b8519d8ea03c0"]]},{"id":"1b9b2cf9ad7af168","type":"link out","z":"e8c5f729a17793a1","g":"9a9d81c9ce8d3d49","name":"get first out","mode":"return","links":[],"x":795,"y":200,"wires":[]},{"id":"fe78f31803b143fa","type":"comment","z":"e8c5f729a17793a1","g":"9a9d81c9ce8d3d49","name":"Dejar pasar el primer mensaje de un burst","info":"","x":440,"y":160,"wires":[]},{"id":"f48b8519d8ea03c0","type":"junction","z":"e8c5f729a17793a1","g":"9a9d81c9ce8d3d49","x":220,"y":200,"wires":[["8fb5c5ef63bb2a92","5951891e7061b9c6"]]}]
Created 2 years, 5 months ago
Rating:
  • change (x1)
  • delay (x1)
  • link in (x1)
  • link out (x1)
  • group (x1)
  • junction (x1)
  • q-gate (x1)
  • queue
  • first
  • message
