Compte à rebours
Permet de décompter de x secondes jusqu'à 0 avec la possibilité de mettre en pause et de rajouter y secondes en cours de décompte.
[{"id":"81afc4855bd0fe21","type":"ui_button","z":"b7aa5db6c0a82fd7","name":"Ajout 300s","group":"e9d2ffc0.56619","order":2,"width":0,"height":0,"passthru":false,"label":"Add 300s","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":570,"y":280,"wires":[["6ea366a78c2989de"]]},{"id":"406ceabf7c556cca","type":"function","z":"b7aa5db6c0a82fd7","name":"","func":"\nflow.set(\"timer\",300);\n\nmsg.payload = flow.get(\"timer\");\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":220,"wires":[["40577e4fdd731fc7"]]},{"id":"6ea366a78c2989de","type":"function","z":"b7aa5db6c0a82fd7","name":"","func":"temp = flow.get(\"timer\") ;\ntimer = temp + 300;\nflow.set(\"timer\",timer);\n\nmsg.payload = timer;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":280,"wires":[["40577e4fdd731fc7"]]},{"id":"a44c05b5532e8a7e","type":"ui_ui-button","z":"b7aa5db6c0a82fd7","action":"click","actionType":"str","name":"Init","group":"e9d2ffc0.56619","order":1,"width":0,"height":0,"passthru":false,"label":"Init","tooltip":"","color":"","bgcolor":"","icon":"","x":550,"y":220,"wires":[["406ceabf7c556cca"]]},{"id":"40577e4fdd731fc7","type":"ui_text","z":"b7aa5db6c0a82fd7","group":"e9d2ffc0.56619","order":6,"width":0,"height":0,"name":"","label":"Décompte","format":"{{msg.payload}}","layout":"row-spread","x":1310,"y":280,"wires":[]},{"id":"e8789f8903a9ab7d","type":"delay","z":"b7aa5db6c0a82fd7","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":940,"y":360,"wires":[["fb3489460594a2dd"]]},{"id":"0d29447969af9b25","type":"ui_button","z":"b7aa5db6c0a82fd7","name":"GO","group":"e9d2ffc0.56619","order":3,"width":0,"height":0,"passthru":false,"label":"GO","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":550,"y":340,"wires":[["22cfeb7124dff484"]]},{"id":"22cfeb7124dff484","type":"function","z":"b7aa5db6c0a82fd7","name":"","func":"flow.set(\"timer_run\",1);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":340,"wires":[["e8789f8903a9ab7d"]]},{"id":"f0933c1f9e12afd9","type":"ui_button","z":"b7aa5db6c0a82fd7","name":"Pause","group":"e9d2ffc0.56619","order":4,"width":0,"height":0,"passthru":false,"label":"Pause","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":550,"y":400,"wires":[["58961ca2cf5bc177"]]},{"id":"58961ca2cf5bc177","type":"function","z":"b7aa5db6c0a82fd7","name":"","func":"temp = flow.set(\"timer_run\",0);\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":400,"wires":[["e8789f8903a9ab7d"]]},{"id":"fb3489460594a2dd","type":"function","z":"b7aa5db6c0a82fd7","name":"","func":"msg.payload = flow.get(\"timer\"); \nrun = flow.get(\"timer_run\");\n\nif (run == 1 && msg.payload > 1){\n    // on décompte 1 seconde\n    msg.payload = msg.payload-1;\n    // on sauvegarde la nouvelle valeur\n    flow.set(\"timer\",msg.payload);\n    return msg;\n}else if (msg.payload == 1){\n    msg.payload = \"Terminé !\"\n    // pour ne plus boucler si terminé\n    flow.set(\"timer\",0);\n    return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1120,"y":360,"wires":[["40577e4fdd731fc7","e8789f8903a9ab7d"]]},{"id":"e9d2ffc0.56619","type":"ui_group","name":"DEMO","tab":"fdf11f91.a57c3","order":3,"disp":true,"width":"6","collapse":false},{"id":"fdf11f91.a57c3","type":"ui_tab","name":"DEMO","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
Created 4 years, 1 month ago
  • delay (x1)
  • function (x5)
  • time
  • décompte
  • timer
